[petsc-users] Building MatIS with dense local matrix ?
Stefano Zampini stefano.zampini at gmail.com
Tue Jun 20 13:45:47 CDT 2017
Franck,
is it your "real" case working properly now?
Stefano
2017-06-20 17:31 GMT+02:00 Franck Houssen <franck.houssen at inria.fr>:
> OK.
> Franck
> *De: *"Stefano Zampini" <stefano.zampini at gmail.com>
> *À: *"Franck Houssen" <franck.houssen at inria.fr>
> *Cc: *"PETSc users list" <petsc-users at mcs.anl.gov>
> *Envoyé: *Mardi 20 Juin 2017 17:08:29
> *Objet: *Re: [petsc-users] Building MatIS with dense local matrix ?
> It should be fixed right now, both in master and in maint.
> Again, sorry for this ping-pong of fixes, my brain it's not fully
> functional these days....
> https://bitbucket.org/petsc/petsc/commits/c6f20c4fa7817632f09219574920bd
> 3bd922f6f1
> 2017-06-20 16:30 GMT+02:00 Franck Houssen <franck.houssen at inria.fr>:
>> OK. I moved from petsc-3.7.6 to development version (git clone bitbucket).
>> The very first version of the dummy example (=
>> matISCSRDenseSquare/Rect.cpp) works with this fix:
>> https://bitbucket.org/petsc/petsc/commits/4c8dd594d1988a0cbe282f8a37d991
>> 6f61e0c445.
>> The second version of the dummy example works too with the fix if one
>> moves to petsc bitbucket (master).
>> But, the code still breaks in "my" initial "real" case (using now master
>> from petsc bitbucket)... With another error "SEGV under
>> MatISSetMPIXAIJPreallocation_Private" (note: this is not a "new non
>> zero" message, this seems to be another problem).
>> Here is a third version of the dummy example that breaks with "SEGV under
>> MatISSetMPIXAIJPreallocation_Private" (using master from petsc
>> bitbucket) : the idea is the same but with N procs (not only 2) and a
>> rectangular matrix of size N*(N+1).
>> With 2 procs, it works (all cases).
>> With 4 procs, new problems occur:
>> >> mpirun -n 4 ./matISCSRDenseSquare.exe csr; mpirun -n 4
>> ./matISCSRDenseSquare.exe dense => OK
>> >> mpirun -n 4 ./matISCSRDenseRect.exe csr => OK
>> but
>> >> mpirun -n 4 ./matISCSRDenseRect.exe dense;
>> dense
>> dense
>> dense
>> dense
>> [3]PETSC ERROR: ------------------------------
>> [3]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>> probably memory access out of range
>> [3]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>> [3]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/
>> documentation/faq.html#valgrind
>> [3]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS
>> X to find memory corruption errors
>> [3]PETSC ERROR: likely location of problem given in stack below
>> [3]PETSC ERROR: ---------------------  Stack Frames
>> [3]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>> available,
>> [3]PETSC ERROR:       INSTEAD the line number of the start of the function
>> [3]PETSC ERROR:       is given.
>> [3]PETSC ERROR: [3] MatISSetMPIXAIJPreallocation_Private line 1055
>> /home/fghoussen/Documents/INRIA/petsc/src/mat/impls/is/matis.c
>> [3]PETSC ERROR: [3] MatISGetMPIXAIJ_IS line 1230
>> [3]PETSC ERROR: [3] MatISGetMPIXAIJ line 1384 /home/fghoussen/Documents/
>> [3]PETSC ERROR: --------------------- Error Message
>> I tried to go through this with caution... But I have to say I feel
>> messy. Can you reproduce this problem at your side ?
>> Franck
>> >> git diff .
>> --- a/matISCSRDenseRect.cpp
>> +++ b/matISCSRDenseRect.cpp
>> @@ -14,19 +14,17 @@ int main(int argc,char **argv) {
>>    if (matType != "csr" && matType != "dense") {cout << "error: need arg
>> = csr or dense" << endl; return 1;}
>>    PetscInitialize(&argc, &argv, NULL, NULL);
>> -  int size = 0; MPI_Comm_size(MPI_COMM_WORLD, &size); if (size != 2)
>> {cout << "error: mpi != 2" << endl; return 1;}
>> +  int size = 0; MPI_Comm_size(MPI_COMM_WORLD, &size);
>>    int rank = 0; MPI_Comm_rank(MPI_COMM_WORLD, &rank);
>> -  PetscInt localIdx[2] = {0, 0};
>> -  if (rank == 0) {localIdx[0] = 0; localIdx[1] = 1;}
>> -  else           {localIdx[0] = 1; localIdx[1] = 2;}
>> +  PetscInt localIdx[2] = {rank, rank+1};
>>    ISLocalToGlobalMapping rmap;
>>    ISLocalToGlobalMappingCreate(PETSC_COMM_WORLD, 1, 1, &rank,
>> PETSC_COPY_VALUES, &rmap);
>>    ISLocalToGlobalMapping cmap;
>>    ISLocalToGlobalMappingCreate(PETSC_COMM_WORLD, 1, 2, localIdx,
>> PETSC_COPY_VALUES, &cmap);
>>    Mat A;
>> -  MatCreateIS(PETSC_COMM_WORLD, 1, PETSC_DECIDE, PETSC_DECIDE, 2, 3,
>> rmap, cmap, &A);
>> +  MatCreateIS(PETSC_COMM_WORLD, 1, PETSC_DECIDE, PETSC_DECIDE, size,
>> size+1, rmap, cmap, &A);
>>    Mat Aloc;
>>    if (matType == "csr") {cout << matType << endl;
>> MatCreateSeqAIJ(PETSC_COMM_SELF, 1, 2, 2, NULL, &Aloc);}
>> --- a/matISCSRDenseSquare.cpp
>> +++ b/matISCSRDenseSquare.cpp
>>    Mat A;
>> -  MatCreateIS(PETSC_COMM_WORLD, 1, PETSC_DECIDE, PETSC_DECIDE, 3, 3,
>> rmap, cmap, &A);
>> +  MatCreateIS(PETSC_COMM_WORLD, 1, PETSC_DECIDE, PETSC_DECIDE, size+1,
>>    Mat Aloc;
>> MatCreateSeqAIJ(PETSC_COMM_SELF, 2, 2, 2, NULL, &Aloc);}
>> *Envoyé: *Mardi 20 Juin 2017 13:23:27
>> Franck
>> I tested your new example with master and it works. However, It doesn't
>> work with maint. I fixed the rectangular case a while ago in master and
>> forgot to add the change to maint too. Sorry for that.
>> This should fix the problem with maint: https://bitbucket.org/petsc/
>> petsc/commits/0ea065fb06d751599c4157d36bfe1a1b41348e0b
>> Test your real case and let me know.
>> If you could, it would be good to test against master too.
>> Thanks,
>> Stefano
>> 2017-06-20 12:58 GMT+02:00 Franck Houssen <franck.houssen at inria.fr>:
>>> As I said, it is often difficult to reduce the "real" problem: it turns
>>> out that your fix solves the "matISCSRDenseSquare/Rect.cpp" dummy example I
>>> sent, but, it's still not working in "my real" situation.
>>> I changed a bit the "matISCSRDenseSquare/Rect.cpp" dummy example (see
>>> git diff below - I just changed the point that overlaps) : the dummy
>>> example is still failing
>>> "mpirun -n 2 ./matISCSRDenseSquare.exe csr" and "mpirun -n 2
>>> ./matISCSRDenseSquare.exe dense" : OK
>>> but
>>> "mpirun -n 2 ./matISCSRDenseRect.exe csr" and "mpirun -n 2
>>> ./matISCSRDenseRect.exe dense": KO with error "Argument out of range - New
>>> nonzero at (0,2) caused a malloc"
>>> I would say, the problem (I am concerned with the "real" case) is around
>>> lines 360-380 of /src/mat/impls/is/matis.c (not around 181 : this fixes a
>>> valid problem, but, this problem is another one)
>>> Franck
>>> @@ -18,7 +18,7 @@ int main(int argc,char **argv) {
>>> +  if (rank == 0) {localIdx[0] = 0; localIdx[1] = 2;}
>>> diff --git a/Graphs/Franck/03.petscDDM/02.petscMailList/matISCSRDenseSquare.cpp
>>> b/Graphs/Franck/03.petscDDM/02.petscMailList/matISCSRDenseSquare.cpp
>>> index 4bc6190..4a6ea41 100644
>>> *Envoyé: *Mardi 20 Juin 2017 00:23:24
>>> It should be fixed now in maint and master
>>> 6f61e0c445
>>> Thanks for reporting the problem,
>>> Stefano
>>> On Jun 19, 2017, at 10:46 PM, Stefano Zampini <stefano.zampini at gmail.com>
>>> wrote:
>>> Franck,
>>> Thanks. I'll​ get back soon with a fix.
>>> Stefano
>>> Il 19 Giu 2017 18:17, "Franck Houssen" <franck.houssen at inria.fr> ha
>>> scritto:
>>>> The problem was difficult to reduce as reducing make things
>>>> disappear... Luckily, I believe I got it (or at least, it looks "like" the
>>>> one I "really" have...).
>>>> Seems that for square matrix, it works fine for csr and dense matrix.
>>>> But, If I am not mistaken, it does not for dense rectangular matrix (still
>>>> OK for csr).
>>>> matISCSRDenseSquare.cpp: 2 procs, global 3x3 matrix, each proc adds a
>>>> 2x2 local matrix in the global matrix.
>>>> matISCSRDenseRect.cpp: 2 procs, global *2*x3 matrix, each proc adds a
>>>> *1*x2 local *vector* in the global matrix.
>>>> reminder: running debian/testing with gcc-6.3 + petsc-3.7.6
>>>> Franck
>>>> >> mpirun -n 2 ./matISCSRDenseSquare.exe csr; mpirun -n 2
>>>> csr
>>>> csr
>>>> Mat Object: 2 MPI processes
>>>>   type: is
>>>>   Mat Object:   1 MPI processes
>>>>     type: seqaij
>>>> row 0: (0, 1.)  (1, 0.)
>>>> row 1: (0, 0.)  (1, 1.)
>>>>     type: seqaij
>>>> dense
>>>> dense
>>>>   type: is
>>>>     type: seqdense
>>>> 1.0000000000000000e+00 0.0000000000000000e+00
>>>> 0.0000000000000000e+00 1.0000000000000000e+00
>>>>     type: seqdense
>>>> >> mpirun -n 2 ./matISCSRDenseRect.exe csr; mpirun -n 2
>>>> csr
>>>> csr
>>>>   type: is
>>>>     type: seqaij
>>>>     type: seqaij
>>>> dense
>>>> dense
>>>> [0]PETSC ERROR: --------------------- Error Message
>>>> [0]PETSC ERROR: Argument out of range
>>>> [0]PETSC ERROR: [1]PETSC ERROR: --------------------- Error Message
>>>> [1]PETSC ERROR: Argument out of range
>>>> [1]PETSC ERROR: New nonzero at (0,1) caused a malloc
>>>> Use MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE) to
>>>> turn off this check
>>>> [1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>>>> for trouble shooting.
>>>> [1]PETSC ERROR: Petsc Release Version 3.7.6, Apr, 24, 2017
>>>> [1]PETSC ERROR: ./matISCSRDenseRect.exe on a arch-linux2-c-debug named
>>>> yoda by fghoussen Mon Jun 19 18:08:58 2017
>>>> turn off this check
>>>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>>>> [0]PETSC ERROR: Petsc Release Version 3.7.6, Apr, 24, 2017
>>>> [1]PETSC ERROR: Configure options --prefix=/home/fghoussen/
>>>> Documents/INRIA/petsc-3.7.6/local --with-mpi=1 --with-pthread=1
>>>> --download-f2cblaslapack=yes --download-mumps=yes --download-scalapack=yes
>>>> --download-superlu=yes --download-suitesparse=yes
>>>> [1]PETSC ERROR: #1 MatSetValues_MPIAIJ() line 616 in
>>>> /home/fghoussen/Documents/INRIA/petsc-3.7.6/src/mat/
>>>> impls/aij/mpi/mpiaij.c
>>>> [1]PETSC ERROR: #2 MatSetValues() line 1190 in
>>>> /home/fghoussen/Documents/INRIA/petsc-3.7.6/src/mat/interface/matrix.c
>>>> [1]PETSC ERROR: #3 MatSetValuesLocal() line 2053 in
>>>> [1]PETSC ERROR: #4 MatISGetMPIXAIJ_IS() line 365 in
>>>> /home/fghoussen/Documents/INRIA/petsc-3.7.6/src/mat/impls/is/matis.c
>>>> [1]PETSC ERROR: #5 MatISGetMPIXAIJ() line 437 in
>>>> [0]PETSC ERROR: ./matISCSRDenseRect.exe on a arch-linux2-c-debug named
>>>> [0]PETSC ERROR: Configure options --prefix=/home/fghoussen/
>>>> [0]PETSC ERROR: #1 MatSetValues_MPIAIJ() line 582 in
>>>> [0]PETSC ERROR: #2 MatSetValues() line 1190 in
>>>> [0]PETSC ERROR: #3 MatSetValuesLocal() line 2053 in
>>>> [0]PETSC ERROR: #4 MatISGetMPIXAIJ_IS() line 365 in
>>>> [0]PETSC ERROR: #5 MatISGetMPIXAIJ() line 437 in
>>>>   type: is
>>>>     type: seqdense
>>>>     type: seqdense
>>>> >> diff matISCSRDenseSquare.cpp matISCSRDenseRect.cpp
>>>> 3c3
>>>> < // ~> g++ -o matISCSRDenseSquare.exe matISCSRDenseSquare.cpp -lpetsc
>>>> -lm; mpirun -n 2 matISCSRDenseSquare.exe
>>>> > // ~> g++ -o matISCSRDenseRect.exe matISCSRDenseRect.cpp -lpetsc -lm;
>>>> mpirun -n 2 matISCSRDenseRect.exe
>>>> 24c24
>>>> <   ISLocalToGlobalMappingCreate(PETSC_COMM_WORLD, 1, 2, localIdx,
>>>> 29c29
>>>> <   MatCreateIS(PETSC_COMM_WORLD, 1, PETSC_DECIDE, PETSC_DECIDE, 3, 3,
>>>> rmap, cmap, &A);
>>>> rmap, cmap, &A);
>>>> 32,33c32,33
>>>> <   if (matType == "csr") {cout << matType << endl;
>>>> <   else {cout << matType << endl; MatCreateSeqDense(PETSC_COMM_SELF,
>>>> 1, 2, NULL, &Aloc);}
>>>> 35,36c35,36
>>>> <   PetscScalar localVal[4] = {1., 0., 0., 1.};
>>>> <   MatSetValues(Aloc, 2, localIdx, 2, localIdx, localVal, ADD_VALUES);
>>>> // Add local 2x2 matrix
>>>> >   PetscScalar localVal[2] = {1., 0.}; PetscInt oneLocalRow = 0;
>>>> >   MatSetValues(Aloc, 1, &oneLocalRow, 2, localIdx, localVal,
>>>> ADD_VALUES); // Add local row
>>>> *Envoyé: *Lundi 19 Juin 2017 15:25:35
>>>> Can you send a minimal working example so that I can fix the code?
>>>> Thanks
>>>> Stefano
>>>> Il 19 Giu 2017 15:20, "Franck Houssen" <franck.houssen at inria.fr> ha
>>>> scritto:
>>>>> Hi,
>>>>> I try to call MatISGetMPIXAIJ on a MatIS (A) that has been feed
>>>>> locally by sequential (Aloc) dense matrix.
>>>>> Seems this ends up with this error: [0]PETSC ERROR: New nonzero at
>>>>> (0,1) caused a malloc. Is this a known error / limitation ? (not supposed
>>>>> to work with dense matrix ?)
>>>>> This (pseudo code) works fine:
>>>>> MatCreateIS(..., A)
>>>>> MatCreateSeqAIJ(..., Aloc)
>>>>> MatISSetLocalMat(pcA, pcALoc)
>>>>> MatISGetMPIXAIJ(A, ...) // OK !
>>>>> When I try to replace MatCreateSeqAIJ(..., Aloc) with
>>>>> MatCreateSeqDense(..., Aloc), it does no more work.
>>>>> Franck
>>>>> PS: running debian/testing with gcc-6.3 + petsc-3.7.6
>> Stefano
> Stefano
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170620/c26e18dc/attachment-0001.html>
