[petsc-users] Building MatIS with dense local matrix ?
Franck Houssen franck.houssen at inria.fr
Tue Jun 20 05:58:25 CDT 2017
As I said, it is often difficult to reduce the "real" problem: it turns out that your fix solves the "matISCSRDenseSquare/Rect.cpp" dummy example I sent, but, it's still not working in "my real" situation.
I changed a bit the "matISCSRDenseSquare/Rect.cpp" dummy example (see git diff below - I just changed the point that overlaps) : the dummy example is still failing
"mpirun -n 2 ./matISCSRDenseSquare.exe csr" and "mpirun -n 2 ./matISCSRDenseSquare.exe dense" : OK
but
"mpirun -n 2 ./matISCSRDenseRect.exe csr" and "mpirun -n 2 ./matISCSRDenseRect.exe dense": KO with error "Argument out of range - New nonzero at (0,2) caused a malloc"
I would say, the problem (I am concerned with the "real" case) is around lines 360-380 of /src/mat/impls/is/matis.c (not around 181 : this fixes a valid problem, but, this problem is another one)
Franck
--- a/matISCSRDenseRect.cpp
+++ b/matISCSRDenseRect.cpp
@@ -18,7 +18,7 @@ int main(int argc,char **argv) {
int rank = 0; MPI_Comm_rank(MPI_COMM_WORLD, &rank);
PetscInt localIdx[2] = {0, 0};
- if (rank == 0) {localIdx[0] = 0; localIdx[1] = 1;}
+ if (rank == 0) {localIdx[0] = 0; localIdx[1] = 2;}
else {localIdx[0] = 1; localIdx[1] = 2;}
ISLocalToGlobalMapping rmap;
ISLocalToGlobalMappingCreate(PETSC_COMM_WORLD, 1, 1, &rank, PETSC_COPY_VALUES, &rmap);
diff --git a/Graphs/Franck/03.petscDDM/02.petscMailList/matISCSRDenseSquare.cpp b/Graphs/Franck/03.petscDDM/02.petscMailList/matISCSRDenseSquare.cpp
index 4bc6190..4a6ea41 100644
--- a/matISCSRDenseSquare.cpp
+++ b/matISCSRDenseSquare.cpp
ISLocalToGlobalMappingCreate(PETSC_COMM_WORLD, 1, 2, localIdx, PETSC_COPY_VALUES, &rmap);
----- Mail original -----
> De: "Stefano Zampini" <stefano.zampini at gmail.com>
> À: "Franck Houssen" <franck.houssen at inria.fr>
> Cc: "PETSc users list" <petsc-users at mcs.anl.gov>
> Envoyé: Mardi 20 Juin 2017 00:23:24
> Objet: Re: [petsc-users] Building MatIS with dense local matrix ?
> It should be fixed now in maint and master
> https://bitbucket.org/petsc/petsc/commits/4c8dd594d1988a0cbe282f8a37d9916f61e0c445
> Thanks for reporting the problem,
> Stefano
> > On Jun 19, 2017, at 10:46 PM, Stefano Zampini < stefano.zampini at gmail.com >
> > wrote:
> > Franck,
> > Thanks. I'll​ get back soon with a fix.
> > Stefano
> > Il 19 Giu 2017 18:17, "Franck Houssen" < franck.houssen at inria.fr > ha
> > scritto:
> > > The problem was difficult to reduce as reducing make things disappear...
> > > Luckily, I believe I got it (or at least, it looks "like" the one I
> > > "really"
> > > have...).
> > > Seems that for square matrix, it works fine for csr and dense matrix.
> > > But,
> > > If
> > > I am not mistaken, it does not for dense rectangular matrix (still OK for
> > > csr).
> > > matISCSRDenseSquare.cpp: 2 procs, global 3x3 matrix, each proc adds a 2x2
> > > local matrix in the global matrix.
> > > matISCSRDenseRect.cpp: 2 procs, global 2 x3 matrix, each proc adds a 1 x2
> > > local vector in the global matrix.
> > > reminder: running debian/testing with gcc-6.3 + petsc-3.7.6
> > > Franck
> > > >> mpirun -n 2 ./matISCSRDenseSquare.exe csr; mpirun -n 2
> > > csr
> > > csr
> > > Mat Object: 2 MPI processes
> > > type: is
> > > Mat Object: 1 MPI processes
> > > type: seqaij
> > > row 0: (0, 1.) (1, 0.)
> > > row 1: (0, 0.) (1, 1.)
> > > type: seqaij
> > > dense
> > > dense
> > > type: is
> > > type: seqdense
> > > 1.0000000000000000e+00 0.0000000000000000e+00
> > > 0.0000000000000000e+00 1.0000000000000000e+00
> > > type: seqdense
> > > >> mpirun -n 2 ./matISCSRDenseRect.exe csr; mpirun -n 2
> > > csr
> > > csr
> > > type: is
> > > type: seqaij
> > > type: seqaij
> > > dense
> > > dense
> > > [0]PETSC ERROR: --------------------- Error Message
> > > [0]PETSC ERROR: Argument out of range
> > > [0]PETSC ERROR: [1]PETSC ERROR: --------------------- Error Message
> > > [1]PETSC ERROR: Argument out of range
> > > [1]PETSC ERROR: New nonzero at (0,1) caused a malloc
> > > Use MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE) to turn
> > > off
> > > this check
> > > [1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> > > for
> > > trouble shooting.
> > > [1]PETSC ERROR: Petsc Release Version 3.7.6, Apr, 24, 2017
> > > [1]PETSC ERROR: ./matISCSRDenseRect.exe on a arch-linux2-c-debug named
> > > yoda
> > > by fghoussen Mon Jun 19 18:08:58 2017
> > > off
> > > this check
> > > [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> > > for
> > > trouble shooting.
> > > [0]PETSC ERROR: Petsc Release Version 3.7.6, Apr, 24, 2017
> > > [1]PETSC ERROR: Configure options
> > > --prefix=/home/fghoussen/Documents/INRIA/petsc-3.7.6/local --with-mpi=1
> > > --with-pthread=1 --download-f2cblaslapack=yes --download-mumps=yes
> > > --download-scalapack=yes --download-superlu=yes
> > > --download-suitesparse=yes
> > > [1]PETSC ERROR: #1 MatSetValues_MPIAIJ() line 616 in
> > > /home/fghoussen/Documents/INRIA/petsc-3.7.6/src/mat/impls/aij/mpi/mpiaij.c
> > > [1]PETSC ERROR: #2 MatSetValues() line 1190 in
> > > /home/fghoussen/Documents/INRIA/petsc-3.7.6/src/mat/interface/matrix.c
> > > [1]PETSC ERROR: #3 MatSetValuesLocal() line 2053 in
> > > [1]PETSC ERROR: #4 MatISGetMPIXAIJ_IS() line 365 in
> > > /home/fghoussen/Documents/INRIA/petsc-3.7.6/src/mat/impls/is/matis.c
> > > [1]PETSC ERROR: #5 MatISGetMPIXAIJ() line 437 in
> > > [0]PETSC ERROR: ./matISCSRDenseRect.exe on a arch-linux2-c-debug named
> > > yoda
> > > [0]PETSC ERROR: Configure options
> > > [0]PETSC ERROR: #1 MatSetValues_MPIAIJ() line 582 in
> > > [0]PETSC ERROR: #2 MatSetValues() line 1190 in
> > > [0]PETSC ERROR: #3 MatSetValuesLocal() line 2053 in
> > > [0]PETSC ERROR: #4 MatISGetMPIXAIJ_IS() line 365 in
> > > [0]PETSC ERROR: #5 MatISGetMPIXAIJ() line 437 in
> > > type: is
> > > type: seqdense
> > > type: seqdense
> > > >> diff matISCSRDenseSquare.cpp matISCSRDenseRect.cpp
> > > 3c3
> > > < // ~> g++ -o matISCSRDenseSquare.exe matISCSRDenseSquare.cpp -lpetsc
> > > -lm;
> > > mpirun -n 2 matISCSRDenseSquare.exe
> > > > // ~> g++ -o matISCSRDenseRect.exe matISCSRDenseRect.cpp -lpetsc -lm;
> > > > mpirun -n 2 matISCSRDenseRect.exe
> > > 24c24
> > > < ISLocalToGlobalMappingCreate(PETSC_COMM_WORLD, 1, 2, localIdx,
> > > 29c29
> > > < MatCreateIS(PETSC_COMM_WORLD, 1, PETSC_DECIDE, PETSC_DECIDE, 3, 3,
> > > rmap,
> > > cmap, &A);
> > > > MatCreateIS(PETSC_COMM_WORLD, 1, PETSC_DECIDE, PETSC_DECIDE, 2, 3,
> > > > rmap,
> > > > cmap, &A);
> > > 32,33c32,33
> > > < if (matType == "csr") {cout << matType << endl;
> > > MatCreateSeqAIJ(PETSC_COMM_SELF, 2, 2, 2, NULL, &Aloc);}
> > > < else {cout << matType << endl; MatCreateSeqDense(PETSC_COMM_SELF, 2, 2,
> > > NULL, &Aloc);}
> > > > MatCreateSeqAIJ(PETSC_COMM_SELF, 1, 2, 2, NULL, &Aloc);}
> > > > else {cout << matType << endl; MatCreateSeqDense(PETSC_COMM_SELF, 1, 2,
> > > > NULL, &Aloc);}
> > > 35,36c35,36
> > > < PetscScalar localVal[4] = {1., 0., 0., 1.};
> > > < MatSetValues(Aloc, 2, localIdx, 2, localIdx, localVal, ADD_VALUES); //
> > > Add
> > > local 2x2 matrix
> > > > PetscScalar localVal[2] = {1., 0.}; PetscInt oneLocalRow = 0;
> > > > MatSetValues(Aloc, 1, &oneLocalRow, 2, localIdx, localVal, ADD_VALUES);
> > > > Add local row
> > > > De: "Stefano Zampini" < stefano.zampini at gmail.com >
> > > > À: "Franck Houssen" < franck.houssen at inria.fr >
> > > > Cc: "PETSc users list" < petsc-users at mcs.anl.gov >
> > > > Envoyé: Lundi 19 Juin 2017 15:25:35
> > > > Can you send a minimal working example so that I can fix the code?
> > > > Thanks
> > > > Stefano
> > > > Il 19 Giu 2017 15:20, "Franck Houssen" < franck.houssen at inria.fr > ha
> > > > scritto:
> > > > > Hi,
> > > > > I try to call MatISGetMPIXAIJ on a MatIS (A) that has been feed
> > > > > locally
> > > > > by
> > > > > sequential (Aloc) dense matrix.
> > > > > Seems this ends up with this error: [0]PETSC ERROR: New nonzero at
> > > > > (0,1)
> > > > > caused a malloc. Is this a known error / limitation ? (not supposed
> > > > > to
> > > > > work
> > > > > with dense matrix ?)
> > > > > This (pseudo code) works fine:
> > > > > MatCreateIS(..., A)
> > > > > MatCreateSeqAIJ(..., Aloc)
> > > > > MatISSetLocalMat(pcA, pcALoc)
> > > > > MatISGetMPIXAIJ(A, ...) // OK !
> > > > > When I try to replace MatCreateSeqAIJ(..., Aloc) with
> > > > > MatCreateSeqDense(...,
> > > > > Aloc), it does no more work.
> > > > > Franck
> > > > > PS: running debian/testing with gcc-6.3 + petsc-3.7.6
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170620/d1bdb228/attachment-0001.html>
Type: text/x-c++src
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170620/d1bdb228/attachment-0002.cpp>
Type: text/x-c++src
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170620/d1bdb228/attachment-0003.cpp>
