[petsc-users] Building MatIS with dense local matrix ?
Franck Houssen
franck.houssen at inria.fr
Mon Jun 19 11:17:20 CDT 2017
The problem was difficult to reduce as reducing make things disappear... Luckily, I believe I got it (or at least, it looks "like" the one I "really" have...).
Seems that for square matrix, it works fine for csr and dense matrix. But, If I am not mistaken, it does not for dense rectangular matrix (still OK for csr).
matISCSRDenseSquare.cpp: 2 procs, global 3x3 matrix, each proc adds a 2x2 local matrix in the global matrix.
matISCSRDenseRect.cpp: 2 procs, global 2 x3 matrix, each proc adds a 1 x2 local vector in the global matrix.
reminder: running debian/testing with gcc-6.3 + petsc-3.7.6
Franck
>> mpirun -n 2 ./matISCSRDenseSquare.exe csr; mpirun -n 2 ./matISCSRDenseSquare.exe dense
csr
csr
Mat Object: 2 MPI processes
type: is
Mat Object: 1 MPI processes
type: seqaij
row 0: (0, 1.) (1, 0.)
row 1: (0, 0.) (1, 1.)
type: seqaij
dense
dense
type: is
type: seqdense
1.0000000000000000e+00 0.0000000000000000e+00
0.0000000000000000e+00 1.0000000000000000e+00
type: seqdense
>> mpirun -n 2 ./matISCSRDenseRect.exe csr; mpirun -n 2 ./matISCSRDenseRect.exe dense
csr
csr
type: is
type: seqaij
type: seqaij
dense
dense
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: Argument out of range
[0]PETSC ERROR: [1]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[1]PETSC ERROR: Argument out of range
[1]PETSC ERROR: New nonzero at (0,1) caused a malloc
Use MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE) to turn off this check
[1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[1]PETSC ERROR: Petsc Release Version 3.7.6, Apr, 24, 2017
[1]PETSC ERROR: ./matISCSRDenseRect.exe on a arch-linux2-c-debug named yoda by fghoussen Mon Jun 19 18:08:58 2017
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.7.6, Apr, 24, 2017
[1]PETSC ERROR: Configure options --prefix=/home/fghoussen/Documents/INRIA/petsc-3.7.6/local --with-mpi=1 --with-pthread=1 --download-f2cblaslapack=yes --download-mumps=yes --download-scalapack=yes --download-superlu=yes --download-suitesparse=yes
[1]PETSC ERROR: #1 MatSetValues_MPIAIJ() line 616 in /home/fghoussen/Documents/INRIA/petsc-3.7.6/src/mat/impls/aij/mpi/mpiaij.c
[1]PETSC ERROR: #2 MatSetValues() line 1190 in /home/fghoussen/Documents/INRIA/petsc-3.7.6/src/mat/interface/matrix.c
[1]PETSC ERROR: #3 MatSetValuesLocal() line 2053 in /home/fghoussen/Documents/INRIA/petsc-3.7.6/src/mat/interface/matrix.c
[1]PETSC ERROR: #4 MatISGetMPIXAIJ_IS() line 365 in /home/fghoussen/Documents/INRIA/petsc-3.7.6/src/mat/impls/is/matis.c
[1]PETSC ERROR: #5 MatISGetMPIXAIJ() line 437 in /home/fghoussen/Documents/INRIA/petsc-3.7.6/src/mat/impls/is/matis.c
[0]PETSC ERROR: ./matISCSRDenseRect.exe on a arch-linux2-c-debug named yoda by fghoussen Mon Jun 19 18:08:58 2017
[0]PETSC ERROR: Configure options --prefix=/home/fghoussen/Documents/INRIA/petsc-3.7.6/local --with-mpi=1 --with-pthread=1 --download-f2cblaslapack=yes --download-mumps=yes --download-scalapack=yes --download-superlu=yes --download-suitesparse=yes
[0]PETSC ERROR: #1 MatSetValues_MPIAIJ() line 582 in /home/fghoussen/Documents/INRIA/petsc-3.7.6/src/mat/impls/aij/mpi/mpiaij.c
[0]PETSC ERROR: #2 MatSetValues() line 1190 in /home/fghoussen/Documents/INRIA/petsc-3.7.6/src/mat/interface/matrix.c
[0]PETSC ERROR: #3 MatSetValuesLocal() line 2053 in /home/fghoussen/Documents/INRIA/petsc-3.7.6/src/mat/interface/matrix.c
[0]PETSC ERROR: #4 MatISGetMPIXAIJ_IS() line 365 in /home/fghoussen/Documents/INRIA/petsc-3.7.6/src/mat/impls/is/matis.c
[0]PETSC ERROR: #5 MatISGetMPIXAIJ() line 437 in /home/fghoussen/Documents/INRIA/petsc-3.7.6/src/mat/impls/is/matis.c
type: is
type: seqdense
type: seqdense
>> diff matISCSRDenseSquare.cpp matISCSRDenseRect.cpp
3c3
< // ~> g++ -o matISCSRDenseSquare.exe matISCSRDenseSquare.cpp -lpetsc -lm; mpirun -n 2 matISCSRDenseSquare.exe
> // ~> g++ -o matISCSRDenseRect.exe matISCSRDenseRect.cpp -lpetsc -lm; mpirun -n 2 matISCSRDenseRect.exe
24c24
< ISLocalToGlobalMappingCreate(PETSC_COMM_WORLD, 1, 2, localIdx, PETSC_COPY_VALUES, &rmap);
> ISLocalToGlobalMappingCreate(PETSC_COMM_WORLD, 1, 1, &rank, PETSC_COPY_VALUES, &rmap);
29c29
< MatCreateIS(PETSC_COMM_WORLD, 1, PETSC_DECIDE, PETSC_DECIDE, 3, 3, rmap, cmap, &A);
> MatCreateIS(PETSC_COMM_WORLD, 1, PETSC_DECIDE, PETSC_DECIDE, 2, 3, rmap, cmap, &A);
32,33c32,33
< if (matType == "csr") {cout << matType << endl; MatCreateSeqAIJ(PETSC_COMM_SELF, 2, 2, 2, NULL, &Aloc);}
< else {cout << matType << endl; MatCreateSeqDense(PETSC_COMM_SELF, 2, 2, NULL, &Aloc);}
> if (matType == "csr") {cout << matType << endl; MatCreateSeqAIJ(PETSC_COMM_SELF, 1, 2, 2, NULL, &Aloc);}
> else {cout << matType << endl; MatCreateSeqDense(PETSC_COMM_SELF, 1, 2, NULL, &Aloc);}
35,36c35,36
< PetscScalar localVal[4] = {1., 0., 0., 1.};
< MatSetValues(Aloc, 2, localIdx, 2, localIdx, localVal, ADD_VALUES); // Add local 2x2 matrix
> PetscScalar localVal[2] = {1., 0.}; PetscInt oneLocalRow = 0;
> MatSetValues(Aloc, 1, &oneLocalRow, 2, localIdx, localVal, ADD_VALUES); // Add local row
----- Mail original -----
> De: "Stefano Zampini" <stefano.zampini at gmail.com>
> À: "Franck Houssen" <franck.houssen at inria.fr>
> Cc: "PETSc users list" <petsc-users at mcs.anl.gov>
> Envoyé: Lundi 19 Juin 2017 15:25:35
> Objet: Re: [petsc-users] Building MatIS with dense local matrix ?
> Can you send a minimal working example so that I can fix the code?
> Thanks
> Stefano
> Il 19 Giu 2017 15:20, "Franck Houssen" < franck.houssen at inria.fr > ha
> scritto:
> > Hi,
> > I try to call MatISGetMPIXAIJ on a MatIS (A) that has been feed locally by
> > sequential (Aloc) dense matrix.
> > Seems this ends up with this error: [0]PETSC ERROR: New nonzero at (0,1)
> > caused a malloc. Is this a known error / limitation ? (not supposed to work
> > with dense matrix ?)
> > This (pseudo code) works fine:
> > MatCreateIS(..., A)
> > MatCreateSeqAIJ(..., Aloc)
> > MatISSetLocalMat(pcA, pcALoc)
> > MatISGetMPIXAIJ(A, ...) // OK !
> > When I try to replace MatCreateSeqAIJ(..., Aloc) with
> > MatCreateSeqDense(...,
> > Aloc), it does no more work.
> > Franck
> > PS: running debian/testing with gcc-6.3 + petsc-3.7.6
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170619/7d61f924/attachment-0001.html>
Type: text/x-c++src
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170619/7d61f924/attachment-0002.cpp>
Type: text/x-c++src
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170619/7d61f924/attachment-0003.cpp>
