[petsc-users] Fwd: strange PETSc/KSP GMRES timings for MPI+OMP configuration on KNLs
Damian Kaliszan
damian at man.poznan.pl
Mon Jun 19 08:32:43 CDT 2017
Thank you for the answer and the article.
I use SLURM (srun) for job submission by running
'srun script.py script_parameters' command inside batch script so this is SPMD model.
What I noticed is that the problems I'm having now didn't happened
before on CPU E5-2697 v3 nodes (28 cores - the best perormance I had
was using 14MPIs/2OMP per node). Problems started to appear when I moved to KNLs.
The funny thing is that switching OMP on/off (by setting
OMP_NUM_THREADS to 1) doesn't help for all #NODES/# MPI/ #OMP
combinations. For example, for 2 nodes, 16 MPIs, for OMP=1 and 2 the
timings are huge and for 4 is OK.
Playing with affinitty didn't help so far.
In other words at first glance results look completely random (I can
provide more such examples).
Best,
Damian
W liście datowanym 19 czerwca 2017 (14:50:25) napisano:
On Mon, Jun 19, 2017 at 6:42 AM, Damian Kaliszan <damian at man.poznan.pl> wrote:
Regarding my previous post
I looked into both logs of 64MPI/1 OMP vs. 64MPI/2 OMP.
What attracted my attention is huge difference in MPI timings in the following places:
Average time to get PetscTime(): 2.14577e-07
Average time for MPI_Barrier(): 3.9196e-05
Average time for zero size MPI_Send(): 5.45382e-06
vs.
Average time to get PetscTime(): 4.05312e-07
Average time for MPI_Barrier(): 0.348399
Average time for zero size MPI_Send(): 0.029937
Isn't something wrong with PETSc library itself?...
I don't think so. This is bad interaction of MPI and your threading mechanism. MPI_Barrier() and MPI_Send() are lower
level than PETSc. What threading mode did you choose for MPI? This can have a performance impact.
Also, the justifications for threading in this context are weak (or non-existent): http://www.orau.gov/hpcor2015/whitepapers/Exascale_Computing_without_Threads-Barry_Smith.pdf
Matt
Best,
Damian
Wiadomość przekazana
Od: Damian Kaliszan <damian at man.poznan.pl>
Do: PETSc users list <petsc-users at mcs.anl.gov>
Data: 16 czerwca 2017, 14:57:10
Temat: [petsc-users] strange PETSc/KSP GMRES timings for MPI+OMP configuration on KNLs
===8<===============Treść oryginalnej wiadomości===============
For several days I've been trying to figure out what is going wrong
with my python app timings solving Ax=b with KSP (GMRES) solver when trying to run on Intel's KNL 7210/7230.
I downsized the problem to 1000x1000 A matrix and a single node and
observed the following:
I'm attaching 2 extreme timings where configurations differ only by 1 OMP thread (64MPI/1 OMP vs 64/2 OMPs),
23321 vs 23325 slurm task ids.
Any help will be appreciated....
Best,
Damian
===8<===========Koniec treści oryginalnej wiadomości===========
Damian Kaliszan
Poznan Supercomputing and Networking Center
HPC and Data Centres Technologies
ul. Jana Pawła II 10
61-139 Poznan
POLAND
phone (+48 61) 858 5109
e-mail damian at man.poznan.pl
www - http://www.man.poznan.pl/
---------- Forwarded message ----------
To: PETSc users list <petsc-users at mcs.anl.gov>
Cc:
Bcc:
Date: Fri, 16 Jun 2017 14:57:10 +0200
Subject: [petsc-users] strange PETSc/KSP GMRES timings for MPI+OMP configuration on KNLs
Best,
Damian
-- Norbert Wiener
http://www.caam.rice.edu/~mk51/
Damian Kaliszan
61-139 Poznan
POLAND
