[petsc-users] undefined symbol: petsc_null_function_
Barry Smith
bsmith at mcs.anl.gov
Fri Jun 16 19:12:01 CDT 2017
Please send make.log and configure.log from building PETSc
This is a fortran stub function, is there any fortran in your code?
If there is no fortran you can reconfigure PETSc with the option -with-fc=0
Otherwise we need to track down why it is not being found.
Barry
> On Jun 16, 2017, at 6:31 PM, TianHao Le <thl at gps.caltech.edu> wrote:
> Dear all,
> I try to put a 3-D radiative transfer model in the python Large-Scale
> Simulations model. However, when I setup the LES model, I got the
> following error message:
> Traceback (most recent call last):
> File "main.py", line 33, in <module>
> main()
> File "main.py", line 17, in main
> main3d(namelist)
> File "main.py", line 23, in main3d
> import Simulation3d
> File "Radiation.pxd", line 11, in init Simulation3d (Simulation3d.c:29383)
> cdef class RadiationBase:
> ImportError: /global/home/thl/pycles-test/Radiation.so: undefined symbol:
> Seems cannot find the PETSC NULL FUNCTION.
> I add the following 5 include paths in the setup.py (because I am not sure
> that I should add which one.)
> include_path += ['/home/thl/petsc/include/petsc/finclude']
> include_path += ['/home/thl/petsc/include/petsc/private']
> include_path += ['/home/thl/petsc/fast_double/include']
> include_path += ['/home/thl/petsc/include']
> include_path += ['/home/thl/petsc/include/petsc']
> and add the following 2 library directions.
> library_dirs.append('/home/thl/tenstream/build/lib')
> library_dirs.append('/home/thl/petsc/fast_double/lib')
> Now I am not sure what may cause this, maybe didn't install PETSC
> correctly? Or add wrong include path or in a wrong way?
> If anyone knows how to fix this, please let me know!
> Thanks,
> Tianhao
