[petsc-users] PETSC profiling on 1536 cores
Richard Tran Mills
rtmills at anl.gov
Fri Jun 16 15:03:05 CDT 2017
Pietro,
On Fri, Jun 16, 2017 at 1:29 AM, Pietro Incardona <asmprog32 at hotmail.com>
wrote:
> I will try now other examples more in the direction of having only CG and
> no preconditioners to see what happen in scalability and understand what I
> am doing wrong. But in the meanwhile I have a second question does the fact
> that I compiled PETSC with debugging = 0 could affect the profiler numbers
> to be unreliable ?
Building with debugging = 0 is the right thing to do if you want to do any
performance studies. Building with debugging turned *on* is what might make
the profile numbers unreliable.
--Richard
> Thanks in advance
> Pietro Incardona
> *Da:* Barry Smith <bsmith at mcs.anl.gov>
> *Inviato:* giovedì 15 giugno 2017 23:16:50
> *A:* Pietro Incardona
> *Cc:* petsc-users at mcs.anl.gov
> *Oggetto:* Re: [petsc-users] PETSC profiling on 1536 cores
> Please send the complete -log_view files as attachments. Both 1536 and
> 48 cores. The mailers mess up the ASCII formatting in text so I can't make
> heads or tails out of the result.
> What is the MPI being used and what kind of interconnect does the
> network have? Also is the MPI specific to that interconnect or just
> something compiled off the web?
> Barry
> > On Jun 15, 2017, at 4:09 PM, Pietro Incardona <asmprog32 at hotmail.com>
> wrote:
> > Dear All
> > I tried PETSC version 3.6.5 to solve a linear system with 256 000 000
> unknown. The equation is Finite differences Poisson equation.
> > I am using Conjugate gradient (the matrix is symmetric) with no
> preconditioner. Visualizing the solution is reasonable.
> > Unfortunately the Conjugate-Gradient does not scale at all and I am
> extremely concerned about this problem in paticular about the profiling
> numbers.
> > Looking at the profiler it seem that
> > 1536 cores = 24 cores x 64
> > VecScatterBegin 348 1.0 2.3975e-01 1.8 0.00e+00 0.0 7.7e+06 3.1e+04
> 0.0e+00 0 0 85 99 0 0 0 85 99 0 0
> > VecScatterEnd 348 1.0 2.8680e+00 1.8 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00 1 0 0 0 0 1 0 0 0 0 0
> > MatMult 348 1.0 4.1088e+00 1.4 8.18e+08 1.3 7.7e+06 3.1e+04
> 0.0e+00 2 52 85 99 0 2 52 85 99 0 281866
> > I was expecting that this part was the most expensive and take around 4
> second in total that sound reasonable
> > Unfortunately
> > on 1536 cores = 24 cores x 64
> > VecTDot 696 1.0 3.4442e+01 1.4 2.52e+08 1.3 0.0e+00 0.0e+00
> 7.0e+02 12 16 0 0 65 12 16 0 0 65 10346
> > VecNorm 349 1.0 1.1101e+02 1.1 1.26e+08 1.3 0.0e+00 0.0e+00
> 3.5e+02 46 8 0 0 33 46 8 0 0 33 1610
> > VecAXPY 696 1.0 8.3134e+01 1.1 2.52e+08 1.3 0.0e+00 0.0e+00
> 0.0e+00 34 16 0 0 0 34 16 0 0 0 4286
> > Take over 228 seconds. Considering that doing some test on the cluster I
> do not see any problem with MPI_Reduce I do not understand how these
> numbers are possible
> > ////////////////////////// I also attach to the profiling part the
> inversion on 48 cores /////////////////////////
> > VecTDot 696 1.0 1.4684e+01 1.3 3.92e+09 1.1 0.0e+00 0.0e+00
> 7.0e+02 6 16 0 0 65 6 16 0 0 65 24269
> > VecNorm 349 1.0 4.9612e+01 1.3 1.96e+09 1.1 0.0e+00 0.0e+00
> 3.5e+02 22 8 0 0 33 22 8 0 0 33 3602
> > VecCopy 351 1.0 8.8359e+00 7.7 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00 2 0 0 0 0 2 0 0 0 0 0
> > VecSet 2 1.0 1.6177e-02 2.6 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> > VecAXPY 696 1.0 8.8559e+01 1.1 3.92e+09 1.1 0.0e+00 0.0e+00
> 0.0e+00 42 16 0 0 0 42 16 0 0 0 4024
> > VecAYPX 347 1.0 4.6790e+00 1.2 1.95e+09 1.1 0.0e+00 0.0e+00
> 0.0e+00 2 8 0 0 0 2 8 0 0 0 37970
> > VecAssemblyBegin 2 1.0 5.0942e-02 2.9 0.00e+00 0.0 0.0e+00 0.0e+00
> 6.0e+00 0 0 0 0 1 0 0 0 0 1 0
> > VecAssemblyEnd 2 1.0 1.9073e-05 6.7 0.00e+00 0.0 0.0e+00 0.0e+00
> > VecScatterBegin 348 1.0 1.2763e+00 1.5 0.00e+00 0.0 4.6e+05 2.0e+05
> 0.0e+00 0 0 97100 0 0 0 97100 0 0
> > VecScatterEnd 348 1.0 4.6741e+00 5.6 0.00e+00 0.0 0.0e+00 0.0e+00
> > MatMult 348 1.0 2.8440e+01 1.1 1.27e+10 1.1 4.6e+05 2.0e+05
> 0.0e+00 13 52 97100 0 13 52 97100 0 40722
> > MatAssemblyBegin 1 1.0 7.4749e-0124.5 0.00e+00 0.0 0.0e+00 0.0e+00
> 2.0e+00 0 0 0 0 0 0 0 0 0 0 0
> > MatAssemblyEnd 1 1.0 8.3194e-01 1.0 0.00e+00 0.0 2.7e+03 5.1e+04
> 8.0e+00 0 0 1 0 1 0 0 1 0 1 0
> > KSPSetUp 1 1.0 8.2883e-02 1.7 0.00e+00 0.0 0.0e+00 0.0e+00
> > KSPSolve 1 1.0 1.7964e+02 1.0 2.45e+10 1.1 4.6e+05 2.0e+05
> 1.0e+03 87100 97100 98 87100 97100 98 12398
> > PCSetUp 1 1.0 1.1921e-06 0.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > PCApply 349 1.0 8.8166e+00 7.8 0.00e+00 0.0 0.0e+00 0.0e+00
> > If you need more information or test please let me know.
> > Thanks in advance
> > Here the log of 1536 cores
> > 345 KSP Residual norm 1.007085286893e-02
> > 346 KSP Residual norm 1.010054402040e-02
> > 347 KSP Residual norm 1.002139574355e-02
> > 348 KSP Residual norm 9.775851299055e-03
> > Max div for vorticity 1.84572e-05 Integral: 6.62466e-09 130.764 -132
> > *** WIDEN YOUR WINDOW TO 120 CHARACTERS. Use 'enscript -r
> -fCourier9' to print this document ***
> > ---------------------------------------------- PETSc Performance
> Summary: ----------------------------------------------
> > ./vic_petsc on a arch-linux2-c-opt named taurusi6217 with 1536
> processors, by incard Thu Jun 15 22:27:09 2017
> > Using Petsc Release Version 3.6.4, Apr, 12, 2016
> > Max Max/Min Avg Total
> > Time (sec): 2.312e+02 1.00027 2.312e+02
> > Objects: 1.900e+01 1.00000 1.900e+01
> > Flops: 1.573e+09 1.32212 1.450e+09 2.227e+12
> > Flops/sec: 6.804e+06 1.32242 6.271e+06 9.633e+09
> > MPI Messages: 8.202e+03 2.06821 5.871e+03 9.018e+06
> > MPI Message Lengths: 2.013e+08 1.86665 2.640e+04 2.381e+11
> > MPI Reductions: 1.066e+03 1.00000
> > Flop counting convention: 1 flop = 1 real number operation of type
> (multiply/divide/add/subtract)
> > e.g., VecAXPY() for real vectors of length N
> --> 2N flops
> > and VecAXPY() for complex vectors of length N
> --> 8N flops
> > Summary of Stages: ----- Time ------ ----- Flops ----- --- Messages
> --- -- Message Lengths -- -- Reductions --
> > Avg %Total Avg %Total counts
> %Total Avg %Total counts %Total
> > 0: Main Stage: 2.3120e+02 100.0% 2.2272e+12 100.0% 9.018e+06
> 100.0% 2.640e+04 100.0% 1.065e+03 99.9%
> > See the 'Profiling' chapter of the users' manual for details on
> interpreting output.
> > Phase summary info:
> > Count: number of times phase was executed
> > Time and Flops: Max - maximum over all processors
> > Ratio - ratio of maximum to minimum over all processors
> > Mess: number of messages sent
> > Avg. len: average message length (bytes)
> > Reduct: number of global reductions
> > Global: entire computation
> > Stage: stages of a computation. Set stages with PetscLogStagePush()
> and PetscLogStagePop().
> > %T - percent time in this phase %F - percent flops in this
> phase
> > %M - percent messages in this phase %L - percent message
> lengths in this phase
> > %R - percent reductions in this phase
> > Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time
> > Event Count Time (sec)
> Flops --- Global --- --- Stage --- Total
> > Max Ratio Max Ratio Max Ratio Mess Avg len
> Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s
> > --- Event Stage 0: Main Stage
> > VecCopy 351 1.0 2.7609e-01 5.8 0.00e+00 0.0 0.0e+00 0.0e+00
> > VecSet 2 1.0 3.8961e-0256.9 0.00e+00 0.0 0.0e+00 0.0e+00
> > VecAYPX 347 1.0 2.0852e-01 2.0 1.25e+08 1.3 0.0e+00 0.0e+00
> 0.0e+00 0 8 0 0 0 0 8 0 0 0 852044
> > VecAssemblyBegin 2 1.0 8.3237e-02 1.8 0.00e+00 0.0 0.0e+00 0.0e+00
> > VecAssemblyEnd 2 1.0 5.1022e-0517.8 0.00e+00 0.0 0.0e+00 0.0e+00
> > MatAssemblyBegin 1 1.0 9.1920e-02 3.4 0.00e+00 0.0 0.0e+00 0.0e+00
> > MatAssemblyEnd 1 1.0 3.9093e+00 1.0 0.00e+00 0.0 4.4e+04 7.7e+03
> 8.0e+00 2 0 0 0 1 2 0 0 0 1 0
> > KSPSetUp 1 1.0 8.1890e-03 4.3 0.00e+00 0.0 0.0e+00 0.0e+00
> > KSPSolve 1 1.0 2.1525e+02 1.0 1.57e+09 1.3 7.7e+06 3.1e+04
> 1.0e+03 93100 85 99 98 93100 85 99 98 10347
> > PCSetUp 1 1.0 5.5075e-05 0.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > PCApply 349 1.0 2.7485e-01 6.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > Memory usage is given in bytes:
> > Object Type Creations Destructions Memory Descendants'
> Mem.
> > Reports information only for process 0.
> > Vector 10 7 7599552 0
> > Vector Scatter 1 1 1088 0
> > Matrix 3 3 20858912 0
> > Krylov Solver 1 1 1216 0
> > Index Set 2 2 242288 0
> > Preconditioner 1 1 816 0
> > Viewer 1 0 0 0
> > Average time to get PetscTime(): 9.53674e-08
> > Average time for MPI_Barrier(): 3.68118e-05
> > Average time for zero size MPI_Send(): 3.24349e-06
> > #PETSc Option Table entries:
> > -ksp_atol 0.010000
> > -ksp_max_it 500
> > -ksp_monitor
> > -ksp_type cg
> > -log_summary
> > #End of PETSc Option Table entries
> > Compiled without FORTRAN kernels
> > Compiled with full precision matrices (default)
> > sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
> sizeof(PetscScalar) 8 sizeof(PetscInt) 4
> > Configure options: --with-cxx-dialect=C++11 --with-mpi-dir=/sw/taurus/libraries/openmpi/1.10.2-gnu
> --with-parmetis=yes --with-parmetis-dir=/scratch/p_ppm//PARMETIS/
> --with-metis=yes --with-metis-dir=/scratch/p_ppm//METIS --with-boost=yes
> --with-boost-dir=/scratch/p_ppm//BOOST --with-blas-lib=/scratch/p_
> ppm//OPENBLAS/lib/libopenblas.a --with-lapack-lib=/scratch/p_
> ppm//OPENBLAS/lib/libopenblas.a --with-suitesparse=yes
> --with-suitesparse-dir=/scratch/p_ppm//SUITESPARSE --with-trilinos=yes
> -with-trilinos-dir=/scratch/p_ppm//TRILINOS --with-scalapack=yes
> -with-scalapack-dir=/scratch/p_ppm//SCALAPACK --with-mumps=yes
> --with-mumps-include=/scratch/p_ppm//MUMPS/include
> --with-superlu_dist=yes --with-superlu_dist-lib=/
> scratch/p_ppm//SUPERLU_DIST/lib/libsuperlu_dist_4.3.a
> --with-superlu_dist-include=/scratch/p_ppm//SUPERLU_DIST/include/
> --with-hypre=yes -with-hypre-dir=/scratch/p_ppm//HYPRE
> --with-mumps-lib=""/scratch/p_ppm//MUMPS/lib/libdmumps.a
> /scratch/p_ppm//MUMPS/lib/libmumps_common.a /scratch/p_ppm//MUMPS/lib/libpord.a""
> --prefix=/scratch/p_ppm//PETSC --with-debugging=0
> > Libraries compiled on Wed Feb 22 17:30:49 2017 on tauruslogin4
> > Machine characteristics: Linux-2.6.32-642.11.1.el6.
> Bull.106.x86_64-x86_64-with-redhat-6.8-Santiago
> > Using PETSc directory: /lustre/scratch2/p_ppm/
> jenkins2/workspace/OpenFPM_high_scal_tests/petsc-3.6.4
> > Using PETSc arch: arch-linux2-c-opt
> > Using C compiler: /sw/taurus/libraries/openmpi/1.10.2-gnu/bin/mpicc
> -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -O
> ${COPTFLAGS} ${CFLAGS}
> > Using Fortran compiler: /sw/taurus/libraries/openmpi/1.10.2-gnu/bin/mpif90
> -fPIC -Wall -Wno-unused-variable -ffree-line-length-0
> -Wno-unused-dummy-argument -O ${FOPTFLAGS} ${FFLAGS}
> > Using include paths: -I/lustre/scratch2/p_ppm/
> jenkins2/workspace/OpenFPM_high_scal_tests/petsc-3.6.4/arch-linux2-c-opt/include
> -I/lustre/scratch2/p_ppm/jenkins2/workspace/OpenFPM_
> high_scal_tests/petsc-3.6.4/include -I/lustre/scratch2/p_ppm/
> jenkins2/workspace/OpenFPM_high_scal_tests/petsc-3.6.4/include
> -I/scratch/p_ppm/TRILINOS/include -I/scratch/p_ppm/HYPRE/include
> -I/scratch/p_ppm/SUPERLU_DIST/include -I/scratch/p_ppm/SUITESPARSE/include
> -I/scratch/p_ppm/MUMPS/include -I/scratch/p_ppm/PARMETIS/include
> -I/scratch/p_ppm/METIS/include -I/scratch/p_ppm/BOOST/include
> -I/sw/taurus/libraries/openmpi/1.10.2-gnu/include
> > Using C linker: /sw/taurus/libraries/openmpi/1.10.2-gnu/bin/mpicc
> > Using Fortran linker: /sw/taurus/libraries/openmpi/1.10.2-gnu/bin/mpif90
> > Using libraries: -Wl,-rpath,/lustre/scratch2/p_ppm/jenkins2/workspace/
> OpenFPM_high_scal_tests/petsc-3.6.4/arch-linux2-c-opt/lib
> -L/lustre/scratch2/p_ppm/jenkins2/workspace/OpenFPM_
> high_scal_tests/petsc-3.6.4/arch-linux2-c-opt/lib -lpetsc
> -Wl,-rpath,/scratch/p_ppm/TRILINOS/lib -L/scratch/p_ppm/TRILINOS/lib
> -lpike-blackbox -ltrilinoscouplings -lmsqutil -lmesquite -lctrilinos
> -lsundancePdeopt -lsundanceStdFwk -lsundanceStdMesh -lsundanceCore
> -lsundanceInterop -lsundanceUtils -lsundancePlaya -lpiro -lrol
> -lstokhos_muelu -lstokhos_ifpack2 -lstokhos_amesos2 -lstokhos_tpetra
> -lstokhos_sacado -lstokhos -lmoochothyra -lmoocho -lrythmos
> -lmuelu-adapters -lmuelu-interface -lmuelu -lmoertel -llocathyra
> -llocaepetra -llocalapack -lloca -lnoxepetra -lnoxlapack -lnox -lphalanx
> -lstk_mesh_fixtures -lstk_search_util_base -lstk_search
> -lstk_unit_test_utils -lstk_io_util -lstk_io -lstk_mesh_base -lstk_topology
> -lstk_util_use_cases -lstk_util_registry -lstk_util_diag -lstk_util_env
> -lstk_util_util -lstkclassic_search_util -lstkclassic_search
> -lstkclassic_rebalance_utils -lstkclassic_rebalance -lstkclassic_linsys
> -lstkclassic_io_util -lstkclassic_io -lstkclassic_expreval
> -lstkclassic_algsup -lstkclassic_mesh_fem -lstkclassic_mesh_base
> -lstkclassic_util_use_cases -lstkclassic_util_unit_test_support
> -lstkclassic_util_parallel -lstkclassic_util_diag -lstkclassic_util_env
> -lstkclassic_util_util -lstk_mesh_fixtures -lstk_search_util_base
> -lstk_search -lstk_unit_test_utils -lstk_io_util -lstk_io -lstk_mesh_base
> -lstk_topology -lstk_util_use_cases -lstk_util_registry -lstk_util_diag
> -lstk_util_env -lstk_util_util -lstkclassic_search_util -lstkclassic_search
> -lstkclassic_util_util -lintrepid -lteko -lfei_trilinos -lfei_base
> -lstratimikos -lstratimikosbelos -lstratimikosaztecoo -lstratimikosamesos
> -lstratimikosml -lstratimikosifpack -lifpack2-adapters -lifpack2
> -lanasazitpetra -lModeLaplace -lanasaziepetra -lanasazi -lkomplex -lsupes
> -laprepro_lib -lchaco -lIonit -lIotr -lIohb -lIogn -lIopg -lIoss -lsupes
> -laprepro_lib -lchaco -lIonit -lIotr -lIohb -lIogn -lIopg -lIoss -lamesos2
> -lshylu -lbelostpetra -lbelosepetra -lbelos -lml -lifpack -lzoltan2
> -lpamgen_extras -lpamgen -lamesos -lgaleri-xpetra -lgaleri-epetra -laztecoo
> -ldpliris -lisorropia -loptipack -lxpetra-sup -lxpetra -lthyratpetra
> -lthyraepetraext -lthyraepetra -lthyracore -lthyratpetra -lthyraepetraext
> -lthyraepetra -lthyracore -lepetraext -ltpetraext -ltpetrainout -ltpetra
> -lkokkostsqr -ltpetrakernels -ltpetraclassiclinalg -ltpetraclassicnodeapi
> -ltpetraclassic -ltpetraext -ltpetrainout -ltpetra -lkokkostsqr
> -ltpetraclassic -ltriutils -lglobipack -lshards -lzoltan -lepetra -lsacado
> -lrtop -lteuchoskokkoscomm -lteuchoskokkoscompat -lteuchosremainder
> -lteuchosnumerics -lteuchoscomm -lteuchosparameterlist -lteuchoscore
> -lkokkosalgorithms -lkokkoscontainers -lkokkoscore -lkokkosalgorithms
> -lkokkoscontainers -lkokkoscore -ltpi -lgtest -lpthread
> -Wl,-rpath,/scratch/p_ppm/HYPRE/lib -L/scratch/p_ppm/HYPRE/lib -lHYPRE
> -Wl,-rpath,/sw/taurus/libraries/openmpi/1.10.2-gnu/lib
> -L/sw/taurus/libraries/openmpi/1.10.2-gnu/lib -Wl,-rpath,/sw/global/compilers/gcc/5.3.0/lib64
> -L/sw/global/compilers/gcc/5.3.0/lib64 -Wl,-rpath,/sw/global/
> compilers/gcc/5.3.0/lib/gcc/x86_64-unknown-linux-gnu/5.3.0
> -L/sw/global/compilers/gcc/5.3.0/lib/gcc/x86_64-unknown-linux-gnu/5.3.0
> -Wl,-rpath,/sw/global/compilers/gcc/5.3.0/libexec/
> gcc/x86_64-unknown-linux-gnu/5.3.0 -L/sw/global/compilers/gcc/5.
> 3.0/libexec/gcc/x86_64-unknown-linux-gnu/5.3.0 -Wl,-rpath,/sw/global/
> compilers/gcc/5.3.0/x86_64-unknown-linux-gnu/lib
> -L/sw/global/compilers/gcc/5.3.0/x86_64-unknown-linux-gnu/lib
> -L/sw/global/compilers/gcc/5.3.0/lib -lmpi_cxx -lstdc++
> -Wl,-rpath,/scratch/p_ppm//SUPERLU_DIST/lib -L/scratch/p_ppm//SUPERLU_DIST/lib
> -lsuperlu_dist_4.3 -Wl,-rpath,/scratch/p_ppm/SUITESPARSE/lib
> -L/scratch/p_ppm/SUITESPARSE/lib -lumfpack -lklu -lcholmod -lbtf
> -lccolamd -lcolamd -lcamd -lamd -lsuitesparseconfig -lrt -ldmumps
> -Wl,-rpath,/scratch/p_ppm//MUMPS/lib -L/scratch/p_ppm//MUMPS/lib
> -lmumps_common -lpord -Wl,-rpath,/scratch/p_ppm/SCALAPACK/lib
> -L/scratch/p_ppm/SCALAPACK/lib -lscalapack -Wl,-rpath,/scratch/p_ppm//OPENBLAS/lib
> -L/scratch/p_ppm//OPENBLAS/lib -lopenblas -Wl,-rpath,/scratch/p_ppm/PARMETIS/lib
> -L/scratch/p_ppm/PARMETIS/lib -lparmetis -Wl,-rpath,/scratch/p_ppm/METIS/lib
> -L/scratch/p_ppm/METIS/lib -lmetis -lX11 -lhwloc -lssl -lcrypto -lm
> -lmpi_usempi -lmpi_mpifh -lgfortran -lm -lgfortran -lm -lquadmath -lm
> -lmpi_cxx -lstdc++ -Wl,-rpath,/sw/taurus/libraries/openmpi/1.10.2-gnu/lib
> -L/sw/global/compilers/gcc/5.3.0/lib64 -Wl,-rpath,/sw/global/compilers/gcc/5.3.0/lib64
> compilers/gcc/5.3.0/libexec/gcc/x86_64-unknown-linux-gnu/5.3.0
> -L/sw/global/compilers/gcc/5.3.0/libexec/gcc/x86_64-unknown-linux-gnu/5.3.0
> -Wl,-rpath,/sw/global/compilers/gcc/5.3.0/lib/gcc/x86_64-unknown-linux-gnu/5.3.0
> -Wl,-rpath,/sw/global/compilers/gcc/5.3.0/x86_64-unknown-linux-gnu/lib
> -L/sw/global/compilers/gcc/5.3.0/lib -ldl -Wl,-rpath,/sw/taurus/
> libraries/openmpi/1.10.2-gnu/lib -lmpi -lgcc_s -lpthread -ldl
> > Regards
> > Pietro Incardona
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170616/070b4fec/attachment-0001.html>
