[petsc-users] slow generation of petsc MPIAIJ matrix
Wed Jun 14 15:20:16 CDT 2017
http://www.mcs.anl.gov/petsc/documentation/faq.html#efficient-assembly
> On Jun 14, 2017, at 3:18 PM, Jed Brown <jed at jedbrown.org> wrote:
> "Kannan, Ramakrishnan" <kannanr at ornl.gov> writes:
>> I am running NHEP across 16 MPI processors over 16 nodes in a matrix of global size of 1,000,000x1,000,000 with approximately global 16,000,000 non-zeros. Each node has the 1D  row distribution of the matrix with exactly 62500 rows and 1 million columns with 1million non-zeros as CSR/COO matrix.
>> I am generating this graph as follows. It takes approximately 12 seconds to insert 25000 NNZ into petsc matrix with MatSetValues which means it is taking closer to 10 minutes to 1million NNZ’s in every processes. It takes 12 seconds for assembly. Is these times normal? Is there a faster way of doing it? I am unable to construct matrices of 1 billion global nnz’s in which each process has closer to 100 million entries.
>>  Generate_petsc_matrix(int n_rows, int n_cols, int n_nnz,
>>                PetscInt *row_idx, PetscInt *col_idx, PetscScalar *val,
>>                const MPICommunicator& communicator) {
>>    int *start_row = new int[communicator.size()];
>>    MPI_Allgather(&n_rows, 1, MPI_INT, all_proc_rows, 1, MPI_INT, MPI_COMM_WORLD);
>>    start_row[0] = 0;
>>    for (int i = 0; i < communicator.size(); i++) {
>>      if (i > 0) {
>>        start_row[i] = start_row[i - 1] + all_proc_rows[i];
>>    MatCreate(PETSC_COMM_WORLD, &A);
>>    MatSetType(A, MATMPIAIJ);
>>    MatSetSizes(A, n_rows, PETSC_DECIDE, global_rows, n_cols);
>>    MatMPIAIJSetPreallocation(A, PETSC_DEFAULT, PETSC_NULL, PETSC_DEFAULT, PETSC_NULL);
> This preallocation is not sufficient.  Either put in the maximum number
> of entries any any row or provide the arrays.  This will make your
> matrix assembly orders of magnitude faster.
>>    PetscInt local_row_idx;
>>    PetscInt local_col_idx;
>>    PetscScalar local_val;
>>    int my_start_row = start_row[MPI_RANK];
>>    int my_start_col = 0;
>> double petsc_insert_time=0.0;
>>    for (int i = 0; i < n_nnz; i++) {
>>      local_row_idx = my_start_row + row_idx[i];
>>      local_col_idx = my_start_col + col_idx[i];
>>      local_val = val[i];
>> tic();
>>      ierr = MatSetValues(A, 1, &local_row_idx, 1, &local_col_idx, &local_val, INSERT_VALUES);
>>      petsc_insert_time += toc();
>>      if (i % 25000 == 0){
>>        PRINTROOT("25000 time::" << petsc_insert_time);
>>        petsc_insert_time=0;
>>      CHKERRV(ierr);
>>    PRINTROOT("100000 time::" << petsc_insert_time);
>>    tic();
>>    MatAssemblyBegin(A, MAT_FINAL_ASSEMBLY);
>>    MatAssemblyEnd(A, MAT_FINAL_ASSEMBLY);
>>    petsc_insert_time = toc();
>>    PRINTROOT("calling assembly to end::took::" << petsc_insert_time);
>> Regards,
>> Ramki
