[petsc-users] Advice on improving Stokes Schur preconditioners
David Nolte
dnolte at dim.uchile.cl
Wed Jun 14 12:41:55 CDT 2017
Dave, thanks a lot for your great answer and for sharing your
experience. I have a much clearer picture now. :)
The experiments 3/ give the desired results for examples of cavity flow.
The (1/mu scaled) mass matrix seems OK.
I followed your and Matt's recommendations, used a FULL Schur
factorization, LU in the 0th split, and gradually relaxed the tolerance
of GMRES/Jacobi in split 1 (observed the gradual increase in outer
iterations). Then I replaced the split_0 LU with AMG (further increase
of outer iterations and iterations on the Schur complement).
Doing so I converged to using hypre boomeramg (smooth_type Euclid,
strong_threshold 0.75) and 3 iterations of GMRES/Jacobi on the Schur
block, which gave the best time-to-solution in my particular setup and
convergence to rtol=1e-8 within 60 outer iterations.
In my cases, using GMRES in the 0th split (with rtol 1e-1 or 1e-2)
instead of "preonly" did not help convergence (on the contrary).
I also repeated the experiments with "-pc_fieldsplit_schur_precondition
selfp", with hypre(ilu) in split 0 and hypre in split 1, just to check,
and somewhat disappointingly ( ;-) ) the wall time is less than half
than when using gmres/Jac and Sp = mass matrix.
I am aware that this says nothing about scaling and robustness with
respect to h-refinement...
Would you agree that these configurations "make sense"?
Furthermore, maybe anyone has a hint where to start tuning multigrid? So
far hypre worked better than ML, but I have not experimented much with
the parameters.
Thanks again for your help!
Best wishes,
David
On 06/12/2017 04:52 PM, Dave May wrote:
> I've been following the discussion and have a couple of comments:
> 1/ For the preconditioners that you are using (Schur factorisation
> LDU, or upper block triangular DU), the convergence properties (e.g. 1
> iterate for LDU and 2 iterates for DU) come from analysis involving
> exact inverses of A_00 and S
> Once you switch from using exact inverses of A_00 and S, you have to
> rely on spectral equivalence of operators. That is fine, but the
> spectral equivalence does not tell you how many iterates LDU or DU
> will require to converge. What it does inform you about is that if you
> have a spectrally equivalent operator for A_00 and S (Schur
> complement), then under mesh refinement, your iteration count
> (whatever it was prior to refinement) will not increase.
> 2/ Looking at your first set of options, I see you have opted to use
> -fieldsplit_ksp_type preonly (for both split 0 and 1). That is nice as
> it creates a linear operator thus you don't need something like FGMRES
> or GCR applied to the saddle point problem.
> Your choice for Schur is fine in the sense that the diagonal of M is
> spectrally equivalent to M, and M is spectrally equivalent to S.
> Whether it is "fine" in terms of the iteration count for Schur
> systems, we cannot say apriori (since the spectral equivalence doesn't
> give us direct info about the iterations we should expect).
> Your preconditioner for A_00 relies on AMG producing a spectrally
> equivalent operator with bounds which are tight enough to ensure
> convergence of the saddle point problem. I'll try explain this.
> In my experience, for many problems (unstructured FE with variable
> coefficients, structured FE meshes with variable coefficients) AMG and
> preonly is not a robust choice. To control the approximation (the
> spectral equiv bounds), I typically run a stationary or Krylov method
> on split 0 (e.g. -fieldsplit_0_ksp_type xxx -fieldsplit_0_kps_rtol
> yyy). Since the AMG preconditioner generated is spectrally equivalent
> (usually!), these solves will converge to a chosen rtol in a constant
> number of iterates under h-refinement. In practice, if I don't enforce
> that I hit something like rtol=1.0e-1 (or 1.0e-2) on the 0th split,
> saddle point iterates will typically increase for "hard" problems
> under mesh refinement (1e4-1e7 coefficient variation), and may not
> even converge at all when just using -fieldsplit_0_ksp_type preonly.
> Failure ultimately depends on how "strong" the preconditioner for A_00
> block is (consider re-discretized geometric multigrid versus AMG).
> Running an iterative solve on the 0th split lets you control and
> recover from weak/poor, but spectrally equivalent preconditioners for
> A_00. Note that people hate this approach as it invariably nests
> Krylov methods, and subsequently adds more global reductions. However,
> it is scalable, optimal, tuneable and converges faster than the case
> which didn't converge at all :D
> 3/ I agree with Matt's comments, but I'd do a couple of other things
> first.
> * I'd first check the discretization is implemented correctly. Your
> P2/P1 element is inf-sup stable - thus the condition number of S
> (unpreconditioned) should be independent of the mesh resolution (h).
> An easy way to verify this is to run either LDU (schur_fact_type full)
> or DU (schur_fact_type upper) and monitor the iterations required for
> those S solves. Use -fieldsplit_1_pc_type none -fieldsplit_1_ksp_rtol
> 1.0e-8 -fieldsplit_1_ksp_monitor_true_residual
> -fieldsplit_1_ksp_pc_right -fieldsplit_1_ksp_type gmres
> -fieldsplit_0_pc_type lu
> Then refine the mesh (ideally via sub-division) and repeat the experiment.
> If the S iterates don't asymptote, but instead grow with each
> refinement - you likely have a problem with the discretisation.
> * Do the same experiment, but this time use your mass matrix as the
> preconditioner for S and use -fieldsplit_1_pc_type lu. If the
> iterates, compared with the previous experiments (without a Schur PC)
> have gone up your mass matrix is not defined correctly. If in the
> previous experiment (without a Schur PC) iterates on the S solves were
> bounded, but now when preconditioned with the mass matrix the iterates
> go up, then your mass matrix is definitely not correct.
> 4/ Lastly, to finally get to your question regarding does +400
> iterates for the solving the Schur seem "reasonable" and what is
> "normal behaviour"?
> It seems "high" to me. However the specifics of your discretisation,
> mesh topology, element quality, boundary conditions render it almost
> impossible to say what should be expected. When I use a Q2-P2*
> discretisation on a structured mesh with a non-constant viscosity I'd
> expect something like 50-60 for 1.0e-10 with a mass matrix scaled by
> the inverse (local) viscosity. For constant viscosity maybe 30
> iterates. I think this kind of statement is not particularly useful or
> helpful though.
> Given you use an unstructured tet mesh, it is possible that some
> elements have very bad quality (high aspect ratio (AR), highly
> skewed). I am certain that P2/P1 has an inf-sup constant which is
> sensitive to the element aspect ratio (I don't recall the exact
> scaling wrt AR). From experience I know that using the mass matrix as
> a preconditioner for Schur is not robust as AR increases (e.g.
> iterations for the S solve grow). Hence, with a couple of "bad"
> element in your mesh, I could imagine that you could end up having to
> perform +400 iterations
> 5/ Lastly, definitely don't impose one Dirichlet BC on pressure to
> make the pressure unique. This really screws up all the nice
> properties of your matrices. Just enforce the constant null space for
> p. And as you noticed, GMRES magically just does it automatically if
> the RHS of your original system was consistent.
> Thanks,
> Dave
> On 12 June 2017 at 20:20, David Nolte <dnolte at dim.uchile.cl
> <mailto:dnolte at dim.uchile.cl>> wrote:
> Ok. With "-pc_fieldsplit_schur_fact_type full" the outer iteration
> converges in 1 step. The problem remain the Schur iterations.
> I was not sure if the problem was maybe the singular pressure or
> the pressure Dirichlet BC. I tested the solver with a standard
> Stokes flow in a pipe with a constriction (zero Neumann BC for the
> pressure at the outlet) and in a 3D cavity (enclosed flow, no
> pressure BC or fixed at one point). I am not sure if I need to
> attach the constant pressure nullspace to the matrix for GMRES.
> Not doing so does not alter the convergence of GMRES in the Schur
> solver (nor the pressure solution), using a pressure Dirichlet BC
> however slows down convergence (I suppose because of the scaling
> of the matrix).
> I also checked the pressure mass matrix that I give PETSc, it
> looks correct.
> In all these cases, the solver behaves just as before. With LU in
> fieldsplit_0 and GMRES/LU with rtol 1e-10 in fieldsplit_1, it
> converges after 1 outer iteration, but the inner Schur solver
> converges slowly.
> How should the convergence of GMRES/LU of the Schur complement
> *normally* behave?
> Thanks again!
> David
> On 06/12/2017 12:41 PM, Matthew Knepley wrote:
>> On Mon, Jun 12, 2017 at 10:36 AM, David Nolte
>> <dnolte at dim.uchile.cl <mailto:dnolte at dim.uchile.cl>> wrote:
>> On 06/12/2017 07:50 AM, Matthew Knepley wrote:
>>> On Sun, Jun 11, 2017 at 11:06 PM, David Nolte
>>> Thanks Matt, makes sense to me!
>>> I skipped direct solvers at first because for these
>>> 'real' configurations LU (mumps/superlu_dist) usally
>>> goes out of memory (got 32GB RAM). It would be
>>> reasonable to take one more step back and play with
>>> synthetic examples.
>>> I managed to run one case though with 936k dofs using:
>>> ("user" =pressure mass matrix)
>>> -pc_fieldsplit_schur_fact_type upper
>>> -pc_fieldsplit_schur_precondition user
>>> -fieldsplit_0_pc_factor_mat_solver_package mumps
>>> -fieldsplit_1_ksp_monitor_true_residuals
>>> -fieldsplit_1_ksp_rtol 1e-10
>>> -fieldsplit_1_pc_factor_mat_solver_package mumps
>>> It takes 2 outer iterations, as expected. However the
>>> fieldsplit_1 solve takes very long.
>>> 1) It should take 1 outer iterate, not two. The problem is
>>> that your Schur tolerance is way too high. Use
>>> or something like that. Then it will take 1 iterate.
>> Shouldn't it take 2 with a triangular Schur factorization and
>> exact preconditioners, and 1 with a full factorization? (cf.
>> Benzi et al 2005, p.66,
>> http://www.mathcs.emory.edu/~benzi/Web_papers/bgl05.pdf
>> <http://www.mathcs.emory.edu/%7Ebenzi/Web_papers/bgl05.pdf>)
>> That's exactly what I set: -fieldsplit_1_ksp_rtol 1e-10 and
>> the Schur solver does drop below "rtol < 1e-10"
>> Oh, yes. Take away the upper until things are worked out.
>> Thanks,
>> Matt
>>> 2) There is a problem with the Schur solve. Now from the
>>> iterates
>>> 423 KSP preconditioned resid norm 2.638419658982e-02 true
>>> resid norm 7.229653211635e-11 ||r(i)||/||b|| 7.229653211635e-11
>>> it is clear that the preconditioner is really screwing stuff
>>> up. For testing, you can use
>>> -pc_fieldsplit_schur_precondition full
>>> and your same setup here. It should take one iterate. I
>>> think there is something wrong with your
>>> mass matrix.
>> I agree. I forgot to mention that I am considering an
>> "enclosed flow" problem, with u=0 on all the boundary and a
>> Dirichlet condition for the pressure in one point for fixing
>> the constant pressure. Maybe the preconditioner is not
>> consistent with this setup, need to check this..
>> Thanks a lot
>>> Thanks,
>>> Matt
>>> 0 KSP unpreconditioned resid norm 4.038466809302e-03
>>> true resid norm 4.038466809302e-03 ||r(i)||/||b||
>>> 1.000000000000e+00
>>> Residual norms for fieldsplit_1_ solve.
>>> 0 KSP preconditioned resid norm 0.000000000000e+00
>>> true resid norm 0.000000000000e+00
>>> ||r(i)||/||b|| -nan
>>> Linear fieldsplit_1_ solve converged due to
>>> CONVERGED_ATOL iterations 0
>>> 1 KSP unpreconditioned resid norm 4.860095964831e-06
>>> true resid norm 4.860095964831e-06 ||r(i)||/||b||
>>> 1.203450763452e-03
>>> 0 KSP preconditioned resid norm 2.965546249872e+08
>>> true resid norm 1.000000000000e+00 ||r(i)||/||b||
>>> 1.000000000000e+00
>>> 1 KSP preconditioned resid norm 1.347596594634e+08
>>> true resid norm 3.599678801575e-01 ||r(i)||/||b||
>>> 3.599678801575e-01
>>> 2 KSP preconditioned resid norm 5.913230136403e+07
>>> true resid norm 2.364916760834e-01 ||r(i)||/||b||
>>> 2.364916760834e-01
>>> 3 KSP preconditioned resid norm 4.629700028930e+07
>>> true resid norm 1.984444715595e-01 ||r(i)||/||b||
>>> 1.984444715595e-01
>>> 4 KSP preconditioned resid norm 3.804431276819e+07
>>> true resid norm 1.747224559120e-01 ||r(i)||/||b||
>>> 1.747224559120e-01
>>> 5 KSP preconditioned resid norm 3.178769422140e+07
>>> true resid norm 1.402254864444e-01 ||r(i)||/||b||
>>> 1.402254864444e-01
>>> 6 KSP preconditioned resid norm 2.648669043919e+07
>>> true resid norm 1.191164310866e-01 ||r(i)||/||b||
>>> 1.191164310866e-01
>>> 7 KSP preconditioned resid norm 2.203522108614e+07
>>> true resid norm 9.690500018007e-02 ||r(i)||/||b||
>>> 9.690500018007e-02
>>> 422 KSP preconditioned resid norm 2.984888715147e-02
>>> true resid norm 8.598401046494e-11 ||r(i)||/||b||
>>> 8.598401046494e-11
>>> true resid norm 7.229653211635e-11 ||r(i)||/||b||
>>> 7.229653211635e-11
>>> CONVERGED_RTOL iterations 423
>>> 2 KSP unpreconditioned resid norm 3.539889585599e-16
>>> true resid norm 3.542279617063e-16 ||r(i)||/||b||
>>> 8.771347603759e-14
>>> Linear solve converged due to CONVERGED_RTOL iterations 2
>>> Does the slow convergence of the Schur block mean that
>>> my preconditioning matrix Sp is a poor choice?
>>> Thanks,
>>> David
>>> On 06/11/2017 08:53 AM, Matthew Knepley wrote:
>>>> On Sat, Jun 10, 2017 at 8:25 PM, David Nolte
>>>> Dear all,
>>>> I am solving a Stokes problem in 3D aorta
>>>> geometries, using a P2/P1
>>>> finite elements discretization on tetrahedral
>>>> meshes resulting in
>>>> ~1-1.5M DOFs. Viscosity is uniform (can be adjusted
>>>> arbitrarily), and
>>>> the right hand side is a function of noisy
>>>> measurement data.
>>>> In other settings of "standard" Stokes flow
>>>> problems I have obtained
>>>> good convergence with an "upper" Schur complement
>>>> preconditioner, using
>>>> AMG (ML or Hypre) on the velocity block and
>>>> approximating the Schur
>>>> complement matrix by the diagonal of the pressure
>>>> mass matrix:
>>>> -ksp_converged_reason
>>>> -ksp_monitor_true_residual
>>>> -ksp_initial_guess_nonzero
>>>> -ksp_diagonal_scale
>>>> -ksp_diagonal_scale_fix
>>>> -ksp_type fgmres
>>>> -ksp_rtol 1.0e-8
>>>> -pc_type fieldsplit
>>>> -pc_fieldsplit_type schur
>>>> -pc_fieldsplit_detect_saddle_point
>>>> -pc_fieldsplit_schur_precondition user # <--
>>>> -fieldsplit_0_pc_type ml
>>>> -fieldsplit_1_ksp_type preonly
>>>> -fieldsplit_1_pc_type jacobi
>>>> 1) I always recommend starting from an exact solver and
>>>> backing off in small steps for optimization. Thus
>>>> I would start with LU on the upper block and
>>>> GMRES/LU with toelrance 1e-10 on the Schur block.
>>>> This should converge in 1 iterate.
>>>> 2) I don't think you want preonly on the Schur system.
>>>> You might want GMRES/Jacobi to invert the mass matrix.
>>>> 3) You probably want to tighten the tolerance on the
>>>> Schur solve, at least to start, and then slowly let it
>>>> out. The
>>>> tight tolerance will show you how effective the
>>>> preconditioner is using that Schur operator. Then you
>>>> can start
>>>> to evaluate how effective the Schur linear sovler is.
>>>> Does this make sense?
>>>> Thanks,
>>>> Matt
>>>> In my present case this setup gives rather slow
>>>> convergence (varies for
>>>> different geometries between 200-500 or several
>>>> thousands!). I obtain
>>>> better convergence with
>>>> "-pc_fieldsplit_schur_precondition selfp"and
>>>> using multigrid on S, with "-fieldsplit_1_pc_type
>>>> ml" (I don't think
>>>> this is optimal, though).
>>>> I don't understand why the pressure mass matrix
>>>> approach performs so
>>>> poorly and wonder what I could try to improve the
>>>> convergence. Until now
>>>> I have been using ML and Hypre BoomerAMG mostly
>>>> with default parameters.
>>>> Surely they can be improved by tuning some
>>>> parameters. Which could be a
>>>> good starting point? Are there other options I
>>>> should consider?
>>>> With the above setup (jacobi) for a case that works
>>>> better than others,
>>>> the KSP terminates with
>>>> 467 KSP unpreconditioned resid norm
>>>> 2.072014323515e-09 true resid norm
>>>> 2.072014322600e-09 ||r(i)||/||b|| 9.939098100674e-09
>>>> You can find the output of -ksp_view below. Let me
>>>> know if you need more
>>>> details.
>>>> Thanks in advance for your advice!
>>>> Best wishes
>>>> David
>>>> KSP Object: 1 MPI processes
>>>> type: fgmres
>>>> GMRES: restart=30, using Classical (unmodified)
>>>> Gram-Schmidt
>>>> Orthogonalization with no iterative refinement
>>>> GMRES: happy breakdown tolerance 1e-30
>>>> maximum iterations=10000
>>>> tolerances: relative=1e-08, absolute=1e-50,
>>>> divergence=10000.
>>>> right preconditioning
>>>> diagonally scaled system
>>>> using nonzero initial guess
>>>> using UNPRECONDITIONED norm type for convergence test
>>>> PC Object: 1 MPI processes
>>>> type: fieldsplit
>>>> FieldSplit with Schur preconditioner,
>>>> factorization UPPER
>>>> Preconditioner for the Schur complement formed
>>>> from user provided matrix
>>>> Split info:
>>>> Split number 0 Defined by IS
>>>> Split number 1 Defined by IS
>>>> KSP solver for A00 block
>>>> KSP Object: (fieldsplit_0_) 1 MPI
>>>> processes
>>>> type: preonly
>>>> maximum iterations=10000, initial guess is zero
>>>> tolerances: relative=1e-05,
>>>> absolute=1e-50, divergence=10000.
>>>> left preconditioning
>>>> using NONE norm type for convergence test
>>>> PC Object: (fieldsplit_0_) 1 MPI
>>>> processes
>>>> type: ml
>>>> MG: type is MULTIPLICATIVE, levels=5 cycles=v
>>>> Cycles per PCApply=1
>>>> Using Galerkin computed coarse grid
>>>> matrices
>>>> Coarse grid solver -- level
>>>> KSP Object:
>>>> (fieldsplit_0_mg_coarse_) 1 MPI
>>>> processes
>>>> type: preonly
>>>> is zero
>>>> PC Object:
>>>> processes
>>>> type: lu
>>>> LU: out-of-place factorization
>>>> tolerance for zero pivot 2.22045e-14
>>>> using diagonal shift on blocks to
>>>> prevent zero pivot
>>>> [INBLOCKS]
>>>> matrix ordering: nd
>>>> factor fill ratio given 5., needed 1.
>>>> Factored matrix follows:
>>>> Mat Object: 1
>>>> MPI processes
>>>> type: seqaij
>>>> rows=3, cols=3
>>>> package used to perform
>>>> factorization: petsc
>>>> total: nonzeros=3, allocated
>>>> nonzeros=3
>>>> total number of mallocs used
>>>> during MatSetValues
>>>> calls =0
>>>> not using I-node routines
>>>> linear system matrix = precond matrix:
>>>> Mat Object: 1 MPI processes
>>>> type: seqaij
>>>> rows=3, cols=3
>>>> total: nonzeros=3, allocated nonzeros=3
>>>> total number of mallocs used during
>>>> MatSetValues calls =0
>>>> Down solver (pre-smoother) on level 1
>>>> KSP Object:
>>>> (fieldsplit_0_mg_levels_1_) 1
>>>> MPI processes
>>>> type: richardson
>>>> Richardson: damping factor=1.
>>>> maximum iterations=2
>>>> PC Object:
>>>> MPI processes
>>>> type: sor
>>>> SOR: type = local_symmetric,
>>>> iterations = 1, local
>>>> iterations = 1, omega = 1.
>>>> type: seqaij
>>>> rows=15, cols=15
>>>> total: nonzeros=69, allocated nonzeros=69
>>>> Up solver (post-smoother) same as down
>>>> Down solver (pre-smoother) on level 2
>>>> KSP Object:
>>>> (fieldsplit_0_mg_levels_2_) 1
>>>> MPI processes
>>>> type: richardson
>>>> PC Object:
>>>> MPI processes
>>>> type: sor
>>>> type: seqaij
>>>> rows=304, cols=304
>>>> total: nonzeros=7354, allocated
>>>> nonzeros=7354
>>>> Down solver (pre-smoother) on level 3
>>>> KSP Object:
>>>> (fieldsplit_0_mg_levels_3_) 1
>>>> MPI processes
>>>> type: richardson
>>>> PC Object:
>>>> MPI processes
>>>> type: sor
>>>> type: seqaij
>>>> rows=30236, cols=30236
>>>> total: nonzeros=2730644, allocated
>>>> nonzeros=2730644
>>>> Down solver (pre-smoother) on level 4
>>>> KSP Object:
>>>> (fieldsplit_0_mg_levels_4_) 1
>>>> MPI processes
>>>> type: richardson
>>>> PC Object:
>>>> MPI processes
>>>> type: sor
>>>> Mat Object: (fieldsplit_0_)
>>>> 1 MPI
>>>> processes
>>>> type: seqaij
>>>> rows=894132, cols=894132
>>>> total: nonzeros=70684164, allocated
>>>> nonzeros=70684164
>>>> 1 MPI processes
>>>> type: seqaij
>>>> nonzeros=70684164
>>>> KSP solver for S = A11 - A10 inv(A00) A01
>>>> KSP Object: (fieldsplit_1_) 1 MPI
>>>> processes
>>>> type: preonly
>>>> PC Object: (fieldsplit_1_) 1 MPI
>>>> processes
>>>> type: jacobi
>>>> linear system matrix followed by
>>>> preconditioner matrix:
>>>> Mat Object: (fieldsplit_1_)
>>>> 1 MPI processes
>>>> type: schurcomplement
>>>> rows=42025, cols=42025
>>>> Schur complement A11 - A10 inv(A00) A01
>>>> A11
>>>> Mat Object:
>>>> (fieldsplit_1_) 1
>>>> MPI processes
>>>> type: seqaij
>>>> total: nonzeros=554063, allocated
>>>> nonzeros=554063
>>>> A10
>>>> type: seqaij
>>>> rows=42025, cols=894132
>>>> total: nonzeros=6850107, allocated
>>>> nonzeros=6850107
>>>> KSP of A00
>>>> KSP Object:
>>>> (fieldsplit_0_) 1
>>>> MPI processes
>>>> type: preonly
>>>> guess is zero
>>>> absolute=1e-50,
>>>> divergence=10000.
>>>> convergence test
>>>> PC Object:
>>>> (fieldsplit_0_) 1
>>>> MPI processes
>>>> type: ml
>>>> levels=5 cycles=v
>>>> grid matrices
>>>> KSP Object:
>>>> processes
>>>> type: preonly
>>>> absolute=1e-50,
>>>> divergence=10000.
>>>> convergence test
>>>> PC Object:
>>>> processes
>>>> type: lu
>>>> 2.22045e-14
>>>> blocks to prevent zero
>>>> pivot [INBLOCKS]
>>>> matrix ordering: nd
>>>> needed 1.
>>>> Mat Object:
>>>> 1 MPI
>>>> processes
>>>> type: seqaij
>>>> rows=3, cols=3
>>>> total: nonzeros=3,
>>>> used during
>>>> matrix:
>>>> Mat Object:
>>>> 1 MPI processes
>>>> type: seqaij
>>>> rows=3, cols=3
>>>> nonzeros=3
>>>> during MatSetValues
>>>> calls =0
>>>> KSP Object:
>>>> (fieldsplit_0_mg_levels_1_) 1 MPI
>>>> processes
>>>> type: richardson
>>>> absolute=1e-50,
>>>> divergence=10000.
>>>> convergence test
>>>> PC Object:
>>>> processes
>>>> type: sor
>>>> matrix:
>>>> Mat Object:
>>>> 1 MPI processes
>>>> type: seqaij
>>>> rows=15, cols=15
>>>> nonzeros=69
>>>> during MatSetValues
>>>> calls =0
>>>> down solver (pre-smoother)
>>>> KSP Object:
>>>> (fieldsplit_0_mg_levels_2_) 1 MPI
>>>> processes
>>>> type: richardson
>>>> absolute=1e-50,
>>>> divergence=10000.
>>>> convergence test
>>>> PC Object:
>>>> processes
>>>> type: sor
>>>> matrix:
>>>> Mat Object:
>>>> 1 MPI processes
>>>> type: seqaij
>>>> rows=304, cols=304
>>>> allocated nonzeros=7354
>>>> during MatSetValues
>>>> calls =0
>>>> KSP Object:
>>>> (fieldsplit_0_mg_levels_3_) 1 MPI
>>>> processes
>>>> type: richardson
>>>> absolute=1e-50,
>>>> divergence=10000.
>>>> convergence test
>>>> PC Object:
>>>> processes
>>>> type: sor
>>>> matrix:
>>>> Mat Object:
>>>> 1 MPI processes
>>>> type: seqaij
>>>> allocated nonzeros=2730644
>>>> during MatSetValues
>>>> calls =0
>>>> KSP Object:
>>>> (fieldsplit_0_mg_levels_4_) 1 MPI
>>>> processes
>>>> type: richardson
>>>> absolute=1e-50,
>>>> divergence=10000.
>>>> convergence test
>>>> PC Object:
>>>> processes
>>>> type: sor
>>>> matrix:
>>>> Mat Object:
>>>> (fieldsplit_0_) 1 MPI processes
>>>> type: seqaij
>>>> allocated nonzeros=70684164
>>>> during MatSetValues
>>>> calls =0
>>>> Mat Object:
>>>> type: seqaij
>>>> during MatSetValues calls =0
>>>> A01
>>>> type: seqaij
>>>> rows=894132, cols=42025
>>>> nonzeros=6850107
>>>> type: seqaij
>>>> nonzeros=554063
>>>> type: seqaij
>>>> rows=936157, cols=936157
>>>> total: nonzeros=84938441, allocated
>>>> nonzeros=84938441
>>>> What most experimenters take for granted before they
>>>> begin their experiments is infinitely more interesting
>>>> than any results to which their experiments lead.
>>>> -- Norbert Wiener
>>>> http://www.caam.rice.edu/~mk51/
>>>> <http://www.caam.rice.edu/%7Emk51/>
>>> What most experimenters take for granted before they begin
>>> their experiments is infinitely more interesting than any
>>> -- Norbert Wiener
>> experiments is infinitely more interesting than any results to
>> -- Norbert Wiener
>> http://www.caam.rice.edu/~mk51/ <http://www.caam.rice.edu/%7Emk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170614/83cd3ab0/attachment-0001.html>
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170614/83cd3ab0/attachment-0001.pgp>
