[petsc-users] Advice on improving Stokes Schur preconditioners
Mon Jun 12 11:41:02 CDT 2017
On Mon, Jun 12, 2017 at 10:36 AM, David Nolte <dnolte at dim.uchile.cl> wrote:
> On 06/12/2017 07:50 AM, Matthew Knepley wrote:
> On Sun, Jun 11, 2017 at 11:06 PM, David Nolte <dnolte at dim.uchile.cl>
> wrote:
>> Thanks Matt, makes sense to me!
>> I skipped direct solvers at first because for these 'real' configurations
>> LU (mumps/superlu_dist) usally goes out of memory (got 32GB RAM). It would
>> be reasonable to take one more step back and play with synthetic examples.
>> I managed to run one case though with 936k dofs using: ("user" =pressure
>> mass matrix)
>> -pc_fieldsplit_schur_fact_type upper
>> -pc_fieldsplit_schur_precondition user
>> -fieldsplit_0_ksp_type preonly
>> -fieldsplit_0_pc_type lu
>> -fieldsplit_0_pc_factor_mat_solver_package mumps
>> -fieldsplit_1_ksp_type gmres
>> -fieldsplit_1_ksp_monitor_true_residuals
>> -fieldsplit_1_ksp_rtol 1e-10
>> -fieldsplit_1_pc_type lu
>> -fieldsplit_1_pc_factor_mat_solver_package mumps
>> It takes 2 outer iterations, as expected. However the fieldsplit_1 solve
>> takes very long.
> 1) It should take 1 outer iterate, not two. The problem is that your Schur
> tolerance is way too high. Use
> or something like that. Then it will take 1 iterate.
> Shouldn't it take 2 with a triangular Schur factorization and exact
> preconditioners, and 1 with a full factorization? (cf. Benzi et al 2005,
> p.66, http://www.mathcs.emory.edu/~benzi/Web_papers/bgl05.pdf)
> That's exactly what I set: -fieldsplit_1_ksp_rtol 1e-10 and the Schur
> solver does drop below "rtol < 1e-10"
Oh, yes. Take away the upper until things are worked out.
    Matt
> 2) There is a problem with the Schur solve. Now from the iterates
> 423 KSP preconditioned resid norm 2.638419658982e-02 true resid norm
> 7.229653211635e-11 ||r(i)||/||b|| 7.229653211635e-11
> it is clear that the preconditioner is really screwing stuff up. For
> testing, you can use
>   -pc_fieldsplit_schur_precondition full
> and your same setup here. It should take one iterate. I think there is
> something wrong with your
> mass matrix.
> I agree. I forgot to mention that I am considering an "enclosed flow"
> problem, with u=0 on all the boundary and a Dirichlet condition for the
> pressure in one point for fixing the constant pressure. Maybe the
> preconditioner is not consistent with this setup, need to check this..
> Thanks a lot
>   Thanks,
>     Matt
>>   0 KSP unpreconditioned resid norm 4.038466809302e-03 true resid norm
>> 4.038466809302e-03 ||r(i)||/||b|| 1.000000000000e+00
>>     Residual norms for fieldsplit_1_ solve.
>>     0 KSP preconditioned resid norm 0.000000000000e+00 true resid norm
>> 0.000000000000e+00 ||r(i)||/||b||           -nan
>>   Linear fieldsplit_1_ solve converged due to CONVERGED_ATOL iterations 0
>>   1 KSP unpreconditioned resid norm 4.860095964831e-06 true resid norm
>> 4.860095964831e-06 ||r(i)||/||b|| 1.203450763452e-03
>>     0 KSP preconditioned resid norm 2.965546249872e+08 true resid norm
>> 1.000000000000e+00 ||r(i)||/||b|| 1.000000000000e+00
>>     1 KSP preconditioned resid norm 1.347596594634e+08 true resid norm
>> 3.599678801575e-01 ||r(i)||/||b|| 3.599678801575e-01
>>     2 KSP preconditioned resid norm 5.913230136403e+07 true resid norm
>> 2.364916760834e-01 ||r(i)||/||b|| 2.364916760834e-01
>>     3 KSP preconditioned resid norm 4.629700028930e+07 true resid norm
>> 1.984444715595e-01 ||r(i)||/||b|| 1.984444715595e-01
>>     4 KSP preconditioned resid norm 3.804431276819e+07 true resid norm
>> 1.747224559120e-01 ||r(i)||/||b|| 1.747224559120e-01
>>     5 KSP preconditioned resid norm 3.178769422140e+07 true resid norm
>> 1.402254864444e-01 ||r(i)||/||b|| 1.402254864444e-01
>>     6 KSP preconditioned resid norm 2.648669043919e+07 true resid norm
>> 1.191164310866e-01 ||r(i)||/||b|| 1.191164310866e-01
>>     7 KSP preconditioned resid norm 2.203522108614e+07 true resid norm
>> 9.690500018007e-02 ||r(i)||/||b|| 9.690500018007e-02
>>     422 KSP preconditioned resid norm 2.984888715147e-02 true resid norm
>> 8.598401046494e-11 ||r(i)||/||b|| 8.598401046494e-11
>>   Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations
>> 423
>>   2 KSP unpreconditioned resid norm 3.539889585599e-16 true resid norm
>> 3.542279617063e-16 ||r(i)||/||b|| 8.771347603759e-14
>> Linear solve converged due to CONVERGED_RTOL iterations 2
>> Does the slow convergence of the Schur block mean that my preconditioning
>> matrix Sp is a poor choice?
>> Thanks,
>> David
>> On 06/11/2017 08:53 AM, Matthew Knepley wrote:
>> On Sat, Jun 10, 2017 at 8:25 PM, David Nolte <dnolte at dim.uchile.cl>
>> wrote:
>>> Dear all,
>>> I am solving a Stokes problem in 3D aorta geometries, using a P2/P1
>>> finite elements discretization on tetrahedral meshes resulting in
>>> ~1-1.5M DOFs. Viscosity is uniform (can be adjusted arbitrarily), and
>>> the right hand side is a function of noisy measurement data.
>>> In other settings of "standard" Stokes flow problems I have obtained
>>> good convergence with an "upper" Schur complement preconditioner, using
>>> AMG (ML or Hypre) on the velocity block and approximating the Schur
>>> complement matrix by the diagonal of the pressure mass matrix:
>>>     -ksp_converged_reason
>>>     -ksp_monitor_true_residual
>>>     -ksp_initial_guess_nonzero
>>>     -ksp_diagonal_scale
>>>     -ksp_diagonal_scale_fix
>>>     -ksp_type fgmres
>>>     -ksp_rtol 1.0e-8
>>>     -pc_type fieldsplit
>>>     -pc_fieldsplit_type schur
>>>     -pc_fieldsplit_detect_saddle_point
>>>     -pc_fieldsplit_schur_precondition user    # <-- pressure mass matrix
>>>     -fieldsplit_0_pc_type ml
>>>     -fieldsplit_1_ksp_type preonly
>>>     -fieldsplit_1_pc_type jacobi
>> 1) I always recommend starting from an exact solver and backing off in
>> small steps for optimization. Thus
>>     I would start with LU on the upper block and GMRES/LU with toelrance
>> 1e-10 on the Schur block.
>>     This should converge in 1 iterate.
>> 2) I don't think you want preonly on the Schur system. You might want
>> GMRES/Jacobi to invert the mass matrix.
>> 3) You probably want to tighten the tolerance on the Schur solve, at
>> least to start, and then slowly let it out. The
>>     tight tolerance will show you how effective the preconditioner is
>> using that Schur operator. Then you can start
>>     to evaluate how effective the Schur linear sovler is.
>> Does this make sense?
>>   Thanks,
>>      Matt
>>> In my present case this setup gives rather slow convergence (varies for
>>> different geometries between 200-500 or several thousands!). I obtain
>>> better convergence with "-pc_fieldsplit_schur_precondition selfp"and
>>> using multigrid on S, with "-fieldsplit_1_pc_type ml" (I don't think
>>> this is optimal, though).
>>> I don't understand why the pressure mass matrix approach performs so
>>> poorly and wonder what I could try to improve the convergence. Until now
>>> I have been using ML and Hypre BoomerAMG mostly with default parameters.
>>> Surely they can be improved by tuning some parameters. Which could be a
>>> good starting point? Are there other options I should consider?
>>> With the above setup (jacobi) for a case that works better than others,
>>> the KSP terminates with
>>> 467 KSP unpreconditioned resid norm 2.072014323515e-09 true resid norm
>>> 2.072014322600e-09 ||r(i)||/||b|| 9.939098100674e-09
>>> You can find the output of -ksp_view below. Let me know if you need more
>>> details.
>>> Thanks in advance for your advice!
>>> Best wishes
>>> David
>>> KSP Object: 1 MPI processes
>>>   type: fgmres
>>>     GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
>>> Orthogonalization with no iterative refinement
>>>     GMRES: happy breakdown tolerance 1e-30
>>>   maximum iterations=10000
>>>   tolerances:  relative=1e-08, absolute=1e-50, divergence=10000.
>>>   right preconditioning
>>>   diagonally scaled system
>>>   using nonzero initial guess
>>>   using UNPRECONDITIONED norm type for convergence test
>>> PC Object: 1 MPI processes
>>>   type: fieldsplit
>>>     FieldSplit with Schur preconditioner, factorization UPPER
>>>     Preconditioner for the Schur complement formed from user provided
>>> matrix
>>>     Split info:
>>>     Split number 0 Defined by IS
>>>     Split number 1 Defined by IS
>>>     KSP solver for A00 block
>>>       KSP Object:      (fieldsplit_0_)       1 MPI processes
>>>         type: preonly
>>>         maximum iterations=10000, initial guess is zero
>>>         tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>>>         left preconditioning
>>>         using NONE norm type for convergence test
>>>       PC Object:      (fieldsplit_0_)       1 MPI processes
>>>         type: ml
>>>           MG: type is MULTIPLICATIVE, levels=5 cycles=v
>>>             Cycles per PCApply=1
>>>             Using Galerkin computed coarse grid matrices
>>>         Coarse grid solver -- level -------------------------------
>>>           KSP Object:          (fieldsplit_0_mg_coarse_)           1 MPI
>>> processes
>>>             type: preonly
>>> divergence=10000.
>>>           PC Object:          (fieldsplit_0_mg_coarse_)           1 MPI
>>> processes
>>>             type: lu
>>>               LU: out-of-place factorization
>>>               tolerance for zero pivot 2.22045e-14
>>>               using diagonal shift on blocks to prevent zero pivot
>>> [INBLOCKS]
>>>               matrix ordering: nd
>>>               factor fill ratio given 5., needed 1.
>>>                 Factored matrix follows:
>>>                   Mat Object:                   1 MPI processes
>>>                     type: seqaij
>>>                     rows=3, cols=3
>>>                     package used to perform factorization: petsc
>>>                     total: nonzeros=3, allocated nonzeros=3
>>>                     total number of mallocs used during MatSetValues
>>> calls =0
>>>                       not using I-node routines
>>>             linear system matrix = precond matrix:
>>>               type: seqaij
>>>               rows=3, cols=3
>>>               total number of mallocs used during MatSetValues calls =0
>>>         Down solver (pre-smoother) on level 1
>>>           KSP Object:          (fieldsplit_0_mg_levels_1_)           1
>>> MPI processes
>>>             type: richardson
>>>               Richardson: damping factor=1.
>>>             maximum iterations=2
>>> divergence=10000.
>>>           PC Object:          (fieldsplit_0_mg_levels_1_)           1
>>> MPI processes
>>>             type: sor
>>>               SOR: type = local_symmetric, iterations = 1, local
>>> iterations = 1, omega = 1.
>>>               type: seqaij
>>>               rows=15, cols=15
>>>               total: nonzeros=69, allocated nonzeros=69
>>>         Up solver (post-smoother) same as down solver (pre-smoother)
>>>         Down solver (pre-smoother) on level 2
>>>           KSP Object:          (fieldsplit_0_mg_levels_2_)           1
>>> MPI processes
>>>             type: richardson
>>> divergence=10000.
>>>           PC Object:          (fieldsplit_0_mg_levels_2_)           1
>>> MPI processes
>>>             type: sor
>>>               type: seqaij
>>>               rows=304, cols=304
>>>               total: nonzeros=7354, allocated nonzeros=7354
>>>         Down solver (pre-smoother) on level 3
>>>           KSP Object:          (fieldsplit_0_mg_levels_3_)           1
>>> MPI processes
>>>             type: richardson
>>> divergence=10000.
>>>           PC Object:          (fieldsplit_0_mg_levels_3_)           1
>>> MPI processes
>>>             type: sor
>>>               type: seqaij
>>>               rows=30236, cols=30236
>>>               total: nonzeros=2730644, allocated nonzeros=2730644
>>>         Down solver (pre-smoother) on level 4
>>>           KSP Object:          (fieldsplit_0_mg_levels_4_)           1
>>> MPI processes
>>>             type: richardson
>>> divergence=10000.
>>>           PC Object:          (fieldsplit_0_mg_levels_4_)           1
>>> MPI processes
>>>             type: sor
>>>             Mat Object:            (fieldsplit_0_)             1 MPI
>>> processes
>>>               type: seqaij
>>>               rows=894132, cols=894132
>>>               total: nonzeros=70684164, allocated nonzeros=70684164
>>>         Mat Object:        (fieldsplit_0_)         1 MPI processes
>>>           type: seqaij
>>>     KSP solver for S = A11 - A10 inv(A00) A01
>>>       KSP Object:      (fieldsplit_1_)       1 MPI processes
>>>         type: preonly
>>>       PC Object:      (fieldsplit_1_)       1 MPI processes
>>>         type: jacobi
>>>         linear system matrix followed by preconditioner matrix:
>>>         Mat Object:        (fieldsplit_1_)         1 MPI processes
>>>           type: schurcomplement
>>>           rows=42025, cols=42025
>>>             Schur complement A11 - A10 inv(A00) A01
>>>             A11
>>> MPI processes
>>>                 type: seqaij
>>>                 total: nonzeros=554063, allocated nonzeros=554063
>>>             A10
>>>                 type: seqaij
>>>                 rows=42025, cols=894132
>>>                 total: nonzeros=6850107, allocated nonzeros=6850107
>>>             KSP of A00
>>> MPI processes
>>>                 type: preonly
>>> divergence=10000.
>>> MPI processes
>>>                 type: ml
>>>                   KSP Object:
>>> (fieldsplit_0_mg_coarse_)                   1 MPI processes
>>>                     type: preonly
>>> divergence=10000.
>>>                   PC Object:
>>>                     type: lu
>>> pivot [INBLOCKS]
>>>                       matrix ordering: nd
>>>                           Mat Object:                           1 MPI
>>> processes
>>>                             type: seqaij
>>>                             rows=3, cols=3
>>>                       type: seqaij
>>>                       rows=3, cols=3
>>> calls =0
>>>                   KSP Object:
>>> (fieldsplit_0_mg_levels_1_)                   1 MPI processes
>>>                     type: richardson
>>> divergence=10000.
>>>                   PC Object:
>>>                     type: sor
>>>                       type: seqaij
>>>                       rows=15, cols=15
>>> calls =0
>>> (pre-smoother)
>>>                   KSP Object:
>>> (fieldsplit_0_mg_levels_2_)                   1 MPI processes
>>>                     type: richardson
>>> divergence=10000.
>>>                   PC Object:
>>>                     type: sor
>>>                       type: seqaij
>>>                       rows=304, cols=304
>>> calls =0
>>> (pre-smoother)
>>>                   KSP Object:
>>> (fieldsplit_0_mg_levels_3_)                   1 MPI processes
>>>                     type: richardson
>>> divergence=10000.
>>>                   PC Object:
>>>                     type: sor
>>>                       type: seqaij
>>> calls =0
>>> (pre-smoother)
>>>                   KSP Object:
>>> (fieldsplit_0_mg_levels_4_)                   1 MPI processes
>>>                     type: richardson
>>> divergence=10000.
>>>                   PC Object:
>>>                     type: sor
>>>                     Mat Object:
>>>                       type: seqaij
>>> nonzeros=70684164
>>> calls =0
>>> (pre-smoother)
>>>                 Mat Object:
>>>                   type: seqaij
>>> =0
>>>             A01
>>>                 type: seqaij
>>>                 rows=894132, cols=42025
>>>           type: seqaij
>>>     type: seqaij
>>>     rows=936157, cols=936157
>>>     total: nonzeros=84938441, allocated nonzeros=84938441
>> experiments lead.
>> -- Norbert Wiener
>> http://www.caam.rice.edu/~mk51/
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170612/cdb495bb/attachment-0001.html>
