[petsc-users] questions on BAIJ matrix
Hong
hzhang at mcs.anl.gov
Thu Jun 8 14:17:43 CDT 2017
Xiangdong:
MatCreateMPIBAIJWithArrays() is obviously buggy, and not been tested.
> 1) In the remark of the function MatCreateMPIBAIJWithArrays, it says " bs -
> the block size, only a block size of 1 is supported". Why must the block
> size be 1? Is this a typo?
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/
> Mat/MatCreateMPIBAIJWithArrays.html
It seems only bs=1 was implemented. I would not trust it without a test
example.
> 2) In the Line 4040 of the implemention of MatCreateMPIBAIJWithArrays,
> would the matrix type be matmpibaij instead of matmpiSbaij?
This is an error. It should be matmpibaij.
> http://www.mcs.anl.gov/petsc/petsc-current/src/mat/impls/bai
> j/mpi/mpibaij.c.html#MatCreateMPIBAIJWithArrays
> 4031: PetscErrorCode MatCreateMPIBAIJWithArrays(MPI_Comm comm,PetscInt
> bs,PetscInt m,PetscInt n,PetscInt M,PetscInt N,const PetscInt i[],const
> PetscInt j[],const PetscScalar a[],Mat *mat)
> 4032: {
> 4036: if (i[0]) SETERRQ(PETSC_COMM_SELF,PETSC_ERR_ARG_OUTOFRANGE,"i
> (row indices) must start with 0");
> 4037: if (m < 0) SETERRQ(PETSC_COMM_SELF,PETSC_ERR_ARG_OUTOFRANGE,"local
> number of rows (m) cannot be PETSC_DECIDE, or negative");
> 4038: MatCreate(comm,mat);
> 4039: MatSetSizes(*mat,m,n,M,N);
> 4040: MatSetType(*mat,MATMPISBAIJ);
It should be MATMPIBAIJ.
> 3) I want to create a petsc matrix M equivalent to the sum of two block
> csr matrix/array (M1csr, M2csr). What is the best way to achieve it? I am
> thinking of created two petsc baij matrix (M1baij and M2baij) by
> calling MatCreateMPIBAIJWithArrays twice and then call MATAXPY to get the
> sum M=M1baij + M2baij. Is there a better way to do it?
This is an approach. However MatCreateMPIBAIJWithArrays() needs to be
fixed, tested and implemented with requested bs. What bs do you need?
Why not use MatCreate(), MatSetValuses() (set a block values at time) to
create two MPIBAIJ matrices, then call MATAXPY. Since petsc MPIBAIJ matrix
has different internal data structure than csr,
"The i, j, and a arrays ARE copied by MatCreateMPIBAIJWithArrays() into the
internal format used by PETSc;", so this approach would give similar
performance.
Hong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170608/e20f54f7/attachment.html>
