[petsc-users] Strange Segmentation Violation error
TAY wee-beng
zonexo at gmail.com
Wed Jun 7 01:57:37 CDT 2017
I have been PETSc together with my CFD code. There seems to be a bug
with the Intel compiler such that when I call some DM routines such as
DMLocalToLocalBegin, a segmentation violation will occur if full
optimization is used. I had posted this question a while back. So the
current solution is to use -O1 -ip instead of -O3 -ipo -ip for certain
source files which uses DMLocalToLocalBegin etc.
Recently, I made some changes to the code, mainly adding some stuffs.
However, depending on my options. some cases still go thru the same
program path.
Now when I tried to run those same cases, I got segmentation violation,
which didn't happen before:
/ IIB_I_cell_no_uvw_total2 14 10 6 3//
// 2 1/
/[0]PETSC ERROR:
//[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range//
//[0]PETSC ERROR: Try option -start_in_debugger or
-on_error_attach_debugger//
//[0]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind//
//[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac
OS X to find memory corruption errors//
//[0]PETSC ERROR: configure using --with-debugging=yes, recompile, link,
and run //
//[0]PETSC ERROR: to get more information on the crash.//
//[0]PETSC ERROR: --------------------- Error Message
//[0]PETSC ERROR: Signal received//
//[0]PETSC ERROR: See
http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.//
//[0]PETSC ERROR: Petsc Release Version 3.7.4, Oct, 02, 2016 //
//[0]PETSC ERROR: ./a.out /
I can't debug using VS since the codes have been optimized. I tried to
print messages (if (myid == 0) print "1") to pinpoint the error.
Strangely, after adding these print messages, the error disappears.
// 2 1//
// 1//
// 2//
// 3//
// 4//
// 5//
// 1 0.26873613 0.12620288 0.12949340 1.11422363
0.43983516E-06 -0.59311066E-01 0.25546227E+04//
// 2 0.22236892 0.14528589 0.16939270 1.10459102
0.74556128E-02 -0.55168234E-01 0.25532419E+04//
// 3 0.20764796 0.14832689 0.18780489 1.08039569
0.80299767E-02 -0.46972411E-01 0.25523174E+04/
Can anyone give a logical explanation why this is happening? Moreover,
if I removed printing 1 to 3, and only print 4 and 5, segmentation
violation appears again.
I am using Intel Fortran 2016.1.150. I wonder if it helps if I post in
the Intel Fortran forum.
I can provide more info if require.
Thank you very much.
Yours sincerely,
TAY Wee-Beng (Zheng Weiming) 郑伟明
Personal research webpage: http://tayweebeng.wixsite.com/website
Youtube research showcase: https://www.youtube.com/channel/UC72ZHtvQNMpNs2uRTSToiLA
linkedin: www.linkedin.com/in/tay-weebeng
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170607/a4d4a255/attachment.html>
