[petsc-users] How to VecScatter from global to local vector, and then, VecGather back ?
Franck Houssen franck.houssen at inria.fr
Tue Jun 6 11:45:48 CDT 2017
This is a very simple use case: I need to split a global vector in local (possibly overlapping) pieces, then I need to modify each local piece (x2), and finally I need to assemble (+=) back local parts into a global vector.
Read the doc and went through examples... But still can't make this work: can I get some help on this ?
Note: running petsc-3.7.6 on debian with gcc-6.3
Franck
~> head -n 12 vecScatterGather.cpp
// How to VecScatter from global to local vector, and then, VecGather back ?
// global vector: 3x1 2 overlapping local vector: 2x1 global vector: 3x1
// x2
// |1 -> |2
// |1 scatter |1 |2 gather |2
// |1 -> -> |4
// |1 |1 -> |2 |2
// |1 |2
// ~> g++ -o vecScatterGather.exe vecScatterGather.cpp -lpetsc -lm; mpirun -n 2 vecScatterGather.exe
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170606/fe85fb84/attachment.html>
Type: text/x-c++src
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170606/fe85fb84/attachment.cpp>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170606/fe85fb84/attachment.bin>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170606/fe85fb84/attachment.obj>
