[petsc-users] DMPlex distribution with custom adjacency
Matthew Knepley
knepley at gmail.com
Mon Jun 5 17:01:31 CDT 2017
On Mon, Jun 5, 2017 at 12:18 PM, Lawrence Mitchell <
lawrence.mitchell at imperial.ac.uk> wrote:
> > On 2 Jun 2017, at 05:09, Matthew Knepley <knepley at gmail.com> wrote:
> > Coming back to this, I think I understand the problem a little better.
> > Consider this mesh:
> > |\ 3 |
> > |2 \ |
> > |\ 1 |
> > |0 \ |
> > Let's say I run on 3 processes and the initial (non-overlapped) cell
> > partition is:
> > rank 0: cell 0
> > rank 1: cell 1 & 2
> > rank 2: cell 3
> > Now I'd like to grow the overlap such that any cell I can see through
> > a facet (and its closure) lives in the overlap.
> > So great, I just need a new adjacency relation that gathers
> > closure(support(point))
> > But, that isn't right, because now on rank 0, I will get a mesh that
> > looks like:
> > I do not understand why you think its not right. Toby and I are trying
> to push a formalism for
> > this understanding, in https://arxiv.org/abs/1508.02470. So you say
> that if sigma is a dual
> > basis function associated with point p, then the support of its matching
> psi, sigma(psi) = 1
> > in the biorthogonal bases, is exactly star(p).
> > So, if you have no sigma sitting on your vertex, who cares if you put
> that extra edge and node
> > in. It will not affect the communication pattern for dofs. If you do,
> then shouldn't you be including
> > that edge?
> Hmm, I think we are talking at cross-purposes. Let me try and explain
> again where I am coming from:
> To do a FEM integral on some cell c I need:
> i) to evaluate coefficients at quadrature points (on the cell)
> ii) to evaluate basis functions at quadrature points (on the cell)
> for (i), I need all the dofs in closure(c).
> for (ii), I just need the definition of the finite element.
> To do a FEM integral on a facet f I need:
> i) to evaluate coefficients at quadrature points (on the facet)
> ii) to evaluate basis functions at quadrature points (on the facet)
> for (i), I need all the dofs in closure(support(f)).
So this is a jump term, since I need both sides. Is it nonlinear? If its
linear, things are easy
and just compute from both sides and add, but of course that does not work
for nonlinear things.
> So now, my model for how I want to global assembly of a facet integral is:
> loop over all facets:
> gather from global coefficient to local data
> evaluate coefficient at quad points
> perform integral
> local to global
> In parallel, I just make a partition of the facets (so that each facet is
> integrated exactly once).
> OK, so what data do I need in parallel?
> Exactly the dofs that correspond to closure(support(facet)) for all owned
> facets in my partition.
> So I was hoping to be able to grow a distributed cell partition by exactly
> that means: add in those remote cells which are in the support of owned
> facets (I'm happy if this is symmetrically grown, although I think I can do
> it with one-sided growth).
> So that's my rationale for wanting this "strange" adjacency. I can get
> enough adjacency by using the current FEM adjacency and filtering which
> entities I iterate over, but it seems a bit wasteful.
I see that you have edges you do not necessarily want, but do they mess up
your loop? It seems like you will not encounter them looping over facets.
This is exactly what happens to me in FV, where I just ignore them.
If you do really want to prune them, then I guess overriding the
DMPlexGetAdjacency() as you propose is probably the best way. I would
be willing to put it in. Please send me a reminder email since this week is
pretty heinous for me.
Matt
> For the currently implemented adjacencies, however, the code definitely
> assumes in various places that the closure of the cells on a partition
> covers all the points. And doing, say, DMPlexSetAdjacencyUseCone/Closure(PETSC_FALSE)
> results in meshes where that is not true.
> See the below:
> Lawrence
> $ mpiexec -n 3 ./bork
> [0] face 7 has support: 0
> [0] face 8 has support: 0
> [0] face 9 has support: 0 1
> [0] face 10 has support: 1
> [0] face 11 has support: 1
> [0] face 12 has support:
> [1] face 10 has support: 0 2
> [1] face 11 has support: 0 1
> [1] face 12 has support: 0
> [1] face 13 has support: 1
> [1] face 14 has support: 2
> [1] face 15 has support: 2
> [1] face 16 has support: 1 3
> [1] face 17 has support: 3
> [1] face 18 has support: 3
> [2] face 7 has support: 0 1
> [2] face 8 has support: 0
> [2] face 9 has support: 0
> [2] face 10 has support: 1
> [2] face 11 has support:
> [2] face 12 has support: 1[2]PETSC ERROR: --------------------- Error
> Message --------------------------------------------------------------
> [2]PETSC ERROR: Petsc has generated inconsistent data
> [2]PETSC ERROR: Number of depth 2 faces 6 does not match permuted nubmer 5
> [2]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [2]PETSC ERROR: Petsc Development GIT revision: v3.7.6-3857-gda66ab19e3
> GIT Date: 2017-05-10 09:02:09 -0500
> [2]PETSC ERROR: ./bork on a arch-darwin-c-opt named yam-laptop.local by
> lmitche1 Mon Jun 5 18:15:31 2017
> [2]PETSC ERROR: Configure options --download-chaco=1 --download-ctetgen=1
> --download-eigen --download-exodusii=1 --download-hdf5=1 --download-hypre=1
> --download-metis=1 --download-ml=1 --download-mumps=1 --download-netcdf=1
> --download-parmetis=1 --download-ptscotch=1 --download-scalapack=1
> --download-triangle=1 --with-c2html=0 --with-debugging=0
> --with-shared-libraries=1 PETSC_ARCH=arch-darwin-c-opt
> [2]PETSC ERROR: #1 DMPlexCreateOrderingClosure_Static() line 41 in
> /Users/lmitche1/Documents/work/src/deps/petsc/src/dm/
> impls/plex/plexreorder.c
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Petsc has generated inconsistent data
> [0]PETSC ERROR: Number of depth 2 faces 6 does not match permuted nubmer 5
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> [0]PETSC ERROR: Petsc Development GIT revision: v3.7.6-3857-gda66ab19e3
> [0]PETSC ERROR: ./bork on a arch-darwin-c-opt named yam-laptop.local by
> [0]PETSC ERROR: Configure options --download-chaco=1 --download-ctetgen=1
> [0]PETSC ERROR: #1 DMPlexCreateOrderingClosure_Static() line 41 in
> [0]PETSC ERROR: #2 DMPlexGetOrdering() line 133 in
> [0]PETSC ERROR: #3 main() line 87 in /Users/lmitche1/Documents/
> work/src/petsc-doodles/bork.c
> [0]PETSC ERROR: No PETSc Option Table entries
> [0]PETSC ERROR: ----------------End of Error Message -------send entire
> error message to petsc-maint at mcs.anl.gov----------
> [2]PETSC ERROR: #2 DMPlexGetOrdering() line 133 in
> [2]PETSC ERROR: #3 main() line 87 in /Users/lmitche1/Documents/
> [2]PETSC ERROR: No PETSc Option Table entries
> [2]PETSC ERROR: ----------------End of Error Message -------send entire
> application called MPI_Abort(MPI_COMM_WORLD, 77) - process 0
> #include <petsc.h>
> #include <petscsf.h>
> int main(int argc, char **argv)
> PetscErrorCode ierr;
> DM dm = NULL, dmParallel = NULL;
> PetscSF sf = NULL;
> PetscPartitioner partitioner = NULL;
> IS perm = NULL;
> const PetscReal coords[12] = {0, 0,
> 0, 0.5,
> 0, 1,
> 1, 0,
> 1, 0.5,
> 1, 1};
> const PetscInt cells[12] = {0, 1, 3,
> 1, 4, 3,
> 1, 2, 4,
> 2, 5, 4};
> const PetscInt sizes[3] = {1, 2, 1};
> const PetscInt points[4] = {0, 1, 2, 3};
> PetscInt fStart, fEnd;
> PetscMPIInt rank, size;
> MPI_Comm comm;
> PetscInitialize(&argc, &argv, NULL, NULL);
> comm = PETSC_COMM_WORLD;
> ierr = MPI_Comm_rank(comm, &rank); CHKERRQ(ierr);
> ierr = MPI_Comm_size(comm, &size); CHKERRQ(ierr);
> if (size != 3) SETERRQ(comm, PETSC_ERR_ARG_WRONG, "Requires 3
> processes");
> if (!rank) {
> ierr = DMPlexCreateFromCellList(comm, 2, 4, 6, 3, PETSC_TRUE,
> cells, 2, coords, &dm);
> CHKERRQ(ierr);
> } else {
> ierr = DMPlexCreateFromCellList(comm, 2, 0, 0, 3, PETSC_TRUE,
> NULL, 2, NULL, &dm); CHKERRQ(ierr);
> ierr = PetscPartitionerCreate(comm, &partitioner); CHKERRQ(ierr);
> ierr = PetscPartitionerSetType(partitioner, PETSCPARTITIONERSHELL);
> CHKERRQ(ierr);
> if (!rank) {
> ierr = PetscPartitionerShellSetPartition(partitioner, size,
> sizes, points); CHKERRQ(ierr);
> } else {
> ierr = PetscPartitionerShellSetPartition(partitioner, 3, NULL,
> NULL); CHKERRQ(ierr);
> ierr = DMPlexSetPartitioner(dm, partitioner); CHKERRQ(ierr);
> ierr = DMPlexDistribute(dm, 0, &sf, &dmParallel); CHKERRQ(ierr);
> ierr = DMDestroy(&dm); CHKERRQ(ierr);
> ierr = PetscSFDestroy(&sf); CHKERRQ(ierr);
> ierr = PetscPartitionerDestroy(&partitioner); CHKERRQ(ierr);
> ierr = DMViewFromOptions(dmParallel, NULL, "-parallel_dm_view");
> CHKERRQ(ierr);
> ierr = DMPlexSetAdjacencyUseCone(dmParallel, PETSC_FALSE);
> CHKERRQ(ierr);
> ierr = DMPlexSetAdjacencyUseClosure(dmParallel, PETSC_FALSE);
> CHKERRQ(ierr);
> ierr = DMPlexDistributeOverlap(dmParallel, 1, &sf, &dm);
> CHKERRQ(ierr);
> ierr = DMDestroy(&dmParallel); CHKERRQ(ierr);
> ierr = DMViewFromOptions(dm, NULL, "-overlap_dm_view"); CHKERRQ(ierr);
> ierr = DMPlexGetHeightStratum(dm, 1, &fStart, &fEnd); CHKERRQ(ierr);
> for (PetscInt f = fStart; f < fEnd; f++) {
> const PetscInt *support = NULL;
> PetscInt supportSize;
> ierr = DMPlexGetSupportSize(dm, f, &supportSize); CHKERRQ(ierr);
> ierr = DMPlexGetSupport(dm, f, &support); CHKERRQ(ierr);
> ierr = PetscSynchronizedPrintf(comm, "[%d] face %d has support:",
> rank, f); CHKERRQ(ierr);
> for (PetscInt p = 0; p < supportSize; p++) {
> ierr = PetscSynchronizedPrintf(comm, " %d", support[p]);
> CHKERRQ(ierr);
> ierr = PetscSynchronizedPrintf(comm, "\n"); CHKERRQ(ierr);
> ierr = PetscSynchronizedFlush(comm, PETSC_STDOUT); CHKERRQ(ierr);
> ierr = DMPlexGetOrdering(dm, MATORDERINGRCM, NULL, &perm);
> CHKERRQ(ierr);
> if (perm) {
> ierr = ISViewFromOptions(perm, NULL, "-ordering_is_view");
> CHKERRQ(ierr);
> ierr = ISDestroy(&perm); CHKERRQ(ierr);
> ierr = PetscFinalize();
> return 0;
experiments lead.
-- Norbert Wiener
http://www.caam.rice.edu/~mk51/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170605/6f779d59/attachment.html>
