[petsc-users] Parallel vector with shared memory in Fortran
Matthew Knepley
knepley at gmail.com
Mon Jun 5 11:36:44 CDT 2017
On Mon, Jun 5, 2017 at 11:20 AM, Francesco Migliorini <
francescomigliorini93 at gmail.com> wrote:
> Dear Stefano,
> Thank you for your answer. I tried to use VecScatterCreateToAll as you
> suggested but it does not work since the first processor can only view its
> part of the vector.
Then there is a bug in your code. The
example src/vec/vec/examples/tests/ex33.c tests this. Take a look at it.
Matt
> Here's how I managed the code:
> Vec fePS
> VecScatter Scatter
> call VecScatterCreateToAll(feP,Scatter,fePS,perr)
> call VecScatterBegin(Scatter,feP,fePS,INSERT_VALUES,SCATTER_FORWARD,perr)
> call VecScatterEnd(Scatter,feP,fePS,INSERT_VALUES,SCATTER_FORWARD,perr)
> call VecScatterDestroy(Scatter,perr)
> call VecDestroy(fePS,perr)
> As I said, after this piece of code, if I print all the entries of feP
> from one processor, the values are correct if they belong to the part of
> the processor randon values.
> Bests,
> Francesco
> 2017-06-05 16:44 GMT+02:00 Stefano Zampini <stefano.zampini at gmail.com>:
>> Sorry, bad copy and paste
>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/
>> Vec/VecScatterCreateToAll.html
>> Il 05 Giu 2017 4:43 PM, "Stefano Zampini" <stefano.zampini at gmail.com> ha
>> scritto:
>>> petsc-current/docs/manualpages/Vec/VecScatterCreateToAll.html
>>> Il 05 Giu 2017 4:12 PM, "Francesco Migliorini" <
>>> francescomigliorini93 at gmail.com> ha scritto:
>>>> Hello there!
>>>> I am working with an MPI code in which I should create a petsc vector
>>>> such that all the processes can access to all its entries. So, I tried with
>>>> VecCreateShared but it does not work with my machine. Then I tried
>>>> VecCreateMPI but it seems to me that it does not change anything from the
>>>> usual VecCreate. Finally I found the scatter commands but the examples are
>>>> a bit tricky. So, are there any other way? If no, could someone please show
>>>> me how to use scatter in this simple code?
>>>> Vec feP !The vector to be shared with all the processes
>>>> mpi_np = 2 !The number of processes
>>>> ind(1) = 10 !The global dimension of the vector
>>>> call VecCreate(PETSC_COMM_WORLD,feP,perr)
>>>> call VecSetSizes(feP,PETSC_DECIDE,ind,perr)
>>>> call VecSetFromOptions(feP,perr)
>>>> (...) !Here feP is filled in
>>>> call VecAssemblyBegin(feP,perr)
>>>> call VecAssemblyEnd(feP,perr)
>>>> Many thanks,
>>>> Francesco
experiments lead.
-- Norbert Wiener
http://www.caam.rice.edu/~mk51/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170605/11b5f07b/attachment.html>
