[petsc-users] interpreting results of ISLocalToGlobalMappingView
Matthew Knepley
knepley at gmail.com
Sun Jun 4 19:15:13 CDT 2017
On Sun, Jun 4, 2017 at 7:08 PM, Wang <quanwang.us at gmail.com> wrote:
> Hello. I have some confusions about the results given
> by ISLocalToGlobalMappingView.
> After reading a simple mesh and associate each vertex with a scalar dof,
> the test code uses DMPlexDistribute to get a distributed dm. Then I use the
> following calls
> call DMGetLocalToGlobalMapping(dm,ltog,ierr)
> call ISLocalToGlobalMappingView(ltog, PETSC_VIEWER_STDOUT_WORLD, ierr);
> and get following results for l2g. (MatGetOwnershipRange gives [0 3] for
> rank 0 and [3 9] for rank 1)
> ISLocalToGlobalMapping Object: 2 MPI processes
> type: basic
> [0] 0 0
> [0] 1 1
> [0] 2 5
> [0] 3 2
> [0] 4 6
> [0] 5 8
> [1] 0 3
> [1] 1 4
> [1] 2 5
> [1] 3 6
> [1] 4 7
> [1] 5 8
> The question is why, on rank 0, the global indices (I assume the third
> column) are not grouped into local chunks and ghost chunks. I understand
> how to do local to global mapping without any concern of the actual
> ordering, but I have some impression that in PETSC the ghost information is
> always coming later in the local vector.
Nope. That is only guaranteed when using VecGhost.
> In this case, on rank 0, global index 5 should appear later than 0,1,2,
> because it is ghost vertex for rank 0.
> I'm not trying to use this for FEM, but instead using the mesh management
> in dmplex for other tasks. So I need to know more details.
We base the dof ordering on the mesh ordering. If you ordered the shared
parts of the mesh last, this would produce the ordering you expect.
Matt
> Thank you.
> QW
experiments lead.
-- Norbert Wiener
http://www.caam.rice.edu/~mk51/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170604/0e4d4972/attachment.html>
