[petsc-users] Using FAS with SNES
Karin&NiKo niko.karin at gmail.com
Thu Jun 1 09:30:53 CDT 2017
Dear PETSc team,
I have interfaced our fortran legacy code with PETSC SNES. I mainly
followed the examples you provide. What I conceptually used is :
    call SNESCreate(PETSC_COMM_WORLD,snes,ierr)
    call SNESSetFromOptions(snes,ierr)
    call SNESSETFunction(snes, pf, nonlinFormFunction, PETSC_NULL_OBJECT,
ierr)
    call SNESSetJacobian(snes, mat, mat, nonlinFormJacobian,
PETSC_NULL_OBJECT, ierr)
    call SNESSetKSP(snes, myksp, ierr)
The code runs fine with -snes_type newtonls or newtontr. But when using
-snes_type fas, it complains with the message :
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Corrupt argument:
http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[0]PETSC ERROR: Fortran callback not set on this object
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.7.2, Jun, 05, 2016
[0]PETSC
ERROR:
on a arch-linux2-c-debug named dsp0780450 by niko Thu Jun  1 16:18:43 2017
[0]PETSC ERROR: Configure options
--prefix=/home/niko/dev/codeaster-prerequisites/petsc-3.7.2/Install
--with-mpi=yes --with-x=yes
--download-ml=/home/niko/dev/codeaster-prerequisites/petsc-3.7.2/ml-6.2-p3.tar.gz
--with-mumps-lib="-L/home/niko/dev/codeaster-prerequisites/v13/prerequisites/Mumps-502_consortium_aster1/MPI/lib
-lzmumps -ldmumps -lmumps_common -lpord
-L/home/niko/dev/codeaster-prerequisites/v13/prerequisites/Scotch_aster-604_aster6/MPI/lib
-lesmumps -lptscotch -lptscotcherr -lptscotcherrexit -lscotch -lscotcherr
-lscotcherrexit
-L/home/niko/dev/codeaster-prerequisites/v13/prerequisites/Parmetis_aster-403_aster/lib
-lparmetis
-L/home/niko/dev/codeaster-prerequisites/v13/prerequisites/Metis_aster-510_aster1/lib
-lmetis -L/usr/lib -lscalapack-openmpi -L/usr/lib -lblacs-openmpi
-lblacsCinit-openmpi -lblacsF77init-openmpi -L/usr/lib/x86_64-linux-gnu
-lgomp "
--with-mumps-include=/home/niko/dev/codeaster-prerequisites/v13/prerequisites/Mumps-502_consortium_aster1/MPI/include
--with-scalapack-lib="-L/usr/lib -lscalapack-openmpi"
--with-blacs-lib="-L/usr/lib -lblacs-openmpi -lblacsCinit-openmpi
-lblacsF77init-openmpi" --with-blas-lib="-L/usr/lib -lopenblas -lcblas"
--with-lapack-lib="-L/usr/lib -llapack"
[0]PETSC ERROR: #1 PetscObjectGetFortranCallback() line 263 in
/home/niko/dev/codeaster-prerequisites/petsc-3.7.2/src/sys/objects/inherit.c
[0]PETSC ERROR: #2 oursnesjacobian() line 105 in
/home/niko/dev/codeaster-prerequisites/petsc-3.7.2/src/snes/interface/ftn-custom/zsnesf.c
[0]PETSC ERROR: #3 SNESComputeJacobian() line 2312 in
/home/niko/dev/codeaster-prerequisites/petsc-3.7.2/src/snes/interface/snes.c
[0]PETSC ERROR: #4 SNESSolve_NEWTONLS() line 228 in
/home/niko/dev/codeaster-prerequisites/petsc-3.7.2/src/snes/impls/ls/ls.c
[0]PETSC ERROR: #5 SNESSolve() line 4008 in
[0]PETSC ERROR: #6 SNESFASDownSmooth_Private() line 512 in
/home/niko/dev/codeaster-prerequisites/petsc-3.7.2/src/snes/impls/fas/fas.c
[0]PETSC ERROR: #7 SNESFASCycle_Multiplicative() line 816 in
[0]PETSC ERROR: #8 SNESSolve_FAS() line 987 in
[0]PETSC ERROR: #9 SNESSolve() line 4008 in
When exploring a little bit with a debugger, it seems that the object
snes->vec_rhs which is used is fas.c is a null pointer.
What is this object vec_rhs and how to set it?
Thank you in advance,
Nicolas
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170601/2bfcafa5/attachment.html>
