[petsc-users] PetscFECreateDefault in Fortran
Matthew Knepley
knepley at gmail.com
Thu Jun 1 07:52:02 CDT 2017
On Wed, May 31, 2017 at 10:00 PM, Justin Pogacnik <j.pogacnik at auckland.ac.nz
> wrote:
> Thanks Matt! That works perfectly now. I have another question regarding
> accessing the quadrature information.
> When I use PetscFEGetQuadrature(), then PetscQuadratureView(), I see what
> I expect regarding point locations, weights.
> However, when I try to use PetscQuadratureGetData() the pointers seem to
> point to random memory locations.
> The exact line from my test problem is: call PetscQuadratureGetData(quad,q_
> nc,q_dim,q_num,pq_points,pq_weights,ierr);
> where the pq_* are the pointers giving strange output. The q_nc, q_dim,
> and q_num are all giving what I would expect to see.
You are clearly the first Fortran user interested in this stuff ;) Handling
of arrays in Fortran demands some more work
from us. I need to write a wrapper for that function. I will do it as soon
as I can.
Matt
> Happy to send along the file if that helps.
> Thanks again,
> Justin
> *From:* Matthew Knepley <knepley at gmail.com>
> *Sent:* Thursday, June 1, 2017 1:34 AM
> *To:* Justin Pogacnik
> *Cc:* petsc-users at mcs.anl.gov
> *Subject:* Re: [petsc-users] PetscFECreateDefault in Fortran
> On Wed, May 31, 2017 at 7:53 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Tue, May 30, 2017 at 10:19 PM, Justin Pogacnik <
>> j.pogacnik at auckland.ac.nz> wrote:
>>> Hello,
>>> I'm developing a finite element code in fortran 90. I recently updated
>>> my PETSc and am now getting the following error during compile/linking on
>>> an existing application:
>>> Undefined symbols for architecture x86_64:
>>> "_petscfecreatedefault_", referenced from:
>>> _MAIN__ in fe_test.o
>>> ld: symbol(s) not found for architecture x86_64
>>> collect2: error: ld returned 1 exit status
>>> make: *** [dist/fe_test] Error 1
>>> I'm running Mac OS X Yosemite (10.10.5). I've created a "minimum working
>>> example" (attached) that re-creates the problem. It's basically
>>> just dm/impls/plex/examples/tutorials/ex3f90, but tries to create a
>>> PetscFE object. Everything goes fine and the DM looks like what is expected
>>> if PetscFECreateDefault is commented out. Any idea what am I missing?
>> Yes, I had not made a Fortran binding for this function. I will do it now.
> I have merged it to the 'next' branch, and it will be in 'master' soon.
> Thanks,
> Matt
>> Thanks,
>> Matt
>>> Many thanks!
>>> Justin
>> experiments lead.
>> -- Norbert Wiener
>> http://www.caam.rice.edu/~mk51/
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170601/d25cc5ac/attachment.html>
