[petsc-users] error in DMDACreate3d
Sepideh Kavousi
skavou1 at lsu.edu
Wed Jul 19 10:56:53 CDT 2017
The problem was solved when I gave the directory of mpiecex in petsc installed packages before writing mpiexec.
Sepideh
Sent: Wednesday, July 19, 2017 10:32:16 AM
To: Sepideh Kavousi
Cc: petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] error in DMDACreate3d
Sepideh,
All of the valgrind messages are from OpenMPI (it is horribly not valgrind clean; you should use --download-mpich if you want to use MPI with valgrind).
Please send the output from running on both systems without valgrind. I want to see the exact error message.
Are you running with -pc_type mg ?
Barry
> On Jul 19, 2017, at 10:10 AM, Sepideh Kavousi <skavou1 at lsu.edu> wrote:
> Hi,
> I am writing a petsc code where I create a 3d da object using DMDACreate3d, I want to have 2 processors in x , 1 processor in y and 2 processors in z direction. for this I write:
> ierr= DMDACreate3d(PETSC_COMM_WORLD,DM_BOUNDARY_NONE,DM_BOUNDARY_NONE,DM_BOUNDARY_NONE,DMDA_STENCIL_BOX,
> 60,60,60,2,1,2,2,1,llx,lly,llz,&da2) ;CHKERRQ(ierr);
> and llx and lly and llz are as : llx[2]={30,30},lly[1]={60},llz[2]={30,30}
> it works fine when I run with my personal workstation. But when I want to run it on hpc it gives an error. and by running with valgrind it gives the following error. I do not understand why it says: Too many processors in X direction: 2 1. Can some one please help me about it?
> Thanks,
> Sepideh
> ==102997== Memcheck, a memory error detector
> ==102997== Copyright (C) 2002-2012, and GNU GPL'd, by Julian Seward et al.
> ==102997== Using Valgrind-3.8.1 and LibVEX; rerun with -h for copyright info
> ==102997== Command: mpiexec -n 4 ./try3-jacob-3.out -ts_monitor -snes_monitor -snes_mf -log_view -ts_max_snes_failures -1 -ts_type bdf -snes_type newtontr -pc_type asm -ksp_gmres_restart 300 -sub_ksp_type preonly -sub_pc_type lu -pc_asm_overlap 4 -ts_adapt_monitor -snes_linesearch_type bt -ksp_type gmres -snes_atol 1.0e-20 -snes_monitor -ts_view -ts_adapt_monitor
> ==102997==
> ==102997== Invalid read of size 8
> ==102997== at 0x4CAC833: opal_basename (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x40446C: orterun (orterun.c:494)
> ==102997== by 0x4041A3: main (main.c:13)
> ==102997== Address 0x61528f8 is 0 bytes after a block of size 8 alloc'd
> ==102997== at 0x4A06A2E: malloc (vg_replace_malloc.c:270)
> ==102997== by 0x40EF6D: __intel_sse2_strdup (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== by 0x742F2E0034006E2C: ???
> ==102997== by 0x6F63616A2D337971: ???
> ==102997== by 0x74756F2E332D61: ???
> ==102997== by 0x696E6F6D5F73742C: ???
> ==102997== by 0x656E732D00726F73: ???
> ==102997== by 0x6F74696E6F6D5F72: ???
> ==102997== by 0x5F73656E732D0071: ???
> ==102997== by 0x5F676F6C2D00666C: ???
> ==102997== by 0x73742D0077656975: ???
> ==102997== by 0x656E735F78616D5E: ???
> ==102997==
> ==102997== at 0x4CAC886: opal_basename (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== Conditional jump or move depends on uninitialised value(s)
> ==102997== at 0x40E977: __intel_sse2_strcat (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== by 0x4CA8683: mca_base_param_environ_variable (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CACAED: opal_cmd_line_create (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4044AA: orterun (orterun.c:498)
> ==102997==
> ==102997== Use of uninitialised value of size 8
> ==102997== at 0x40EBC5: __intel_sse2_strcat (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== by 0x4CA868E: mca_base_param_environ_variable (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x40E9EA: __intel_sse2_strcat (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== at 0x40E995: __intel_sse2_strcat (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== by 0x4CA86A2: mca_base_param_environ_variable (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997== by 0x4CA86AD: mca_base_param_environ_variable (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997== at 0x40EA41: __intel_sse2_strcat (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== at 0x40EBB9: __intel_sse2_strcat (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== by 0x4CACCB8: opal_cmd_line_make_opt_mca (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CA1045: mca_base_cmd_line_setup (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4044B9: orterun (orterun.c:499)
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997== at 0x40E75B: __intel_sse2_strncmp (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== by 0x4CAD821: opal_cmd_line_parse (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4044E1: orterun (orterun.c:500)
> ==102997== Address 0x615ce50 is 0 bytes inside a block of size 3 alloc'd
> ==102997== by 0x72756C6961665F72: ???
> ==102997==
> ==102997== at 0x4CAD9D5: opal_cmd_line_parse (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x40EEF8: __intel_sse2_strdup (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== by 0x4CABAF8: opal_argv_append_nosize (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CABB75: opal_argv_append (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CAD38B: opal_cmd_line_parse (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x615cf00 is 0 bytes inside a block of size 2 alloc'd
> ==102997== by 0x332D626F63616A2C: ???
> ==102997== by 0x73742D0074756F2D: ???
> ==102997== by 0x726F74696E6F6D5E: ???
> ==102997== by 0x6D5F73656E732CFF: ???
> ==102997== by 0x2D00726F74696E6E: ???
> ==102997== by 0x666D5F73656E72: ???
> ==102997== by 0x6569765F676F6C2C: ???
> ==102997== by 0x616D5F73742D0076: ???
> ==102997== by 0x665F73656E735F77: ???
> ==102997== by 0x736572756C6960: ???
> ==102997==
> ==102997== at 0x40EF46: __intel_sse2_strdup (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== Address 0x615cfd0 is 16 bytes inside a block of size 19 alloc'd
> ==102997== by 0x6F2E332D626F6360: ???
> ==102997== by 0x6D5F73742D007474: ???
> ==102997== by 0x6E6F6D5F73656E72: ???
> ==102997== by 0x6E732D00726F7468: ???
> ==102997== by 0x6C2D00666D5F7364: ???
> ==102997== by 0x776569765F676E: ???
> ==102997== by 0x5F78616D5F73742C: ???
> ==102997== by 0x6961665F73656E72: ???
> ==102997== by 0x312D00736572756B: ???
> ==102997==
> ==102997== by 0x4CAD600: opal_cmd_line_parse (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x615d098 is 8 bytes inside a block of size 12 alloc'd
> ==102997== by 0x742D00312D007364: ???
> ==102997== by 0x6200657079745F72: ???
> ==102997== by 0x73656E732D006663: ???
> ==102997==
> ==102997== at 0x40E548: __intel_sse2_strlen (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== by 0x4CB698C: opal_output_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CB9023: opal_output_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C84BBD: opal_init_util (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x40458C: orterun (orterun.c:535)
> ==102997== Address 0x6161a80 is 16 bytes inside a block of size 18 alloc'd
> ==102997== by 0x3C8BA6F41F: vasprintf (in /lib64/libc-2.12.so)
> ==102997== by 0x3C8BA4F307: asprintf (in /lib64/libc-2.12.so)
> ==102997== by 0x4CB8E9E: opal_output_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CAACC1: mca_base_param_reg_string_name (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CAA54A: mca_base_param_recache_files (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CAB796: mca_base_param_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CAB0F2: mca_base_param_reg_string_name (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CB561D: opal_net_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C84C6D: opal_init_util (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6164d48 is 8 bytes inside a block of size 12 alloc'd
> ==102997==
> ==102997== at 0x40EBFB: __intel_sse2_strncat (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== by 0x4CAAD3B: mca_base_param_reg_string_name (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x40ECF9: __intel_sse2_strncat (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== by 0x4CAAD56: mca_base_param_reg_string_name (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997== by 0x4CAAD63: mca_base_param_reg_string_name (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997== by 0x4CAACDD: mca_base_param_reg_string_name (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CAA575: mca_base_param_recache_files (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x61650b0 is 16 bytes inside a block of size 23 alloc'd
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997== at 0x40E556: __intel_sse2_strlen (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== by 0x4CAAD93: mca_base_param_reg_string_name (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x3C8BA6F6A3: vsnprintf (in /lib64/libc-2.12.so)
> ==102997== by 0x3C8BA4F1E2: snprintf (in /lib64/libc-2.12.so)
> ==102997== by 0x4CAAE40: mca_base_param_reg_string_name (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x3C8BA756C4: _IO_str_init_static_internal (in /lib64/libc-2.12.so)
> ==102997== by 0x3C8BA6F703: vsnprintf (in /lib64/libc-2.12.so)
> ==102997==
> ==102997== at 0x3C8BA7455B: _IO_default_xsputn (in /lib64/libc-2.12.so)
> ==102997== by 0x3C8BA4814F: vfprintf (in /lib64/libc-2.12.so)
> ==102997== by 0x3C8BA6F711: vsnprintf (in /lib64/libc-2.12.so)
> ==102997==
> ==102997== at 0x3C8BA7456F: _IO_default_xsputn (in /lib64/libc-2.12.so)
> ==102997==
> ==102997== at 0x3C8BA74578: _IO_default_xsputn (in /lib64/libc-2.12.so)
> ==102997==
> ==102997== at 0x3C8BA74582: _IO_default_xsputn (in /lib64/libc-2.12.so)
> ==102997==
> ==102997== at 0x3C8BA74670: _IO_default_xsputn (in /lib64/libc-2.12.so)
> ==102997==
> ==102997== at 0x3C8BA745E5: _IO_default_xsputn (in /lib64/libc-2.12.so)
> ==102997==
> ==102997== at 0x3C8BA48160: vfprintf (in /lib64/libc-2.12.so)
> ==102997==
> ==102997== at 0x4A0A02A: mempcpy (mc_replace_strmem.c:1268)
> ==102997== by 0x3C8BA7461D: _IO_default_xsputn (in /lib64/libc-2.12.so)
> ==102997==
> ==102997== at 0x4A0A033: mempcpy (mc_replace_strmem.c:128)
> ==102997==
> ==102997== at 0x4A0A048: mempcpy (mc_replace_strmem.c:1268)
> ==102997==
> ==102997== at 0x4A0A095: mempcpy (mc_replace_strmem.c:1268)
> ==102997==
> ==102997== at 0x4A0A0A8: mempcpy (mc_replace_strmem.c:1268)
> ==102997==
> ==102997== at 0x4A0A0AC: mempcpy (mc_replace_strmem.c:1268)
> ==102997==
> ==102997== at 0x4A0A0BB: mempcpy (mc_replace_strmem.c:1268)
> ==102997==
> ==102997==
> ==102997== at 0x3C8BA6F71E: vsnprintf (in /lib64/libc-2.12.so)
> ==102997==
> ==102997== by 0x4CAA5D4: mca_base_param_recache_files (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x61656f0 is 16 bytes inside a block of size 21 alloc'd
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997== by 0x4CAA601: mca_base_param_recache_files (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6165ce8 is 24 bytes inside a block of size 27 alloc'd
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997== at 0x40EF55: __intel_sse2_strdup (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== by 0x6F2E2F31756F7660: ???
> ==102997== by 0x6D2F69706D6E656F: ???
> ==102997== by 0x6D617261702D6162: ???
> ==102997== by 0x666E6F632E72: ???
> ==102997==
> ==102997== at 0x4A08B6A: memcpy (mc_replace_strmem.c:119)
> ==102997== by 0x40EFCD: __intel_sse2_strdup (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== at 0x4A08B8C: memcpy (mc_replace_strmem.c:882)
> ==102997==
> ==102997== at 0x4A08C18: memcpy (mc_replace_strmem.c:882)
> ==102997==
> ==102997== at 0x4A08C3E: memcpy (mc_replace_strmem.c:882)
> ==102997==
> ==102997== at 0x4A08C5B: memcpy (mc_replace_strmem.c:882)
> ==102997==
> ==102997== at 0x4A08C6C: memcpy (mc_replace_strmem.c:882)
> ==102997==
> ==102997== at 0x4A08C80: memcpy (mc_replace_strmem.c:882)
> ==102997==
> ==102997== at 0x4A08C8C: memcpy (mc_replace_strmem.c:882)
> ==102997==
> ==102997== at 0x4A08C98: memcpy (mc_replace_strmem.c:882)
> ==102997==
> ==102997== at 0x4A08CB2: memcpy (mc_replace_strmem.c:882)
> ==102997==
> ==102997== at 0x4A08CB8: memcpy (mc_replace_strmem.c:882)
> ==102997==
> ==102997== at 0x4A08CBF: memcpy (mc_replace_strmem.c:882)
> ==102997==
> ==102997== at 0x4A08CCA: memcpy (mc_replace_strmem.c:882)
> ==102997==
> ==102997== by 0x4CB510C: opal_util_keyval_parse (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CAA8EF: mca_base_param_recache_files (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CB511A: opal_util_keyval_parse (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4A06BAE: realloc (vg_replace_malloc.c:662)
> ==102997== by 0x4CB5137: opal_util_keyval_parse (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CB5164: opal_util_keyval_parse (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CB517C: opal_util_keyval_parse (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x40E3B5: __intel_sse2_strncpy (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== by 0x4CB5187: opal_util_keyval_parse (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x40E410: __intel_sse2_strncpy (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997==
> ==102997== More than 100 errors detected. Subsequent errors
> ==102997== will still be recorded, but in less detail than before.
> ==102997== at 0x40E41D: __intel_sse2_strncpy (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== at 0x40E4EC: __intel_sse2_strncpy (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== at 0x40E502: __intel_sse2_strncpy (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== at 0x4CB518B: opal_util_keyval_parse (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x40EF3C: __intel_sse2_strdup (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== by 0x4CAB8E9: save_value (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CB52E6: opal_util_keyval_parse (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4A08D03: memcpy (mc_replace_strmem.c:882)
> ==102997==
> ==102997== at 0x4A08D09: memcpy (mc_replace_strmem.c:882)
> ==102997==
> ==102997== at 0x4A08D21: memcpy (mc_replace_strmem.c:882)
> ==102997==
> ==102997== at 0x4A08D28: memcpy (mc_replace_strmem.c:882)
> ==102997==
> ==102997== at 0x4A08D2A: memcpy (mc_replace_strmem.c:882)
> ==102997==
> ==102997== at 0x4A08D13: memcpy (mc_replace_strmem.c:882)
> ==102997==
> ==102997== at 0x4A08D30: memcpy (mc_replace_strmem.c:882)
> ==102997==
> ==102997== at 0x4A08D76: memcpy (mc_replace_strmem.c:882)
> ==102997==
> ==102997== at 0x40EC89: __intel_sse2_strncat (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== by 0x4CABD1F: opal_argv_split (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CB5630: opal_net_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4C84F9A: opal_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C84C99: opal_init_util (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x617be00 is 0 bytes inside a block of size 7 alloc'd
> ==102997==
> ==102997== at 0x4CAAD87: mca_base_param_reg_string_name (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x3C8BA74667: _IO_default_xsputn (in /lib64/libc-2.12.so)
> ==102997==
> ==102997== by 0x4CAAE55: mca_base_param_reg_string_name (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x617bb58 is 8 bytes inside a block of size 9 alloc'd
> ==102997== by 0x4C84F41: opal_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CA553B: mca_base_param_reg_int_name (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C84FD7: opal_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x617c038 is 0 bytes after a block of size 8 alloc'd
> ==102997==
> ==102997== by 0x4CA55B5: mca_base_param_reg_int_name (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997== by 0x4CA55D0: mca_base_param_reg_int_name (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997== by 0x4CA55DD: mca_base_param_reg_int_name (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997== at 0x4CA5601: mca_base_param_reg_int_name (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4C85027: opal_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x617c238 is 8 bytes inside a block of size 13 alloc'd
> ==102997==
> ==102997== at 0x3C8BA7458C: _IO_default_xsputn (in /lib64/libc-2.12.so)
> ==102997==
> ==102997== by 0x4CF201F: opal_shmem_base_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C8503E: opal_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x617c418 is 8 bytes inside a block of size 13 alloc'd
> ==102997==
> ==102997== by 0x4CA560D: mca_base_param_reg_int_name (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4CEF8F8: opal_paffinity_base_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C8504C: opal_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x617d198 is 8 bytes inside a block of size 13 alloc'd
> ==102997==
> ==102997== by 0x4CA7356: mca_base_param_reg_syn_name (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CEF96C: opal_paffinity_base_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997== by 0x4CA7370: mca_base_param_reg_syn_name (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997== by 0x4CA737C: mca_base_param_reg_syn_name (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997== by 0x4CA73A8: mca_base_param_reg_syn_name (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4CEF9B7: opal_paffinity_base_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x617d9d8 is 8 bytes inside a block of size 11 alloc'd
> ==102997==
> ==102997== by 0x4CA844D: mca_base_param_lookup_string (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CBCC96: opal_util_register_stackhandlers (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C84CB2: opal_init_util (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x617bf28 is 8 bytes inside a block of size 9 alloc'd
> ==102997==
> ==102997== by 0x4CA82F4: mca_base_param_lookup_string (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x617dd18 is 8 bytes inside a block of size 9 alloc'd
> ==102997==
> ==102997== by 0x4CA5557: mca_base_param_reg_int_name (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CBD0B0: opal_util_init_sys_limits (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C84CCB: opal_init_util (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x617de60 is 16 bytes inside a block of size 19 alloc'd
> ==102997==
> ==102997== at 0x4CA621A: mca_base_param_register_int (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C8AAFC: opal_dss_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C84CFD: opal_init_util (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x617e070 is 0 bytes inside a block of size 7 alloc'd
> ==102997==
> ==102997== at 0x4CA624D: mca_base_param_register_int (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x617e0c0 is 0 bytes inside a block of size 5 alloc'd
> ==102997==
> ==102997== by 0x4CA62C7: mca_base_param_register_int (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997== by 0x4CA62E2: mca_base_param_register_int (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997== by 0x4CA62EF: mca_base_param_register_int (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997== by 0x4CA630A: mca_base_param_register_int (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997== by 0x4CA6317: mca_base_param_register_int (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997== by 0x4C8AB37: opal_dss_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x617e238 is 8 bytes inside a block of size 15 alloc'd
> ==102997==
> ==102997== Address 0x617e280 is 0 bytes inside a block of size 5 alloc'd
> ==102997==
> ==102997==
> ==102997==
> ==102997== by 0x4CA6347: mca_base_param_register_int (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4CA6236: mca_base_param_register_int (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C8AB67: opal_dss_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x617f550 is 16 bytes inside a block of size 17 alloc'd
> ==102997==
> ==102997== Address 0x617f5a0 is 0 bytes inside a block of size 5 alloc'd
> ==102997==
> ==102997== by 0x4C42E29: orte_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x404BB9: orterun (orterun.c:632)
> ==102997== Address 0x6180ff8 is 8 bytes inside a block of size 12 alloc'd
> ==102997==
> ==102997== Address 0x6181058 is 24 bytes inside a block of size 31 alloc'd
> ==102997== by 0x4CAACE8: mca_base_param_reg_string_name (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4C42E7C: orte_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6181408 is 8 bytes inside a block of size 13 alloc'd
> ==102997==
> ==102997== by 0x4C42EBD: orte_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x61815f0 is 0 bytes inside a block of size 6 alloc'd
> ==102997==
> ==102997==
> ==102997== by 0x4C42F08: orte_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x61817e8 is 8 bytes inside a block of size 14 alloc'd
> ==102997==
> ==102997== by 0x4C42F2E: orte_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x61819d8 is 8 bytes inside a block of size 14 alloc'd
> ==102997==
> ==102997== by 0x4C4315F: orte_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6184ff8 is 8 bytes inside a block of size 14 alloc'd
> ==102997==
> ==102997== by 0x4C431A0: orte_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x61851f8 is 8 bytes inside a block of size 12 alloc'd
> ==102997==
> ==102997== Address 0x6185258 is 24 bytes inside a block of size 31 alloc'd
> ==102997== by 0x4CA5562: mca_base_param_reg_int_name (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4C431EB: orte_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x61853e8 is 8 bytes inside a block of size 12 alloc'd
> ==102997==
> ==102997== by 0x4C43245: orte_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6185818 is 8 bytes inside a block of size 15 alloc'd
> ==102997==
> ==102997== by 0x4C43298: orte_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6185c30 is 0 bytes inside a block of size 7 alloc'd
> ==102997==
> ==102997==
> ==102997== by 0x4C432D9: orte_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6185e18 is 8 bytes inside a block of size 15 alloc'd
> ==102997==
> ==102997== by 0x4C43339: orte_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6186028 is 8 bytes inside a block of size 12 alloc'd
> ==102997==
> ==102997== by 0x4C433E1: orte_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6186508 is 8 bytes inside a block of size 14 alloc'd
> ==102997==
> ==102997== by 0x4C43432: orte_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6186728 is 8 bytes inside a block of size 13 alloc'd
> ==102997==
> ==102997== by 0x4C43511: orte_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6186de8 is 8 bytes inside a block of size 9 alloc'd
> ==102997==
> ==102997==
> ==102997== by 0x4C43530: orte_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4C435AA: orte_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x61874a8 is 8 bytes inside a block of size 11 alloc'd
> ==102997==
> ==102997== by 0x4C435EB: orte_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6187688 is 8 bytes inside a block of size 11 alloc'd
> ==102997==
> ==102997== by 0x4C43643: orte_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6187878 is 8 bytes inside a block of size 11 alloc'd
> ==102997==
> ==102997== by 0x4C43689: orte_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6187a68 is 8 bytes inside a block of size 9 alloc'd
> ==102997==
> ==102997==
> ==102997== by 0x4C437A6: orte_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x61882d8 is 8 bytes inside a block of size 12 alloc'd
> ==102997==
> ==102997== by 0x4C437F2: orte_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x61884d8 is 8 bytes inside a block of size 13 alloc'd
> ==102997==
> ==102997== by 0x4CA8E12: param_lookup (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CAAF43: mca_base_param_reg_string_name (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x61885f0 is 0 bytes inside a block of size 6 alloc'd
> ==102997==
> ==102997== by 0x4CA8CCF: param_lookup (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6188640 is 0 bytes inside a block of size 6 alloc'd
> ==102997==
> ==102997== by 0x4C43860: orte_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x61889b0 is 0 bytes inside a block of size 6 alloc'd
> ==102997==
> ==102997==
> ==102997== by 0x4C438EE: orte_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6188e18 is 8 bytes inside a block of size 10 alloc'd
> ==102997==
> ==102997==
> ==102997== at 0x4CA739C: mca_base_param_reg_syn_name (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C43910: orte_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4C4392B: orte_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4C43A3C: orte_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6189c78 is 8 bytes inside a block of size 9 alloc'd
> ==102997==
> ==102997==
> ==102997== by 0x4C43A6C: orte_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6189e48 is 8 bytes inside a block of size 10 alloc'd
> ==102997==
> ==102997==
> ==102997== by 0x4C43A95: orte_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x618e478 is 8 bytes inside a block of size 11 alloc'd
> ==102997==
> ==102997== by 0x4C43AD1: orte_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x618e648 is 8 bytes inside a block of size 12 alloc'd
> ==102997==
> ==102997== by 0x4C43B0D: orte_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x618e818 is 8 bytes inside a block of size 10 alloc'd
> ==102997==
> ==102997==
> ==102997== by 0x4C43D03: orte_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x618edf8 is 8 bytes inside a block of size 14 alloc'd
> ==102997==
> ==102997== by 0x4C43D4B: orte_register_params (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x618efd8 is 8 bytes inside a block of size 15 alloc'd
> ==102997==
> ==102997== by 0x4092E9: create_app (orterun.c:1908)
> ==102997== by 0x408ACD: parse_locals (orterun.c:1681)
> ==102997== by 0x404D1E: orterun (orterun.c:658)
> ==102997== Address 0x619c0f0 is 0 bytes inside a block of size 3 alloc'd
> ==102997==
> ==102997== by 0x4CA4826: mca_base_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C849A7: opal_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C39500: orte_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x404DBC: orterun (orterun.c:693)
> ==102997== Address 0x61ae808 is 8 bytes inside a block of size 15 alloc'd
> ==102997==
> ==102997== by 0x4CA4871: mca_base_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4CA48C5: mca_base_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x61af098 is 0 bytes after a block of size 8 alloc'd
> ==102997==
> ==102997==
> ==102997== by 0x4CA48FA: mca_base_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x61af200 is 0 bytes inside a block of size 7 alloc'd
> ==102997==
> ==102997== at 0x4CA4933: mca_base_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x61af250 is 0 bytes inside a block of size 7 alloc'd
> ==102997==
> ==102997== at 0x4CA4982: mca_base_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4CB6C67: opal_output_reopen (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CA4C03: mca_base_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x61af360 is 16 bytes inside a block of size 18 alloc'd
> ==102997== by 0x4CA4BF7: mca_base_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4C8EB45: canonicalize_path (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C8F942: try_dlopen..0 (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C8C313: lt_dlopenadvise (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C9353B: lt_dlpreload_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C9313F: lt_dlinit (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CA3BB4: mca_base_component_repository_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CA4C27: mca_base_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x61af548 is 8 bytes inside a block of size 9 alloc'd
> ==102997== by 0x4C8B635: lt__malloc (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C8B6C2: lt__memdup (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C8F92A: try_dlopen..0 (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4C8FAA6: try_dlopen..0 (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x61af598 is 8 bytes inside a block of size 9 alloc'd
> ==102997== by 0x4C8EB6C: canonicalize_path (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4C8FBE5: try_dlopen..0 (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4C9172F: try_dlopen..0 (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x61af5e0 is 0 bytes inside a block of size 7 alloc'd
> ==102997== by 0x4C8FC7B: try_dlopen..0 (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4C9179A: try_dlopen..0 (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4C8B67F: lt__strdup (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C8F6D5: tryall_dlopen (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C917FA: try_dlopen..0 (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x61af638 is 8 bytes inside a block of size 12 alloc'd
> ==102997== by 0x4C9175B: try_dlopen..0 (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4C8B68F: lt__strdup (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4A0937A: _intel_fast_memcpy (mc_replace_strmem.c:119)
> ==102997== by 0x4C8B6D5: lt__memdup (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4A0939C: _intel_fast_memcpy (mc_replace_strmem.c:893)
> ==102997==
> ==102997== at 0x4A09513: _intel_fast_memcpy (mc_replace_strmem.c:893)
> ==102997==
> ==102997== at 0x4A09519: _intel_fast_memcpy (mc_replace_strmem.c:893)
> ==102997==
> ==102997== at 0x4A09531: _intel_fast_memcpy (mc_replace_strmem.c:893)
> ==102997==
> ==102997== at 0x4A09538: _intel_fast_memcpy (mc_replace_strmem.c:893)
> ==102997==
> ==102997== at 0x4A0953A: _intel_fast_memcpy (mc_replace_strmem.c:893)
> ==102997==
> ==102997== at 0x4A09540: _intel_fast_memcpy (mc_replace_strmem.c:893)
> ==102997==
> ==102997== at 0x4A0955C: _intel_fast_memcpy (mc_replace_strmem.c:893)
> ==102997==
> ==102997== at 0x4A09563: _intel_fast_memcpy (mc_replace_strmem.c:893)
> ==102997==
> ==102997== at 0x4A09566: _intel_fast_memcpy (mc_replace_strmem.c:893)
> ==102997==
> ==102997== at 0x4A09586: _intel_fast_memcpy (mc_replace_strmem.c:893)
> ==102997==
> ==102997== at 0x4C92C11: lt_dlsym (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C93190: loader_init_callback (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C93552: lt_dlpreload_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== Invalid read of size 4
> ==102997== at 0x40E2D8: __intel_sse2_strcpy (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== by 0x4C92DD2: lt_dlsym (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x61af5e4 is 4 bytes inside a block of size 7 alloc'd
> ==102997==
> ==102997== at 0x40E2E4: __intel_sse2_strcpy (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== by 0x4C92D22: lt_dlsym (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997== by 0x4C92D2D: lt_dlsym (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997== by 0x4CBFAB7: opal_hwloc_base_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C849BD: opal_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x61af968 is 8 bytes inside a block of size 13 alloc'd
> ==102997==
> ==102997== by 0x4CA43F0: mca_base_components_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CBFCC7: opal_hwloc_base_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4CA3E4A: mca_base_components_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x61b09d8 is 8 bytes inside a block of size 13 alloc'd
> ==102997==
> ==102997== by 0x4C8E79B: foreach_dirinpath (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C91EF6: lt_dlforeachfile (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CA1EF1: mca_base_component_find (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CA3F46: mca_base_components_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x61b0cc8 is 56 bytes inside a block of size 59 alloc'd
> ==102997== by 0x3C8BA8AEE2: argz_create_sep (in /lib64/libc-2.12.so)
> ==102997== by 0x4C8E710: foreach_dirinpath (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x40E31C: __intel_sse2_strcpy (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== by 0x4C8E809: foreach_dirinpath (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4C919D5: foreachfile_callback (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C8E85C: foreach_dirinpath (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x61b0d48 is 56 bytes inside a block of size 60 alloc'd
> ==102997== by 0x4C8E7D1: foreach_dirinpath (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997== at 0x4C919D6: foreachfile_callback (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4C91A66: foreachfile_callback (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997== by 0x4C91B9B: foreachfile_callback (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x40E32C: __intel_sse2_strcpy (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== at 0x40E33C: __intel_sse2_strcpy (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== at 0x40E345: __intel_sse2_strcpy (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== at 0x40E35C: __intel_sse2_strcpy (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== at 0x40E373: __intel_sse2_strcpy (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== at 0x40E38C: __intel_sse2_strcpy (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== by 0x4C91BAA: foreachfile_callback (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997== at 0x40EC15: __intel_sse2_strncat (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== by 0x4C91BB8: foreachfile_callback (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x40EC37: __intel_sse2_strncat (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997==
> ==102997== at 0x4C91BB9: foreachfile_callback (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4C91E19: foreachfile_callback (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x61b8e48 is 72 bytes inside a block of size 73 alloc'd
> ==102997== by 0x4C91B6C: foreachfile_callback (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x40E5B8: __intel_sse2_strend (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== by 0x4C91C66: foreachfile_callback (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x61bbcd0 is 1,088 bytes inside a block of size 1,091 alloc'd
> ==102997== at 0x4A06C20: realloc (vg_replace_malloc.c:662)
> ==102997== by 0x3C8BA8B16F: argz_insert (in /lib64/libc-2.12.so)
> ==102997== by 0x4C91C9D: foreachfile_callback (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4C91D8D: foreachfile_callback (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6201eb8 is 6,312 bytes inside a block of size 6,314 alloc'd
> ==102997==
> ==102997== by 0x4C8E8A7: foreach_dirinpath (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x40E578: __intel_sse2_strchr (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== by 0x4CA1DC4: mca_base_component_find (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x61b0bc8 is 88 bytes inside a block of size 93 alloc'd
> ==102997==
> ==102997== by 0x4C8E6A2: foreach_dirinpath (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CA17BE: mca_base_component_find (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x40E90C: __intel_sse2_strrchr (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== by 0x4CA189F: mca_base_component_find (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6202798 is 72 bytes inside a block of size 76 alloc'd
> ==102997==
> ==102997== at 0x40E5DA: __intel_sse2_strncmp (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== by 0x4CA18BA: mca_base_component_find (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x40E601: __intel_sse2_strncmp (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== at 0x40E677: __intel_sse2_strncmp (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== by 0x4CA435F: mca_base_components_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x620e438 is 8 bytes inside a block of size 9 alloc'd
> ==102997==
> ==102997== Address 0x620e488 is 8 bytes inside a block of size 9 alloc'd
> ==102997==
> ==102997==
> ==102997== at 0x40E6C8: __intel_sse2_strncmp (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== by 0x4CEF88B: opal_paffinity_base_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C849F9: opal_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== Address 0x6207c18 is 72 bytes inside a block of size 79 alloc'd
> ==102997==
> ==102997== at 0x40E774: __intel_sse2_strncmp (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== at 0x40E8C1: __intel_sse2_strncmp (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== at 0x40E8C9: __intel_sse2_strncmp (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== at 0x40E8D8: __intel_sse2_strncmp (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== at 0x4CA1988: mca_base_component_find (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CA198A: mca_base_component_find (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x40E3C0: __intel_sse2_strncpy (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== by 0x4CA19A6: mca_base_component_find (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6207c1c is 76 bytes inside a block of size 79 alloc'd
> ==102997==
> ==102997== at 0x40E3C8: __intel_sse2_strncpy (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== at 0x40E449: __intel_sse2_strncpy (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== by 0x4CA19F5: mca_base_component_find (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x40E477: __intel_sse2_strncpy (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== by 0x4CA1A4C: mca_base_component_find (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x40E8E4: __intel_sse2_strncmp (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== at 0x40E8E9: __intel_sse2_strncmp (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== by 0x4C8EB61: canonicalize_path (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C8C693: try_dlopen (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C8C3BE: lt_dlopenadvise (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CA27CB: open_component (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CA1D20: mca_base_component_find (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x62116a0 is 80 bytes inside a block of size 82 alloc'd
> ==102997== by 0x4C8C660: try_dlopen (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4C8C833: try_dlopen (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6211740 is 80 bytes inside a block of size 82 alloc'd
> ==102997==
> ==102997== by 0x4C8C973: try_dlopen (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4C8D5C6: try_dlopen (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6212438 is 56 bytes inside a block of size 59 alloc'd
> ==102997== by 0x4C8F50B: parse_dotla_file (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C8D258: try_dlopen (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4C8D633: try_dlopen (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6212340 is 16 bytes inside a block of size 23 alloc'd
> ==102997== by 0x4C8F5BD: parse_dotla_file (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4C8B69B: lt__strdup (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C8D702: try_dlopen (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6212570 is 80 bytes inside a block of size 82 alloc'd
> ==102997== by 0x4C8D645: try_dlopen (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CA27FB: open_component (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4C92BAA: lt_dlsym (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CA2901: open_component (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4C92C2D: lt_dlsym (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6211820 is 16 bytes inside a block of size 20 alloc'd
> ==102997== by 0x4C8C9CA: try_dlopen (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4C92C41: lt_dlsym (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x40E2FA: __intel_sse2_strcpy (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997==
> ==102997==
> ==102997== at 0x40EA59: __intel_sse2_strcat (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== at 0x40EA98: __intel_sse2_strcat (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== at 0x40EAB8: __intel_sse2_strcat (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== at 0x40EB8D: __intel_sse2_strcat (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== at 0x40EB92: __intel_sse2_strcat (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== at 0x40EB96: __intel_sse2_strcat (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== at 0x40E30A: __intel_sse2_strcpy (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== by 0x4C92D96: lt_dlsym (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997== at 0x4CA4F0A: mca_base_param_reg_int (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x6552EB1: hwloc_register (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_paffinity_hwloc.so)
> ==102997== by 0x4CA4022: mca_base_components_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6213710 is 0 bytes inside a block of size 6 alloc'd
> ==102997==
> ==102997== at 0x4CA4F3D: mca_base_param_reg_int (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6213768 is 8 bytes inside a block of size 9 alloc'd
> ==102997==
> ==102997== by 0x4CA4FB7: mca_base_param_reg_int (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997== by 0x4CA4FD2: mca_base_param_reg_int (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997== by 0x4CA4FDF: mca_base_param_reg_int (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997== by 0x4CA5007: mca_base_param_reg_int (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997== by 0x4CA5037: mca_base_param_reg_int (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4CEF3F4: linux_register (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CE6536: opal_memory_base_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C84A32: opal_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6214b60 is 0 bytes inside a block of size 6 alloc'd
> ==102997==
> ==102997== by 0x4CA4F59: mca_base_param_reg_int (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6214bc0 is 16 bytes inside a block of size 20 alloc'd
> ==102997==
> ==102997== by 0x4CA4FFA: mca_base_param_reg_int (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997==
> ==102997== Address 0x6214c38 is 40 bytes inside a block of size 46 alloc'd
> ==102997== by 0x4CA4F64: mca_base_param_reg_int (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4CEF41D: linux_register (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6214de0 is 0 bytes inside a block of size 6 alloc'd
> ==102997==
> ==102997== by 0x4CEF449: linux_register (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x62150e0 is 0 bytes inside a block of size 6 alloc'd
> ==102997==
> ==102997== by 0x4CEF475: linux_register (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x62153e0 is 0 bytes inside a block of size 6 alloc'd
> ==102997==
> ==102997== by 0x4CEBAC2: opal_memory_linux_hook_pull (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CEF5E7: opal_memory_linux_ptmalloc2_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CEF4D6: linux_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CA4094: mca_base_components_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6215710 is 0 bytes inside a block of size 6 alloc'd
> ==102997==
> ==102997== Address 0x6215768 is 0 bytes after a block of size 8 alloc'd
> ==102997==
> ==102997== by 0x4CE62C9: opal_memchecker_base_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C84A61: opal_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6315bd8 is 0 bytes after a block of size 8 alloc'd
> ==102997==
> ==102997==
> ==102997== by 0x4CF2AF8: opal_timer_linux_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CF2A60: opal_timer_base_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C84AAC: opal_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997== by 0x4CBDE5F: opal_carto_base_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C84AC5: opal_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6317f38 is 8 bytes inside a block of size 13 alloc'd
> ==102997==
> ==102997== by 0x4CBDEBA: opal_carto_base_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6203110 is 80 bytes inside a block of size 81 alloc'd
> ==102997==
> ==102997==
> ==102997== by 0x3C8BA440E8: vfprintf (in /lib64/libc-2.12.so)
> ==102997== by 0x4CA2871: open_component (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997== at 0x3C8BA440F3: vfprintf (in /lib64/libc-2.12.so)
> ==102997==
> ==102997== by 0x3C8BA445DE: vfprintf (in /lib64/libc-2.12.so)
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997== at 0x3C8BA445F0: vfprintf (in /lib64/libc-2.12.so)
> ==102997==
> ==102997== at 0x40E924: __intel_sse2_strrchr (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== by 0x4C8EEA1: parse_dotla_file (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x40E93F: __intel_sse2_strrchr (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== by 0x4C8EEDB: parse_dotla_file (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4C8EF1B: parse_dotla_file (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4C8EF24: parse_dotla_file (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4C8EF2E: parse_dotla_file (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4C8F4DA: parse_dotla_file (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997==
> ==102997== at 0x4A09595: _intel_fast_memcpy (mc_replace_strmem.c:893)
> ==102997==
> ==102997== at 0x4A095FC: _intel_fast_memcpy (mc_replace_strmem.c:893)
> ==102997==
> ==102997== at 0x4A095FF: _intel_fast_memcpy (mc_replace_strmem.c:893)
> ==102997==
> ==102997== at 0x4A09601: _intel_fast_memcpy (mc_replace_strmem.c:893)
> ==102997==
> ==102997== at 0x4C8F4EB: parse_dotla_file (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4C8EFBD: parse_dotla_file (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997== by 0x4C8EFF7: parse_dotla_file (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4C8F031: parse_dotla_file (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4C8F03A: parse_dotla_file (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4C8F044: parse_dotla_file (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4C8F536: parse_dotla_file (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997== at 0x4A09523: _intel_fast_memcpy (mc_replace_strmem.c:893)
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997== at 0x4C8F544: parse_dotla_file (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== Address 0x631f078 is 8 bytes inside a block of size 15 alloc'd
> ==102997==
> ==102997== by 0x6F58B51: auto_detect_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_carto_auto_detect.so)
> ==102997== Address 0x6320d18 is 8 bytes inside a block of size 12 alloc'd
> ==102997==
> ==102997== Address 0x6320d68 is 8 bytes inside a block of size 9 alloc'd
> ==102997==
> ==102997==
> ==102997== at 0x4CA5B53: mca_base_param_reg_string (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x715DB35: file_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_carto_file.so)
> ==102997== Address 0x6320fd0 is 0 bytes inside a block of size 5 alloc'd
> ==102997==
> ==102997== at 0x4CA5B86: mca_base_param_reg_string (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6321020 is 0 bytes inside a block of size 5 alloc'd
> ==102997==
> ==102997== by 0x4CA5C05: mca_base_param_reg_string (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997== by 0x4CA5C20: mca_base_param_reg_string (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997== by 0x4CA5C2D: mca_base_param_reg_string (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997== by 0x4CA5C48: mca_base_param_reg_string (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997== by 0x4CA5C55: mca_base_param_reg_string (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997== by 0x715DBA9: file_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_carto_file.so)
> ==102997== Address 0x6321200 is 0 bytes inside a block of size 5 alloc'd
> ==102997==
> ==102997== Address 0x6321258 is 8 bytes inside a block of size 9 alloc'd
> ==102997==
> ==102997== by 0x4C9F0E2: opal_event_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C84AF7: opal_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6321908 is 8 bytes inside a block of size 14 alloc'd
> ==102997==
> ==102997== by 0x715B212: mmap_register (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_shmem_mmap.so)
> ==102997== by 0x4CF20B4: opal_shmem_base_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C84B2E: opal_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x632f120 is 0 bytes inside a block of size 5 alloc'd
> ==102997==
> ==102997== Invalid read of size 8
> ==102997== by 0x715B280: mmap_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_shmem_mmap.so)
> ==102997== Address 0x632f380 is 0 bytes inside a block of size 5 alloc'd
> ==102997==
> ==102997== by 0x4041A3: main (main.c:13)
> ==102997== Address 0x632f3d8 is 8 bytes inside a block of size 9 alloc'd
> ==102997== at 0x4A06A2E: malloc (vg_replace_malloc.c:270)
> ==102997== by 0x40EF6D: __intel_sse2_strdup (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== by 0x715B2A9: mmap_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_shmem_mmap.so)
> ==102997== Address 0x632f700 is 0 bytes inside a block of size 5 alloc'd
> ==102997==
> ==102997== by 0x715B2D6: mmap_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_shmem_mmap.so)
> ==102997== Address 0x632f990 is 0 bytes inside a block of size 5 alloc'd
> ==102997==
> ==102997== by 0x4CA5BA2: mca_base_param_reg_string (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x632f9f0 is 16 bytes inside a block of size 22 alloc'd
> ==102997==
> ==102997== by 0x4CA5C85: mca_base_param_reg_string (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x632fa68 is 40 bytes inside a block of size 46 alloc'd
> ==102997== by 0x4CA5BAE: mca_base_param_reg_string (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== Conditional jump or move depends on uninitialised value(s)
> ==102997==
> ==102997== by 0x735DFDC: posix_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_shmem_posix.so)
> ==102997== Address 0x632fd00 is 0 bytes inside a block of size 6 alloc'd
> ==102997==
> ==102997== Address 0x632fd58 is 8 bytes inside a block of size 9 alloc'd
> ==102997==
> ==102997== by 0x7560CAC: sysv_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_shmem_sysv.so)
> ==102997== Address 0x632ffb0 is 0 bytes inside a block of size 5 alloc'd
> ==102997==
> ==102997== Address 0x6330008 is 8 bytes inside a block of size 9 alloc'd
> ==102997==
> ==102997== by 0x4C85CB1: opal_cr_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C84B60: opal_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6330308 is 0 bytes after a block of size 8 alloc'd
> ==102997==
> ==102997== by 0x4C85D36: opal_cr_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x63304e8 is 8 bytes inside a block of size 11 alloc'd
> ==102997==
> ==102997== Use of uninitialised value of size 8
> ==102997== at 0x40EEB2: __intel_sse2_strncat (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997==
> ==102997== by 0x4C85D98: opal_cr_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x63306c8 is 8 bytes inside a block of size 13 alloc'd
> ==102997==
> ==102997== by 0x4C85E6D: opal_cr_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6330d28 is 0 bytes after a block of size 8 alloc'd
> ==102997==
> ==102997== by 0x4C85ED7: opal_cr_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6330f30 is 0 bytes inside a block of size 7 alloc'd
> ==102997==
> ==102997==
> ==102997== by 0x4C85F2C: opal_cr_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6331158 is 8 bytes inside a block of size 14 alloc'd
> ==102997==
> ==102997== by 0x4C85FBF: opal_cr_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6331358 is 0 bytes after a block of size 8 alloc'd
> ==102997==
> ==102997== by 0x4C475E9: orte_proc_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C395E3: orte_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x63315c8 is 0 bytes after a block of size 8 alloc'd
> ==102997==
> ==102997==
> ==102997== by 0x4C476C2: orte_proc_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6331998 is 0 bytes after a block of size 8 alloc'd
> ==102997==
> ==102997==
> ==102997== by 0x4C476FD: orte_proc_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4C47739: orte_proc_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6331bb8 is 8 bytes inside a block of size 10 alloc'd
> ==102997==
> ==102997==
> ==102997== by 0x4C4777C: orte_proc_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6331d98 is 8 bytes inside a block of size 13 alloc'd
> ==102997==
> ==102997== at 0x40E424: __intel_sse2_strncpy (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== by 0x4C5D15B: orte_ess_base_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C395FC: orte_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x620466c is 76 bytes inside a block of size 77 alloc'd
> ==102997==
> ==102997== at 0x40E42C: __intel_sse2_strncpy (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== at 0x4C8D617: try_dlopen (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x634c6d8 is 8 bytes inside a block of size 15 alloc'd
> ==102997==
> ==102997== at 0x40EA41: __intel_sse2_strcat (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== at 0x40E548: __intel_sse2_strlen (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== Address 0x635bf28 is 24 bytes inside a block of size 30 alloc'd
> ==102997== by 0x4CA6274: mca_base_param_register_int (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x40EBB9: __intel_sse2_strcat (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== by 0x7969B7B: orte_plm_rsh_component_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_plm_rsh.so)
> ==102997== by 0x4C6EFF7: orte_plm_base_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x7563471: rte_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_ess_hnp.so)
> ==102997== by 0x4C3961A: orte_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x637cbb0 is 0 bytes inside a block of size 4 alloc'd
> ==102997==
> ==102997== Address 0x637cc08 is 8 bytes inside a block of size 15 alloc'd
> ==102997==
> ==102997==
> ==102997==
> ==102997== by 0x7969BC3: orte_plm_rsh_component_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_plm_rsh.so)
> ==102997== Address 0x637cdf0 is 0 bytes inside a block of size 4 alloc'd
> ==102997==
> ==102997== Address 0x637ce48 is 8 bytes inside a block of size 10 alloc'd
> ==102997==
> ==102997== by 0x7969C04: orte_plm_rsh_component_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_plm_rsh.so)
> ==102997== Address 0x637d040 is 0 bytes inside a block of size 4 alloc'd
> ==102997==
> ==102997== Address 0x637d098 is 8 bytes inside a block of size 13 alloc'd
> ==102997==
> ==102997== by 0x7969C45: orte_plm_rsh_component_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_plm_rsh.so)
> ==102997== Address 0x637d290 is 0 bytes inside a block of size 4 alloc'd
> ==102997==
> ==102997== Address 0x637d2e8 is 8 bytes inside a block of size 15 alloc'd
> ==102997==
> ==102997== by 0x7969C86: orte_plm_rsh_component_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_plm_rsh.so)
> ==102997== Address 0x637d4f0 is 0 bytes inside a block of size 4 alloc'd
> ==102997==
> ==102997== by 0x7969CC7: orte_plm_rsh_component_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_plm_rsh.so)
> ==102997== Address 0x637d740 is 0 bytes inside a block of size 4 alloc'd
> ==102997==
> ==102997== by 0x7969D12: orte_plm_rsh_component_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_plm_rsh.so)
> ==102997== Address 0x637d9a0 is 0 bytes inside a block of size 4 alloc'd
> ==102997==
> ==102997== Address 0x637d9f8 is 8 bytes inside a block of size 9 alloc'd
> ==102997==
> ==102997== by 0x7969D3E: orte_plm_rsh_component_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_plm_rsh.so)
> ==102997== Address 0x637dc60 is 0 bytes inside a block of size 4 alloc'd
> ==102997==
> ==102997== Address 0x637dcb0 is 0 bytes inside a block of size 6 alloc'd
> ==102997==
> ==102997== at 0x4CA502B: mca_base_param_reg_int (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x7969D60: orte_plm_rsh_component_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_plm_rsh.so)
> ==102997== Address 0x637de90 is 0 bytes inside a block of size 4 alloc'd
> ==102997==
> ==102997== Address 0x637dee8 is 8 bytes inside a block of size 11 alloc'd
> ==102997==
> ==102997== by 0x7B71001: plm_slurm_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_plm_slurm.so)
> ==102997== Address 0x637e120 is 0 bytes inside a block of size 6 alloc'd
> ==102997==
> ==102997== Address 0x637e170 is 0 bytes inside a block of size 5 alloc'd
> ==102997==
> ==102997== at 0x40ECF9: __intel_sse2_strncat (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== at 0x4CA5C79: mca_base_param_reg_string (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x7D74DB2: plm_tm_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_plm_tm.so)
> ==102997== Address 0x637e640 is 0 bytes inside a block of size 3 alloc'd
> ==102997==
> ==102997==
> ==102997== at 0x4C74769: orte_plm_base_rsh_launch_agent_lookup (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x7969FAF: orte_plm_rsh_component_query (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_plm_rsh.so)
> ==102997== by 0x4CA45F7: mca_base_select (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C6F2CE: orte_plm_base_select (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x7563480: rte_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_ess_hnp.so)
> ==102997== Address 0x637ea40 is 0 bytes inside a block of size 5 alloc'd
> ==102997==
> ==102997== at 0x4C747C8: orte_plm_base_rsh_launch_agent_lookup (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x40EF55: __intel_sse2_strdup (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== by 0x6F76616B732F6B71: ???
> ==102997== by 0x74706164612F3174: ???
> ==102997== by 0x796C754A2F657668: ???
> ==102997== by 0x6D756E2D656E6F2E: ???
> ==102997== by 0x366E6F6974616562: ???
> ==102997==
> ==102997== by 0x4CB65CA: opal_os_path (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CB9673: opal_path_access (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CB95C5: opal_path_find (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CB933D: opal_path_findv (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C74811: orte_plm_base_rsh_launch_agent_lookup (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x637ec68 is 56 bytes inside a block of size 62 alloc'd
> ==102997== by 0x69706D6F632F6C60: ???
> ==102997== by 0x746E492F7372656B: ???
> ==102997== by 0x6F706D6F632F6C64: ???
> ==102997== by 0x325F65785F726572: ???
> ==102997== by 0x37302E302E33312F: ???
> ==102997== by 0x6E692F6E69622F38: ???
> ==102997== by 0x752F0034366C6573: ???
> ==102997== by 0x6C61636F6C2F7272: ???
> ==102997== by 0x6567616B6361702E: ???
> ==102997== by 0x706D6E65706F2F72: ???
> ==102997==
> ==102997== at 0x4CB65AE: opal_os_path (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x637eb90 is 0 bytes inside a block of size 4 alloc'd
> ==102997==
> ==102997== at 0x40E977: __intel_sse2_strcat (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== by 0x4CB672D: opal_os_path (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x40E9EA: __intel_sse2_strcat (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== at 0x40EA75: __intel_sse2_strcat (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== at 0x40E995: __intel_sse2_strcat (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== by 0x4CB6788: opal_os_path (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x40EBC5: __intel_sse2_strcat (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== by 0x4CB6793: opal_os_path (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997== at 0x40E985: __intel_sse2_strcat (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== Address 0x6380418 is 56 bytes inside a block of size 57 alloc'd
> ==102997== by 0x4CB6689: opal_os_path (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997== at 0x40E963: __intel_sse2_strcat (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== Address 0x63804e8 is 8 bytes inside a block of size 11 alloc'd
> ==102997==
> ==102997== at 0x40E9FA: __intel_sse2_strcat (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== Address 0x637eee4 is 4 bytes inside a block of size 5 alloc'd
> ==102997== by 0x732F3A6E69622F71: ???
> ==102997== by 0x7273752F3A6E6961: ???
> ==102997== by 0x752F3A6E6962732E: ???
> ==102997== by 0x73752F3A6E69622E: ???
> ==102997== by 0x2F6C61636F6C2F71: ???
> ==102997== by 0x73752F3A6E696272: ???
> ==102997== by 0x2F36523131582F71: ???
> ==102997== by 0x702F6C61636F6C2E: ???
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997== at 0x4CAACC1: mca_base_param_reg_string_name (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C7BB7C: orte_rml_base_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x75634A3: rte_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_ess_hnp.so)
> ==102997== Address 0x6380658 is 0 bytes after a block of size 8 alloc'd
> ==102997==
> ==102997==
> ==102997== by 0x86B2ED2: mca_oob_tcp_component_register (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_oob_tcp.so)
> ==102997== by 0x4C6E5E4: mca_oob_base_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x7968B66: rml_oob_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_rml_oob.so)
> ==102997== by 0x4C7BBAF: orte_rml_base_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6389c50 is 0 bytes inside a block of size 4 alloc'd
> ==102997==
> ==102997== Address 0x6389ca8 is 0 bytes after a block of size 8 alloc'd
> ==102997==
> ==102997== by 0x86B2EFF: mca_oob_tcp_component_register (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_oob_tcp.so)
> ==102997== Address 0x6389ea0 is 0 bytes inside a block of size 4 alloc'd
> ==102997==
> ==102997== Address 0x6389ef8 is 8 bytes inside a block of size 11 alloc'd
> ==102997==
> ==102997== by 0x86B2F2C: mca_oob_tcp_component_register (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_oob_tcp.so)
> ==102997== Address 0x638a0f0 is 0 bytes inside a block of size 4 alloc'd
> ==102997==
> ==102997== Address 0x638a148 is 8 bytes inside a block of size 13 alloc'd
> ==102997==
> ==102997== by 0x86B2F56: mca_oob_tcp_component_register (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_oob_tcp.so)
> ==102997== Address 0x638a340 is 0 bytes inside a block of size 4 alloc'd
> ==102997==
> ==102997== Address 0x638a390 is 0 bytes inside a block of size 6 alloc'd
> ==102997==
> ==102997==
> ==102997== by 0x86B2F83: mca_oob_tcp_component_register (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_oob_tcp.so)
> ==102997== Address 0x638a570 is 0 bytes inside a block of size 4 alloc'd
> ==102997==
> ==102997== Address 0x638a5c0 is 0 bytes inside a block of size 7 alloc'd
> ==102997==
> ==102997==
> ==102997== by 0x86B2FB0: mca_oob_tcp_component_register (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_oob_tcp.so)
> ==102997== Address 0x638a7a0 is 0 bytes inside a block of size 4 alloc'd
> ==102997==
> ==102997== Address 0x638a7f0 is 0 bytes inside a block of size 7 alloc'd
> ==102997==
> ==102997==
> ==102997== by 0x86B2FDA: mca_oob_tcp_component_register (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_oob_tcp.so)
> ==102997== Address 0x638a9d0 is 0 bytes inside a block of size 4 alloc'd
> ==102997==
> ==102997== Address 0x638aa28 is 8 bytes inside a block of size 11 alloc'd
> ==102997==
> ==102997==
> ==102997== by 0x86B3004: mca_oob_tcp_component_register (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_oob_tcp.so)
> ==102997== Address 0x638ac00 is 0 bytes inside a block of size 4 alloc'd
> ==102997==
> ==102997== Address 0x638ac58 is 0 bytes after a block of size 8 alloc'd
> ==102997==
> ==102997== by 0x86B306D: mca_oob_tcp_component_register (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_oob_tcp.so)
> ==102997== Address 0x638ae40 is 0 bytes inside a block of size 4 alloc'd
> ==102997==
> ==102997== Address 0x638ae98 is 8 bytes inside a block of size 11 alloc'd
> ==102997==
> ==102997== by 0x86B3092: mca_oob_tcp_component_register (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_oob_tcp.so)
> ==102997== Address 0x638b070 is 0 bytes inside a block of size 4 alloc'd
> ==102997==
> ==102997== Address 0x638b0c8 is 0 bytes after a block of size 8 alloc'd
> ==102997==
> ==102997== by 0x86B30FE: mca_oob_tcp_component_register (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_oob_tcp.so)
> ==102997== Address 0x638b2b0 is 0 bytes inside a block of size 4 alloc'd
> ==102997==
> ==102997== Address 0x638b308 is 8 bytes inside a block of size 14 alloc'd
> ==102997==
> ==102997== by 0x86B3129: mca_oob_tcp_component_register (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_oob_tcp.so)
> ==102997== Address 0x638b510 is 0 bytes inside a block of size 4 alloc'd
> ==102997==
> ==102997== Address 0x638b568 is 8 bytes inside a block of size 12 alloc'd
> ==102997==
> ==102997== by 0x86B31FD: mca_oob_tcp_component_register (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_oob_tcp.so)
> ==102997== Address 0x638b830 is 0 bytes inside a block of size 4 alloc'd
> ==102997==
> ==102997== by 0x86B3227: mca_oob_tcp_component_register (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_oob_tcp.so)
> ==102997== Address 0x638bad0 is 0 bytes inside a block of size 4 alloc'd
> ==102997==
> ==102997== by 0x86B329F: mca_oob_tcp_component_register (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_oob_tcp.so)
> ==102997== Address 0x638bd30 is 0 bytes inside a block of size 4 alloc'd
> ==102997==
> ==102997== Address 0x638bd88 is 8 bytes inside a block of size 13 alloc'd
> ==102997==
> ==102997== by 0x86B3372: mca_oob_tcp_component_register (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_oob_tcp.so)
> ==102997== Address 0x638bf90 is 0 bytes inside a block of size 4 alloc'd
> ==102997==
> ==102997== Address 0x638bfe8 is 8 bytes inside a block of size 14 alloc'd
> ==102997==
> ==102997== by 0x86B342A: mca_oob_tcp_component_register (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_oob_tcp.so)
> ==102997== Address 0x638c1c0 is 0 bytes inside a block of size 4 alloc'd
> ==102997==
> ==102997== Address 0x638c218 is 8 bytes inside a block of size 15 alloc'd
> ==102997==
> ==102997== by 0x4C7BC46: orte_rml_base_select (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x75634B2: rte_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_ess_hnp.so)
> ==102997== Address 0x638ca08 is 0 bytes after a block of size 8 alloc'd
> ==102997==
> ==102997== at 0x4CAAD87: mca_base_param_reg_string_name (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x40E3D4: __intel_sse2_strncpy (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== by 0x4CB2A3B: opal_ifindextoname (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x86B66BB: mca_oob_tcp_component_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_oob_tcp.so)
> ==102997== by 0x4C6E857: mca_oob_base_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x79698F1: rml_oob_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_rml_oob.so)
> ==102997== by 0x4C7BCC4: orte_rml_base_select (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x8ED0B06: orte_routed_radix_component_query (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_routed_radix.so)
> ==102997== by 0x4C7C9A4: orte_routed_base_select (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x75634D0: rte_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_ess_hnp.so)
> ==102997== Address 0x63b2530 is 0 bytes inside a block of size 6 alloc'd
> ==102997==
> ==102997==
> ==102997== at 0x4C749A0: orte_plm_base_rsh_launch_agent_setup (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x7D757DF: plm_tm_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_plm_tm.so)
> ==102997== by 0x7563501: rte_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_ess_hnp.so)
> ==102997== Address 0x63c7cb0 is 0 bytes inside a block of size 5 alloc'd
> ==102997== by 0x4C7487A: orte_plm_base_rsh_launch_agent_lookup (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4C749FE: orte_plm_base_rsh_launch_agent_setup (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CB65BE: opal_os_path (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C74ACF: orte_plm_base_rsh_launch_agent_setup (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CB6675: opal_os_path (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4CB6722: opal_os_path (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997== at 0x40EBB3: __intel_sse2_strcat (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997==
> ==102997== Address 0x63c97ac is 12 bytes inside a block of size 15 alloc'd
> ==102997== by 0x4C74A48: orte_plm_base_rsh_launch_agent_setup (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x40EA17: __intel_sse2_strcat (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== at 0x40EEF8: __intel_sse2_strdup (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== by 0x4CAC821: opal_basename (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C74AFC: orte_plm_base_rsh_launch_agent_setup (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x63c97a8 is 8 bytes inside a block of size 15 alloc'd
> ==102997==
> ==102997== at 0x40EF3C: __intel_sse2_strdup (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== at 0x4A08D4C: memcpy (mc_replace_strmem.c:882)
> ==102997== by 0x40EFCD: __intel_sse2_strdup (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== at 0x4A08D53: memcpy (mc_replace_strmem.c:882)
> ==102997==
> ==102997== at 0x4A08D56: memcpy (mc_replace_strmem.c:882)
> ==102997==
> ==102997== at 0x4CAC833: opal_basename (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x63cae38 is 8 bytes inside a block of size 13 alloc'd
> ==102997==
> ==102997== at 0x4CAC886: opal_basename (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4CAC8E8: opal_basename (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x8CCAC01: orte_ras_loadleveler_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_ras_loadleveler.so)
> ==102997== by 0x4C77D96: orte_ras_base_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x7563510: rte_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_ess_hnp.so)
> ==102997== Address 0x63dc798 is 8 bytes inside a block of size 12 alloc'd
> ==102997==
> ==102997== Address 0x63dc7e8 is 8 bytes inside a block of size 9 alloc'd
> ==102997==
> ==102997== by 0x8ECCED1: ras_slurm_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_ras_slurm.so)
> ==102997== Address 0x63dca50 is 0 bytes inside a block of size 6 alloc'd
> ==102997==
> ==102997== Address 0x63dcaa8 is 8 bytes inside a block of size 9 alloc'd
> ==102997==
> ==102997== by 0x90CFCEC: ras_tm_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_ras_tm.so)
> ==102997== Address 0x63dccf0 is 0 bytes inside a block of size 3 alloc'd
> ==102997==
> ==102997== Address 0x63dcd48 is 8 bytes inside a block of size 9 alloc'd
> ==102997==
> ==102997== by 0x90CFD62: ras_tm_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_ras_tm.so)
> ==102997== Address 0x63dd000 is 0 bytes inside a block of size 3 alloc'd
> ==102997==
> ==102997== Address 0x63dd058 is 8 bytes inside a block of size 13 alloc'd
> ==102997==
> ==102997==
> ==102997== at 0x4CA553B: mca_base_param_reg_int_name (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C7905A: orte_rmaps_base_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x756352E: rte_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_ess_hnp.so)
> ==102997== Address 0x63dd698 is 8 bytes inside a block of size 13 alloc'd
> ==102997==
> ==102997== by 0x4C790A0: orte_rmaps_base_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x63dd878 is 8 bytes inside a block of size 15 alloc'd
> ==102997==
> ==102997== by 0x4C792AB: orte_rmaps_base_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x63de568 is 8 bytes inside a block of size 12 alloc'd
> ==102997==
> ==102997== by 0x4C792EC: orte_rmaps_base_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x63de788 is 8 bytes inside a block of size 15 alloc'd
> ==102997==
> ==102997== at 0x40EA83: __intel_sse2_strcat (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== by 0x4C79466: orte_rmaps_base_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997== by 0x92D3580: orte_rmaps_resilient_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_rmaps_resilient.so)
> ==102997== Address 0x63f8b48 is 8 bytes inside a block of size 10 alloc'd
> ==102997==
> ==102997== Address 0x63f8b98 is 8 bytes inside a block of size 15 alloc'd
> ==102997==
> ==102997==
> ==102997== at 0x40E556: __intel_sse2_strlen (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== by 0x4CD2862: hwloc_find_linux_cpuset_mntpnt (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CCA5B1: opal_hwloc132_hwloc_look_linux (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CDD5A2: hwloc_discover (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CDCFAA: opal_hwloc132_hwloc_topology_load (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C668D0: orte_odls_base_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x7563626: rte_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_ess_hnp.so)
> ==102997==
> ==102997== at 0x4CD286B: hwloc_find_linux_cpuset_mntpnt (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CD2877: hwloc_find_linux_cpuset_mntpnt (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CD2881: hwloc_find_linux_cpuset_mntpnt (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CD28A2: hwloc_find_linux_cpuset_mntpnt (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CD209F: look_sysfsnode (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CCBF03: opal_hwloc132_hwloc_look_linux (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CD20AF: look_sysfsnode (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4CD20AB: look_sysfsnode (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4CD105B: look_sysfscpu (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CCBE1E: opal_hwloc132_hwloc_look_linux (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997== at 0x4CCD72A: hwloc__get_dmi_one_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CCC03F: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CCB3B1: opal_hwloc132_hwloc_look_linux (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCD73B: hwloc__get_dmi_one_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCD740: hwloc__get_dmi_one_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x404DBC: orterun (orterun.c:693)
> ==102997==
> ==102997== at 0x4CCD756: hwloc__get_dmi_one_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCD758: hwloc__get_dmi_one_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4CDB9A8: opal_hwloc132_hwloc_obj_add_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CCD76D: hwloc__get_dmi_one_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4CCC08A: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997== at 0x4CCC1C8: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCC1D9: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCC1DE: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCC1F4: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCC1F6: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCC359: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCC36A: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCC36F: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCC385: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCC387: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCC67B: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCC68C: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCC691: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCC6A7: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCC6A9: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCC80C: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCC81D: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCC822: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCC838: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCC83A: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCC99D: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCC9AE: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCC9B3: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCC9C9: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCC9CB: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCCB2E: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCCB3F: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCCB44: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCCB5A: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCCB5C: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCCE50: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCCE61: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCCE66: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCCE7C: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCCE7E: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCCFE1: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCCFF2: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCCFF7: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCD00D: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCD00F: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCD172: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCD183: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCD188: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCD19E: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCD1A0: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCD303: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCD314: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCD319: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCD32F: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCD331: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCD49E: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCD4AF: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCD4B4: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCD4CA: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CCD4CC: hwloc__get_dmi_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x7765C25: query (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_sysinfo_linux.so)
> ==102997== by 0x4CF2782: opal_sysinfo_base_query (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C664D2: orte_odls_base_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6368e78 is 8 bytes inside a block of size 13 alloc'd
> ==102997==
> ==102997== by 0x4C66542: orte_odls_base_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x64ad018 is 8 bytes inside a block of size 13 alloc'd
> ==102997==
> ==102997== by 0x4CA3F46: mca_base_components_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C665D1: orte_odls_base_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4C47EDB: orte_session_dir_get_name (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C47B35: orte_session_dir (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x75636ED: rte_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_ess_hnp.so)
> ==102997== Address 0x6331ab8 is 0 bytes after a block of size 8 alloc'd
> ==102997== by 0x4C0E357: ???
> ==102997== by 0x7FEFFEA8F: ???
> ==102997== by 0x7FEFFEAB7: ???
> ==102997== by 0x4C0DFFF: ??? (in /usr/lib64/valgrind/vgpreload_memcheck-amd64-linux.so)
> ==102997==
> ==102997== by 0x4C48024: orte_session_dir_get_name (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x64b5e60 is 0 bytes inside a block of size 6 alloc'd
> ==102997== by 0x3C8BA6F41F: vasprintf (in /lib64/libc-2.12.so)
> ==102997== by 0x3C8BA4F307: asprintf (in /lib64/libc-2.12.so)
> ==102997== by 0x4C47FC9: orte_session_dir_get_name (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== Invalid read of size 4
> ==102997== at 0x40E9CB: __intel_sse2_strcat (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== Address 0x64b5f60 is 0 bytes inside a block of size 2 alloc'd
> ==102997== by 0x4C47FE7: orte_session_dir_get_name (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997== by 0x4C48117: orte_session_dir_get_name (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x64b6130 is 0 bytes inside a block of size 5 alloc'd
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997==
> ==102997== by 0x4C48146: orte_session_dir_get_name (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x736E6F6973736572: ???
> ==102997== by 0x31756F76616B732C: ???
> ==102997== by 0x323733656B696D3F: ???
> ==102997== by 0x305E: ???
> ==102997==
> ==102997== by 0x4CB5FE0: opal_os_dirpath_create (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C47E09: orte_session_dir (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x64b61b0 is 48 bytes inside a block of size 52 alloc'd
> ==102997==
> ==102997==
> ==102997== by 0x4CB6158: opal_os_dirpath_create (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997== by 0x4CB6034: opal_os_dirpath_create (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997== at 0x4CB60EE: opal_os_dirpath_create (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x4CB60FB: opal_os_dirpath_create (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4CB6114: opal_os_dirpath_create (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997==
> ==102997== Address 0x64b63e0 is 32 bytes inside a block of size 35 alloc'd
> ==102997==
> ==102997== by 0x4CB60FA: opal_os_dirpath_create (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997==
> ==102997== Address 0x64b6494 is 4 bytes inside a block of size 6 alloc'd
> ==102997==
> ==102997== Address 0x64b6550 is 0 bytes inside a block of size 2 alloc'd
> ==102997==
> ==102997==
> ==102997== Address 0x64b6690 is 48 bytes inside a block of size 50 alloc'd
> ==102997== by 0x4CB5FEB: opal_os_dirpath_create (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4C47C16: orte_session_dir (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x64b6270 is 0 bytes inside a block of size 5 alloc'd
> ==102997==
> ==102997==
> ==102997== by 0x7563962: rte_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_ess_hnp.so)
> ==102997==
> ==102997== by 0x4C5E5BD: orte_filem_base_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x7563AA2: rte_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_ess_hnp.so)
> ==102997==
> ==102997== by 0xA4F9F90: filem_rsh_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_filem_rsh.so)
> ==102997== by 0x4C5E600: orte_filem_base_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x64caa30 is 0 bytes inside a block of size 4 alloc'd
> ==102997==
> ==102997== Address 0x64caa88 is 8 bytes inside a block of size 9 alloc'd
> ==102997==
> ==102997== by 0xA4F9FC4: filem_rsh_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_filem_rsh.so)
> ==102997== Address 0x64cac60 is 0 bytes inside a block of size 4 alloc'd
> ==102997==
> ==102997== Address 0x64cacb8 is 0 bytes after a block of size 8 alloc'd
> ==102997==
> ==102997== by 0xA4FA045: filem_rsh_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_filem_rsh.so)
> ==102997== Address 0x64cae90 is 0 bytes inside a block of size 4 alloc'd
> ==102997==
> ==102997== Address 0x64caee0 is 0 bytes inside a block of size 4 alloc'd
> ==102997==
> ==102997==
> ==102997==
> ==102997== by 0xA4FA06E: filem_rsh_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_filem_rsh.so)
> ==102997== Address 0x64cb160 is 0 bytes inside a block of size 4 alloc'd
> ==102997==
> ==102997== Address 0x64cb1b0 is 0 bytes inside a block of size 3 alloc'd
> ==102997==
> ==102997==
> ==102997==
> ==102997== by 0xA4FA09B: filem_rsh_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_filem_rsh.so)
> ==102997== Address 0x64cb440 is 0 bytes inside a block of size 4 alloc'd
> ==102997==
> ==102997== Address 0x64cb490 is 0 bytes inside a block of size 4 alloc'd
> ==102997==
> ==102997==
> ==102997== by 0xA4FA0CB: filem_rsh_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_filem_rsh.so)
> ==102997== Address 0x64cb720 is 0 bytes inside a block of size 4 alloc'd
> ==102997==
> ==102997== Address 0x64cb778 is 8 bytes inside a block of size 14 alloc'd
> ==102997==
> ==102997== by 0xA4FA11C: filem_rsh_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_filem_rsh.so)
> ==102997== Address 0x64cb970 is 0 bytes inside a block of size 4 alloc'd
> ==102997==
> ==102997== Address 0x64cb9c8 is 8 bytes inside a block of size 13 alloc'd
> ==102997==
> ==102997== by 0x4C5E693: orte_filem_base_select (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x7563AB1: rte_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_ess_hnp.so)
> ==102997==
> ==102997== by 0x4C45748: orte_cr_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x7563AE2: rte_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_ess_hnp.so)
> ==102997== Address 0x64cd3b8 is 0 bytes after a block of size 8 alloc'd
> ==102997==
> ==102997== by 0xA701A60: command_register (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_notifier_command.so)
> ==102997== by 0x4C65A7E: orte_notifier_base_open (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x7563AF1: rte_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_ess_hnp.so)
> ==102997== Address 0x64d65d8 is 0 bytes after a block of size 8 alloc'd
> ==102997==
> ==102997== Address 0x64d6620 is 0 bytes inside a block of size 4 alloc'd
> ==102997==
> ==102997==
> ==102997== by 0xA701A94: command_register (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_notifier_command.so)
> ==102997== Address 0x64d6918 is 0 bytes after a block of size 8 alloc'd
> ==102997==
> ==102997== Address 0x64d6968 is 0 bytes after a block of size 8 alloc'd
> ==102997==
> ==102997== by 0xA701AC8: command_register (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_notifier_command.so)
> ==102997== Address 0x64d6b58 is 0 bytes after a block of size 8 alloc'd
> ==102997==
> ==102997== Address 0x64d6ba8 is 8 bytes inside a block of size 9 alloc'd
> ==102997==
> ==102997== by 0x4C65812: orte_notifier_base_select (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x7563AFC: rte_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_ess_hnp.so)
> ==102997==
> ==102997== at 0x40EA47: __intel_sse2_strcat (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== by 0x90CFE39: allocate (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_ras_tm.so)
> ==102997== by 0x4C77EDB: orte_ras_base_allocate (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C703F8: orte_plm_base_setup_job (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x7D74F60: plm_tm_launch_job (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_plm_tm.so)
> ==102997== by 0x405C2E: orterun (orterun.c:917)
> ==102997== Address 0x63dd1f0 is 16 bytes inside a block of size 22 alloc'd
> ==102997==
> ==102997== at 0x90CFE9A: allocate (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_ras_tm.so)
> ==102997==
> ==102997== at 0x90CFEAE: allocate (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_ras_tm.so)
> ==102997==
> ==102997== by 0x90CFEB7: allocate (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_ras_tm.so)
> ==102997==
> ==102997== at 0x90D0015: allocate (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_ras_tm.so)
> ==102997==
> ==102997== by 0x90D0021: allocate (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_ras_tm.so)
> ==102997==
> ==102997== at 0x90D0025: allocate (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_ras_tm.so)
> ==102997==
> ==102997== by 0x90D002E: allocate (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_ras_tm.so)
> ==102997==
> ==102997== by 0x4C52A7A: orte_util_encode_nodemap (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C6CBD4: orte_odls_base_default_get_add_procs_data (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C7069F: orte_plm_base_launch_apps (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x7D7550D: plm_tm_launch_job (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_plm_tm.so)
> ==102997== Address 0x64b7fe8 is 0 bytes after a block of size 8 alloc'd
> ==102997==
> ==102997== at 0x4C52AA6: orte_util_encode_nodemap (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x64ea868 is 0 bytes after a block of size 8 alloc'd
> ==102997==
> ==102997== at 0x4C8751A: opal_dss_pack_string (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C871E3: opal_dss_pack (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C52B13: orte_util_encode_nodemap (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4C87536: opal_dss_pack_string (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C7C40C: orte_rml_base_get_contact_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x7B70485: get_wireup_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_routed_binomial.so)
> ==102997== by 0x4C6CCAC: orte_odls_base_default_get_add_procs_data (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x64b8580 is 64 bytes inside a block of size 65 alloc'd
> ==102997== at 0x4A06C20: realloc (vg_replace_malloc.c:662)
> ==102997== by 0x3C8BA6F3D2: vasprintf (in /lib64/libc-2.12.so)
> ==102997== by 0x7969BD8: orte_rml_oob_get_uri (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_rml_oob.so)
> ==102997== by 0x7563A05: rte_init (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_ess_hnp.so)
> ==102997==
> ==102997== by 0x4C3FCA2: orte_dt_pack_app_context (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C6D114: orte_odls_base_default_get_add_procs_data (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x61a0e38 is 8 bytes inside a block of size 12 alloc'd
> ==102997==
> ==102997== by 0x2E36342E30392E33: ???
> ==102997== by 0x313436353A383130: ???
> ==102997== by 0x400031: ??? (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== at 0x40E90C: __intel_sse2_strrchr (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== by 0x86B5450: mca_oob_tcp_parse_uri (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_oob_tcp.so)
> ==102997== by 0x86B51DF: mca_oob_tcp_set_addr (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_oob_tcp.so)
> ==102997== by 0x7969C83: orte_rml_oob_set_uri (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_rml_oob.so)
> ==102997== by 0x4C7C4EA: orte_rml_base_update_contact_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x7B705E5: init_routes (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_routed_binomial.so)
> ==102997== by 0x4C6C86F: orte_odls_base_default_update_daemon_info (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C5A912: orte_daemon_cmd_processor (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C9DE7B: opal_event_base_loop (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C843D7: opal_progress (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C70ABE: orte_plm_base_report_launched (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C7072F: orte_plm_base_launch_apps (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x64ed998 is 24 bytes inside a block of size 26 alloc'd
> ==102997==
> ==102997== at 0x4CB5A68: opal_setenv (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4CB598B: opal_environ_merge (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C6AF83: odls_base_default_setup_fork (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C69D57: orte_odls_base_default_launch_local (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x8CCD21A: orte_odls_default_launch_local_procs (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_odls_default.so)
> ==102997== by 0x4C5BAC7: process_commands (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C5A870: orte_daemon_cmd_processor (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x64f00a8 is 8 bytes inside a block of size 15 alloc'd
> ==102997== by 0x4CB5A4C: opal_setenv (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x40E757: __intel_sse2_strncmp (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== by 0x4CB5AAB: opal_setenv (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4CB5A84: opal_setenv (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x64f17e0 is 16 bytes inside a block of size 20 alloc'd
> ==102997==
> ==102997== at 0x4CB5910: opal_environ_merge (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x61a39a8 is 8 bytes inside a block of size 14 alloc'd
> ==102997== by 0x535300303030313C: ???
> ==102997== by 0x544E45494C435F47: ???
> ==102997== by 0x2E3532312E36393C: ???
> ==102997== by 0x332035392E323130: ???
> ==102997== by 0x32322038383232: ???
> ==102997== by 0x52415F435354454F: ???
> ==102997== by 0x5000656E6F3D4842: ???
> ==102997== by 0x414E424F4A5F5341: ???
> ==102997== by 0x6F73696E613D454C: ???
> ==102997== by 0x5952415242494BFF: ???
> ==102997==
> ==102997== by 0x4CB5967: opal_environ_merge (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x40E75B: __intel_sse2_strncmp (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== Address 0x64f2328 is 8 bytes inside a block of size 14 alloc'd
> ==102997==
> ==102997== at 0x40E578: __intel_sse2_strchr (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== by 0x4CB5957: opal_environ_merge (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x61a42a8 is 24 bytes inside a block of size 25 alloc'd
> ==102997== by 0x4F5449525245545E: ???
> ==102997== by 0x53555F6E653D5951: ???
> ==102997== by 0x2F3D434E495450FF: ???
> ==102997== by 0x3662696C2F727374: ???
> ==102997== by 0x332E332D74712F33: ???
> ==102997== by 0x6564756C636E692E: ???
> ==102997== by 0x575F4F5F53424FFF: ???
> ==102997== by 0x2F3D5249444B524E: ???
> ==102997== by 0x616B732F656D6F67: ???
> ==102997== by 0x726F772F31756F75: ???
> ==102997==
> ==102997== by 0x4CA86AD: mca_base_param_environ_variable (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C6B08C: odls_base_default_setup_fork (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4CA86A2: mca_base_param_environ_variable (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C6B13A: odls_base_default_setup_fork (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997== by 0x4CA856E: mca_base_param_environ_variable (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C5D2BD: orte_ess_env_put (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C6B33E: odls_base_default_setup_fork (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4C5D2E0: orte_ess_env_put (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x65111c8 is 8 bytes inside a block of size 14 alloc'd
> ==102997==
> ==102997== by 0x4CB5C36: opal_unsetenv (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C5D319: orte_ess_env_put (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x65116d8 is 0 bytes after a block of size 24 alloc'd
> ==102997== by 0x4CB5BFE: opal_unsetenv (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4CB5C5A: opal_unsetenv (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4C69D98: orte_odls_base_default_launch_local (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6512cc0 is 0 bytes inside a block of size 5 alloc'd
> ==102997==
> ==102997== by 0x4CAC84F: opal_basename (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C4A436: orte_util_check_context_app (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C69EAA: orte_odls_base_default_launch_local (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6512d20 is 16 bytes inside a block of size 19 alloc'd
> ==102997==
> ==102997== by 0x4CAC8A2: opal_basename (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4C4A464: orte_util_check_context_app (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x6512d80 is 16 bytes inside a block of size 17 alloc'd
> ==102997==
> ==102997== by 0x4C4A499: orte_util_check_context_app (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x64eeb00 is 16 bytes inside a block of size 19 alloc'd
> ==102997== by 0x4C89F6D: opal_dss_unpack_string (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C8A924: opal_dss_unpack_buffer (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C41DE4: orte_dt_unpack_app_context (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C890B9: opal_dss_unpack (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C6C118: orte_odls_base_default_construct_child_list (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x8CCD1FD: orte_odls_default_launch_local_procs (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/openmpi/mca_odls_default.so)
> ==102997==
> ==102997== by 0x40C88C: orte_debugger_init_after_spawn (orterun.c:2904)
> ==102997== by 0x405C4F: orterun (orterun.c:921)
> ==102997== Address 0x61a3070 is 16 bytes inside a block of size 19 alloc'd
> ==102997== by 0x3C8BA81021: strdup (in /lib64/libc-2.12.so)
> ==102997== by 0x40A30F: create_app (orterun.c:2180)
> ==102997== by 0x408ACD: parse_locals (orterun.c:1681)
> ==102997== by 0x404D1E: orterun (orterun.c:658)
> ==102997==
> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [0]PETSC ERROR: Argument out of range
> [0]PETSC ERROR: Too many processors in X direction: 2 1
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.7.5, Jan, 01, 2017
> [0]PETSC ERROR: ./try3-jacob-3.out on a one named mike372 by skavou1 Wed Jul 19 10:06:02 2017
> [0]PETSC ERROR: Configure options PETSC_DIR=/home/skavou1/work/petsc-3.7.5 PETSC_ARCH=one --download-cmake --download-mpich --download-fblaslapack --with-debugging --download-superlu_dist --download-parmetis --download-metis --download-ptscotch --download-mumps --download-hypre --download-scalapack
> [0]PETSC ERROR: #1 DMSetUp_DA_3D() line 224 in /ddnB/work/skavou1/petsc-3.7.5/src/dm/impls/da/da3.c
> [0]PETSC ERROR: #2 DMSetUp_DA() line 27 in /ddnB/work/skavou1/petsc-3.7.5/src/dm/impls/da/dareg.c
> [0]PETSC ERROR: #3 DMSetUp() line 744 in /ddnB/work/skavou1/petsc-3.7.5/src/dm/interface/dm.c
> [0]PETSC ERROR: #4 DMDACreate3d() line 1446 in /ddnB/work/skavou1/petsc-3.7.5/src/dm/impls/da/da3.c
> [0]PETSC ERROR: #5 main() line 208 in /home/skavou1/work/adaptive/July/one-numceation6/try3-jacob-3.c
> [0]PETSC ERROR: PETSc Option Table entries:
> [0]PETSC ERROR: -ksp_gmres_restart 300
> [0]PETSC ERROR: -ksp_type gmres
> [0]PETSC ERROR: -log_view
> [0]PETSC ERROR: -pc_asm_overlap 4
> [0]PETSC ERROR: -pc_type asm
> [0]PETSC ERROR: -snes_atol 1.0e-20
> [0]PETSC ERROR: -snes_linesearch_type bt
> [0]PETSC ERROR: -snes_mf
> [0]PETSC ERROR: -snes_monitor
> [0]PETSC ERROR: -snes_type newtontr
> [0]PETSC ERROR: -sub_ksp_type preonly
> [0]PETSC ERROR: -sub_pc_type lu
> [0]PETSC ERROR: -ts_adapt_monitor
> [0]PETSC ERROR: -ts_max_snes_failures -1
> [0]PETSC ERROR: -ts_monitor
> [0]PETSC ERROR: -ts_type bdf
> [0]PETSC ERROR: -ts_view
> [0]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
> application called MPI_Abort(MPI_COMM_WORLD, 63) - process 0
> [unset]: aborting job:
> ==102997== Invalid read of size 8
> ==102997== by 0x4C68E02: orte_base_default_waitpid_fired (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C5AF39: process_commands (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C5A41D: orte_daemon_cmd_processor (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x405C54: orterun (orterun.c:925)
> ==102997== by 0x4041A3: main (main.c:13)
> ==102997== Address 0x64b66e0 is 0 bytes inside a block of size 5 alloc'd
> ==102997== at 0x4A06A2E: malloc (vg_replace_malloc.c:270)
> ==102997== by 0x40EF6D: __intel_sse2_strdup (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== Address 0x64b6750 is 32 bytes inside a block of size 35 alloc'd
> ==102997==
> ==102997== by 0x4C486B9: orte_session_dir_finalize (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C66CF6: check_proc_complete (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C66C93: orte_odls_base_notify_iof_complete (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C5AE8D: process_commands (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4C48747: orte_session_dir_finalize (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x653b270 is 0 bytes inside a block of size 6 alloc'd
> ==102997== by 0x4C486FB: orte_session_dir_finalize (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== Conditional jump or move depends on uninitialised value(s)
> ==102997==
> ==102997==
> ==102997== at 0x40EA98: __intel_sse2_strcat (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== at 0x40EAB8: __intel_sse2_strcat (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== Use of uninitialised value of size 8
> ==102997== at 0x40EB8D: __intel_sse2_strcat (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== at 0x40EB92: __intel_sse2_strcat (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== at 0x40EB96: __intel_sse2_strcat (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== by 0x4C487A3: orte_session_dir_finalize (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x653b170 is 0 bytes inside a block of size 2 alloc'd
> ==102997== by 0x4C46EBA: orte_util_convert_vpid_to_string (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C486CA: orte_session_dir_finalize (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4CB625C: opal_os_dirpath_destroy (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C487E2: orte_session_dir_finalize (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x40E9B4: __intel_sse2_strcat (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997== by 0x4C4844C: orte_session_dir_cleanup (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C6720E: check_proc_complete (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C68D20: orte_base_default_waitpid_fired (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== by 0x4C484C2: orte_session_dir_cleanup (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x654ea00 is 0 bytes inside a block of size 6 alloc'd
> ==102997== by 0x4C48476: orte_session_dir_cleanup (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997== at 0x40E548: __intel_sse2_strlen (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997== by 0x4CBA2DE: opal_show_help_vstring (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C49B88: orte_show_help (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x407180: dump_aborted_procs (orterun.c:1207)
> ==102997== by 0x405E74: job_completed (orterun.c:957)
> ==102997== by 0x4C452FC: orte_trigger_event (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C72DE0: orte_plm_base_check_job_completed (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4C6F8C3: process_msg (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x654f550 is 16 bytes inside a block of size 23 alloc'd
> ==102997==
> ==102997== by 0x4CBA410: opal_show_help_vstring (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== Address 0x654fd40 is 64 bytes inside a block of size 67 alloc'd
> ==102997==
> ==102997== by 0x4CBA44F: opal_show_help_vstring (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997== by 0x4CBA46A: opal_show_help_vstring (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997==
> ==102997== by 0x4CBA479: opal_show_help_vstring (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> ==102997== Address 0x654fe68 is 24 bytes inside a block of size 28 alloc'd
> ==102997==
> ==102997== by 0x4CBA499: opal_show_help_vstring (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997==
> mpiexec noticed that the job aborted, but has no info as to the process
> that caused that situation.
> ==102997== by 0x4C484EC: orte_session_dir_cleanup (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997== by 0x4063E5: just_quit (orterun.c:1046)
> ==102997== by 0x406302: job_completed (orterun.c:1016)
> ==102997== Address 0x6550f20 is 0 bytes inside a block of size 6 alloc'd
> ==102997==
> ==102997==
> ==102997== by 0x4C4853B: orte_session_dir_cleanup (in /home/packages/openmpi/1.6.2/Intel-13.0.0/lib/libopen-rte.so.4.0.0)
> ==102997==
> ==102997== at 0x40EA59: __intel_sse2_strcat (in /home/packages/openmpi/1.6.2/Intel-13.0.0/bin/orterun)
> ==102997==
> ==102997==
> ==102997== HEAP SUMMARY:
> ==102997== in use at exit: 411,245 bytes in 3,053 blocks
> ==102997== total heap usage: 8,975 allocs, 5,922 frees, 12,560,021 bytes allocated
> ==102997==
> ==102997== LEAK SUMMARY:
> ==102997== definitely lost: 52,793 bytes in 43 blocks
> ==102997== indirectly lost: 17,831 bytes in 61 blocks
> ==102997== possibly lost: 0 bytes in 0 blocks
> ==102997== still reachable: 340,621 bytes in 2,949 blocks
> ==102997== suppressed: 0 bytes in 0 blocks
> ==102997== Rerun with --leak-check=full to see details of leaked memory
> ==102997==
> ==102997== For counts of detected and suppressed errors, rerun with: -v
> ==102997== Use --track-origins=yes to see where uninitialised values come from
> ==102997== ERROR SUMMARY: 45427 errors from 796 contexts (suppressed: 6 from 6)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170719/2a748ed9/attachment-0001.html>
