[petsc-users] Understanding preallocation for MPI
Stefano Zampini
stefano.zampini at gmail.com
Mon Jul 10 03:36:24 CDT 2017
Florian,
Perhaps you might want to take a look at how this is done for MatIS
https://bitbucket.org/petsc/petsc/src/f9d5775f43f69cbce5a7014a6ce3b24cc0e1214a/src/mat/impls/is/matis.c?at=master&fileviewer=file-view-default#matis.c-1050
Stefano
Il 10 Lug 2017 10:23 AM, "Florian Lindner" <mailinglists at xgm.de> ha scritto:
> Hey,
> one more question about preallocation:
> I can determine if a column index is diagonal or off-diagonal using that
> code
> if (col >= col_range_start and col < col_range_end)
> d_nnz[relative_row]++;
> else
> o_nnz[relative_row]++;
> My code, however uses index sets from which a ISlocalToGlobalMapping
> created:
> // Creates a mapping from permutation and use that for the cols
> ierr = ISCreateGeneral(PETSC_COMM_WORLD, local_cols,
> permutation.data(), PETSC_COPY_VALUES, &ISlocal); CHKERRV(ierr);
> ierr = ISSetPermutation(ISlocal); CHKERRV(ierr);
> ierr = ISAllGather(ISlocal, &ISglobal); CHKERRV(ierr); // Gather the IS
> from all processors
> ierr = ISLocalToGlobalMappingCreateIS(ISglobal, &ISmapping);
> CHKERRV(ierr); // Make it a mapping
> // Create an identity mapping and use that for the rows of A.
> ierr = ISCreateStride(PETSC_COMM_WORLD, local_rows, row_range_start, 1,
> &ISidentity); CHKERRV(ierr);
> ierr = ISSetIdentity(ISidentity); CHKERRV(ierr);
> ierr = ISAllGather(ISidentity, &ISidentityGlobal); CHKERRV(ierr);
> ierr = ISLocalToGlobalMappingCreateIS(ISidentityGlobal,
> &ISidentityMapping); CHKERRV(ierr);
> ierr = MatSetLocalToGlobalMapping(A, ISidentityMapping, ISmapping);
> CHKERRV(ierr);
> since SetPreallocation routines define the diagonal / off-diagonal blocks
> from the petsc ordering, I have to translate
> the col to a petsc_col.
> What is the best / fastest way to do that?
> Is that the way to go?
> PetscInt mapSize;
> ISLocalToGlobalMappingGetSize(ISmapping, &mapSize);
> const PetscInt *mapIndizes;
> ISLocalToGlobalMappingGetIndices(ISmapping, &mapIndizes);
> Thanks,
> Florian
> Am 07.07.2017 um 17:31 schrieb Florian Lindner:
> > Hello,
> > I'm having some struggle understanding the preallocation for MPIAIJ
> matrices, especially when a value is in off-diagonal
> > vs. diagonal block.
> > The small example program is at https://pastebin.com/67dXnGm3
> > In general it should be parallel, but right now I just run it in serial.
> > According to my understanding of
> > http://www.mcs.anl.gov/petsc/petsc-3.7/docs/manualpages/
> Mat/MatMPIAIJSetPreallocation.html
> > a entry is in the diagonal submatrix, if its row is in the
> OwnershipRange and its column is in OwnershipRangeColumn.
> > That also means that in a serial run, there is only a diagonal submatrix.
> > However, having MAT_NEW_NONZERO_ALLOCATION_ERR set, I get an error when
> > Inserting 6 elements in row 2, though I have exactly
> > 2 o_nnz = 0, d_nnz = 6 (means 6 elements allocated in the diagonal
> submatrix of row 2)
> > Error is:
> > [0]PETSC ERROR: Argument out of range
> > [0]PETSC ERROR: New nonzero at (2,5) caused a malloc
> > Use MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE) to
> turn off this check
> > What is wrong with my understanding?
> > Thanks,
> > Florian
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170710/7f01cf16/attachment.html>
