[petsc-users] CPR-AMG: SNES with two cores worse than with one
    Robert Annewandter
    robert.annewandter at opengosim.com
    Fri Jul  7 15:11:25 CDT 2017
Thank you Hong!
I've used GMRES via
mpirun \
  -n ${NP} pflotran \
  -pflotranin ${INPUTFILE}.pflinput \
  -flow_ksp_type gmres \
  -flow_pc_type bjacobi \
  -flow_sub_pc_type lu \
  -flow_sub_pc_factor_nonzeros_along_diagonal \
  -snes_monitor
and get:
NP 1
FLOW TS BE steps =     43 newton =       43 linear =         43 cuts
=      0
FLOW TS BE Wasted Linear Iterations = 0
FLOW TS BE SNES time = 197.0 seconds
NP 2
FLOW TS BE steps =     43 newton =       43 linear =        770 cuts
=      0
FLOW TS BE SNES time = 68.7 seconds
Which looks ok to me.
Robert
On 07/07/17 15:49, hong at aspiritech.org wrote:
> What do you get with '-ksp_type gmres' or '-ksp_type bcgs' in parallel
> runs?
> Hong
> On Fri, Jul 7, 2017 at 6:05 AM, Robert Annewandter
> <robert.annewandter at opengosim.com
> <mailto:robert.annewandter at opengosim.com>> wrote:
>     Yes indeed, PFLOTRAN cuts timestep after 8 failed iterations of SNES.
>     I've rerun with -snes_monitor (attached with canonical suffix),
>     their -pc_type is always PCBJACOBI + PCLU (though we'd like to try
>     SUPERLU in the future, however it works only with -mat_type aij..)
>     The sequential and parallel runs I did  with
>         -ksp_type preonly -pc_type lu
>     -pc_factor_nonzeros_along_diagonal -snes_monitor
>     and
>         -ksp_type preonly -pc_type bjacobi -sub_pc_type lu
>     -sub_pc_factor_nonzeros_along_diagonal -snes_monitor
>     As expected, the sequential are bot identical and the parallel
>     takes half the time compared to sequential.
>     On 07/07/17 01:20, Barry Smith wrote:
>>        Looks like PFLOTRAN has a maximum number of SNES iterations as 8 and cuts the timestep if that fails.
>>        Please run with -snes_monitor I don't understand the strange densely packed information that PFLOTRAN is printing.
>>        It looks like the linear solver is converging fine in parallel, normally then there is absolutely no reason that the Newton should behave different on 2 processors than 1 unless there is something wrong with the Jacobian. What is the -pc_type for the two cases LU or your fancy thing?
>>        Please run sequential and parallel with -pc_type lu and also with -snes_monitor.  We need to fix all the knobs but one in order to understand what is going on.
>>        Barry
>>>     On Jul 6, 2017, at 5:11 PM, Robert Annewandter <robert.annewandter at opengosim.com>
>>>     <mailto:robert.annewandter at opengosim.com> wrote:
>>>     Thanks Barry!
>>>     I've attached log files for np = 1 (SNES time: 218 s) and np = 2 (SNES time: 600 s). PFLOTRAN final output:
>>>     NP 1
>>>     FLOW TS BE steps =     43 newton =       43 linear =         43 cuts =      0
>>>     FLOW TS BE SNES time = 218.9 seconds
>>>     NP 2
>>>     FLOW TS BE steps =     67 newton =      176 linear =        314 cuts =     13
>>>     FLOW TS BE Wasted Linear Iterations = 208
>>>     FLOW TS BE SNES time = 600.0 seconds
>>>     Robert
>>>     On 06/07/17 21:24, Barry Smith wrote:
>>>>        So on one process the outer linear solver takes a single iteration this is because the block Jacobi with LU and one block is a direct solver.
>>>>>         11 KSP preconditioned resid norm 1.131868956745e+00 true resid norm 1.526261825526e-05 ||r(i)||/||b|| 1.485509868409e-05
>>>>>     [0] KSPConvergedDefault(): Linear solver has converged. Residual norm 2.148515820410e-14 is less than relative tolerance 1.000000000000e-07 times initial right hand side norm 1.581814306485e-02 at iteration 1
>>>>>         1 KSP unpreconditioned resid norm 2.148515820410e-14 true resid norm 2.148698024622e-14 ||r(i)||/||b|| 1.358375642332e-12
>>>>        On two processes the outer linear solver takes a few iterations to solver, this is to be expected.
>>>>        But what you sent doesn't give any indication about SNES not converging. Please turn off all inner linear solver monitoring and just run with -ksp_monitor_true_residual -snes_monitor -snes_lineseach_monitor -snes_converged_reason
>>>>        Barry
>>>>>     On Jul 6, 2017, at 2:03 PM, Robert Annewandter <robert.annewandter at opengosim.com>
>>>>>      wrote:
>>>>>     Hi all,
>>>>>     I like to understand why the SNES of my CPR-AMG Two-Stage Preconditioner (with KSPFGMRES + multipl. PCComposite (PCGalerkin with KSPGMRES + BoomerAMG, PCBJacobi + PCLU init) on a 24,000 x 24,000 matrix) struggles to converge when using two cores instead of one. Because of the adaptive time stepping of the Newton, this leads to severe cuts in time step.
>>>>>     This is how I run it with two cores
>>>>>     mpirun \
>>>>>       -n 2 pflotran \
>>>>>       -pflotranin het.pflinput \
>>>>>       -ksp_monitor_true_residual \
>>>>>       -flow_snes_view \
>>>>>       -flow_snes_converged_reason \
>>>>>       -flow_sub_1_pc_type bjacobi \
>>>>>       -flow_sub_1_sub_pc_type lu \
>>>>>       -flow_sub_1_sub_pc_factor_pivot_in_blocks true\
>>>>>       -flow_sub_1_sub_pc_factor_nonzeros_along_diagonal \
>>>>>       -options_left \
>>>>>       -log_summary \
>>>>>       -info
>>>>>     With one core I get (after grepping the crap away from -info):
>>>>>      Step     32 Time=  1.80000E+01
>>>>>       0 2r: 1.58E-02 2x: 0.00E+00 2u: 0.00E+00 ir: 7.18E-03 iu: 0.00E+00 rsn:   0
>>>>>     [0] SNESComputeJacobian(): Rebuilding preconditioner
>>>>>         Residual norms for flow_ solve.
>>>>>         0 KSP unpreconditioned resid norm 1.581814306485e-02 true resid norm 1.581814306485e-02 ||r(i)||/||b|| 1.000000000000e+00
>>>>>           Residual norms for flow_sub_0_galerkin_ solve.
>>>>>           0 KSP preconditioned resid norm 5.697603110484e+07 true resid norm 5.175721849125e+03 ||r(i)||/||b|| 5.037527476892e+03
>>>>>           1 KSP preconditioned resid norm 5.041509073319e+06 true resid norm 3.251596928176e+02 ||r(i)||/||b|| 3.164777657484e+02
>>>>>           2 KSP preconditioned resid norm 1.043761838360e+06 true resid norm 8.957519558348e+01 ||r(i)||/||b|| 8.718349288342e+01
>>>>>           3 KSP preconditioned resid norm 1.129189815646e+05 true resid norm 2.722436912053e+00 ||r(i)||/||b|| 2.649746479496e+00
>>>>>           4 KSP preconditioned resid norm 8.829637298082e+04 true resid norm 8.026373593492e+00 ||r(i)||/||b|| 7.812065388300e+00
>>>>>           5 KSP preconditioned resid norm 6.506021637694e+04 true resid norm 3.479889319880e+00 ||r(i)||/||b|| 3.386974527698e+00
>>>>>           6 KSP preconditioned resid norm 6.392263200180e+04 true resid norm 3.819202631980e+00 ||r(i)||/||b|| 3.717228003987e+00
>>>>>           7 KSP preconditioned resid norm 2.464946645480e+04 true resid norm 7.329964753388e-01 ||r(i)||/||b|| 7.134251013911e-01
>>>>>           8 KSP preconditioned resid norm 2.603879153772e+03 true resid norm 2.035525412004e-02 ||r(i)||/||b|| 1.981175861414e-02
>>>>>           9 KSP preconditioned resid norm 1.774410462754e+02 true resid norm 3.001214973121e-03 ||r(i)||/||b|| 2.921081026352e-03
>>>>>         10 KSP preconditioned resid norm 1.664227038378e+01 true resid norm 3.413136309181e-04 ||r(i)||/||b|| 3.322003855903e-04
>>>>>     [0] KSPConvergedDefault(): Linear solver has converged. Residual norm 1.131868956745e+00 is less than relative tolerance 1.000000000000e-07 times initial right hand side norm 2.067297386780e+07 at iteration 11
>>>>>     [0] SNESSolve_NEWTONLS(): iter=0, linear solve iterations=1
>>>>>     [0] SNESNEWTONLSCheckResidual_Private(): ||J^T(F-Ax)||/||F-AX|| 3.590873180642e-01 near zero implies inconsistent rhs
>>>>>     [0] SNESSolve_NEWTONLS(): fnorm=1.5818143064846742e-02, gnorm=1.0695649833687331e-02, ynorm=4.6826522561266171e+02, lssucceed=0
>>>>>     [0] SNESConvergedDefault(): Converged due to small update length: 4.682652256127e+02 < 1.000000000000e-05 * 3.702480426117e+09
>>>>>       1 2r: 1.07E-02 2x: 3.70E+09 2u: 4.68E+02 ir: 5.05E-03 iu: 4.77E+01 rsn: stol
>>>>>     Nonlinear flow_ solve converged due to CONVERGED_SNORM_RELATIVE iterations 1
>>>>>     But with two cores I get:
>>>>>       0 2r: 6.16E-03 2x: 0.00E+00 2u: 0.00E+00 ir: 3.63E-03 iu: 0.00E+00 rsn:   0
>>>>>         0 KSP unpreconditioned resid norm 6.162760088924e-03 true resid norm 6.162760088924e-03 ||r(i)||/||b|| 1.000000000000e+00
>>>>>           0 KSP preconditioned resid norm 8.994949630499e+08 true resid norm 7.982144380936e-01 ||r(i)||/||b|| 1.000000000000e+00
>>>>>           1 KSP preconditioned resid norm 8.950556502615e+08 true resid norm 1.550138696155e+00 ||r(i)||/||b|| 1.942007839218e+00
>>>>>           2 KSP preconditioned resid norm 1.044849684205e+08 true resid norm 2.166193480531e+00 ||r(i)||/||b|| 2.713798920631e+00
>>>>>           3 KSP preconditioned resid norm 8.209708619718e+06 true resid norm 3.076045005154e-01 ||r(i)||/||b|| 3.853657436340e-01
>>>>>           4 KSP preconditioned resid norm 3.027461352422e+05 true resid norm 1.207731865714e-02 ||r(i)||/||b|| 1.513041869549e-02
>>>>>           5 KSP preconditioned resid norm 1.595302164817e+04 true resid norm 4.123713694368e-04 ||r(i)||/||b|| 5.166172769585e-04
>>>>>           6 KSP preconditioned resid norm 1.898935810797e+03 true resid norm 8.275885058330e-05 ||r(i)||/||b|| 1.036799719897e-04
>>>>>           7 KSP preconditioned resid norm 1.429881682558e+02 true resid norm 4.751240525466e-06 ||r(i)||/||b|| 5.952335987324e-06
>>>>>     [0] KSPConvergedDefault(): Linear solver has converged. Residual norm 8.404003313455e+00 is less than relative tolerance 1.000000000000e-07 times initial right hand side norm 8.994949630499e+08 at iteration 8
>>>>>           8 KSP preconditioned resid norm 8.404003313455e+00 true resid norm 3.841921844578e-07 ||r(i)||/||b|| 4.813145016211e-07
>>>>>         1 KSP unpreconditioned resid norm 6.162162548202e-03 true resid norm 6.162162548202e-03 ||r(i)||/||b|| 9.999030400804e-01
>>>>>           0 KSP preconditioned resid norm 4.360556381209e+07 true resid norm 1.000000245433e+00 ||r(i)||/||b|| 1.000000000000e+00
>>>>>           1 KSP preconditioned resid norm 5.385519331932e+06 true resid norm 8.785183939860e-02 ||r(i)||/||b|| 8.785181783689e-02
>>>>>           2 KSP preconditioned resid norm 4.728931283459e+05 true resid norm 2.008708805316e-02 ||r(i)||/||b|| 2.008708312313e-02
>>>>>           3 KSP preconditioned resid norm 2.734215698319e+04 true resid norm 6.418720397673e-03 ||r(i)||/||b|| 6.418718822309e-03
>>>>>           4 KSP preconditioned resid norm 1.002270029334e+04 true resid norm 4.040289515991e-03 ||r(i)||/||b|| 4.040288524372e-03
>>>>>           5 KSP preconditioned resid norm 1.321280190971e+03 true resid norm 1.023292238313e-04 ||r(i)||/||b|| 1.023291987163e-04
>>>>>           6 KSP preconditioned resid norm 6.594292964815e+01 true resid norm 1.877106733170e-06 ||r(i)||/||b|| 1.877106272467e-06
>>>>>           7 KSP preconditioned resid norm 7.816325147216e+00 true resid norm 2.552611664980e-07 ||r(i)||/||b|| 2.552611038486e-07
>>>>>     [0] KSPConvergedDefault(): Linear solver has converged. Residual norm 6.391568446109e-01 is less than relative tolerance 1.000000000000e-07 times initial right hand side norm 4.360556381209e+07 at iteration 8
>>>>>           8 KSP preconditioned resid norm 6.391568446109e-01 true resid norm 1.680724939670e-08 ||r(i)||/||b|| 1.680724527166e-08
>>>>>         2 KSP unpreconditioned resid norm 4.328902922753e-07 true resid norm 4.328902922752e-07 ||r(i)||/||b|| 7.024292460341e-05
>>>>>           0 KSP preconditioned resid norm 8.794597825780e+08 true resid norm 1.000000094566e+00 ||r(i)||/||b|| 1.000000000000e+00
>>>>>           1 KSP preconditioned resid norm 8.609906572102e+08 true resid norm 2.965044981249e+00 ||r(i)||/||b|| 2.965044700856e+00
>>>>>           2 KSP preconditioned resid norm 9.318108989314e+07 true resid norm 1.881262939380e+00 ||r(i)||/||b|| 1.881262761477e+00
>>>>>           3 KSP preconditioned resid norm 6.908723262483e+06 true resid norm 2.639592490398e-01 ||r(i)||/||b|| 2.639592240782e-01
>>>>>           4 KSP preconditioned resid norm 2.651677791227e+05 true resid norm 9.736480169584e-03 ||r(i)||/||b|| 9.736479248845e-03
>>>>>           5 KSP preconditioned resid norm 1.192178471172e+04 true resid norm 3.082839752692e-04 ||r(i)||/||b|| 3.082839461160e-04
>>>>>           6 KSP preconditioned resid norm 1.492201446262e+03 true resid norm 4.633866284506e-05 ||r(i)||/||b|| 4.633865846301e-05
>>>>>           7 KSP preconditioned resid norm 1.160670017241e+02 true resid norm 2.821157348522e-06 ||r(i)||/||b|| 2.821157081737e-06
>>>>>     [0] KSPConvergedDefault(): Linear solver has converged. Residual norm 6.447568262216e+00 is less than relative tolerance 1.000000000000e-07 times initial right hand side norm 8.794597825780e+08 at iteration 8
>>>>>           8 KSP preconditioned resid norm 6.447568262216e+00 true resid norm 1.516068561348e-07 ||r(i)||/||b|| 1.516068417980e-07
>>>>>     [0] KSPConvergedDefault(): Linear solver has converged. Residual norm 6.135731709822e-15 is less than relative tolerance 1.000000000000e-07 times initial right hand side norm 6.162760088924e-03 at iteration 3
>>>>>         3 KSP unpreconditioned resid norm 6.135731709822e-15 true resid norm 1.142020328809e-14 ||r(i)||/||b|| 1.853098793933e-12
>>>>>     [0] SNESSolve_NEWTONLS(): iter=0, linear solve iterations=3
>>>>>     [0] SNESNEWTONLSCheckResidual_Private(): ||J^T(F-Ax)||/||F-AX|| 1.998388224666e-02 near zero implies inconsistent rhs
>>>>>     [0] SNESSolve_NEWTONLS(): fnorm=6.1627600889243711e-03, gnorm=1.0406503258190572e-02, ynorm=6.2999025681245366e+04, lssucceed=0
>>>>>       1 2r: 1.04E-02 2x: 3.70E+09 2u: 6.30E+04 ir: 6.54E-03 iu: 5.00E+04 rsn:   0
>>>>>         0 KSP unpreconditioned resid norm 1.040650325819e-02 true resid norm 1.040650325819e-02 ||r(i)||/||b|| 1.000000000000e+00
>>>>>           0 KSP preconditioned resid norm 6.758906811264e+07 true resid norm 9.814998431686e-01 ||r(i)||/||b|| 1.000000000000e+00
>>>>>           1 KSP preconditioned resid norm 2.503922806424e+06 true resid norm 2.275130113021e-01 ||r(i)||/||b|| 2.318013730574e-01
>>>>>           2 KSP preconditioned resid norm 3.316753614870e+05 true resid norm 3.820733530238e-02 ||r(i)||/||b|| 3.892750016040e-02
>>>>>           3 KSP preconditioned resid norm 2.956751700483e+04 true resid norm 2.143772538677e-03 ||r(i)||/||b|| 2.184180215207e-03
>>>>>           4 KSP preconditioned resid norm 1.277067042524e+03 true resid norm 9.093614251311e-05 ||r(i)||/||b|| 9.265018547485e-05
>>>>>           5 KSP preconditioned resid norm 1.060996002446e+02 true resid norm 1.042893700050e-05 ||r(i)||/||b|| 1.062551061326e-05
>>>>>     [0] KSPConvergedDefault(): Linear solver has converged. Residual norm 5.058127343285e+00 is less than relative tolerance 1.000000000000e-07 times initial right hand side norm 6.758906811264e+07 at iteration 6
>>>>>           6 KSP preconditioned resid norm 5.058127343285e+00 true resid norm 4.054770602120e-07 ||r(i)||/||b|| 4.131198420807e-07
>>>>>     [0] KSPConvergedDefault(): Linear solver has converged. Residual norm 4.449606189225e-10 is less than relative tolerance 1.000000000000e-07 times initial right hand side norm 1.040650325819e-02 at iteration 1
>>>>>         1 KSP unpreconditioned resid norm 4.449606189225e-10 true resid norm 4.449606189353e-10 ||r(i)||/||b|| 4.275793779098e-08
>>>>>     [0] SNESSolve_NEWTONLS(): iter=1, linear solve iterations=1
>>>>>     [0] SNESNEWTONLSCheckResidual_Private(): ||J^T(F-Ax)||/||F-AX|| 4.300066663571e-02 near zero implies inconsistent rhs
>>>>>     [0] SNESSolve_NEWTONLS(): fnorm=1.0406503258190572e-02, gnorm=7.3566280848133728e-02, ynorm=7.9500485128639993e+04, lssucceed=0
>>>>>       2 2r: 7.36E-02 2x: 3.70E+09 2u: 7.95E+04 ir: 4.62E-02 iu: 5.00E+04 rsn:   0
>>>>>         0 KSP unpreconditioned resid norm 7.356628084813e-02 true resid norm 7.356628084813e-02 ||r(i)||/||b|| 1.000000000000e+00
>>>>>           0 KSP preconditioned resid norm 7.253424029194e+06 true resid norm 9.647008645250e-01 ||r(i)||/||b|| 1.000000000000e+00
>>>>>           1 KSP preconditioned resid norm 7.126940190688e+06 true resid norm 1.228009197928e+00 ||r(i)||/||b|| 1.272942984800e+00
>>>>>           2 KSP preconditioned resid norm 9.391591432635e+05 true resid norm 7.804929162756e-01 ||r(i)||/||b|| 8.090517433711e-01
>>>>>           3 KSP preconditioned resid norm 6.538499674761e+04 true resid norm 5.503467432893e-02 ||r(i)||/||b|| 5.704843475602e-02
>>>>>           4 KSP preconditioned resid norm 1.593713396575e+04 true resid norm 8.902701363763e-02 ||r(i)||/||b|| 9.228457951208e-02
>>>>>           5 KSP preconditioned resid norm 4.837260621464e+02 true resid norm 2.966772992825e-03 ||r(i)||/||b|| 3.075329464213e-03
>>>>>           6 KSP preconditioned resid norm 1.681372767335e+02 true resid norm 5.312467443025e-04 ||r(i)||/||b|| 5.506854651406e-04
>>>>>           7 KSP preconditioned resid norm 1.271478850717e+01 true resid norm 2.123810020488e-05 ||r(i)||/||b|| 2.201521838103e-05
>>>>>           8 KSP preconditioned resid norm 1.262723712696e+00 true resid norm 1.150572715331e-06 ||r(i)||/||b|| 1.192673042641e-06
>>>>>     [0] KSPConvergedDefault(): Linear solver has converged. Residual norm 9.053072585125e-02 is less than relative tolerance 1.000000000000e-07 times initial right hand side norm 7.253424029194e+06 at iteration 9
>>>>>           9 KSP preconditioned resid norm 9.053072585125e-02 true resid norm 9.475050575058e-08 ||r(i)||/||b|| 9.821749853747e-08
>>>>>         1 KSP unpreconditioned resid norm 8.171589173162e-03 true resid norm 8.171589173162e-03 ||r(i)||/||b|| 1.110779161180e-01
>>>>>           0 KSP preconditioned resid norm 4.345765068989e+07 true resid norm 9.999992231691e-01 ||r(i)||/||b|| 1.000000000000e+00
>>>>>           1 KSP preconditioned resid norm 5.388715093466e+06 true resid norm 8.125387327699e-02 ||r(i)||/||b|| 8.125393639755e-02
>>>>>           2 KSP preconditioned resid norm 4.763725726436e+05 true resid norm 2.464285618036e-02 ||r(i)||/||b|| 2.464287532371e-02
>>>>>           3 KSP preconditioned resid norm 2.287746683380e+04 true resid norm 7.224823080100e-03 ||r(i)||/||b|| 7.224828692570e-03
>>>>>           4 KSP preconditioned resid norm 4.872858764091e+03 true resid norm 3.972261388893e-03 ||r(i)||/||b|| 3.972264474670e-03
>>>>>           5 KSP preconditioned resid norm 8.670449895323e+02 true resid norm 2.359005963873e-04 ||r(i)||/||b|| 2.359007796423e-04
>>>>>           6 KSP preconditioned resid norm 4.252589693890e+01 true resid norm 1.471904261226e-06 ||r(i)||/||b|| 1.471905404648e-06
>>>>>           7 KSP preconditioned resid norm 5.128476471782e+00 true resid norm 1.643725157865e-07 ||r(i)||/||b|| 1.643726434763e-07
>>>>>     [0] KSPConvergedDefault(): Linear solver has converged. Residual norm 4.311901915856e-01 is less than relative tolerance 1.000000000000e-07 times initial right hand side norm 4.345765068989e+07 at iteration 8
>>>>>           8 KSP preconditioned resid norm 4.311901915856e-01 true resid norm 1.166123921637e-08 ||r(i)||/||b|| 1.166124827519e-08
>>>>>     [0] KSPConvergedDefault(): Linear solver has converged. Residual norm 2.373662391739e-09 is less than relative tolerance 1.000000000000e-07 times initial right hand side norm 7.356628084813e-02 at iteration 2
>>>>>         2 KSP unpreconditioned resid norm 2.373662391739e-09 true resid norm 2.373662391658e-09 ||r(i)||/||b|| 3.226562990941e-08
>>>>>     [0] SNESSolve_NEWTONLS(): iter=2, linear solve iterations=2
>>>>>     [0] SNESNEWTONLSCheckResidual_Private(): ||J^T(F-Ax)||/||F-AX|| 4.343326231305e-02 near zero implies inconsistent rhs
>>>>>     [0] SNESSolve_NEWTONLS(): fnorm=7.3566280848133728e-02, gnorm=7.2259942496422647e-02, ynorm=6.3156901950486099e+04, lssucceed=0
>>>>>       3 2r: 7.23E-02 2x: 3.70E+09 2u: 6.32E+04 ir: 4.52E-02 iu: 5.00E+04 rsn:   0
>>>>>         0 KSP unpreconditioned resid norm 7.225994249642e-02 true resid norm 7.225994249642e-02 ||r(i)||/||b|| 1.000000000000e+00
>>>>>           0 KSP preconditioned resid norm 7.705582590638e+05 true resid norm 9.649751442741e-01 ||r(i)||/||b|| 1.000000000000e+00
>>>>>           1 KSP preconditioned resid norm 2.444424220392e+04 true resid norm 8.243110200738e-03 ||r(i)||/||b|| 8.542303135630e-03
>>>>>           2 KSP preconditioned resid norm 2.080899648412e+03 true resid norm 7.642343147053e-04 ||r(i)||/||b|| 7.919730567570e-04
>>>>>           3 KSP preconditioned resid norm 9.911171129874e+02 true resid norm 5.904182179180e-05 ||r(i)||/||b|| 6.118481096859e-05
>>>>>           4 KSP preconditioned resid norm 5.258230282482e+02 true resid norm 2.043366677644e-04 ||r(i)||/||b|| 2.117532964210e-04
>>>>>           5 KSP preconditioned resid norm 5.522830460456e+01 true resid norm 1.710780366056e-05 ||r(i)||/||b|| 1.772875059225e-05
>>>>>           6 KSP preconditioned resid norm 5.922280741715e+00 true resid norm 1.543198740828e-06 ||r(i)||/||b|| 1.599210870855e-06
>>>>>           7 KSP preconditioned resid norm 3.339500859115e-01 true resid norm 1.221335666427e-07 ||r(i)||/||b|| 1.265665414984e-07
>>>>>     [0] KSPConvergedDefault(): Linear solver has converged. Residual norm 3.329208597672e-02 is less than relative tolerance 1.000000000000e-07 times initial right hand side norm 7.705582590638e+05 at iteration 8
>>>>>           8 KSP preconditioned resid norm 3.329208597672e-02 true resid norm 9.758240835324e-09 ||r(i)||/||b|| 1.011242713683e-08
>>>>>     [0] KSPConvergedDefault(): Linear solver has converged. Residual norm 2.697128456432e-11 is less than relative tolerance 1.000000000000e-07 times initial right hand side norm 7.225994249642e-02 at iteration 1
>>>>>         1 KSP unpreconditioned resid norm 2.697128456432e-11 true resid norm 2.697128457142e-11 ||r(i)||/||b|| 3.732536124389e-10
>>>>>     [0] SNESSolve_NEWTONLS(): iter=3, linear solve iterations=1
>>>>>     [0] SNESNEWTONLSCheckResidual_Private(): ||J^T(F-Ax)||/||F-AX|| 4.329227684222e-02 near zero implies inconsistent rhs
>>>>>     [0] SNESSolve_NEWTONLS(): fnorm=7.2259942496422647e-02, gnorm=5.4435602192925014e-01, ynorm=2.7049750229137400e+04, lssucceed=0
>>>>>     [0] SNESConvergedDefault(): Converged due to small update length: 2.704975022914e+04 < 1.000000000000e-05 * 3.702469482296e+09
>>>>>       4 2r: 5.44E-01 2x: 3.70E+09 2u: 2.70E+04 ir: 3.84E-01 iu: 2.34E+04 rsn: stol
>>>>>     Nonlinear flow_ solve converged due to CONVERGED_SNORM_RELATIVE iterations 4
>>>>>     As the simulation advances this behaviour leads to frequent time step cuts because of 8 subsequently failed Newton iterations, which brings the simulation practically to a halt.
>>>>>     Is the Block Jacobi not a good choice? Better ASM with huge overlap? Or is there something wrong with my RHS? Maybe the SNES, SNESLS, KSP tolerances need better tuning?
>>>>>     Grateful for any clarifying words!
>>>>>     Robert
>>>>>     My SNES_view is:
>>>>>     SNES Object: (flow_) 2 MPI processes
>>>>>       type: newtonls
>>>>>       maximum iterations=8, maximum function evaluations=10000
>>>>>       tolerances: relative=1e-05, absolute=1e-05, solution=1e-05
>>>>>       total number of linear solver iterations=1
>>>>>       total number of function evaluations=2
>>>>>       norm schedule ALWAYS
>>>>>       SNESLineSearch Object: (flow_) 2 MPI processes
>>>>>         type: basic
>>>>>         maxstep=1.000000e+08, minlambda=1.000000e-05
>>>>>         tolerances: relative=1.000000e-05, absolute=1.000000e-05, lambda=1.000000e-08
>>>>>         maximum iterations=40
>>>>>         using user-defined precheck step
>>>>>       KSP Object: (flow_) 2 MPI processes
>>>>>         type: fgmres
>>>>>           GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
>>>>>           GMRES: happy breakdown tolerance 1e-30
>>>>>         maximum iterations=200, initial guess is zero
>>>>>         tolerances:  relative=1e-07, absolute=1e-50, divergence=10000.
>>>>>         right preconditioning
>>>>>         using UNPRECONDITIONED norm type for convergence test
>>>>>       PC Object: (flow_) 2 MPI processes
>>>>>         type: composite
>>>>>         Composite PC type - MULTIPLICATIVE
>>>>>         PCs on composite preconditioner follow
>>>>>           PC Object: (flow_sub_0_) 2 MPI processes
>>>>>             type: galerkin
>>>>>             Galerkin PC
>>>>>             KSP on Galerkin follow
>>>>>             KSP Object: (flow_sub_0_galerkin_) 2 MPI processes
>>>>>               type: gmres
>>>>>               left preconditioning
>>>>>               using PRECONDITIONED norm type for convergence test
>>>>>             PC Object: (flow_sub_0_galerkin_) 2 MPI processes
>>>>>               type: hypre
>>>>>                 HYPRE BoomerAMG preconditioning
>>>>>                 HYPRE BoomerAMG: Cycle type V
>>>>>                 HYPRE BoomerAMG: Maximum number of levels 25
>>>>>                 HYPRE BoomerAMG: Maximum number of iterations PER hypre call 1
>>>>>                 HYPRE BoomerAMG: Convergence tolerance PER hypre call 0.
>>>>>                 HYPRE BoomerAMG: Threshold for strong coupling 0.25
>>>>>                 HYPRE BoomerAMG: Interpolation truncation factor 0.
>>>>>                 HYPRE BoomerAMG: Interpolation: max elements per row 0
>>>>>                 HYPRE BoomerAMG: Number of levels of aggressive coarsening 0
>>>>>                 HYPRE BoomerAMG: Number of paths for aggressive coarsening 1
>>>>>                 HYPRE BoomerAMG: Maximum row sums 0.9
>>>>>                 HYPRE BoomerAMG: Sweeps down         1
>>>>>                 HYPRE BoomerAMG: Sweeps up           1
>>>>>                 HYPRE BoomerAMG: Sweeps on coarse    1
>>>>>                 HYPRE BoomerAMG: Relax down          symmetric-SOR/Jacobi
>>>>>                 HYPRE BoomerAMG: Relax up            symmetric-SOR/Jacobi
>>>>>                 HYPRE BoomerAMG: Relax on coarse     Gaussian-elimination
>>>>>                 HYPRE BoomerAMG: Relax weight  (all)      1.
>>>>>                 HYPRE BoomerAMG: Outer relax weight (all) 1.
>>>>>                 HYPRE BoomerAMG: Using CF-relaxation
>>>>>                 HYPRE BoomerAMG: Not using more complex smoothers.
>>>>>                 HYPRE BoomerAMG: Measure type        local
>>>>>                 HYPRE BoomerAMG: Coarsen type        Falgout
>>>>>                 HYPRE BoomerAMG: Interpolation type  classical
>>>>>               linear system matrix = precond matrix:
>>>>>               Mat Object: 2 MPI processes
>>>>>                 type: mpiaij
>>>>>                 rows=8000, cols=8000
>>>>>                 total: nonzeros=53600, allocated nonzeros=53600
>>>>>                 total number of mallocs used during MatSetValues calls =0
>>>>>                   not using I-node (on process 0) routines
>>>>>             Mat Object: (flow_) 2 MPI processes
>>>>>               type: mpibaij
>>>>>               rows=24000, cols=24000, bs=3
>>>>>               total: nonzeros=482400, allocated nonzeros=482400
>>>>>           PC Object: (flow_sub_1_) 2 MPI processes
>>>>>             type: bjacobi
>>>>>               block Jacobi: number of blocks = 2
>>>>>               Local solve is same for all blocks, in the following KSP and PC objects:
>>>>>             KSP Object: (flow_sub_1_sub_) 1 MPI processes
>>>>>               type: preonly
>>>>>               maximum iterations=10000, initial guess is zero
>>>>>               tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.     <------ not working: -flow_sub_1_sub_ksp_rtol 1e-7
>>>>>               using NONE norm type for convergence test
>>>>>             PC Object: (flow_sub_1_sub_) 1 MPI processes
>>>>>               type: lu
>>>>>                 out-of-place factorization
>>>>>                 tolerance for zero pivot 2.22045e-14
>>>>>                 matrix ordering: nd
>>>>>                 factor fill ratio given 5., needed 18.3108
>>>>>                   Factored matrix follows:
>>>>>                     Mat Object: 1 MPI processes
>>>>>                       type: seqbaij
>>>>>                       rows=12000, cols=12000, bs=3
>>>>>                       package used to perform factorization: petsc
>>>>>                       total: nonzeros=4350654, allocated nonzeros=4350654
>>>>>                           block size is 3
>>>>>               Mat Object: (flow_) 1 MPI processes
>>>>>                 type: seqbaij
>>>>>                 total: nonzeros=237600, allocated nonzeros=237600
>>>>>                     block size is 3
>>>>>               type: mpibaij
>>>>>           type: mpibaij
>>>     <het_np_1.log><het_np_2.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170707/96f53172/attachment-0001.html>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170707/96f53172/attachment-0002.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170707/96f53172/attachment-0003.bin>
