[petsc-users] Understanding preallocation for MPI
Dave May dave.mayhem23 at gmail.com
Fri Jul 7 04:49:39 CDT 2017
On Fri, 7 Jul 2017 at 11:31, Florian Lindner <mailinglists at xgm.de> wrote:
> Hello,
> I'm having some struggle understanding the preallocation for MPIAIJ
> matrices, especially when a value is in off-diagonal
> vs. diagonal block.
> The small example program is at https://pastebin.com/67dXnGm3
> In general it should be parallel, but right now I just run it in serial.
When you run this code in serial, the mat type will be MATSEQAIJ. Hence,
the call to MatMPIAIJSetPreallocation() will have no effect because the mat
type does not match MPIAIJ. As a result, your code doesn't perform any
preallocation for SEQAIJ matrices.
In addition to calling MatMPIAIJSetPreallocation(), add a call to
MatSEQAIJSetPreallocation.
  Dave
> According to my understanding of
> http://www.mcs.anl.gov/petsc/petsc-3.7/docs/manualpages/Mat/MatMPIAIJSetPreallocation.html
> a entry is in the diagonal submatrix, if its row is in the OwnershipRange
> and its column is in OwnershipRangeColumn.
> That also means that in a serial run, there is only a diagonal submatrix.
> However, having MAT_NEW_NONZERO_ALLOCATION_ERR set, I get an error when
> Inserting 6 elements in row 2, though I have exactly
> 2 o_nnz = 0, d_nnz = 6 (means 6 elements allocated in the diagonal
> submatrix of row 2)
> Error is:
> [0]PETSC ERROR: Argument out of range
> [0]PETSC ERROR: New nonzero at (2,5) caused a malloc
> Use MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE) to turn
> off this check
> What is wrong with my understanding?
> Thanks,
> Florian
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170707/2dd5c9db/attachment.html>
