[petsc-users] Is OpenMP still available for PETSc?
Damian Kaliszan damian at man.poznan.pl
Mon Jul 3 09:23:17 CDT 2017
>> 1) You can call Bcast on PETSC_COMM_WORLD
To  be  honest  I  can't find Bcast method in petsc4py.PETSc.Comm (I'm
using petsc4py)
>> 2) If you are using WORLD, the number of iterates will be the same on each process since iteration is collective.
Yes,  this  is  how  it  should  be.  But  what  I noticed is that for
different  --cpus-per-task  numbers  in  slurm  script I get different
number  of  solver iterations which is in turn related to timings. The
imparity    is    huge.  For  example  for   some configurations where  --cpus-per-task=1 I receive 900
iterations and  for --cpus-per-task=2 I receive valid number of 100.000 which is set as max
iter number set when setting solver tolerances.
Best,
Damian
