[petsc-users] Is OpenMP still available for PETSc?
Mon Jul 3 08:50:17 CDT 2017
On Mon, Jul 3, 2017 at 8:47 AM, Damian Kaliszan <damian at man.poznan.pl>
wrote:
> Hi,
> I use MPI.COMM_WORLD as communicator because I use bcast to send around
> some other info to all processes before reading in the matrices and running
> solver.
> (I can't call bcast on PETSc.COMM_WORLD).
1) You can call Bcast on PETSC_COMM_WORLD
2) If you are using WORLD, the number of iterates will be the same on each
process since iteration is collective.
    Matt
> Best,
> Damian
> W liście datowanym 3 lipca 2017 (15:14:10) napisano:
> On Mon, Jul 3, 2017 at 4:18 AM, Damian Kaliszan <damian at man.poznan.pl>
> wrote:
> Hi,
> OK. So this is clear now.
> Maybe    you    will  be able to help the answer the question I raised
> some time ago, why, when
> submitting   a   slurm   job   and   setting   different   number   of
> --cpus-per-task,  the  execution  times of ksp solver
> (gmres type) vary when max number of iterations set to 100.000
> and ksp, when finished, returns ksp.getIterationNumber() (in petsc4py)
> equal to 900 (for some cases) and 100.000 for other.
> It  looks  like  number of cpus per task influence the number of steps
> the solver solves the equation. Is it possible at all?
> If you have one solver executing on the whole communicator,
> PETSC_COMM_WORLD,
> all processes will report the same number of iterates. If you have
> independent, serial
> solvers on each process, PETSC_COMM_SELF, they can report different
> numbers of iterates
> depending on the convergence criteria.
>  Matt
> Best,
> Damian
> W liście datowanym 1 lipca 2017 (22:23:19) napisano:
> >> On Jul 1, 2017, at 3:15 PM, Damian Kaliszan <damian at man.poznan.pl>
> wrote:
> >> Hi,
> >> So... - - with-openmp=0/1 configuration option seems to be useless?...
> >    It merely enables the compiler flags for compiling with OpenMP;
> > for example if your code has OpenMP in it.
> >> In one of my previous messages I wrote that, when openmp enabled, and
> OMP_NUM_THREADS set, I notice different timings for ksp solver. Strange....?
> >    For the PETSc part yes number of threads shouldn't matter since PETSc
> would only use 1.
> >> Best,
> >> Damian
> >> W dniu 1 lip 2017, o 00:50, użytkownik Barry Smith <bsmith at mcs.anl.gov>
> napisał:
> >>   The current version of PETSc does not use OpenMP, you are free to use
> OpenMP in your portions of the code of course. If you want PETSc using
> OpenMP you have to use the old, unsupported version of PETSc. We never
> found any benefit to using OpenMP.
> >>    Barry
> >>  On Jun 30, 2017, at 5:40 PM, Danyang Su <danyang.su at gmail.com> wrote:
> >>  Dear All,
> >>  I recalled there was OpenMP available for PETSc for the old
> development version. When google "petsc hybrid mpi openmp", there returned
> some papers about this feature. My code was first parallelized using OpenMP
> and then redeveloped using PETSc, with OpenMP kept but not used together
> with MPI. Before retesting the code using hybrid mpi-openmp, I picked one
> PETSc example ex10 by adding "omp_set_num_threads(max_threads);" under
> PetscInitialize.
> >>  The PETSc is the current development version configured as follows
> >>  --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --with-debugging=0
> --CFLAGS=-fopenmp --CXXFLAGS=-fopenmp --FFLAGS=-fopenmp COPTFLAGS="-O3
> -march=native -mtune=native" CXXOPTFLAGS="-O3 -march=native -mtune=native"
> FOPTFLAGS="-O3 -march=native -mtune=native" --with-large-file-io=1
> --download-cmake=yes --download-mumps --download-scalapack
> --download-parmetis --download-metis --download-ptscotch
> --download-fblaslapack --download-mpich --download-hypre
> --download-superlu_dist --download-hdf5=yes --with-openmp --with-threadcomm
> --with-pthreadclasses --with-openmpclasses
> >>  The code can be successfully compiled. However, when I run the code
> with OpenMP, it does not work, the time shows no change in performance if 1
> or 2 threads per processor is used. Also, the CPU/Threads usage indicates
> that no thread is used.
> >>  I just wonder if OpenMP is still available in the latest version,
> though it is not recommended to use.
> >>  mpiexec -n 2 ./ex10 -f0 mat_rhs_pc_nonzero/a_react_in_2.bin -rhs
> mat_rhs_pc_nonzero/b_react_in_2.bin -ksp_rtol 1.0e-20 -ksp_monitor
> -ksp_error_if_not_converged -sub_pc_factor_shift_type nonzero -mat_view
> ascii::ascii_info -log_view -max_threads 1 -threadcomm_type openmp
> -threadcomm_nthreads 1
> >>  KSPSolve               1 1.0 8.9934e-01 1.0 1.03e+09 1.0 7.8e+01
> 3.6e+04 7.8e+01 69 97 89  6 76  89 97 98 98 96  2290
> >>  PCSetUp                2 1.0 8.9590e-02 1.0 2.91e+07 1.0 0.0e+00
> 0.0e+00 0.0e+00  7  3  0  0  0   9  3  0  0  0   648
> >>  PCSetUpOnBlocks        2 1.0 8.9465e-02 1.0 2.91e+07 1.0 0.0e+00
> 0.0e+00 0.0e+00  7  3  0  0  0   9  3  0  0  0   649
> >>  PCApply               40 1.0 3.1993e-01 1.0 2.70e+08 1.0 0.0e+00
> 0.0e+00 0.0e+00 24 25  0  0  0  32 25  0  0  0  1686
> ascii::ascii_info -log_view -max_threads 2 -threadcomm_type openmp
> -threadcomm_nthreads 2
> >>  KSPSolve               1 1.0 8.9701e-01 1.0 1.03e+09 1.0 7.8e+01
> 3.6e+04 7.8e+01 69 97 89  6 76  89 97 98 98 96  2296
> >>  PCSetUp                2 1.0 8.7635e-02 1.0 2.91e+07 1.0 0.0e+00
> 0.0e+00 0.0e+00  7  3  0  0  0   9  3  0  0  0   663
> >>  PCSetUpOnBlocks        2 1.0 8.7511e-02 1.0 2.91e+07 1.0 0.0e+00
> 0.0e+00 0.0e+00  7  3  0  0  0   9  3  0  0  0   664
> >>  PCApply               40 1.0 3.1878e-01 1.0 2.70e+08 1.0 0.0e+00
> 0.0e+00 0.0e+00 24 25  0  0  0  32 25  0  0  0  1692
> >>  Thanks and regards,
> >>  Danyang
> >>  <ex10.c><makefile.txt>
experiments lead.
-- Norbert Wiener
http://www.caam.rice.edu/~mk51/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170703/c944863d/attachment-0001.html>
