[petsc-users] Is OpenMP still available for PETSc?
Damian Kaliszan
damian at man.poznan.pl
Sat Jul 1 15:15:46 CDT 2017
So... - - with-openmp=0/1 configuration option seems to be useless?...
In one of my previous messages I wrote that, when openmp enabled, and OMP_NUM_THREADS set, I notice different timings for ksp solver. Strange....?
Best,
Damian
W dniu 1 lip 2017, 00:50, o 00:50, użytkownik Barry Smith <bsmith at mcs.anl.gov> napisał:
>The current version of PETSc does not use OpenMP, you are free to use
>OpenMP in your portions of the code of course. If you want PETSc using
>OpenMP you have to use the old, unsupported version of PETSc. We never
>found any benefit to using OpenMP.
> Barry
>> On Jun 30, 2017, at 5:40 PM, Danyang Su <danyang.su at gmail.com> wrote:
>> Dear All,
>> I recalled there was OpenMP available for PETSc for the old
>development version. When google "petsc hybrid mpi openmp", there
>returned some papers about this feature. My code was first parallelized
>using OpenMP and then redeveloped using PETSc, with OpenMP kept but not
>used together with MPI. Before retesting the code using hybrid
>mpi-openmp, I picked one PETSc example ex10 by adding
>"omp_set_num_threads(max_threads);" under PetscInitialize.
>> The PETSc is the current development version configured as follows
>> --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --with-debugging=0
>--CFLAGS=-fopenmp --CXXFLAGS=-fopenmp --FFLAGS=-fopenmp COPTFLAGS="-O3
>-march=native -mtune=native" CXXOPTFLAGS="-O3 -march=native
>-mtune=native" FOPTFLAGS="-O3 -march=native -mtune=native"
>--with-large-file-io=1 --download-cmake=yes --download-mumps
>--download-scalapack --download-parmetis --download-metis
>--download-ptscotch --download-fblaslapack --download-mpich
>--download-hypre --download-superlu_dist --download-hdf5=yes
>--with-openmp --with-threadcomm --with-pthreadclasses
>--with-openmpclasses
>> The code can be successfully compiled. However, when I run the code
>with OpenMP, it does not work, the time shows no change in performance
>if 1 or 2 threads per processor is used. Also, the CPU/Threads usage
>indicates that no thread is used.
>> I just wonder if OpenMP is still available in the latest version,
>though it is not recommended to use.
>> mpiexec -n 2 ./ex10 -f0 mat_rhs_pc_nonzero/a_react_in_2.bin -rhs
>mat_rhs_pc_nonzero/b_react_in_2.bin -ksp_rtol 1.0e-20 -ksp_monitor
>-ksp_error_if_not_converged -sub_pc_factor_shift_type nonzero -mat_view
>ascii::ascii_info -log_view -max_threads 1 -threadcomm_type openmp
>-threadcomm_nthreads 1
>> KSPSolve 1 1.0 8.9934e-01 1.0 1.03e+09 1.0 7.8e+01
>3.6e+04 7.8e+01 69 97 89 6 76 89 97 98 98 96 2290
>> PCSetUp 2 1.0 8.9590e-02 1.0 2.91e+07 1.0 0.0e+00
>0.0e+00 0.0e+00 7 3 0 0 0 9 3 0 0 0 648
>> PCSetUpOnBlocks 2 1.0 8.9465e-02 1.0 2.91e+07 1.0 0.0e+00
>0.0e+00 0.0e+00 7 3 0 0 0 9 3 0 0 0 649
>> PCApply 40 1.0 3.1993e-01 1.0 2.70e+08 1.0 0.0e+00
>0.0e+00 0.0e+00 24 25 0 0 0 32 25 0 0 0 1686
>ascii::ascii_info -log_view -max_threads 2 -threadcomm_type openmp
>-threadcomm_nthreads 2
>> KSPSolve 1 1.0 8.9701e-01 1.0 1.03e+09 1.0 7.8e+01
>3.6e+04 7.8e+01 69 97 89 6 76 89 97 98 98 96 2296
>> PCSetUp 2 1.0 8.7635e-02 1.0 2.91e+07 1.0 0.0e+00
>0.0e+00 0.0e+00 7 3 0 0 0 9 3 0 0 0 663
>> PCSetUpOnBlocks 2 1.0 8.7511e-02 1.0 2.91e+07 1.0 0.0e+00
>0.0e+00 0.0e+00 7 3 0 0 0 9 3 0 0 0 664
>> PCApply 40 1.0 3.1878e-01 1.0 2.70e+08 1.0 0.0e+00
>0.0e+00 0.0e+00 24 25 0 0 0 32 25 0 0 0 1692
>> Thanks and regards,
>> Danyang
>> <ex10.c><makefile.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170701/8ed03c36/attachment.html>
