[petsc-users] monitoring the convergence of fieldsplit 0 and 1
Klaij, Christiaan C.Klaij at marin.nl
Mon Jan 16 01:47:33 CST 2017
Barry,
Sure, here's the output with:
-sys_ksp_view -sys_ksp_converged_reason -sys_fieldsplit_0_ksp_converged_reason -sys_fieldsplit_1_ksp_converged_reason
(In my previous email, I rearranged 0 & 1 for easy summing.)
Chris
  Linear sys_fieldsplit_0_ solve converged due to CONVERGED_RTOL iterations 1
  Linear sys_fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 22
  Linear sys_fieldsplit_0_ solve converged due to CONVERGED_RTOL iterations 2
  Linear sys_fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 6
  Linear sys_fieldsplit_0_ solve converged due to CONVERGED_RTOL iterations 7
  Linear sys_fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 3
  Linear sys_fieldsplit_0_ solve converged due to CONVERGED_RTOL iterations 8
Linear sys_ solve converged due to CONVERGED_RTOL iterations 6
KSP Object:(sys_) 1 MPI processes
  type: fgmres
    GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
    GMRES: happy breakdown tolerance 1e-30
  maximum iterations=300, initial guess is zero
  tolerances:  relative=0.01, absolute=1e-50, divergence=10000.
  right preconditioning
  using UNPRECONDITIONED norm type for convergence test
PC Object:(sys_) 1 MPI processes
  type: fieldsplit
    FieldSplit with Schur preconditioner, factorization FULL
    Preconditioner for the Schur complement formed from Sp, an assembled approximation to S, which uses (lumped, if requested) A00's diagonal's inverse
    Split info:
    Split number 0 Defined by IS
    Split number 1 Defined by IS
    KSP solver for A00 block
      KSP Object:      (sys_fieldsplit_0_)       1 MPI processes
        type: gmres
        maximum iterations=10000, initial guess is zero
      PC Object:      (sys_fieldsplit_0_)       1 MPI processes
        type: ilu
          ILU: out-of-place factorization
          0 levels of fill
          tolerance for zero pivot 2.22045e-14
          matrix ordering: natural
          factor fill ratio given 1., needed 1.
            Factored matrix follows:
              Mat Object:               1 MPI processes
                type: seqaij
                rows=9600, cols=9600
                package used to perform factorization: petsc
                total: nonzeros=47280, allocated nonzeros=47280
                total number of mallocs used during MatSetValues calls =0
                  not using I-node routines
        linear system matrix = precond matrix:
        Mat Object:        (sys_fieldsplit_0_)         1 MPI processes
          type: seqaij
    KSP solver for upper A00 in upper triangular factor
      KSP Object:      (sys_fieldsplit_1_upper_)       1 MPI processes
        type: preonly
        tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
        left preconditioning
        using NONE norm type for convergence test
      PC Object:      (sys_fieldsplit_1_upper_)       1 MPI processes
        type: jacobi
          type: seqaij
    KSP solver for S = A11 - A10 inv(A00) A01
      KSP Object:      (sys_fieldsplit_1_)       1 MPI processes
        type: gmres
      PC Object:      (sys_fieldsplit_1_)       1 MPI processes
        type: ilu
          0 levels of fill
                type: seqaij
                rows=3200, cols=3200
                total: nonzeros=40404, allocated nonzeros=40404
        linear system matrix followed by preconditioner matrix:
        Mat Object:        (sys_fieldsplit_1_)         1 MPI processes
          type: schurcomplement
            Schur complement A11 - A10 inv(A00) A01
            A11
                type: seqaij
            A10
                type: seqaij
                rows=3200, cols=9600
            KSP of A00
              KSP Object:              (sys_fieldsplit_1_inner_)               1 MPI processes
                type: preonly
              PC Object:              (sys_fieldsplit_1_inner_)               1 MPI processes
                type: jacobi
                  type: seqaij
            A01
                type: seqaij
                rows=9600, cols=3200
          type: seqaij
    type: nest
    rows=12800, cols=12800
      Matrix object:
        type=nest, rows=2, cols=2
        MatNest structure:
        (0,0) : prefix="mom_", type=seqaij, rows=9600, cols=9600
        (0,1) : prefix="grad_", type=seqaij, rows=9600, cols=3200
        (1,0) : prefix="div_", type=seqaij, rows=3200, cols=9600
        (1,1) : prefix="stab_", type=seqaij, rows=3200, cols=3200
    type: nest
      Matrix object:
        MatNest structure:
        (0,0) : prefix="sys_fieldsplit_0_", type=seqaij, rows=9600, cols=9600
        (0,1) : type=seqaij, rows=9600, cols=3200
        (1,0) : type=seqaij, rows=3200, cols=9600
        (1,1) : prefix="sys_fieldsplit_1_", type=seqaij, rows=3200, cols=3200
 nusediter_vv          37
 nusediter_pp          37
dr. ir. Christiaan Klaij  | CFD Researcher | Research & Development
MARIN | T +31 317 49 33 44 | mailto:C.Klaij at marin.nl | http://www.marin.nl
MARIN news: http://www.marin.nl/web/News/News-items/The-Ocean-Cleanup-testing-continues.htm
Sent: Friday, January 13, 2017 7:51 PM
To: Klaij, Christiaan
Cc: petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] monitoring the convergence of fieldsplit 0 and 1
   Yes, I would have expected this to work. Could you send the output from -ksp_view in this case?
> On Jan 13, 2017, at 3:46 AM, Klaij, Christiaan <C.Klaij at marin.nl> wrote:
> Barry,
> It's been a while but I'm finally using this function in
> 3.7.4. Is it supposed to work with fieldsplit? Here's why.
> I'm solving a Navier-Stokes system with fieldsplit (pc has one
> velocity solve and one pressure solve) and trying to retrieve the
> totals like this:
>  CALL KSPSolve(ksp_system,rr_system,xx_system,ierr); CHKERRQ(ierr)
>  CALL PCFieldSplitGetSubKSP(pc_system,numsplit,subksp,ierr); CHKERRQ(ierr)
>  CALL KSPGetTotalIterations(subksp(1),nusediter_vv,ierr); CHKERRQ(ierr)
>  CALL KSPGetTotalIterations(subksp(2),nusediter_pp,ierr); CHKERRQ(ierr)
> print *, 'nusediter_vv', nusediter_vv
> print *, 'nusediter_pp', nusediter_pp
> Running the code shows this surprise:
> nusediter_vv          37
> nusediter_pp          37
> So the value of nusediter_pp is indeed 37, but for nusediter_vv
> it should be 66. Any idea what went wrong?
> Chris
> MARIN news: http://www.marin.nl/web/News/News-items/MARIN-wishes-you-a-challenging-inspiring-2017.htm
> From: Barry Smith <bsmith at mcs.anl.gov>
> Sent: Saturday, April 11, 2015 12:27 AM
>  Chris,
>  I have added KSPGetTotalIterations() to the branch barry/add-ksp-total-iterations/master and next. After tests it will go into master
>  Barry
>> On Apr 10, 2015, at 8:07 AM, Klaij, Christiaan <C.Klaij at marin.nl> wrote:
>> Barry,
>> Sure, I can call PCFieldSplitGetSubKSP() to get the fieldsplit_0
>> ksp and then KSPGetIterationNumber, but what does this number
>> mean?
>> It appears to be the number of iterations of the last time that
>> the subsystem was solved, right? If so, this corresponds to the
>> last iteration of the coupled system, how about all the previous
>> iterations?
>> Chris
>> Sent: Friday, April 10, 2015 2:48 PM
>>  Chris,
>>    It appears you should call PCFieldSplitGetSubKSP() and then get the information you want out of the individual KSPs. If this doesn't work please let us know.
>>  Barry
>>> On Apr 10, 2015, at 6:48 AM, Klaij, Christiaan <C.Klaij at marin.nl> wrote:
>>> A question when using PCFieldSplit: for each linear iteration of
>>> the system, how many iterations for fielsplit 0 and 1?
>>> One way to find out is to run with -ksp_monitor,
>>> -fieldsplit_0_ksp_monitor and -fieldsplit_0_ksp_monitor. This
>>> gives the complete convergence history.
>>> Another way, suggested by Matt, is to use -ksp_monitor,
>>> -fieldsplit_0_ksp_converged_reason and
>>> -fieldsplit_1_ksp_converged_reason. This gives only the totals
>>> for fieldsplit 0 and 1 (but without saying for which one).
>>> Both ways require to somehow process the output, which is a bit
>>> inconvenient. Could KSPGetResidualHistory perhaps return (some)
>>> information on the subsystems' convergence for processing inside
>>> the code?
>>> Chris
>>> CFD Researcher
>>> E mailto:C.Klaij at marin.nl
>>> T +31 317 49 33 44
>>> MARIN
>>> 2, Haagsteeg, P.O. Box 28, 6700 AA Wageningen, The Netherlands
>>> T +31 317 49 39 11, F +31 317 49 32 45, I www.marin.nl
