[petsc-users] low dimensional sub-problem
Sat Feb 25 11:00:42 CST 2017
On Sat, Feb 25, 2017 at 10:12 AM, Gideon Simpson <gideon.simpson at gmail.com>
wrote:
> -gideon
> On Feb 25, 2017, at 10:44 AM, Jed Brown <jed at jedbrown.org> wrote:
> Gideon Simpson <gideon.simpson at gmail.com> writes:
> I’ve been continuing working on implementing a projection method problem,
> which, loosely, looks like the following.  Vec y contains the state vector
> for my system, y’ = f(y) which is solved with a TS, using, for now, rk4.
> I have added to this a TSPostStep which does root finding on the nonlinear
> problem
> f(lambda) = f(lambda; y, w) =  g(y + lambda * w) - g0
> You might want to treat this as a DAE.
> Yea, we discussed DAE previously.  For the sake of a reviewer, I’m trying
> to implement a classical method (explicit time step + projection), rather
> than DAE.
> y and w are vectors that are the size of the system (numbers of mesh
> points), and lambda is a scalar perturbation.
> Right now, the snes function for solving this amounts to:
> PetscErrorCode projector(SNES snes, Vec lam, Vec f, void *ctx){
>  AppCtx * user = (AppCtx *) ctx;
>  const PetscScalar *lam_value;
>  PetscScalar *f_value;
>  VecGetArrayRead(lam, &lam_value);
>  VecGetArray(f, &f_value);
>  VecCopy(user->y, user->w);
>  VecAXPY(user->w, lam_value[0], user->gradMy);
>  f_value[0] = g(user->w) -user->g0;
>  VecRestoreArrayRead(lam, &lam_value);
>  VecRestoreArray(f, &f_value);
>  return 0;
> To get this all to work, I constructed the SNES and Vec lam with
> PETSC_COMM_SELF, effectively putting a copy of the nonlinear problem on
> each process.  Basically, the nonlinear problem is low dimensional, but it
> parametrically depends on the high dimensional, distributed, vectors y and
> w.
> The one thing that bothers me about this is:
> 1.  It would seem that each process is is doing all of these vector
> operations, which is entirely redundant, as the only thing that really
> needs to be shared amongst the processes is the value of lambda.  Is that
> correct?
> Only the SNES part is redundant, but it's super cheap because it's a
> scalar problem.  The Vec operations are using global (parallel,
> distributed) vectors, so they are not redundant.  Of course it is
> critical for the SNES on every process to be configured identically and
> deterministic so that the processes don't diverge.  And g(user->w) must
> return the same value on each process (it probably finishes with an
> MPI_Allreduce or similar).
> So within the root finding problem, when it calls, for instance, VecCopy
> (which is acting on distributed vectors), it’s not doing that once on
> process 0, once on process 1, once on process 2, etc.  Or it is, but you’re
> saying it’s too cheap to matter?
No they are collective. That is why Jed said its crucial that the same
branches are taken on all processes.
> Two things I’m mildly concerned about is that, since user->w changes at
> each step of the solver, by virtue of the lambda scalar changing,  if the
> SNES’s are running asynchronously, by virtue of them being PETSC_COMM_SELF
> constructs, couldn’t there be a collision?
Yes, as I say above. I think its much safer to run a COMM_WORLD SNES that
just has nothing on most procs than to do the former
since you are already synchronizing everywhere.
The operation g(user->w) does indeed conclude with an MPI_Allreduce,
> followed by DMDAVecRestoreArray and DMRestoreLocalVector.
> Lastly, in the TSPostStep, it runs as:
> SNESSolve(user->snes, NULL,user->lam);
> VecGetArray(user->lam, &lam_value);
> VecAXPY(y, lam_value[0], user->gradMy);
> VecRestoreArray(user->lam, &lam_value);
> Is there any communication issue with ensuring that all the SNES’s have
> finished on each process, before proceeding to do the vector operations?
No.
> I keep wondering if I should just write this as a global, with the data
> structures stored on process 0, just to avoid this kind of headache.
Yes.
   Matt
> 2.  Is there an obvious way around this redundancy?
> -gideon
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170225/e31dab25/attachment.html>
