[petsc-users] consider an error message as a petscinfo??
Kong, Fande
fande.kong at inl.gov
Fri Feb 24 15:08:53 CST 2017
Thanks a lot for your explanation, Barry,
This makes sense!
Fande,
On Fri, Feb 24, 2017 at 1:56 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Fande,
> Yes. Say one is doing a timestepping and using a direct solver. With
> time stepping we do not want to necessarily stop (in fact we almost never)
> on a failed solve (due to for example a failed factorization). We want the
> code to continue up the stack until it gets to the time stepper with the
> information that the linear solver failed; then the timestepper can decide
> what to do, decrease the time step and try again (common) or switch to
> another method etc. The same could be true for linear solvers called from
> within optimization routines.
> The reason we do the funny business with putting infinity into the
> vector is so that errors that occur on any process get propagated to all
> processes during the next inner product or norm computation, otherwise we
> would need to have some "side channel" communication which MPI doesn't
> really provide to propagate errors to all processes, this would be a lot of
> performance crippling communication that would have to take place during
> the entire solution process. Plus our approach since it doesn't change the
> flow of control cannot result in lost memory etc. Note that C (and MPI)
> don't have any exception mechanism that could be used to handle these
> "exceptional cases" directly.
> Note that you can use options like -snes_error_if_not_converged or
> -ksp_error_if_not_converged to force the error to be set as soon as any
> problem with convergence or zero factorization is found (good for
> debugging, but not usually for production unless production is solving a
> linear system only).
> Barry
> > On Feb 24, 2017, at 2:40 PM, Kong, Fande <fande.kong at inl.gov> wrote:
> > Hi All,
> > In MatSolve(), there is a piece of code:
> > if (mat->errortype) {
> > ierr = PetscInfo1(mat,"MatFactorError %D\n",mat->errortype);CHKERRQ(
> ierr);
> > ierr = VecSetInf(x);CHKERRQ(ierr);
> > } else {
> > ierr = (*mat->ops->solve)(mat,b,x);CHKERRQ(ierr);
> > If a direct solver such as LU or superlu fails to create a
> factorization, why we do not stop here and throw out an error message here
> or earlier? Now we just let solver keep doing garbage computation, and
> finally we have a solution like this:
> > Vec Object: 1 MPI processes
> > type: mpi
> > Process [0]
> > inf.
> > inf.
> > inf.
> > inf.
> > inf.
> > inf.
> > inf.
> > inf.
> > inf.
> > inf.
> > inf.
> > inf.
> > inf.
> > inf.
> > inf.
> > inf.
> > Any particular reason to handle the thing in this way?
> > Fande,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170224/e129ba08/attachment.html>
