[petsc-users] GAMG huge hash being requested
Justin Chang
jychang48 at gmail.com
Sun Feb 19 12:55:50 CST 2017
Okay, it doesn't seem like the Firedrake fork (which is what I am using)
has this latest fix. Lawrence, when do you think it's possible you folks
can incorporate these fixes?
On Sun, Feb 19, 2017 at 8:56 AM, Matthew Knepley <knepley at gmail.com> wrote:
> Satish fixed this error. I believe the fix is now in master.
> Thanks,
> Matt
> On Sun, Feb 19, 2017 at 3:05 AM, Justin Chang <jychang48 at gmail.com> wrote:
>> Hi all,
>> So I am attempting to employ the DG1 finite element method on the poisson
>> equation using GAMG. When I attempt to solve a problem with roughly 4
>> million DOFs across 20 cores, i get this error:
>> Traceback (most recent call last):
>> File "pFiredrake.py", line 109, in <module>
>> solve(a==L,solution,options_prefix='fe_',solver_parameters=
>> solver_params)
>> File "/home/jchang23/Software/firedrake/src/firedrake/firedrake/solving.py",
>> line 122, in solve
>> _solve_varproblem(*args, **kwargs)
>> line 152, in _solve_varproblem
>> solver.solve()
>> File "/home/jchang23/Software/firedrake/src/firedrake/firedrake/variational_solver.py",
>> line 220, in solve
>> self.snes.solve(None, v)
>> File "PETSc/SNES.pyx", line 537, in petsc4py.PETSc.SNES.solve
>> (src/petsc4py.PETSc.c:172359)
>> petsc4py.PETSc.Error: error code 63
>> [ 6] SNESSolve() line 4128 in /tmp/pip-FNpsya-build/src/snes
>> /interface/snes.c
>> [ 6] SNESSolve_KSPONLY() line 40 in /tmp/pip-FNpsya-build/src/snes
>> /impls/ksponly/ksponly.c
>> [ 6] KSPSolve() line 620 in /tmp/pip-FNpsya-build/src/ksp/
>> ksp/interface/itfunc.c
>> [ 6] KSPSetUp() line 393 in /tmp/pip-FNpsya-build/src/ksp/
>> [ 6] PCSetUp() line 968 in /tmp/pip-FNpsya-build/src/ksp/
>> pc/interface/precon.c
>> [ 6] PCSetUp_GAMG() line 524 in /tmp/pip-FNpsya-build/src/ksp/
>> pc/impls/gamg/gamg.c
>> [ 6] PCGAMGCoarsen_AGG() line 955 in /tmp/pip-FNpsya-build/src/ksp/
>> pc/impls/gamg/agg.c
>> [ 6] MatTransposeMatMult() line 9962 in /tmp/pip-FNpsya-build/src/mat/
>> interface/matrix.c
>> [ 6] MatTransposeMatMult_MPIAIJ_MPIAIJ() line 902 in
>> /tmp/pip-FNpsya-build/src/mat/impls/aij/mpi/mpimatmatmult.c
>> [ 6] MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1676 in
>> [ 6] PetscTableCreate() line 52 in /tmp/pip-FNpsya-build/src/sys/
>> utils/ctable.c
>> [ 6] PetscTableCreateHashSize() line 28 in /tmp/pip-FNpsya-build/src/sys/
>> utils/ctable.c
>> [ 6] Argument out of range
>> [ 6] A really huge hash is being requested.. cannot process: 4096000
>> MPI_ABORT was invoked on rank 6 in communicator MPI_COMM_WORLD
>> with errorcode 1.
>> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>> You may or may not see output from other processes, depending on
>> exactly when Open MPI kills them.
>> solver_params)
>> line 122, in solve
>> solver_params)
>> solver_params)
>> line 122, in solve
>> solver_params)
>> line 122, in solve
>> solver_params)
>> line 122, in solve
>> line 122, in solve
>> solver_params)
>> line 122, in solve
>> solver.solve()
>> line 220, in solve
>> solver.solve()
>> line 220, in solve
>> solver.solve()
>> line 220, in solve
>> solver.solve()
>> line 220, in solve
>> solver.solve()
>> solver.solve()
>> line 220, in solve
>> petsc4py.PETSc.Error solve(a==L,solution,options_pr
>> efix='fe_',solver_parameters=solver_params)
>> petsc4py.PETSc.Errorpetsc4py.PETSc.Errorpetsc4py.PETSc.Error:
>> solve(a==L,solution,options_prefix='fe_',solver_parameters=solver_params)
>> : error code 63
>> [ 3] SNESSolve() line 4128 in /tmp/pip-FNpsya-build/src/snes
>> /interface/snes.c
>> [ 3] SNESSolve_KSPONLY() line 40 in /tmp/pip-FNpsya-build/src/snes
>> [ 3] KSPSolve() line 620 in /tmp/pip-FNpsya-build/src/ksp/
>> [ 3] KSPSetUp() line 393 in /tmp/pip-FNpsya-build/src/ksp/
>> [ 3] PCSetUp() line 968 in /tmp/pip-FNpsya-build/src/ksp/
>> [ 3] PCSetUp_GAMG() line 524 in /tmp/pip-FNpsya-build/src/ksp/
>> [ 3] PCGAMGCoarsen_AGG() line 955 in /tmp/pip-FNpsya-build/src/ksp/
>> pc/impls/gamg/agg.c
>> [ 3] MatTransposeMatMult() line 9962 in /tmp/pip-FNpsya-build/src/mat/
>> interface/matrix.c
>> [ 3] MatTransposeMatMult_MPIAIJ_MPIAIJ() line 902 in
>> [ 3] MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1676 in
>> [ 3] PetscTableCreate() line 52 in /tmp/pip-FNpsya-build/src/sys/
>> utils/ctable.c
>> [ 3] PetscTableCreateHashSize() line 28 in /tmp/pip-FNpsya-build/src/sys/
>> utils/ctable.c
>> [ 3] Argument out of range
>> [ 3] A really huge hash is being requested.. cannot process: 4096000
>> line 220, in solve
>> : error code 63
>> [ 1] SNESSolve() line 4128 in /tmp/pip-FNpsya-build/src/snes
>> /interface/snes.c
>> [ 1] SNESSolve_KSPONLY() line 40 in /tmp/pip-FNpsya-build/src/snes
>> [ 1] KSPSolve() line 620 in /tmp/pip-FNpsya-build/src/ksp/
>> [ 1] KSPSetUp() line 393 in /tmp/pip-FNpsya-build/src/ksp/
>> [ 1] PCSetUp() line 968 in /tmp/pip-FNpsya-build/src/ksp/
>> [ 1] PCSetUp_GAMG() line 524 in /tmp/pip-FNpsya-build/src/ksp/
>> [ 1] PCGAMGCoarsen_AGG() line 955 in /tmp/pip-FNpsya-build/src/ksp/
>> pc/impls/gamg/agg.c
>> [ 1] MatTransposeMatMult() line 9962 in /tmp/pip-FNpsya-build/src/mat/
>> interface/matrix.c
>> [ 1] MatTransposeMatMult_MPIAIJ_MPIAIJ() line 902 in
>> [ 1] MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1676 in
>> [ 1] PetscTableCreate() line 52 in /tmp/pip-FNpsya-build/src/sys/
>> utils/ctable.c
>> [ 1] PetscTableCreateHashSize() line 28 in /tmp/pip-FNpsya-build/src/sys/
>> utils/ctable.c
>> [ 1] Argument out of range
>> [ 1] A really huge hash is being requested.. cannot process: 4096000
>> : error code 63
>> [17] SNESSolve() line 4128 in /tmp/pip-FNpsya-build/src/snes
>> /interface/snes.c
>> [17] SNESSolve_KSPONLY() line 40 in /tmp/pip-FNpsya-build/src/snes
>> [17] KSPSolve() line 620 in /tmp/pip-FNpsya-build/src/ksp/
>> [17] KSPSetUp() line 393 in /tmp/pip-FNpsya-build/src/ksp/
>> [17] PCSetUp() line 968 in /tmp/pip-FNpsya-build/src/ksp/
>> [17] PCSetUp_GAMG() line 524 in /tmp/pip-FNpsya-build/src/ksp/
>> [17] PCGAMGCoarsen_AGG() line 955 in /tmp/pip-FNpsya-build/src/ksp/
>> pc/impls/gamg/agg.c
>> [17] MatTransposeMatMult() line 9962 in /tmp/pip-FNpsya-build/src/mat/
>> interface/matrix.c
>> [17] MatTransposeMatMult_MPIAIJ_MPIAIJ() line 902 in
>> [17] MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1676 in
>> [17] PetscTableCreate() line 52 in /tmp/pip-FNpsya-build/src/sys/
>> utils/ctable.c
>> [17] PetscTableCreateHashSize() line 28 in /tmp/pip-FNpsya-build/src/sys/
>> utils/ctable.c
>> [17] Argument out of range
>> [17] A really huge hash is being requested.. cannot process: 4096000
>> solver_params)
>> error code 63
>> [ 5] SNESSolve() line 4128 in /tmp/pip-FNpsya-build/src/snes
>> /interface/snes.c
>> [ 5] SNESSolve_KSPONLY() line 40 in /tmp/pip-FNpsya-build/src/snes
>> [ 5] KSPSolve() line 620 in /tmp/pip-FNpsya-build/src/ksp/
>> [ 5] KSPSetUp() line 393 in /tmp/pip-FNpsya-build/src/ksp/
>> [ 5] PCSetUp() line 968 in /tmp/pip-FNpsya-build/src/ksp/
>> [ 5] PCSetUp_GAMG() line 524 in /tmp/pip-FNpsya-build/src/ksp/
>> [ 5] PCGAMGCoarsen_AGG() line 955 in /tmp/pip-FNpsya-build/src/ksp/
>> pc/impls/gamg/agg.c
>> [ 5] MatTransposeMatMult() line 9962 in /tmp/pip-FNpsya-build/src/mat/
>> interface/matrix.c
>> [ 5] MatTransposeMatMult_MPIAIJ_MPIAIJ() line 902 in
>> [ 5] MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1676 in
>> [ 5] PetscTableCreate() line 52 in /tmp/pip-FNpsya-build/src/sys/
>> utils/ctable.c
>> [ 5] PetscTableCreateHashSize() line 28 in /tmp/pip-FNpsya-build/src/sys/
>> utils/ctable.c
>> [ 5] Argument out of range
>> [ 5] A really huge hash is being requested.. cannot process: 4096000
>> line 122, in solve
>> line 122, in solve
>> line 122, in solve
>> [ 9] SNESSolve() line 4128 in /tmp/pip-FNpsya-build/src/snes
>> /interface/snes.c
>> [ 9] SNESSolve_KSPONLY() line 40 in /tmp/pip-FNpsya-build/src/snes
>> [ 9] KSPSolve() line 620 in /tmp/pip-FNpsya-build/src/ksp/
>> [ 9] KSPSetUp() line 393 in /tmp/pip-FNpsya-build/src/ksp/
>> [ 9] PCSetUp() line 968 in /tmp/pip-FNpsya-build/src/ksp/
>> [ 9] PCSetUp_GAMG() line 524 in /tmp/pip-FNpsya-build/src/ksp/
>> [ 9] PCGAMGCoarsen_AGG() line 955 in /tmp/pip-FNpsya-build/src/ksp/
>> pc/impls/gamg/agg.c
>> [ 9] MatTransposeMatMult() line 9962 in /tmp/pip-FNpsya-build/src/mat/
>> interface/matrix.c
>> [ 9] MatTransposeMatMult_MPIAIJ_MPIAIJ() line 902 in
>> [ 9] MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1676 in
>> [ 9] PetscTableCreate() line 52 in /tmp/pip-FNpsya-build/src/sys/
>> utils/ctable.c
>> [ 9] PetscTableCreateHashSize() line 28 in /tmp/pip-FNpsya-build/src/sys/
>> utils/ctable.c
>> [ 9] Argument out of range
>> [ 9] A really huge hash is being requested.. cannot process: 4096000
>> solver_params)
>> solver_params)
>> [ 4] SNESSolve() line 4128 in /tmp/pip-FNpsya-build/src/snes
>> /interface/snes.c
>> [ 4] SNESSolve_KSPONLY() line 40 in /tmp/pip-FNpsya-build/src/snes
>> [ 4] KSPSolve() line 620 in /tmp/pip-FNpsya-build/src/ksp/
>> [ 4] KSPSetUp() line 393 in /tmp/pip-FNpsya-build/src/ksp/
>> [ 4] PCSetUp() line 968 in /tmp/pip-FNpsya-build/src/ksp/
>> [ 4] PCSetUp_GAMG() line 524 in /tmp/pip-FNpsya-build/src/ksp/
>> [ 4] PCGAMGCoarsen_AGG() line 955 in /tmp/pip-FNpsya-build/src/ksp/
>> pc/impls/gamg/agg.c
>> [ 4] MatTransposeMatMult() line 9962 in /tmp/pip-FNpsya-build/src/mat/
>> interface/matrix.c
>> [ 4] MatTransposeMatMult_MPIAIJ_MPIAIJ() line 902 in
>> [ 4] MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1676 in
>> [ 4] PetscTableCreate() line 52 in /tmp/pip-FNpsya-build/src/sys/
>> utils/ctable.c
>> [ 4] PetscTableCreateHashSize() line 28 in /tmp/pip-FNpsya-build/src/sys/
>> utils/ctable.c
>> [ 4] Argument out of range
>> [ 4] A really huge hash is being requested.. cannot process: 4096000
>> line 122, in solve
>> solver_params)
>> line 122, in solve
>> solver_params)
>> line 122, in solve
>> solver.solve()
>> solver_params)
>> line 122, in solve
>> solver_params)
>> line 122, in solve
>> solver.solve()
>> line 220, in solve
>> line 220, in solve
>> line 122, in solve
>> solver.solve()
>> solver_params)
>> solver_params)
>> [13] SNESSolve() line 4128 in /tmp/pip-FNpsya-build/src/snes
>> /interface/snes.c
>> [13] SNESSolve_KSPONLY() line 40 in /tmp/pip-FNpsya-build/src/snes
>> [13] KSPSolve() line 620 in /tmp/pip-FNpsya-build/src/ksp/
>> [13] KSPSetUp() line 393 in /tmp/pip-FNpsya-build/src/ksp/
>> [13] PCSetUp() line 968 in /tmp/pip-FNpsya-build/src/ksp/
>> [13] PCSetUp_GAMG() line 524 in /tmp/pip-FNpsya-build/src/ksp/
>> [13] PCGAMGCoarsen_AGG() line 955 in /tmp/pip-FNpsya-build/src/ksp/
>> pc/impls/gamg/agg.c
>> [13] MatTransposeMatMult() line 9962 in /tmp/pip-FNpsya-build/src/mat/
>> interface/matrix.c
>> [13] MatTransposeMatMult_MPIAIJ_MPIAIJ() line 902 in
>> [13] MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1676 in
>> [13] PetscTableCreate() line 52 in /tmp/pip-FNpsya-build/src/sys/
>> utils/ctable.c
>> [13] PetscTableCreateHashSize() line 28 in /tmp/pip-FNpsya-build/src/sys/
>> utils/ctable.c
>> [13] Argument out of range
>> [13] A really huge hash is being requested.. cannot process: 4096000
>> solver.solve()
>> line 220, in solve
>> solver.solve()
>> line 122, in solve
>> solver_params)
>> solver.solve()
>> petsc4py.PETSc.Error File "/home/jchang23/Software/fired
>> rake/src/firedrake/firedrake/solving.py", line 122, in solve
>> : error code 63
>> [11] SNESSolve() line 4128 in /tmp/pip-FNpsya-build/src/snes
>> /interface/snes.c
>> [11] SNESSolve_KSPONLY() line 40 in /tmp/pip-FNpsya-build/src/snes
>> [11] KSPSolve() line 620 in /tmp/pip-FNpsya-build/src/ksp/
>> [11] KSPSetUp() line 393 in /tmp/pip-FNpsya-build/src/ksp/
>> [11] PCSetUp() line 968 in /tmp/pip-FNpsya-build/src/ksp/
>> [11] PCSetUp_GAMG() line 524 in /tmp/pip-FNpsya-build/src/ksp/
>> [11] PCGAMGCoarsen_AGG() line 955 in /tmp/pip-FNpsya-build/src/ksp/
>> pc/impls/gamg/agg.c
>> [11] MatTransposeMatMult() line 9962 in /tmp/pip-FNpsya-build/src/mat/
>> interface/matrix.c
>> [11] MatTransposeMatMult_MPIAIJ_MPIAIJ() line 902 in
>> [11] MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1676 in
>> [11] PetscTableCreate() line 52 in /tmp/pip-FNpsya-build/src/sys/
>> utils/ctable.c
>> [11] PetscTableCreateHashSize() line 28 in /tmp/pip-FNpsya-build/src/sys/
>> utils/ctable.c
>> [11] Argument out of range
>> [11] A really huge hash is being requested.. cannot process: 4096000
>> line 220, in solve
>> solver_params)
>> solver.solve()
>> line 220, in solve
>> solver.solve()
>> line 220, in solve
>> solver.solve()
>> line 220, in solve
>> line 122, in solve
>> line 220, in solve
>> line 122, in solve
>> line 220, in solve
>> [14] SNESSolve() line 4128 in /tmp/pip-FNpsya-build/src/snes
>> /interface/snes.c
>> [14] SNESSolve_KSPONLY() line 40 in /tmp/pip-FNpsya-build/src/snes
>> [14] KSPSolve() line 620 in /tmp/pip-FNpsya-build/src/ksp/
>> [14] KSPSetUp() line 393 in /tmp/pip-FNpsya-build/src/ksp/
>> [14] PCSetUp() line 968 in /tmp/pip-FNpsya-build/src/ksp/
>> [14] PCSetUp_GAMG() line 524 in /tmp/pip-FNpsya-build/src/ksp/
>> [14] PCGAMGCoarsen_AGG() line 955 in /tmp/pip-FNpsya-build/src/ksp/
>> pc/impls/gamg/agg.c
>> [14] MatTransposeMatMult() line 9962 in /tmp/pip-FNpsya-build/src/mat/
>> interface/matrix.c
>> [14] MatTransposeMatMult_MPIAIJ_MPIAIJ() line 902 in
>> [14] MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1676 in
>> [14] PetscTableCreate() line 52 in /tmp/pip-FNpsya-build/src/sys/
>> utils/ctable.c
>> [14] PetscTableCreateHashSize() line 28 in /tmp/pip-FNpsya-build/src/sys/
>> utils/ctable.c
>> [14] Argument out of range
>> [14] A really huge hash is being requested.. cannot process: 4096000
>> [19] SNESSolve() line 4128 in /tmp/pip-FNpsya-build/src/snes
>> /interface/snes.c
>> [19] SNESSolve_KSPONLY() line 40 in /tmp/pip-FNpsya-build/src/snes
>> [19] KSPSolve() line 620 in /tmp/pip-FNpsya-build/src/ksp/
>> [19] KSPSetUp() line 393 in /tmp/pip-FNpsya-build/src/ksp/
>> [19] PCSetUp() line 968 in /tmp/pip-FNpsya-build/src/ksp/
>> [19] PCSetUp_GAMG() line 524 in /tmp/pip-FNpsya-build/src/ksp/
>> [19] PCGAMGCoarsen_AGG() line 955 in /tmp/pip-FNpsya-build/src/ksp/
>> pc/impls/gamg/agg.c
>> [19] MatTransposeMatMult() line 9962 in /tmp/pip-FNpsya-build/src/mat/
>> interface/matrix.c
>> [19] MatTransposeMatMult_MPIAIJ_MPIAIJ() line 902 in
>> [19] MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1676 in
>> [19] PetscTableCreate() line 52 in /tmp/pip-FNpsya-build/src/sys/
>> utils/ctable.c
>> [19] PetscTableCreateHashSize() line 28 in /tmp/pip-FNpsya-build/src/sys/
>> utils/ctable.c
>> [19] Argument out of range
>> [19] A really huge hash is being requested.. cannot process: 4096000
>> [15] SNESSolve() line 4128 in /tmp/pip-FNpsya-build/src/snes
>> /interface/snes.c
>> [15] SNESSolve_KSPONLY() line 40 in /tmp/pip-FNpsya-build/src/snes
>> [15] KSPSolve() line 620 in /tmp/pip-FNpsya-build/src/ksp/
>> [15] KSPSetUp() line 393 in /tmp/pip-FNpsya-build/src/ksp/
>> [15] PCSetUp() line 968 in /tmp/pip-FNpsya-build/src/ksp/
>> [15] PCSetUp_GAMG() line 524 in /tmp/pip-FNpsya-build/src/ksp/
>> [15] PCGAMGCoarsen_AGG() line 955 in /tmp/pip-FNpsya-build/src/ksp/
>> pc/impls/gamg/agg.c
>> [15] MatTransposeMatMult() line 9962 in /tmp/pip-FNpsya-build/src/mat/
>> interface/matrix.c
>> [15] MatTransposeMatMult_MPIAIJ_MPIAIJ() line 902 in
>> [15] MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1676 in
>> [15] PetscTableCreate() line 52 in /tmp/pip-FNpsya-build/src/sys/
>> utils/ctable.c
>> [15] PetscTableCreateHashSize() line 28 in /tmp/pip-FNpsya-build/src/sys/
>> utils/ctable.c
>> [15] Argument out of range
>> [15] A really huge hash is being requested.. cannot process: 4096000
>> [ 7] SNESSolve() line 4128 in /tmp/pip-FNpsya-build/src/snes
>> /interface/snes.c
>> [ 7] SNESSolve_KSPONLY() line 40 in /tmp/pip-FNpsya-build/src/snes
>> [ 7] KSPSolve() line 620 in /tmp/pip-FNpsya-build/src/ksp/
>> [ 7] KSPSetUp() line 393 in /tmp/pip-FNpsya-build/src/ksp/
>> [ 7] PCSetUp() line 968 in /tmp/pip-FNpsya-build/src/ksp/
>> [ 7] PCSetUp_GAMG() line 524 in /tmp/pip-FNpsya-build/src/ksp/
>> [ 7] PCGAMGCoarsen_AGG() line 955 in /tmp/pip-FNpsya-build/src/ksp/
>> pc/impls/gamg/agg.c
>> [ 7] MatTransposeMatMult() line 9962 in /tmp/pip-FNpsya-build/src/mat/
>> interface/matrix.c
>> [ 7] MatTransposeMatMult_MPIAIJ_MPIAIJ() line 902 in
>> [ 7] MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1676 in
>> [ 7] PetscTableCreate() line 52 in /tmp/pip-FNpsya-build/src/sys/
>> utils/ctable.c
>> [ 7] PetscTableCreateHashSize() line 28 in /tmp/pip-FNpsya-build/src/sys/
>> utils/ctable.c
>> [ 7] Argument out of range
>> [ 7] A really huge hash is being requested.. cannot process: 4096000
>> solver.solve()
>> rake/src/firedrake/firedrake/solving.py", line 152, in _solve_varproblem
>> : error code 63
>> [12] SNESSolve() line 4128 in /tmp/pip-FNpsya-build/src/snes
>> /interface/snes.c
>> [12] SNESSolve_KSPONLY() line 40 in /tmp/pip-FNpsya-build/src/snes
>> [12] KSPSolve() line 620 in /tmp/pip-FNpsya-build/src/ksp/
>> [12] KSPSetUp() line 393 in /tmp/pip-FNpsya-build/src/ksp/
>> [12] PCSetUp() line 968 in /tmp/pip-FNpsya-build/src/ksp/
>> [12] PCSetUp_GAMG() line 524 in /tmp/pip-FNpsya-build/src/ksp/
>> [12] PCGAMGCoarsen_AGG() line 955 in /tmp/pip-FNpsya-build/src/ksp/
>> pc/impls/gamg/agg.c
>> [12] MatTransposeMatMult() line 9962 in /tmp/pip-FNpsya-build/src/mat/
>> interface/matrix.c
>> [12] MatTransposeMatMult_MPIAIJ_MPIAIJ() line 902 in
>> [12] MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1676 in
>> [12] PetscTableCreate() line 52 in /tmp/pip-FNpsya-build/src/sys/
>> utils/ctable.c
>> [12] PetscTableCreateHashSize() line 28 in /tmp/pip-FNpsya-build/src/sys/
>> utils/ctable.c
>> [12] Argument out of range
>> [12] A really huge hash is being requested.. cannot process: 4096000
>> solver.solve()
>> petsc4py.PETSc.Error: File "PETSc/SNES.pyx", line 537, in
>> petsc4py.PETSc.SNES.solve (src/petsc4py.PETSc.c:172359)
>> error code 63
>> [ 2] SNESSolve() line 4128 in /tmp/pip-FNpsya-build/src/snes
>> /interface/snes.c
>> [ 2] SNESSolve_KSPONLY() line 40 in /tmp/pip-FNpsya-build/src/snes
>> [ 2] KSPSolve() line 620 in /tmp/pip-FNpsya-build/src/ksp/
>> [ 2] KSPSetUp() line 393 in /tmp/pip-FNpsya-build/src/ksp/
>> [ 2] PCSetUp() line 968 in /tmp/pip-FNpsya-build/src/ksp/
>> [ 2] PCSetUp_GAMG() line 524 in /tmp/pip-FNpsya-build/src/ksp/
>> [ 2] PCGAMGCoarsen_AGG() line 955 in /tmp/pip-FNpsya-build/src/ksp/
>> pc/impls/gamg/agg.c
>> [ 2] MatTransposeMatMult() line 9962 in /tmp/pip-FNpsya-build/src/mat/
>> interface/matrix.c
>> [ 2] MatTransposeMatMult_MPIAIJ_MPIAIJ() line 902 in
>> [ 2] MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1676 in
>> [ 2] PetscTableCreate() line 52 in /tmp/pip-FNpsya-build/src/sys/
>> utils/ctable.c
>> [ 2] PetscTableCreateHashSize() line 28 in /tmp/pip-FNpsya-build/src/sys/
>> utils/ctable.c
>> [ 2] Argument out of range
>> [ 2] A really huge hash is being requested.. cannot process: 4096000
>> rake/src/firedrake/firedrake/variational_solver.py", line 220, in solve
>> : error code 63
>> [ 8] SNESSolve() line 4128 in /tmp/pip-FNpsya-build/src/snes
>> /interface/snes.c
>> [ 8] SNESSolve_KSPONLY() line 40 in /tmp/pip-FNpsya-build/src/snes
>> [ 8] KSPSolve() line 620 in /tmp/pip-FNpsya-build/src/ksp/
>> [ 8] KSPSetUp() line 393 in /tmp/pip-FNpsya-build/src/ksp/
>> [ 8] PCSetUp() line 968 in /tmp/pip-FNpsya-build/src/ksp/
>> [ 8] PCSetUp_GAMG() line 524 in /tmp/pip-FNpsya-build/src/ksp/
>> [ 8] PCGAMGCoarsen_AGG() line 955 in /tmp/pip-FNpsya-build/src/ksp/
>> pc/impls/gamg/agg.c
>> [ 8] MatTransposeMatMult() line 9962 in /tmp/pip-FNpsya-build/src/mat/
>> interface/matrix.c
>> [ 8] MatTransposeMatMult_MPIAIJ_MPIAIJ() line 902 in
>> [ 8] MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1676 in
>> [ 8] PetscTableCreate() line 52 in /tmp/pip-FNpsya-build/src/sys/
>> utils/ctable.c
>> [ 8] PetscTableCreateHashSize() line 28 in /tmp/pip-FNpsya-build/src/sys/
>> utils/ctable.c
>> [ 8] Argument out of range
>> [ 8] A really huge hash is being requested.. cannot process: 4096000
>> line 220, in solve
>> solver.solve()
>> solver.solve()
>> line 220, in solve
>> line 220, in solve
>> petsc4py.PETSc.Error self.snes.solve(None, v)
>> : error code 63
>> [18] SNESSolve() line 4128 in /tmp/pip-FNpsya-build/src/snes
>> /interface/snes.c
>> [18] SNESSolve_KSPONLY() line 40 in /tmp/pip-FNpsya-build/src/snes
>> [18] KSPSolve() line 620 in /tmp/pip-FNpsya-build/src/ksp/
>> [18] KSPSetUp() line 393 in /tmp/pip-FNpsya-build/src/ksp/
>> [18] PCSetUp() line 968 in /tmp/pip-FNpsya-build/src/ksp/
>> [18] PCSetUp_GAMG() line 524 in /tmp/pip-FNpsya-build/src/ksp/
>> [18] PCGAMGCoarsen_AGG() line 955 in /tmp/pip-FNpsya-build/src/ksp/
>> pc/impls/gamg/agg.c
>> [18] MatTransposeMatMult() line 9962 in /tmp/pip-FNpsya-build/src/mat/
>> interface/matrix.c
>> [18] MatTransposeMatMult_MPIAIJ_MPIAIJ() line 902 in
>> [18] MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1676 in
>> [18] PetscTableCreate() line 52 in /tmp/pip-FNpsya-build/src/sys/
>> utils/ctable.c
>> [18] PetscTableCreateHashSize() line 28 in /tmp/pip-FNpsya-build/src/sys/
>> utils/ctable.c
>> [18] Argument out of range
>> [18] A really huge hash is being requested.. cannot process: 4096000
>> petsc4py.PETSc.Errorpetsc4py.PETSc.Error: error code 63
>> [ 0] SNESSolve() line 4128 in /tmp/pip-FNpsya-build/src/snes
>> /interface/snes.c
>> [ 0] SNESSolve_KSPONLY() line 40 in /tmp/pip-FNpsya-build/src/snes
>> [ 0] KSPSolve() line 620 in /tmp/pip-FNpsya-build/src/ksp/
>> [ 0] KSPSetUp() line 393 in /tmp/pip-FNpsya-build/src/ksp/
>> [ 0] PCSetUp() line 968 in /tmp/pip-FNpsya-build/src/ksp/
>> [ 0] PCSetUp_GAMG() line 524 in /tmp/pip-FNpsya-build/src/ksp/
>> [ 0] PCGAMGCoarsen_AGG() line 955 in /tmp/pip-FNpsya-build/src/ksp/
>> pc/impls/gamg/agg.c
>> [ 0] MatTransposeMatMult() line 9962 in /tmp/pip-FNpsya-build/src/mat/
>> interface/matrix.c
>> [ 0] MatTransposeMatMult_MPIAIJ_MPIAIJ() line 902 in
>> [ 0] MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1676 in
>> [ 0] PetscTableCreate() line 52 in /tmp/pip-FNpsya-build/src/sys/
>> utils/ctable.c
>> [ 0] PetscTableCreateHashSize() line 28 in /tmp/pip-FNpsya-build/src/sys/
>> utils/ctable.c
>> [ 0] Argument out of range
>> [ 0] A really huge hash is being requested.. cannot process: 4096000
>> : error code 63
>> [16] SNESSolve() line 4128 in /tmp/pip-FNpsya-build/src/snes
>> /interface/snes.c
>> [16] SNESSolve_KSPONLY() line 40 in /tmp/pip-FNpsya-build/src/snes
>> [16] KSPSolve() line 620 in /tmp/pip-FNpsya-build/src/ksp/
>> [16] KSPSetUp() line 393 in /tmp/pip-FNpsya-build/src/ksp/
>> [16] PCSetUp() line 968 in /tmp/pip-FNpsya-build/src/ksp/
>> [16] PCSetUp_GAMG() line 524 in /tmp/pip-FNpsya-build/src/ksp/
>> [16] PCGAMGCoarsen_AGG() line 955 in /tmp/pip-FNpsya-build/src/ksp/
>> pc/impls/gamg/agg.c
>> [16] MatTransposeMatMult() line 9962 in /tmp/pip-FNpsya-build/src/mat/
>> interface/matrix.c
>> [16] MatTransposeMatMult_MPIAIJ_MPIAIJ() line 902 in
>> [16] MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1676 in
>> [16] PetscTableCreate() line 52 in /tmp/pip-FNpsya-build/src/sys/
>> utils/ctable.c
>> [16] PetscTableCreateHashSize() line 28 in /tmp/pip-FNpsya-build/src/sys/
>> utils/ctable.c
>> [16] Argument out of range
>> [16] A really huge hash is being requested.. cannot process: 4096000
>> [10] SNESSolve() line 4128 in /tmp/pip-FNpsya-build/src/snes
>> /interface/snes.c
>> [10] SNESSolve_KSPONLY() line 40 in /tmp/pip-FNpsya-build/src/snes
>> [10] KSPSolve() line 620 in /tmp/pip-FNpsya-build/src/ksp/
>> [10] KSPSetUp() line 393 in /tmp/pip-FNpsya-build/src/ksp/
>> [10] PCSetUp() line 968 in /tmp/pip-FNpsya-build/src/ksp/
>> [10] PCSetUp_GAMG() line 524 in /tmp/pip-FNpsya-build/src/ksp/
>> [10] PCGAMGCoarsen_AGG() line 955 in /tmp/pip-FNpsya-build/src/ksp/
>> pc/impls/gamg/agg.c
>> [10] MatTransposeMatMult() line 9962 in /tmp/pip-FNpsya-build/src/mat/
>> interface/matrix.c
>> [10] MatTransposeMatMult_MPIAIJ_MPIAIJ() line 902 in
>> [10] MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1676 in
>> [10] PetscTableCreate() line 52 in /tmp/pip-FNpsya-build/src/sys/
>> utils/ctable.c
>> [10] PetscTableCreateHashSize() line 28 in /tmp/pip-FNpsya-build/src/sys/
>> utils/ctable.c
>> [10] Argument out of range
>> [10] A really huge hash is being requested.. cannot process: 4096000
>> [compute-0-0.local:31182] 19 more processes have sent help message
>> help-mpi-api.txt / mpi-abort
>> [compute-0-0.local:31182] Set MCA parameter "orte_base_help_aggregate" to
>> 0 to see all help / error messages
>> However, if I use either ML or HYPRE i do not. When I downscale the
>> problem to roughly 1.7 million dofs, I get no such error with GAMG, but
>> both ML and HYPRE are still faster.
>> Something tells me I need to tune the GAMG parameters. Here's some -GAMG
>> related info that may help:
>> [0] PCSetUp_GAMG(): level 0) N=4096000, n data rows=1, n data cols=1,
>> nnz/row (ave)=55, np=20
>> [0] PCGAMGFilterGraph(): 78.5842% nnz after filtering, with
>> threshold 0., 55.8 nnz ave. (N=4096000)
>> [0] PCGAMGCoarsen_AGG(): Square Graph on level 1 of 1 to square
>> And if I run with -pc_gamg_threshold 0.08:
>> [0] PCGAMGFilterGraph(): 28.5842% nnz after filtering, with
>> threshold 0.08, 55.8 nnz ave. (N=4096000)
>> Any idea what to do here?
>> Thanks,
>> Justin
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170219/58255603/attachment-0001.html>
