[petsc-users] GAMG huge hash being requested
Justin Chang jychang48 at gmail.com
Sun Feb 19 03:05:33 CST 2017
Hi all,
So I am attempting to employ the DG1 finite element method on the poisson
equation using GAMG. When I attempt to solve a problem with roughly 4
million DOFs across 20 cores, i get this error:
Traceback (most recent call last):
  File "pFiredrake.py", line 109, in <module>
solve(a==L,solution,options_prefix='fe_',solver_parameters=solver_params)
  File
"/home/jchang23/Software/firedrake/src/firedrake/firedrake/solving.py",
line 122, in solve
    _solve_varproblem(*args, **kwargs)
  File
line 152, in _solve_varproblem
    solver.solve()
  File
"/home/jchang23/Software/firedrake/src/firedrake/firedrake/variational_solver.py",
line 220, in solve
    self.snes.solve(None, v)
  File "PETSc/SNES.pyx", line 537, in petsc4py.PETSc.SNES.solve
(src/petsc4py.PETSc.c:172359)
petsc4py.PETSc.Error: error code 63
[ 6] SNESSolve() line 4128 in
/tmp/pip-FNpsya-build/src/snes/interface/snes.c
[ 6] SNESSolve_KSPONLY() line 40 in
/tmp/pip-FNpsya-build/src/snes/impls/ksponly/ksponly.c
[ 6] KSPSolve() line 620 in
/tmp/pip-FNpsya-build/src/ksp/ksp/interface/itfunc.c
[ 6] KSPSetUp() line 393 in
[ 6] PCSetUp() line 968 in
/tmp/pip-FNpsya-build/src/ksp/pc/interface/precon.c
[ 6] PCSetUp_GAMG() line 524 in
/tmp/pip-FNpsya-build/src/ksp/pc/impls/gamg/gamg.c
[ 6] PCGAMGCoarsen_AGG() line 955 in
/tmp/pip-FNpsya-build/src/ksp/pc/impls/gamg/agg.c
[ 6] MatTransposeMatMult() line 9962 in
/tmp/pip-FNpsya-build/src/mat/interface/matrix.c
[ 6] MatTransposeMatMult_MPIAIJ_MPIAIJ() line 902 in
/tmp/pip-FNpsya-build/src/mat/impls/aij/mpi/mpimatmatmult.c
[ 6] MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1676 in
[ 6] PetscTableCreate() line 52 in
/tmp/pip-FNpsya-build/src/sys/utils/ctable.c
[ 6] PetscTableCreateHashSize() line 28 in
[ 6] Argument out of range
[ 6] A really huge hash is being requested.. cannot process: 4096000
MPI_ABORT was invoked on rank 6 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
  File
line 122, in solve
  File
  File
line 122, in solve
  File
line 122, in solve
  File
line 122, in solve
      File
line 122, in solve
  File
line 122, in solve
  File
  File
  File
  File
    solver.solve()
  File
line 220, in solve
  File
    solver.solve()
  File
line 220, in solve
    solver.solve()
  File
line 220, in solve
    solver.solve()
  File
line 220, in solve
solver.solve()
    solver.solve()
  File
line 220, in solve
petsc4py.PETSc.Errorpetsc4py.PETSc.Errorpetsc4py.PETSc.Error:
: error code 63
[ 3] SNESSolve() line 4128 in
[ 3] SNESSolve_KSPONLY() line 40 in
[ 3] KSPSolve() line 620 in
[ 3] KSPSetUp() line 393 in
[ 3] PCSetUp() line 968 in
[ 3] PCSetUp_GAMG() line 524 in
[ 3] PCGAMGCoarsen_AGG() line 955 in
[ 3] MatTransposeMatMult() line 9962 in
[ 3] MatTransposeMatMult_MPIAIJ_MPIAIJ() line 902 in
[ 3] MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1676 in
[ 3] PetscTableCreate() line 52 in
[ 3] PetscTableCreateHashSize() line 28 in
[ 3] Argument out of range
[ 3] A really huge hash is being requested.. cannot process: 4096000
  File
line 220, in solve
: error code 63
[ 1] SNESSolve() line 4128 in
[ 1] SNESSolve_KSPONLY() line 40 in
[ 1] KSPSolve() line 620 in
[ 1] KSPSetUp() line 393 in
[ 1] PCSetUp() line 968 in
[ 1] PCSetUp_GAMG() line 524 in
[ 1] PCGAMGCoarsen_AGG() line 955 in
[ 1] MatTransposeMatMult() line 9962 in
[ 1] MatTransposeMatMult_MPIAIJ_MPIAIJ() line 902 in
[ 1] MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1676 in
[ 1] PetscTableCreate() line 52 in
[ 1] PetscTableCreateHashSize() line 28 in
[ 1] Argument out of range
[ 1] A really huge hash is being requested.. cannot process: 4096000
: error code 63
[17] SNESSolve() line 4128 in
[17] SNESSolve_KSPONLY() line 40 in
[17] KSPSolve() line 620 in
[17] KSPSetUp() line 393 in
[17] PCSetUp() line 968 in
[17] PCSetUp_GAMG() line 524 in
[17] PCGAMGCoarsen_AGG() line 955 in
[17] MatTransposeMatMult() line 9962 in
[17] MatTransposeMatMult_MPIAIJ_MPIAIJ() line 902 in
[17] MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1676 in
[17] PetscTableCreate() line 52 in
[17] PetscTableCreateHashSize() line 28 in
[17] Argument out of range
[17] A really huge hash is being requested.. cannot process: 4096000
error code 63
[ 5] SNESSolve() line 4128 in
[ 5] SNESSolve_KSPONLY() line 40 in
[ 5] KSPSolve() line 620 in
[ 5] KSPSetUp() line 393 in
[ 5] PCSetUp() line 968 in
[ 5] PCSetUp_GAMG() line 524 in
[ 5] PCGAMGCoarsen_AGG() line 955 in
[ 5] MatTransposeMatMult() line 9962 in
[ 5] MatTransposeMatMult_MPIAIJ_MPIAIJ() line 902 in
[ 5] MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1676 in
[ 5] PetscTableCreate() line 52 in
[ 5] PetscTableCreateHashSize() line 28 in
[ 5] Argument out of range
[ 5] A really huge hash is being requested.. cannot process: 4096000
  File
line 122, in solve
  File
line 122, in solve
  File
line 122, in solve
[ 9] SNESSolve() line 4128 in
[ 9] SNESSolve_KSPONLY() line 40 in
[ 9] KSPSolve() line 620 in
[ 9] KSPSetUp() line 393 in
[ 9] PCSetUp() line 968 in
[ 9] PCSetUp_GAMG() line 524 in
[ 9] PCGAMGCoarsen_AGG() line 955 in
[ 9] MatTransposeMatMult() line 9962 in
[ 9] MatTransposeMatMult_MPIAIJ_MPIAIJ() line 902 in
[ 9] MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1676 in
[ 9] PetscTableCreate() line 52 in
[ 9] PetscTableCreateHashSize() line 28 in
[ 9] Argument out of range
[ 9] A really huge hash is being requested.. cannot process: 4096000
[ 4] SNESSolve() line 4128 in
[ 4] SNESSolve_KSPONLY() line 40 in
[ 4] KSPSolve() line 620 in
[ 4] KSPSetUp() line 393 in
[ 4] PCSetUp() line 968 in
[ 4] PCSetUp_GAMG() line 524 in
[ 4] PCGAMGCoarsen_AGG() line 955 in
[ 4] MatTransposeMatMult() line 9962 in
[ 4] MatTransposeMatMult_MPIAIJ_MPIAIJ() line 902 in
[ 4] MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1676 in
[ 4] PetscTableCreate() line 52 in
[ 4] PetscTableCreateHashSize() line 28 in
[ 4] Argument out of range
[ 4] A really huge hash is being requested.. cannot process: 4096000
  File
  File
line 122, in solve
  File
line 122, in solve
  File
  File
line 122, in solve
    solver.solve()
  File
line 122, in solve
  File
line 122, in solve
  File
    solver.solve()
  File
line 220, in solve
  File
line 220, in solve
  File
  File
  File
line 122, in solve
  File
    solver.solve()
  File
[13] SNESSolve() line 4128 in
[13] SNESSolve_KSPONLY() line 40 in
[13] KSPSolve() line 620 in
[13] KSPSetUp() line 393 in
[13] PCSetUp() line 968 in
[13] PCSetUp_GAMG() line 524 in
[13] PCGAMGCoarsen_AGG() line 955 in
[13] MatTransposeMatMult() line 9962 in
[13] MatTransposeMatMult_MPIAIJ_MPIAIJ() line 902 in
[13] MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1676 in
[13] PetscTableCreate() line 52 in
[13] PetscTableCreateHashSize() line 28 in
[13] Argument out of range
[13] A really huge hash is being requested.. cannot process: 4096000
    solver.solve()
  File
  File
line 220, in solve
  File
    solver.solve()
  File
line 122, in solve
    solver.solve()
petsc4py.PETSc.Error  File
line 122, in solve
: error code 63
[11] SNESSolve() line 4128 in
[11] SNESSolve_KSPONLY() line 40 in
[11] KSPSolve() line 620 in
[11] KSPSetUp() line 393 in
[11] PCSetUp() line 968 in
[11] PCSetUp_GAMG() line 524 in
[11] PCGAMGCoarsen_AGG() line 955 in
[11] MatTransposeMatMult() line 9962 in
[11] MatTransposeMatMult_MPIAIJ_MPIAIJ() line 902 in
[11] MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1676 in
[11] PetscTableCreate() line 52 in
[11] PetscTableCreateHashSize() line 28 in
[11] Argument out of range
[11] A really huge hash is being requested.. cannot process: 4096000
  File
line 220, in solve
    solver.solve()
  File
line 220, in solve
    solver.solve()
  File
line 220, in solve
    solver.solve()
  File
line 220, in solve
  File
line 122, in solve
  File
line 220, in solve
  File
line 122, in solve
  File
line 220, in solve
[14] SNESSolve() line 4128 in
[14] SNESSolve_KSPONLY() line 40 in
[14] KSPSolve() line 620 in
[14] KSPSetUp() line 393 in
[14] PCSetUp() line 968 in
[14] PCSetUp_GAMG() line 524 in
[14] PCGAMGCoarsen_AGG() line 955 in
[14] MatTransposeMatMult() line 9962 in
[14] MatTransposeMatMult_MPIAIJ_MPIAIJ() line 902 in
[14] MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1676 in
[14] PetscTableCreate() line 52 in
[14] PetscTableCreateHashSize() line 28 in
[14] Argument out of range
[14] A really huge hash is being requested.. cannot process: 4096000
  File
[19] SNESSolve() line 4128 in
[19] SNESSolve_KSPONLY() line 40 in
[19] KSPSolve() line 620 in
[19] KSPSetUp() line 393 in
[19] PCSetUp() line 968 in
[19] PCSetUp_GAMG() line 524 in
[19] PCGAMGCoarsen_AGG() line 955 in
[19] MatTransposeMatMult() line 9962 in
[19] MatTransposeMatMult_MPIAIJ_MPIAIJ() line 902 in
[19] MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1676 in
[19] PetscTableCreate() line 52 in
[19] PetscTableCreateHashSize() line 28 in
[19] Argument out of range
[19] A really huge hash is being requested.. cannot process: 4096000
  File
[15] SNESSolve() line 4128 in
[15] SNESSolve_KSPONLY() line 40 in
[15] KSPSolve() line 620 in
[15] KSPSetUp() line 393 in
[15] PCSetUp() line 968 in
[15] PCSetUp_GAMG() line 524 in
[15] PCGAMGCoarsen_AGG() line 955 in
[15] MatTransposeMatMult() line 9962 in
[15] MatTransposeMatMult_MPIAIJ_MPIAIJ() line 902 in
[15] MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1676 in
[15] PetscTableCreate() line 52 in
[15] PetscTableCreateHashSize() line 28 in
[15] Argument out of range
[15] A really huge hash is being requested.. cannot process: 4096000
[ 7] SNESSolve() line 4128 in
[ 7] SNESSolve_KSPONLY() line 40 in
[ 7] KSPSolve() line 620 in
[ 7] KSPSetUp() line 393 in
[ 7] PCSetUp() line 968 in
[ 7] PCSetUp_GAMG() line 524 in
[ 7] PCGAMGCoarsen_AGG() line 955 in
[ 7] MatTransposeMatMult() line 9962 in
[ 7] MatTransposeMatMult_MPIAIJ_MPIAIJ() line 902 in
[ 7] MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1676 in
[ 7] PetscTableCreate() line 52 in
[ 7] PetscTableCreateHashSize() line 28 in
[ 7] Argument out of range
[ 7] A really huge hash is being requested.. cannot process: 4096000
    solver.solve()
: error code 63
[12] SNESSolve() line 4128 in
[12] SNESSolve_KSPONLY() line 40 in
[12] KSPSolve() line 620 in
[12] KSPSetUp() line 393 in
[12] PCSetUp() line 968 in
[12] PCSetUp_GAMG() line 524 in
[12] PCGAMGCoarsen_AGG() line 955 in
[12] MatTransposeMatMult() line 9962 in
[12] MatTransposeMatMult_MPIAIJ_MPIAIJ() line 902 in
[12] MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1676 in
[12] PetscTableCreate() line 52 in
[12] PetscTableCreateHashSize() line 28 in
[12] Argument out of range
[12] A really huge hash is being requested.. cannot process: 4096000
    solver.solve()
  File
petsc4py.PETSc.Error:   File "PETSc/SNES.pyx", line 537, in
petsc4py.PETSc.SNES.solve (src/petsc4py.PETSc.c:172359)
error code 63
[ 2] SNESSolve() line 4128 in
[ 2] SNESSolve_KSPONLY() line 40 in
[ 2] KSPSolve() line 620 in
[ 2] KSPSetUp() line 393 in
[ 2] PCSetUp() line 968 in
[ 2] PCSetUp_GAMG() line 524 in
[ 2] PCGAMGCoarsen_AGG() line 955 in
[ 2] MatTransposeMatMult() line 9962 in
[ 2] MatTransposeMatMult_MPIAIJ_MPIAIJ() line 902 in
[ 2] MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1676 in
[ 2] PetscTableCreate() line 52 in
[ 2] PetscTableCreateHashSize() line 28 in
[ 2] Argument out of range
[ 2] A really huge hash is being requested.. cannot process: 4096000
line 220, in solve
: error code 63
[ 8] SNESSolve() line 4128 in
[ 8] SNESSolve_KSPONLY() line 40 in
[ 8] KSPSolve() line 620 in
[ 8] KSPSetUp() line 393 in
[ 8] PCSetUp() line 968 in
[ 8] PCSetUp_GAMG() line 524 in
[ 8] PCGAMGCoarsen_AGG() line 955 in
[ 8] MatTransposeMatMult() line 9962 in
[ 8] MatTransposeMatMult_MPIAIJ_MPIAIJ() line 902 in
[ 8] MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1676 in
[ 8] PetscTableCreate() line 52 in
[ 8] PetscTableCreateHashSize() line 28 in
[ 8] Argument out of range
[ 8] A really huge hash is being requested.. cannot process: 4096000
  File
line 220, in solve
    solver.solve()
    solver.solve()
  File
line 220, in solve
  File
line 220, in solve
petsc4py.PETSc.Error    self.snes.solve(None, v)
: error code 63
[18] SNESSolve() line 4128 in
[18] SNESSolve_KSPONLY() line 40 in
[18] KSPSolve() line 620 in
[18] KSPSetUp() line 393 in
[18] PCSetUp() line 968 in
[18] PCSetUp_GAMG() line 524 in
[18] PCGAMGCoarsen_AGG() line 955 in
[18] MatTransposeMatMult() line 9962 in
[18] MatTransposeMatMult_MPIAIJ_MPIAIJ() line 902 in
[18] MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1676 in
[18] PetscTableCreate() line 52 in
[18] PetscTableCreateHashSize() line 28 in
[18] Argument out of range
[18] A really huge hash is being requested.. cannot process: 4096000
petsc4py.PETSc.Errorpetsc4py.PETSc.Error: error code 63
[ 0] SNESSolve() line 4128 in
[ 0] SNESSolve_KSPONLY() line 40 in
[ 0] KSPSolve() line 620 in
[ 0] KSPSetUp() line 393 in
[ 0] PCSetUp() line 968 in
[ 0] PCSetUp_GAMG() line 524 in
[ 0] PCGAMGCoarsen_AGG() line 955 in
[ 0] MatTransposeMatMult() line 9962 in
[ 0] MatTransposeMatMult_MPIAIJ_MPIAIJ() line 902 in
[ 0] MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1676 in
[ 0] PetscTableCreate() line 52 in
[ 0] PetscTableCreateHashSize() line 28 in
[ 0] Argument out of range
[ 0] A really huge hash is being requested.. cannot process: 4096000
: error code 63
[16] SNESSolve() line 4128 in
[16] SNESSolve_KSPONLY() line 40 in
[16] KSPSolve() line 620 in
[16] KSPSetUp() line 393 in
[16] PCSetUp() line 968 in
[16] PCSetUp_GAMG() line 524 in
[16] PCGAMGCoarsen_AGG() line 955 in
[16] MatTransposeMatMult() line 9962 in
[16] MatTransposeMatMult_MPIAIJ_MPIAIJ() line 902 in
[16] MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1676 in
[16] PetscTableCreate() line 52 in
[16] PetscTableCreateHashSize() line 28 in
[16] Argument out of range
[16] A really huge hash is being requested.. cannot process: 4096000
[10] SNESSolve() line 4128 in
[10] SNESSolve_KSPONLY() line 40 in
[10] KSPSolve() line 620 in
[10] KSPSetUp() line 393 in
[10] PCSetUp() line 968 in
[10] PCSetUp_GAMG() line 524 in
[10] PCGAMGCoarsen_AGG() line 955 in
[10] MatTransposeMatMult() line 9962 in
[10] MatTransposeMatMult_MPIAIJ_MPIAIJ() line 902 in
[10] MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1676 in
[10] PetscTableCreate() line 52 in
[10] PetscTableCreateHashSize() line 28 in
[10] Argument out of range
[10] A really huge hash is being requested.. cannot process: 4096000
[compute-0-0.local:31182] 19 more processes have sent help message
help-mpi-api.txt / mpi-abort
[compute-0-0.local:31182] Set MCA parameter "orte_base_help_aggregate" to 0
to see all help / error messages
However, if I use either ML or HYPRE i do not. When I downscale the problem
to roughly 1.7 million dofs, I get no such error with GAMG, but both ML and
HYPRE are still faster.
Something tells me I need to tune the GAMG parameters. Here's some -GAMG
related info that may help:
[0] PCSetUp_GAMG(): level 0) N=4096000, n data rows=1, n data cols=1,
nnz/row (ave)=55, np=20
[0] PCGAMGFilterGraph():      78.5842% nnz after filtering, with threshold
0., 55.8 nnz ave. (N=4096000)
[0] PCGAMGCoarsen_AGG(): Square Graph on level 1 of 1 to square
And if I run with -pc_gamg_threshold 0.08:
[0] PCGAMGFilterGraph():      28.5842% nnz after filtering, with threshold
0.08, 55.8 nnz ave. (N=4096000)
Any idea what to do here?
Justin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170219/d365e663/attachment-0001.html>
