[petsc-users] A way to distribute 3D arrays.
    Matthew Knepley
    knepley at gmail.com
    Sat Feb 18 15:03:04 CST 2017
On Sat, Feb 18, 2017 at 2:54 PM, Manuel Valera <mvalera at mail.sdsu.edu>
wrote:
> Is very easy Matthew, im porting a serial code into a parallel petsc based
> one and i want to do it in the most natural straightforward way, also im
> learning petsc at the same time.
> So the original code uses staggered grid and every variable is stored in a
> separate array, so i created a DA for each common array of them but they
> differ in just +/-1 to +/-3 in each dimension.
> So i guess i should allocate all of them in the same DA and just ignore
> the extra non used points for some arrays, right?
I have seen many staggered grid implementation in PETSc, but the most
successful have been those that used a single DA for everything,
and just allowed some points at the boundary to unused. I would advocate
this, but before you do it I would make a detailed drawing of the
3 layers around a corner, showing all unknowns and marking them with their
indices. This is invaluable when writing the equations.
     Matt
> Regards,
> Manuel
> On Sat, Feb 18, 2017 at 12:49 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Sat, Feb 18, 2017 at 2:44 PM, Manuel Valera <mvalera at mail.sdsu.edu>
>> wrote:
>>> thanks guys that helped a lot!
>>> I think i got it know, i copy the code i created in case you want to
>>> suggest something or maybe use it as example...
>>> I have a bonus question: Im going to operate next in several arrays at
>>> the same time, i created them using their slightly different layouts, one
>>> DA each, a peer told me different DA are not guaranteed to share the same
>>> corners, is this correct? if so, is there a way to enforce that? Thanks
>> I do not understand. Do these DAs have the same size, meaning number of
>> vertices in X, Y, and Z? If so, why are you
>> using separate arrays. You can just use 'dof' to put all your data there,
>> and strip out subvectors using VecStride
>> functions, such as
>>   http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpage
>> s/Vec/VecStrideScatter.html
>> If the DAs are different sizes, how would they ever have the same corners.
>>   Thanks,
>>      Matt
>>> SUBROUTINE DAs(da,veczero,localv,array)
>>>        ! use PetscObjects, only :: ierr
>>>        ! Umbrella program to update and communicate the arrays in a
>>>        ! distributed fashion using the DMDA objects from PETSc.
>>>        ! Manuel Valera 1/20/17
>>>        ! Arguments:
>>>        ! da = DMDA array (3D) already created and setup
>>>        ! veczero =
>>>        ! globalv =
>>>        ! localv = local chunk each processor works in.
>>>        ! array = the array to be petscified. ONLY 3D ARRAYS as now.
>>>        ! arrayp = the petsc version of the array, may be not needed.
>>>        ! cta = the scatter context to translate globalv to localv in DA
>>> indices
>>>         Vec,intent(inout)             :: veczero,localv
>>>         Vec                           :: natural,globalv
>>>         PetscScalar,dimension(:,:,:)  :: array
>>>         PetscScalar,pointer,dimension(:,:,:) :: arrayp
>>>         DM,intent(inout)              :: da
>>>         VecScatter                    :: cta
>>>         PetscInt                      ::xind,yind,zind,xwidth,ywidt
>>> h,zwidth
>>>         !Debug:
>>>         !print*,"INFO BEFORE SCATTER:"
>>>         call  DAinf(da,xind,yind,zind,xwidth,ywidth,zwidth)
>>>         print*, SIZE(array,1),'x',SIZE(array,2),'x',SIZE(array,3)
>>>         call DMCreateLocalVector(da,localv,ierr)
>>>         !The following if-block is an attempt to scatter the arrays as
>>> vectors
>>>         !loaded from master node.
>>>       if (sizex/= 1)then
>>>         !PETSC Devs suggested:
>>>         !Buffer 3d array natural has diff ordering than DMDAs:
>>>         call DMDACreateNaturalVector(da,natural,ierr)
>>>         call DMDAVecGetArrayF90(da,natural,arrayp,ierr)
>>>         !**fill up veczero***:
>>>         !TODO
>>>         if(rank==0)then
>>>         arrayp = array(xind+1:xwidth,yind+1:ywidth,zind+1:zwidth)
>>>         endif
>>>         call DMDAVecRestoreArrayF90(da,natural,arrayp,ierr)
>>>         !call DMRestoreNaturalVector(da,natural,ierr)      !???? not
>>> needed?
>>>         !Distributing array:
>>>         call VecScatterCreateToZero(natural,cta,veczero,ierr)
>>>         call VecScatterBegin(cta,veczero,na
>>> tural,INSERT_VALUES,SCATTER_REVERSE,ierr)
>>>         call VecScatterEnd(cta,veczero,natu
>>>         call DMCreateGlobalVector(da,globalv,ierr)
>>>         call DMDANaturalToGlobalBegin(da,na
>>> tural,INSERT_VALUES,globalv,ierr)
>>>         call DMDANaturalToGlobalEnd(da,natu
>>>         call DMGlobalToLocalBegin(da,globalv,INSERT_VALUES,localv,ierr)
>>>         call DMGlobalToLocalEnd(da,globalv,INSERT_VALUES,localv,ierr)
>>>       else
>>>         print*, "This should be called in serial only."
>>>         call DMDAVecGetArrayF90(da,localv,arrayp,ierr)
>>>         arrayp = array
>>>         call DMDAVecRestoreArrayF90(da,localv,arrayp,ierr)
>>>         call DMRestoreLocalVector(da,localv,ierr)
>>>       endif
>>>       call  VecDestroy(globalv,ierr)
>>>       call  VecScatterDestroy(cta,ierr)
>>>       call  VecDestroy(natural,ierr)
>>>  END SUBROUTINE DAs
>>> On Wed, Feb 15, 2017 at 7:31 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>>   You can do this in the style of
>>>>  VecLoad_Binary_DA()
>>>> first you take your sequential vector and make it parallel in the
>>>> "natural" ordering for 3d arrays
>>>>   DMDACreateNaturalVector(da,&natural);
>>>>   VecScatterCreateToZero(natural,&scatter,&veczero);  /* veczero is of
>>>> full size on process 0 and has zero entries on all other processes*/
>>>>   /* fill up veczero */
>>>>    VecScatterBegin(scatter,veczero,natural,INSERT_VALUES,SCATT
>>>> ER_REVERSE);
>>>> VecScatterEnd(scatter,veczero,natural,INSERT_VALUES,SCATTER_REVERSE);
>>>>  and then move it into the PETSc DMDA parallel ordering vector with
>>>>   ierr = DMCreateGlobalVector(da,&xin);CHKERRQ(ierr);
>>>>   ierr = DMDANaturalToGlobalBegin(da,natural,INSERT_VALUES,xin);CHKER
>>>> RQ(ierr);
>>>>   ierr = DMDANaturalToGlobalEnd(da,natural,INSERT_VALUES,xin);CHKERRQ
>>>> (ierr);
>>>> > On Feb 15, 2017, at 7:16 PM, Manuel Valera <mvalera at mail.sdsu.edu>
>>>> wrote:
>>>> > Hello,
>>>> > My question this time is just if there is a way to distribute a 3D
>>>> array whos located at Zero rank over the processors, if possible using the
>>>> DMDAs, i'm trying not to do a lot of initialization I/O in parallel.
>>>> > Thanks for your time,
>>>> > Manuel
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170218/4efe2827/attachment.html>
