[petsc-users] A way to distribute 3D arrays.
Manuel Valera mvalera at mail.sdsu.edu
Sat Feb 18 14:44:13 CST 2017
thanks guys that helped a lot!
I think i got it know, i copy the code i created in case you want to
suggest something or maybe use it as example...
I have a bonus question: Im going to operate next in several arrays at the
same time, i created them using their slightly different layouts, one DA
each, a peer told me different DA are not guaranteed to share the same
corners, is this correct? if so, is there a way to enforce that? Thanks
SUBROUTINE DAs(da,veczero,localv,array)
       ! use PetscObjects, only :: ierr
       ! Umbrella program to update and communicate the arrays in a
       ! distributed fashion using the DMDA objects from PETSc.
       ! Manuel Valera 1/20/17
       ! Arguments:
       ! da = DMDA array (3D) already created and setup
       ! veczero =
       ! globalv =
       ! localv = local chunk each processor works in.
       ! array = the array to be petscified. ONLY 3D ARRAYS as now.
       ! arrayp = the petsc version of the array, may be not needed.
       ! cta = the scatter context to translate globalv to localv in DA
indices
        Vec,intent(inout)             :: veczero,localv
        Vec                           :: natural,globalv
        PetscScalar,dimension(:,:,:)  :: array
        PetscScalar,pointer,dimension(:,:,:) :: arrayp
        DM,intent(inout)              :: da
        VecScatter                    :: cta
        PetscInt                      ::xind,yind,zind,xwidth,ywidth,zwidth
        !Debug:
        !print*,"INFO BEFORE SCATTER:"
        call  DAinf(da,xind,yind,zind,xwidth,ywidth,zwidth)
        print*, SIZE(array,1),'x',SIZE(array,2),'x',SIZE(array,3)
        call DMCreateLocalVector(da,localv,ierr)
        !The following if-block is an attempt to scatter the arrays as
vectors
        !loaded from master node.
      if (sizex/= 1)then
        !PETSC Devs suggested:
        !Buffer 3d array natural has diff ordering than DMDAs:
        call DMDACreateNaturalVector(da,natural,ierr)
        call DMDAVecGetArrayF90(da,natural,arrayp,ierr)
        !**fill up veczero***:
        !TODO
        if(rank==0)then
        arrayp = array(xind+1:xwidth,yind+1:ywidth,zind+1:zwidth)
        endif
        call DMDAVecRestoreArrayF90(da,natural,arrayp,ierr)
        !call DMRestoreNaturalVector(da,natural,ierr)      !???? not needed?
        !Distributing array:
        call VecScatterCreateToZero(natural,cta,veczero,ierr)
        call
VecScatterBegin(cta,veczero,natural,INSERT_VALUES,SCATTER_REVERSE,ierr)
        call
VecScatterEnd(cta,veczero,natural,INSERT_VALUES,SCATTER_REVERSE,ierr)
        call DMCreateGlobalVector(da,globalv,ierr)
        call DMDANaturalToGlobalBegin(da,natural,INSERT_VALUES,globalv,ierr)
        call DMDANaturalToGlobalEnd(da,natural,INSERT_VALUES,globalv,ierr)
        call DMGlobalToLocalBegin(da,globalv,INSERT_VALUES,localv,ierr)
        call DMGlobalToLocalEnd(da,globalv,INSERT_VALUES,localv,ierr)
      else
        print*, "This should be called in serial only."
        call DMDAVecGetArrayF90(da,localv,arrayp,ierr)
        arrayp = array
        call DMDAVecRestoreArrayF90(da,localv,arrayp,ierr)
        call DMRestoreLocalVector(da,localv,ierr)
      endif
      call  VecDestroy(globalv,ierr)
      call  VecScatterDestroy(cta,ierr)
      call  VecDestroy(natural,ierr)
 END SUBROUTINE DAs
On Wed, Feb 15, 2017 at 7:31 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   You can do this in the style of
>  VecLoad_Binary_DA()
> first you take your sequential vector and make it parallel in the
> "natural" ordering for 3d arrays
>   DMDACreateNaturalVector(da,&natural);
>   VecScatterCreateToZero(natural,&scatter,&veczero);  /* veczero is of
> full size on process 0 and has zero entries on all other processes*/
>   /* fill up veczero */
>    VecScatterBegin(scatter,veczero,natural,INSERT_VALUES,SCATTER_REVERSE);
> VecScatterEnd(scatter,veczero,natural,INSERT_VALUES,SCATTER_REVERSE);
>  and then move it into the PETSc DMDA parallel ordering vector with
>   ierr = DMCreateGlobalVector(da,&xin);CHKERRQ(ierr);
>   ierr = DMDANaturalToGlobalBegin(da,natural,INSERT_VALUES,xin);
> CHKERRQ(ierr);
>   ierr = DMDANaturalToGlobalEnd(da,natural,INSERT_VALUES,xin);
> CHKERRQ(ierr);
> > On Feb 15, 2017, at 7:16 PM, Manuel Valera <mvalera at mail.sdsu.edu>
> wrote:
> > Hello,
> > My question this time is just if there is a way to distribute a 3D array
> whos located at Zero rank over the processors, if possible using the DMDAs,
> i'm trying not to do a lot of initialization I/O in parallel.
> > Thanks for your time,
> > Manuel
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170218/414e4452/attachment.html>
