[petsc-users] PETSc set off-diagonal matrix pre-allocation
Andrew Ho
andrewh0 at uw.edu
Wed Feb 15 14:34:54 CST 2017
I'm guessing it's because I'm using an optimized build why I get less error
checking. But regardless, what does the "local" column size mean in terms
of which MPI rank owns what portion of the matrix?
Is that the size of the local diagonal block when specifying the non-zeros
for pre-allocation?
The documentation does not make this part clear at all to me.
On Wed, Feb 15, 2017 at 11:01 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Strange. I run your example and get an error message as I expect.
> $ petscmpiexec -n 4 ./ex5
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Nonconforming object sizes
> [0]PETSC ERROR: Sum of local lengths 12 does not equal global length 6, my
> local length 3
> likely a call to VecSetSizes() or MatSetSizes() is wrong.
> See http://www.mcs.anl.gov/petsc/documentation/faq.html#split
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.7.5-3049-ge39721325b
> GIT Date: 2017-02-05 20:43:45 -0600
> [0]PETSC ERROR: ./ex5 on a arch-basic named visitor097-125.wl.anl-
> external.org by barrysmith Wed Feb 15 12:55:53 2017
> [0]PETSC ERROR: Configure options --download-mpich PETSC_ARCH=arch-basic
> --download-hdf5 --download-triangle
> [0]PETSC ERROR: #1 PetscSplitOwnership() line 89 in
> /Users/barrysmith/Src/petsc/src/sys/utils/psplit.c
> [0]PETSC ERROR: #2 PetscLayoutSetUp() line 137 in
> /Users/barrysmith/Src/petsc/src/vec/is/utils/pmap.c
> [0]PETSC ERROR: #3 MatMPIAIJSetPreallocation_MPIAIJ() line 2640 in
> /Users/barrysmith/Src/petsc/src/mat/impls/aij/mpi/mpiaij.c
> [0]PETSC ERROR: #4 MatMPIAIJSetPreallocation() line 3368 in
> [0]PETSC ERROR: #5 main() line 34 in /Users/barrysmith/Src/petsc/
> test-directory/ex5.c
> [0]PETSC ERROR: PETSc Option Table entries:
> [0]PETSC ERROR: -malloc_test
> [0]PETSC ERROR: ----------------End of Error Message -------send entire
> error message to petsc-maint at mcs.anl.gov----------
> [1]PETSC ERROR: --------------------- Error Message
> [1]PETSC ERROR: Nonconforming object sizes
> [1]PETSC ERROR: Sum of local lengths 12 does not equal global length 6, my
> local length 3
> Note that the input you provide is not consistent. You claim the matrix
> has a total of 6 rows but then you try to assign 3 rows to the first
> process, 3 rows to the second, 3 rows to the third, 3 rows to the fourth
> for a total of 12 rows. Hence it should error. Similarly the sum of the
> "local sizes" for columns has to sum up to exactly the total number of
> columns.
> > On Feb 15, 2017, at 9:52 AM, Andrew Ho <andrewh0 at uw.edu> wrote:
> > I don't understand how the matrices are partitioned then. The
> documentation online all shows each mpi rank owning entire rows, with no
> partitioning along columns.
> > I've attached an example where I try to partition a 6x7 matrix into 4
> ranks:
> > rank 0 should own a 3x4 section
> > rank 1 should own a 3x3 section
> > rank 2 should own a 3x4 section
> > rank 3 should own a 3x3 section
> > However, when I run the example and print out the ownership range and
> ownership column range, I get:
> > rank 0 owns rows/cols: [0,3), [0, 4)
> > rank 1 owns rows/cols: [3,6), [4, 7)
> > rank 2 owns rows/cols: [6,9), [7, 11)
> > rank 3 owns rows/cols: [9,12), [11, 14)
> > Which makes no sense since these ranges extend beyond the actual size of
> the matrix.
> > On Tue, Feb 14, 2017 at 6:05 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > 1) on a single process all the columns are in the diagonal block and
> none in the off diagonal block (note that the column partitioning
> corresponding to a partitioning of the vector in the product A *x
> > 2) on two processes you guessed wrong how many columns PETSc would
> put on the first process. You guessed it would put the first three on the
> first process and the last three on the second process.
> > a) it cannot do that, every column has to been owned by some process
> (in the vector x above) so it cannot be 3 and 3, it has to be 4 and 3 or 3
> and 4.
> > b) PETSc puts the "extra" columns on the earlier processes not the
> later processes.
> > For rectangular matrices you really cannot get away with using
> "PETSC_DECIDE" for local columns when using preallocation
> > , since it may decide something different than what you assume.
> > I've attached the parallel code that behaves as expected.
> > Barry
> > > On Feb 14, 2017, at 1:06 PM, Andrew Ho <andrewh0 at uw.edu> wrote:
> > > The problem isn't only with 1 process, but it seems to be with all
> non-square matrices?
> > > For example, here I have a two process program which tries to set a
> 6x7 matrix to (each process owns 3 rows):
> > > 0 0 0 1 1 1 1
> > > 0 0 0 1 1 1 1
> > > 0 0 0 1 1 1 1
> > > 0 0 0 1 1 1 1
> > > 0 0 0 1 1 1 1
> > > 0 0 0 1 1 1 1
> > > #include <petsc.h>
> > > #include <mpi.h>
> > > int main(int argc, char** argv)
> > > PetscErrorCode err;
> > > err = PetscInitialize(&argc, &argv, NULL, "help");
> > > CHKERRQ(err);
> > > int rank, size;
> > > MPI_Comm_rank(MPI_COMM_WORLD, &rank);
> > > MPI_Comm_size(MPI_COMM_WORLD, &size);
> > > if(size != 2)
> > > printf("must run with 2 processes");
> > > MPI_Abort(MPI_COMM_WORLD, -1);
> > > // create a sparse AIJ matrix distributed across MPI
> > > Mat A;
> > > err = MatCreate(MPI_COMM_WORLD, &A);
> > > CHKERRQ(err);
> > > err = MatSetType(A, MATMPIAIJ);
> > > CHKERRQ(err);
> > > // setup pre-allocation for matrix space
> > > err =
> > > MatSetSizes(A, 3, PETSC_DECIDE, 6, 7);
> > > CHKERRQ(err);
> > > if(rank == 0)
> > > PetscInt d_nnz[] = {0, 0, 0};
> > > PetscInt o_nnz[] = {4, 4, 4};
> > > err = MatMPIAIJSetPreallocation(A, 0, d_nnz, 0, o_nnz);
> > > CHKERRQ(err);
> > > else
> > > PetscInt d_nnz[] = {3, 3, 3};
> > > PetscInt o_nnz[] = {1, 1, 1};
> > > CHKERRQ(err);
> > > err = MatSetUp(A);
> > > CHKERRQ(err);
> > > // set values inside the matrix
> > > for (PetscInt row = 0; row < 3; ++row)
> > > for (PetscInt col = 3; col < 7; ++col)
> > > err = MatSetValue(A, 3 * rank + row, col, 1, INSERT_VALUES);
> > > CHKERRQ(err);
> > > err = MatAssemblyBegin(A, MAT_FINAL_ASSEMBLY);
> > > CHKERRQ(err);
> > > err = MatAssemblyEnd(A, MAT_FINAL_ASSEMBLY);
> > > CHKERRQ(err);
> > > err = MatView(A, PETSC_VIEWER_STDOUT_WORLD);
> > > CHKERRQ(err);
> > > // free memory
> > > err = MatDestroy(&A);
> > > CHKERRQ(err);
> > > // cleanup any internal PETSc data at end of program
> > > err = PetscFinalize();
> > > CHKERRQ(err);
> > > On Tue, Feb 14, 2017 at 5:26 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
> > > On Tue, Feb 14, 2017 at 6:41 AM, Andrew Ho <andrewh0 at uw.edu> wrote:
> > > I have a 3x6 matrix, and I want to set it to (just as an example):
> > > 0 0 0 1 1 1
> > > 0 0 0 1 1 1
> > > 0 0 0 1 1 1
> > > From what I can tell, according to the documentation the MPIAIJ
> sparsity of this matrix is:
> > > I believe this is an inconsistency in PETSc for rectangular matrices.
> We divide matrices into diagonal and
> > > off-diagonal parts mainly to separate communication from computation.
> Thus on 1 proc, we never divide
> > > them, even if the matrix is rectangular. Therefore we misinterpret
> your preallocation.
> > > Barry, do you think we want to try and change this?
> > > Matt
> > > d_nnz = [0, 0, 0]
> > > o_nnz = [3, 3, 3]
> > > However, when I do this, I get the following error:
> > > [0]PETSC ERROR: Argument out of range
> > > [0]PETSC ERROR: New nonzero at (0,3) caused a malloc
> > > Use MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE) to
> turn off this check
> documentation/faq.html for trouble shooting.
> > > [0]PETSC ERROR: Petsc Release Version 3.7.5, unknown
> > > [0]PETSC ERROR: ./ex3 on a arch-linux2-c-opt Tue Feb 14 04:23:56 2017
> > > [0]PETSC ERROR: Configure options --with-debugging=0 --COPTFLAGS="-O3
> -march=native" --CXXOPTFLAGS="-O3 -march=native" --FOPTFLAGS="-O3
> -march=native"
> > > [0]PETSC ERROR: #1 MatSetValues_MPIAIJ() line 582 in
> > > [0]PETSC ERROR: #2 MatSetValues() line 1190 in petsc/src/mat/interface/
> matrix.c
> > > [0]PETSC ERROR: #3 main() line 36 in ex3.c
> > > [0]PETSC ERROR: No PETSc Option Table entries
> entire error message to petsc-maint at mcs.anl.gov----------
> > > Here's a working test code:
> > > #include <petsc.h>
> > > #include <mpi.h>
> > > PetscErrorCode err;
> > > CHKERRQ(err);
> > > PetscInt global_width = 6;
> > > PetscInt global_height = 3;
> > > Mat A;
> > > CHKERRQ(err);
> > > CHKERRQ(err);
> > > err =
> > > MatSetSizes(A, global_height, PETSC_DECIDE, global_height,
> global_width);
> > > CHKERRQ(err);
> > > PetscInt o_nnz[] = {3, 3, 3};
> > > CHKERRQ(err);
> > > err = MatSetUp(A);
> > > CHKERRQ(err);
> > > for (PetscInt row = 0; row < global_height; ++row)
> > > for (PetscInt col = global_height; col < global_width; ++col)
> > > err = MatSetValue(A, row, col, 1, INSERT_VALUES);
> > > CHKERRQ(err);
> > > CHKERRQ(err);
> > > CHKERRQ(err);
> > > CHKERRQ(err);
> > > // free memory
> > > CHKERRQ(err);
> > > CHKERRQ(err);
> > > Am I mis-understanding what the d_nnz and o_nnz parameter are supposed
> to mean?
> > > Andrew Ho
> > > What most experimenters take for granted before they begin their
> experiments lead.
> > > -- Norbert Wiener
> > > Andrew Ho
> > Andrew Ho
> > <ex3.c>
Andrew Ho
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170215/bd5255a3/attachment-0001.html>
