[petsc-users] multigrid questions
Jed Brown
jed at jedbrown.org
Wed Feb 15 13:34:54 CST 2017
Barry Smith <bsmith at mcs.anl.gov> writes:
> For optimal implementation of line relaxation (assuming each
> process is only doing sequential lines) you would write a PCSHELL
> that looped over the "lines" for your geometry and use inside it a
> PC created with the tridiagonal matrix for a line.
Or (less code) assemble a Pmat that skips insertions across lines. That
will make a bunch of tridiagonal segments on each process and a direct
solver will be trivially cheap (ILU(0) is a direct solver).
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170215/0869fff4/attachment.pgp>
