[petsc-users] TS question 1: how to stop explicit methods because they do not use SNES(VI)?
Jed Brown
jed at jedbrown.org
Wed Feb 15 12:37:10 CST 2017
Ed Bueler <elbueler at alaska.edu> writes:
> Jed --
>>> u_t - div (u^k |grad u|^{p-2} grad u) = g(t,u)
>>Are you also interested in the case with sliding?
> You must be getting grumpy. There is this 2009 paper about sliding ...
> Yes I am interested in sliding but I was trying to keep things simple for
> you. ;-)
My point was that including sliding potentially adds another
stiff/algebraic term so whatever interface we choose better be able to
support at least two stiff terms.
> The code in question is an under-development example in my book that I am
> trying to use to show off SNESVI functionality in an interesting case and
> yet not get too nasty. See the help string at the top of the file for what
> it actually does:
> https://github.com/bueler/p4pdes/blob/master/c/ch11/ice.c
> In summary, the actual flux is
> q_total = - Gamma H^{n+2} |grad s|^{n-1} grad s + V H
Is V really a prescribed function or the solution of an equation that
involves u?
> and it is all handled implicitly by preference, i.e. in the current API I
> have IFunction = u_t - div q_total.
> The real interest of the problem is the failure of long-range communication
> of low-(spatial)-frequency information when you hit the free boundary, and
> these barriers can emerge anywhere in the domain. (In a mountain range you
> can have neighboring small glaciers completely out of phase; how should
> multigrid ... or any other preconditioning one would hope for ... work for
> all the glaciers in a mountain range?
This already exists for variable coefficient problems -- the electric
potential in a twisted wire pair is independent despite being nearby
points in the solution of a Poisson equation.
An important difference from ice sheets is that the Green's functions
are highly nonlocal for the twisted wire pair, but very local for ice
sheets with sticky beds. With slippery beds (ice shelves are the
limiting case), the velocity Green's functions become similar to
Poisson. That is the scenario where multigrid is needed. Otherwise the
solutions are quite local.
For the SIA thickness equation, I think it would be interesting to
consider the conductivity tensor in the Newton linearization.
d_u [-div (u^k |grad u|^{p-2} grad u)] * w
= -div (k w^{k-1} |grad u|^{p-2} grad u)
-div (u^k [|grad u|^{p-2} I + (p-2) |grad u|^{p-4} grad u \otimes grad u] grad w)
The first part is transport of the perturbation w. The next is
diffusion of w with an anisotropic conductivity tensor.
> So now I'll emphasize what I said before: it is *degenerate* p-bratu.
To my knowledge, "p-Bratu" is just something I invented to combine two
nonlinearities. You don't have an e^u nonlinearity so there is no
Bratu-type nonlinearity.
> Doubly-degenerate because p>2, but the "H^{n+2}" aka "u^k" is the bad
> thing that makes the abrupt free boundary.) Sliding, in this regard,
> is the easy case, so I am throwing it in by generating an artificial
> velocity field; yes this is the coupling that should include the SSA
> in the future ... we already have an SSA solver or two that behave
> surprisingly well, you know, as long as the boundary conditions can be
> figured-out.
I think sliding is the only phenomena that produces a nonlocal response.
Consider an ice shelf. The thickness and slope at the grounding line
instantaneously affect the seaward edge of the shelf. Grounded SIA has
no such dynamics.
>> I would just have a PetscOptionsEList() for whether to evaluate the
>> diffusive term on the left or right. Shouldn't be more than a few lines
>> of code.
> So I have something like?:
> -ice_diffusive_side left,right
> O.k. What if user says
> -ts_type rk -ice_diffusive_side left
> Then I get the current brokenness: code runs and produces nonsense because
> RK does not call SNESVI (constraint never enforced) *and* diffusive stuff
> is never evaluated (because RK does not call IFunction).
Yes, I think TSRK should error if IFunction has been specified.
> So maybe then I also go through possible -ts_types and check whether the
> option combination made sense? Or move some terms to the correct side
> based on what that -ts_type should want? Do I include -ts_type sundials
> because somebody's config might include that third-party thing (even though
> mine doesn't)?
I am not suggesting switching on TS type. I guess I felt that having
dependent options was acceptable in exchange for it being easy/reliable
to know which terms are being treated explicitly or implicitly. If the
method takes over that choice, it makes the interface "smarter" which is
not necessarily a good thing. It requires copious documentation and
diagnostics so the user can tell what the hell is happening under the
hood. But I see the utility.
> That's what I mean by fragile code.
> Such things build up! Each time you shove cool stuff in my face I have to
> get used to seeing ugly stuff turn into beautiful stuff as my aesthetic
> sense follows my growing understanding. But it takes time (learning curve)
> and all the time it is fragile code (i.e. for me ... because I don't
> appreciate all the motivations behind that part of the API ...)
> On the other hand ... I agree that if I am convinced this is really a good
> API for something I want, then indeed I will suck it up and learn it and
> write it.
> Recall my original request was for the ability to know if the TS type I
> have chosen will actually use the SNES I have set ... so long ago it now
> seems.
I think this is just how design conversations work.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170215/aebdf3b6/attachment.pgp>
