[petsc-users] TS question 1: how to stop explicit methods because they do not use SNES(VI)?
Zhang, Hong hongzhang at anl.gov
Tue Feb 14 22:24:24 CST 2017
On Feb 14, 2017, at 9:20 PM, Barry Smith <bsmith at mcs.anl.gov<mailto:bsmith at mcs.anl.gov>> wrote:
On Feb 14, 2017, at 8:56 PM, Emil Constantinescu <emconsta at mcs.anl.gov<mailto:emconsta at mcs.anl.gov>> wrote:
On 2/14/17 4:10 PM, Barry Smith wrote:
 Ok, you don't recompile but forcing that into user code is still disgusting. With my api the user code is
TSSetRHSFunction(ts,NULL,RHSFunction,&ptype[0]);
TSSetLHSFunction(ts,NULL,LHSFunction,&ptype[0]);
 TSSetRHSJacobian(ts,Jac,Jac,RHSJacobian,&ptype[0]);
TSSetLHSJacobian(ts,Jac,Jac,LHSJacobian,&ptype[0]);
and -ts_type xxx works correctly for ALL methods, implicit, explicit and imex without requiring any special command line options for different methods.
Is this a viable solution? Growing the API to fix this situation will just put a burden with each new TS method after we refactor it in the current landscape.
  No just the opposite, the TS implementations will talk to functions who will put things together for it. So All implicit methods will call something like TSBuildImplicitFunction(), all explicit methods will call something like TSBuildExplicitFunction() and then IMEX methods will call both of these. In fact likely we can refactor to make things a little better than today.  Depending on options and flagsTSBuildExplicitFunction() would build out of all the user provided functions what it needs etc.
One problem with the current code is the TS methods call things with the same names as the user API. So implicit methods call TSComputeIFunction() while explicit methods call TSComputeRHSFunction(). This is wrong because implicit methods actually also use the rhs function provided by the user.
The function below absolutely should not be called TSComputeIFunction()! It does not just compute IFunction()
PetscErrorCode TSComputeIFunction(TS ts,PetscReal t,Vec U,Vec Udot,Vec Y,PetscBool imex)
 PetscErrorCode ierr;
 TSIFunction    ifunction;
 TSRHSFunction  rhsfunction;
 void           *ctx;
 DM             dm;
 PetscFunctionBegin;
 PetscValidHeaderSpecific(ts,TS_CLASSID,1);
 PetscValidHeaderSpecific(U,VEC_CLASSID,3);
 PetscValidHeaderSpecific(Udot,VEC_CLASSID,4);
 PetscValidHeaderSpecific(Y,VEC_CLASSID,5);
 ierr = TSGetDM(ts,&dm);CHKERRQ(ierr);
 ierr = DMTSGetIFunction(dm,&ifunction,&ctx);CHKERRQ(ierr);
 ierr = DMTSGetRHSFunction(dm,&rhsfunction,NULL);CHKERRQ(ierr);
 if (!rhsfunction && !ifunction) SETERRQ(PetscObjectComm((PetscObject)ts),PETSC_ERR_USER,"Must call TSSetRHSFunction() and / or TSSetIFunction()");
 ierr = PetscLogEventBegin(TS_FunctionEval,ts,U,Udot,Y);CHKERRQ(ierr);
 if (ifunction) {
   PetscStackPush("TS user implicit function");
   ierr = (*ifunction)(ts,t,U,Udot,Y,ctx);CHKERRQ(ierr);
   PetscStackPop;
 if (imex) {
   if (!ifunction) {
     ierr = VecCopy(Udot,Y);CHKERRQ(ierr);
 } else if (rhsfunction) {
   if (ifunction) {
     Vec Frhs;
     ierr = TSGetRHSVec_Private(ts,&Frhs);CHKERRQ(ierr);
     ierr = TSComputeRHSFunction(ts,t,U,Frhs);CHKERRQ(ierr);
     ierr = VecAXPY(Y,-1,Frhs);CHKERRQ(ierr);
   } else {
     ierr = TSComputeRHSFunction(ts,t,U,Y);CHKERRQ(ierr);
     ierr = VecAYPX(Y,-1,Udot);CHKERRQ(ierr);
 ierr = PetscLogEventEnd(TS_FunctionEval,ts,U,Udot,Y);CHKERRQ(ierr);
 PetscFunctionReturn(0);
The current code entangles too much of the user API to the methods, this can be fixed.
If the user experiments with different ways of splitting the solution they would have to define RHS and IF or RHS and LHS in different ways (according to the splittings they experiment with). It may look disgusting, but I don't see another way around it unless you allow for a list of operators to be defined and then the user to assign them to LHS or RHS.
  Jed suggested having any number of "RHS" functions. I don't think we need more than 2, 1 for left hand side and 1 for right. If that ends up being not enough we can change to have any number of them. Just to be clear. I suggest three functions
  IFunction which defaults to u_t  plus TSSetMassMatrix() which changes the default IFunction to M u_t
  LHS function which defaults to 0, if provided defaults to being treated implicitly by IMEX
  RHS function which defaults to 0, if provided defaults to being treated explicitly by IMEX
It is a great idea to require IFunction to be M u_t or u_t. This allows us to eliminate the weird 'shift' parameter in the current interface. But the LHS function would be as confusing as the old IFunction. Apparently it can be moved to the right hand side. So why don't we use
IFunction
RHS function 1 / RHSJacobian 1
RHS function 2 / RHSJacobian 2
... (and more if needed)
Also we can add command line options to control which RHS terms should be treated explicitly/implicitly, e.g.,
IMEX: -ts_implicit rhs1 -ts_explicit rhs2
fully implicit: -ts_implicit rhs1,rhs2
explicit: -ts_explicit rhs1,rhs2
Hong (Mr.)
  Then a TSSetStiffMatrix(ts,Mat L) (horrible name) that provides u_t -Lu = g() + Lu
  None of the TS implementations will every directly know about what the user has provided. They will call the wrapper functions I mention above.
  I think Jed and Emil may be too enamored with the reductionist model of only IFunction() and RHSFunction() to see that though it encompasses everything it may not be the best user API.
Adding all that logic to keep track of left sides and right sides for academic examples is likely not the best development.
I don't think it is "just academic examples", it is all examples without a mass matrix.
 Once the user has decided with ts_type to use for production if it is fully implicit or explicit then they can depending on the type selected, write just a left hand side, just a right hand side for higher efficiency (less update of ghost points, fewer iterations over loops etc).
 With a constant mass matrix we can have TSSetMassMatrix() and then TSSetIFunction() is reserved for when it is absolutely needed.
As much as I would disagree with growing the API at the level of defining the problem, I think TSSetMassMatrix() would let us do more things in the solvers. Also it would be useful to know if the mass matrix is singular or not for efficiency reasons.
Emil
Barry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170215/13f5ac60/attachment-0001.html>
