[petsc-users] PETSc set off-diagonal matrix pre-allocation
Andrew Ho
andrewh0 at uw.edu
Tue Feb 14 13:06:32 CST 2017
The problem isn't only with 1 process, but it seems to be with all
non-square matrices?
For example, here I have a two process program which tries to set a 6x7
matrix to (each process owns 3 rows):
0 0 0 1 1 1 1
0 0 0 1 1 1 1
0 0 0 1 1 1 1
0 0 0 1 1 1 1
0 0 0 1 1 1 1
0 0 0 1 1 1 1
#include <petsc.h>
#include <mpi.h>
int main(int argc, char** argv)
PetscErrorCode err;
err = PetscInitialize(&argc, &argv, NULL, "help");
CHKERRQ(err);
int rank, size;
MPI_Comm_rank(MPI_COMM_WORLD, &rank);
MPI_Comm_size(MPI_COMM_WORLD, &size);
if(size != 2)
printf("must run with 2 processes");
MPI_Abort(MPI_COMM_WORLD, -1);
// create a sparse AIJ matrix distributed across MPI
Mat A;
err = MatCreate(MPI_COMM_WORLD, &A);
CHKERRQ(err);
err = MatSetType(A, MATMPIAIJ);
CHKERRQ(err);
// setup pre-allocation for matrix space
err =
MatSetSizes(A, 3, PETSC_DECIDE, 6, 7);
CHKERRQ(err);
if(rank == 0)
PetscInt d_nnz[] = {0, 0, 0};
PetscInt o_nnz[] = {4, 4, 4};
err = MatMPIAIJSetPreallocation(A, 0, d_nnz, 0, o_nnz);
CHKERRQ(err);
else
PetscInt d_nnz[] = {3, 3, 3};
PetscInt o_nnz[] = {1, 1, 1};
CHKERRQ(err);
err = MatSetUp(A);
CHKERRQ(err);
// set values inside the matrix
for (PetscInt row = 0; row < 3; ++row)
for (PetscInt col = 3; col < 7; ++col)
err = MatSetValue(A, 3 * rank + row, col, 1, INSERT_VALUES);
CHKERRQ(err);
err = MatAssemblyBegin(A, MAT_FINAL_ASSEMBLY);
CHKERRQ(err);
err = MatAssemblyEnd(A, MAT_FINAL_ASSEMBLY);
CHKERRQ(err);
err = MatView(A, PETSC_VIEWER_STDOUT_WORLD);
CHKERRQ(err);
// free memory
err = MatDestroy(&A);
CHKERRQ(err);
// cleanup any internal PETSc data at end of program
err = PetscFinalize();
CHKERRQ(err);
On Tue, Feb 14, 2017 at 5:26 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Feb 14, 2017 at 6:41 AM, Andrew Ho <andrewh0 at uw.edu> wrote:
>> I have a 3x6 matrix, and I want to set it to (just as an example):
>> 0 0 0 1 1 1
>> 0 0 0 1 1 1
>> 0 0 0 1 1 1
>> From what I can tell, according to the documentation the MPIAIJ sparsity
>> of this matrix is:
> I believe this is an inconsistency in PETSc for rectangular matrices. We
> divide matrices into diagonal and
> off-diagonal parts mainly to separate communication from computation. Thus
> on 1 proc, we never divide
> them, even if the matrix is rectangular. Therefore we misinterpret your
> preallocation.
> Barry, do you think we want to try and change this?
> Matt
>> d_nnz = [0, 0, 0]
>> o_nnz = [3, 3, 3]
>> However, when I do this, I get the following error:
>> [0]PETSC ERROR: --------------------- Error Message
>>> [0]PETSC ERROR: Argument out of range
>>> [0]PETSC ERROR: New nonzero at (0,3) caused a malloc
>>> Use MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE) to
>>> turn off this check
>>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>>> for trouble shooting.
>>> [0]PETSC ERROR: Petsc Release Version 3.7.5, unknown
>>> [0]PETSC ERROR: ./ex3 on a arch-linux2-c-opt Tue Feb 14 04:23:56 2017
>>> [0]PETSC ERROR: Configure options --with-debugging=0 --COPTFLAGS="-O3
>>> -march=native" --CXXOPTFLAGS="-O3 -march=native" --FOPTFLAGS="-O3
>>> -march=native"
>>> [0]PETSC ERROR: #1 MatSetValues_MPIAIJ() line 582 in
>>> petsc/src/mat/impls/aij/mpi/mpiaij.c
>>> [0]PETSC ERROR: #2 MatSetValues() line 1190 in
>>> petsc/src/mat/interface/matrix.c
>>> [0]PETSC ERROR: #3 main() line 36 in ex3.c
>>> [0]PETSC ERROR: No PETSc Option Table entries
>>> [0]PETSC ERROR: ----------------End of Error Message -------send entire
>>> error message to petsc-maint at mcs.anl.gov----------
>> Here's a working test code:
>> #include <petsc.h>
>>> #include <mpi.h>
>>> PetscErrorCode err;
>>> CHKERRQ(err);
>>> PetscInt global_width = 6;
>>> PetscInt global_height = 3;
>>> Mat A;
>>> CHKERRQ(err);
>>> CHKERRQ(err);
>>> err =
>>> MatSetSizes(A, global_height, PETSC_DECIDE, global_height,
>>> global_width);
>>> CHKERRQ(err);
>>> PetscInt o_nnz[] = {3, 3, 3};
>>> CHKERRQ(err);
>>> err = MatSetUp(A);
>>> CHKERRQ(err);
>>> for (PetscInt row = 0; row < global_height; ++row)
>>> for (PetscInt col = global_height; col < global_width; ++col)
>>> err = MatSetValue(A, row, col, 1, INSERT_VALUES);
>>> CHKERRQ(err);
>>> CHKERRQ(err);
>>> CHKERRQ(err);
>>> CHKERRQ(err);
>>> // free memory
>>> CHKERRQ(err);
>>> CHKERRQ(err);
>> Am I mis-understanding what the d_nnz and o_nnz parameter are supposed to
>> mean?
>> Andrew Ho
> experiments lead.
> -- Norbert Wiener
Andrew Ho
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170214/c2700f7e/attachment.html>
