[petsc-users] PETSc set off-diagonal matrix pre-allocation
Andrew Ho
andrewh0 at uw.edu
Tue Feb 14 06:41:01 CST 2017
I have a 3x6 matrix, and I want to set it to (just as an example):
0 0 0 1 1 1
0 0 0 1 1 1
0 0 0 1 1 1
>From what I can tell, according to the documentation the MPIAIJ sparsity of
this matrix is:
d_nnz = [0, 0, 0]
o_nnz = [3, 3, 3]
However, when I do this, I get the following error:
[0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Argument out of range
> [0]PETSC ERROR: New nonzero at (0,3) caused a malloc
> Use MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE) to turn
> off this check
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.7.5, unknown
> [0]PETSC ERROR: ./ex3 on a arch-linux2-c-opt Tue Feb 14 04:23:56 2017
> [0]PETSC ERROR: Configure options --with-debugging=0 --COPTFLAGS="-O3
> -march=native" --CXXOPTFLAGS="-O3 -march=native" --FOPTFLAGS="-O3
> -march=native"
> [0]PETSC ERROR: #1 MatSetValues_MPIAIJ() line 582 in
> petsc/src/mat/impls/aij/mpi/mpiaij.c
> [0]PETSC ERROR: #2 MatSetValues() line 1190 in
> petsc/src/mat/interface/matrix.c
> [0]PETSC ERROR: #3 main() line 36 in ex3.c
> [0]PETSC ERROR: No PETSc Option Table entries
> [0]PETSC ERROR: ----------------End of Error Message -------send entire
> error message to petsc-maint at mcs.anl.gov----------
Here's a working test code:
#include <petsc.h>
> #include <mpi.h>
> int main(int argc, char** argv)
> PetscErrorCode err;
> err = PetscInitialize(&argc, &argv, NULL, "help");
> CHKERRQ(err);
> // create a sparse AIJ matrix distributed across MPI
> PetscInt global_width = 6;
> PetscInt global_height = 3;
> Mat A;
> err = MatCreate(MPI_COMM_WORLD, &A);
> CHKERRQ(err);
> err = MatSetType(A, MATMPIAIJ);
> CHKERRQ(err);
> // setup pre-allocation for matrix space
> err =
> MatSetSizes(A, global_height, PETSC_DECIDE, global_height,
> global_width);
> CHKERRQ(err);
> PetscInt d_nnz[] = {0, 0, 0};
> PetscInt o_nnz[] = {3, 3, 3};
> err = MatMPIAIJSetPreallocation(A, 0, d_nnz, 0, o_nnz);
> CHKERRQ(err);
> err = MatSetUp(A);
> CHKERRQ(err);
> // set values inside the matrix
> for (PetscInt row = 0; row < global_height; ++row)
> for (PetscInt col = global_height; col < global_width; ++col)
> err = MatSetValue(A, row, col, 1, INSERT_VALUES);
> CHKERRQ(err);
> err = MatAssemblyBegin(A, MAT_FINAL_ASSEMBLY);
> CHKERRQ(err);
> err = MatAssemblyEnd(A, MAT_FINAL_ASSEMBLY);
> CHKERRQ(err);
> err = MatView(A, PETSC_VIEWER_STDOUT_WORLD);
> CHKERRQ(err);
> // free memory
> err = MatDestroy(&A);
> CHKERRQ(err);
> // cleanup any internal PETSc data at end of program
> err = PetscFinalize();
> CHKERRQ(err);
Am I mis-understanding what the d_nnz and o_nnz parameter are supposed to
mean?
Andrew Ho
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170214/d1873a22/attachment.html>
