[petsc-users] TS question 1: how to stop explicit methods because they do not use SNES(VI)?
Zhang, Hong
hongzhang at anl.gov
Mon Feb 13 15:59:50 CST 2017
On Feb 13, 2017, at 3:08 PM, Ed Bueler <elbueler at alaska.edu<mailto:elbueler at alaska.edu>> wrote:
Barry --
> Sounds like a bug to me. The methods should be checking if an
> IFunction is being provided and error out in that case.
I don't think it is that simple. I.e. having an IFunction and an explicit scheme is not, by itself, a bug. I think.
If the user has provided IFunction
F(t,u,u_t) = u_t - f(t,u)
which is the convenient form for e.g. TSARKIMEX,
and RHSFunction
G(t,u)
then I guess I assumed that explicit methods like TSRK should,for unconstrained cases, get their RHS by callback like this:
g(t,u) = - F(t,u,0) + G(t,u)
so that the ODE is in form
u_t = g(t,u) = f(t,u) + g(t,u)
PETSc does not transform IFunction to the RHS this way, and PETSc is not supposed to do it automatically. Note that IFunction may involve a mass matrix, e.g. F(t,u,u_t) = M*u_t - f(t,u) and sometimes M is not invertible.
I think that is the behavior I am seeing (i.e. on my problem, using PETSc master).
Explicit methods use only RHSFunction and ignore IFunction, so in your case, if you change TS type to rk and ssp at run time, you are actually solving u_t = G(t,u). If RHSFunction is not provided, PETSc will assume the RHS is zero (u_t=0).
The "nonsense" I am referring to is only from the non-enforcement of the constraint; it would be o.k. for a pure ODE.
I would love to have some projection mechanism to try, for comparing explicit methods with projection to the SNESVI way (i.e. the right way), but that is asking for a lot of PETSc refactoring, I think. For now I just want to error-out if the method is not going to call the SNES at each time step.
Check if TSGetSNES() returns NULL in your code?
Ed
On Mon, Feb 13, 2017 at 11:26 AM, Barry Smith <bsmith at mcs.anl.gov<mailto:bsmith at mcs.anl.gov>> wrote:
> On Feb 13, 2017, at 1:53 PM, Ed Bueler <elbueler at alaska.edu<mailto:elbueler at alaska.edu>> wrote:
> Dear Petsc --
> This is the first of two short TS usage questions.
> My problem is both stiff (diffusive PDE) and constrained, so I require
> -snes_type vinewton{rs|ss}ls
> *and* I split my ODE system into IFunction and RHSFunction
> F(t,u,u_t) = G(t,u)
> where F(t,u,u_t) = u_t + f(t,u) in my case (i.e. no mass matrix needed), and the stiff part goes in f(t,u).
> With this arrangement TS types beuler, theta, bdf, arkimex all work quite well. However, the program runs and produces nonsense with type rk and ssp, that is, explicit methods.
Sounds like a bug to me. The methods should be checking if an IFunction is being provided and error out in that case.
Barry
> So my question is, how do I ask the TS (at run time) whether the chosen TS type will or will not call its SNES at each step? If SNES is not going to be used then I want to SETERRQ and stop. That is, I want to error-out if the *method* is fully explicit.
> Note the constraints are enforced by the SNESVI, as they should be, not ad hoc projection. Also, as a technical matter, I cannot require my iterates to be feasible inside my IFunction evaluation because that would break VINEWTONSSLS.
> Neither TSProblemType (mine is NONLINEAR) nor TSEquationType (mine is IMPLICIT I guess) seem to address this? My problem is indeed nonlinear and has stiff parts, but it is not a DAE and it *is* constrained.
> Thanks!
> Ed
> PS I'd prefer not to enumerate the existing TS types and error on the bad ones. It is not nicely-maintainable.
> Ed Bueler
> Dept of Math and Stat and Geophysical Institute
> University of Alaska Fairbanks
> Fairbanks, AK 99775-6660
> 301C Chapman and 410D Elvey
> 907 474-7693<tel:907%20474-7693> and 907 474-7199<tel:907%20474-7199> (fax 907 474-5394<tel:907%20474-5394>)
Ed Bueler
907 474-7693 and 907 474-7199 (fax 907 474-5394)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170213/71643256/attachment.html>
