[petsc-users] VecScatter betweeen Vectors with different parallel layouts
Barletta, Ivano ibarletta at inogs.it
Mon Feb 13 05:51:58 CST 2017
Hello PETSc users
I was wondering if you've got any suggestion for the issue
mentioned in the topic.
I'm solving a linear system on my unstructured grid that has its
own partitioning. When I set up the linear system in PETSc I
use the model partitioning whose grid points might not be
evenly balanced (generally is not) over the processors.
So far I use VecScatter and IS to re-order the solution vector
with the application numbering.
What I aim at, now, is to let PETSc to decide the linear system
partitioning with PETSC_DECIDE local dimension and
see if I get some gain in performances, but in
this case I have to scatter between vectors that, at any rate, have
different parallel layouts (one of the requirements of
VecScatter is to have 2 Vecs with same layouts)
Does anyone of you have ever faced a similar problem?
any suggestion about how to circumvent this?
Feel free to ask for further information if my explanation is
not clear enough
Thanks in advance
Ivano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170213/f6a95fa7/attachment.html>
