[petsc-users] configure PETSc on Cray
Patrick Sanan
patrick.sanan at gmail.com
Fri Feb 10 12:38:05 CST 2017
On Fri, Feb 10, 2017 at 7:20 PM, Sharp Stone <thronesf at gmail.com> wrote:
> Thanks for the replies.
> The PETSc is installed on the Cray I'm using, but the version is too old
> cray-petsc/3.3.04.
> I've still got two questions:
> 1. how can I use the installed cray-petsc? I've used module load cray-petsc,
> but I can't find the path of petsc, which is required in the makefile.
You can use
module show cray-petsc
to at least get some more hints as to what cray did, PETSc-wise.
> 2. Therefore, I decided to configure the latest version of Petsc. When i use
> ./config/configure.py --with-cc=cc --with-cxx=CC --with-fc=ftn, it give me
> the errors
> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
> details):
> C libraries cannot directly be used from Fortran
> In the log file, I found these:
> details):
> File "./config/configure.py", line 405, in petsc_configure
> framework.configure(out = sys.stdout)
> File
> "/mnt/lustre/lus0/space/fs1036/local/PETSc/petsc-3.7.4/config/BuildSystem/config/framework.py",
> line 1090, in configure
> self.processChildren()
> File
> line 1079, in processChildren
> self.serialEvaluation(self.childGraph)
> File
> line 1060, in serialEvaluation
> child.configure()
> File
> "/mnt/lustre/lus0/space/fs1036/local/PETSc/petsc-3.7.4/config/BuildSystem/config/compilers.py",
> line 1438, in configure
> self.executeTest(self.checkCLibraries)
> File
> "/mnt/lustre/lus0/space/fs1036/local/PETSc/petsc-3.7.4/config/BuildSystem/config/base.py",
> line 126, in executeTest
> ret = test(*args,**kargs)
> File
> line 313, in checkCLibraries
> raise RuntimeError('C libraries cannot directly be used from Fortran')
> Finishing Configure Run at Fri Feb 10 13:07:10 2017
> Thank you again for your help!
> On Fri, Feb 10, 2017 at 1:01 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>> check config/examples/arch-cray-xt6-pkgs-opt.py
>> Also check if your machine already has petsc [from cray] installed
>> module avail petsc
>> Satish
>> On Fri, 10 Feb 2017, Patrick Sanan wrote:
>> > You're missing the 'g' in 'configure.py'.
>> > On Fri, Feb 10, 2017 at 6:51 PM, Sharp Stone <thronesf at gmail.com> wrote:
>> > > Hi all,
>> > > I noticed the instructions of Petsc with MPI. Now I'm using Cray. So
>> > > the
>> > > instruction:
>> > > Vendor provided MPI might already be installed. IBM, SGI, Cray etc
>> > > provide
>> > > their own:
>> > > ./config/confiure.py --with-cc=mpcc --with-fc=mpf77
>> > > When I use the command "./config/confiure.py --with-cc=mpcc
>> > > --with-fc=mpf77", it gives me the error "-bash: ./config/confiure.py:
>> > > No
>> > > such file or directory". But the file "confiure.py" is there in the
>> > > "config"
>> > > folder.
>> > > What should I do?
>> > > Thanks very much!
>> > > Best regards,
>> > > Feng
> Best regards,
> Feng
