[petsc-users] ksp solve error with nested matrix
Manav Bhatia bhatiamanav at gmail.com
Wed Feb 8 15:51:41 CST 2017
aha.. that might be it.
Does that need to be called for the global matrix after each assembly of the Jacobian blocks, or just once for the whole matrix?
-Manav
> On Feb 8, 2017, at 3:47 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> On Feb 8, 2017, at 3:40 PM, Manav Bhatia <bhatiamanav at gmail.com> wrote:
>> Hi,
>>   I have a nested matrix with 2x2 blocks. The blocks (1,1) and (2,2) are AIJ matrices and blocks (1,2) and (2,1) and shell matrices. I am calling the code with the following arguments: -pc_type fieldsplit , and get the error shown below.
>>   I see that the error is complaining about the matrix being in unassembled state, but I think I am initializing and calling assembly end routines on both the diagonal blocks. Still, there is something obvious I am missing.
>  It is complaining about the outer most matrix, not the blocks. Perhaps you haven't finished with setting up your nest matrix?
>>   I would appreciate any guidance on this.
>> Regards,
>> Manav
>> [1;31m[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
>> [0;39m[0;49m[0]PETSC ERROR: Object is in wrong state
>> [0]PETSC ERROR: Not for unassembled matrix
>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
>> [0]PETSC ERROR: Petsc Release Version 3.7.4, Oct, 02, 2016
>> [0]PETSC ERROR: /Users/manav/Library/Developer/Xcode/DerivedData/MAST-crggwcqrouiyeucduvscdahjauvx/Build/Products/Debug/examples on a arch-darwin-cxx-opt named Dhcp-90-250.HPC.MsState.Edu by manav Wed Feb  8 15:28:04 2017
>> [0]PETSC ERROR: Configure options --prefix=/Users/manav/Documents/codes/numerical_lib/petsc/petsc-3.7.4/../ --CC=mpicc-openmpi-clang38 --CXX=mpicxx-openmpi-clang38 --FC=mpif90-openmpi-clang38 --with-clanguage=c++ --with-fortran=0 --with-mpiexec=/opt/local/bin/mpiexec-openmpi-clang38 --with-shared-libraries=1 --with-x=1 --with-x-dir=/opt/X11 --with-debugging=0 --with-lapack-lib=/usr/lib/liblapack.dylib --with-blas-lib=/usr/lib/libblas.dylib --download-superlu=yes --download-superlu_dist=yes --download-suitesparse=yes --download-mumps=yes --download-scalapack=yes --download-parmetis=yes --download-metis=yes --download-hypre=yes --download-ml=yes
>> [0]PETSC ERROR: #1 MatMult() line 2248 in /Users/manav/Documents/codes/numerical_lib/petsc/petsc-3.7.4/src/mat/interface/matrix.c
>> [0]PETSC ERROR: #2 PCApplyBAorAB() line 717 in /Users/manav/Documents/codes/numerical_lib/petsc/petsc-3.7.4/src/ksp/pc/interface/precon.c
>> [0]PETSC ERROR: #3 KSP_PCApplyBAorAB() line 274 in /Users/manav/Documents/codes/numerical_lib/petsc/petsc-3.7.4/include/petsc/private/kspimpl.h
>> [0]PETSC ERROR: #4 KSPGMRESCycle() line 156 in /Users/manav/Documents/codes/numerical_lib/petsc/petsc-3.7.4/src/ksp/ksp/impls/gmres/gmres.c
>> [0]PETSC ERROR: #5 KSPSolve_GMRES() line 240 in /Users/manav/Documents/codes/numerical_lib/petsc/petsc-3.7.4/src/ksp/ksp/impls/gmres/gmres.c
>> [0]PETSC ERROR: #6 KSPSolve() line 656 in /Users/manav/Documents/codes/numerical_lib/petsc/petsc-3.7.4/src/ksp/ksp/interface/itfunc.c
>> [0]PETSC ERROR: #7 SNESSolve_NEWTONLS() line 230 in /Users/manav/Documents/codes/numerical_lib/petsc/petsc-3.7.4/src/snes/impls/ls/ls.c
>> [0]PETSC ERROR: #8 SNESSolve() line 4005 in /Users/manav/Documents/codes/numerical_lib/petsc/petsc-3.7.4/src/snes/interface/snes.c
