[petsc-users] pc gamg did not converge in sinv where it used to
Denis Davydov davydden at gmail.com
Tue Feb 7 15:51:46 CST 2017
Dear all,
I rerun calculations (unit tests) which used to work with slightly older versions of PETSc/SLEPc (a year ago, or so) and
see the  "KSPSolve has not converged” error for shift and invert transformation with gamg preconditioner (below).
Shifted matrix is SPD, could have bad condition number but it worked before.
Judging from a pre-last line in the log below, something is wrong with GAMG or its interaction with SLEPc.
Denis.
[0]PETSC ERROR: Configure options --prefix=/Users/davydden/spack/opt/spack/darwin-sierra-x86_64/clang-8.0.0-apple/petsc-3.7.5-e35uxj5pf7ndtedbnzvq7dot5oie3psc --with-ssl=0 --with-x=0 --download-c2html=0 --download-sowing=0 --download-hwloc=0 --with-mpi=1 --with-mpi-dir=/Users/davydden/spack/opt/spack/darwin-sierra-x86_64/clang-8.0.0-apple/openmpi-2.0.2-oos4cxprn2bislzhc3rbc3lo4dadginw --with-precision=double --with-scalar-type=real --with-shared-libraries=1 --with-debugging=0 --with-64-bit-indices=0 --with-blas-lapack-lib=/Users/davydden/spack/opt/spack/darwin-sierra-x86_64/clang-8.0.0-apple/openblas-0.2.19-xg7etkjyo7xjnvuojsdc2xoixesxoerh/lib/libopenblas.dylib --with-metis=1 --with-metis-dir=/Users/davydden/spack/opt/spack/darwin-sierra-x86_64/clang-8.0.0-apple/metis-5.1.0-c2muo3b6k5aea2743g34s35u2ve23yxq --with-boost=0 --with-hdf5=1 --with-hdf5-dir=/Users/davydden/spack/opt/spack/darwin-sierra-x86_64/clang-8.0.0-apple/hdf5-1.10.0-patch1-kwkdkp5mo4olqpkitojab3xg3xhl6gfz --with-hypre=1 --with-hypre-dir=/Users/davydden/spack/opt/spack/darwin-sierra-x86_64/clang-8.0.0-apple/hypre-2.11.1-dprfz6t4t24wesj74dcfdtajwm5n5qzu --with-parmetis=1 --with-parmetis-dir=/Users/davydden/spack/opt/spack/darwin-sierra-x86_64/clang-8.0.0-apple/parmetis-4.0.3-tm5dd6fqnbw6hiepajhkvmqk42xrrgos --with-mumps=1 --with-mumps-dir=/Users/davydden/spack/opt/spack/darwin-sierra-x86_64/clang-8.0.0-apple/mumps-5.0.2-4pwiz7bplhnmk2lfvg746u4pq4z5wuc3 --with-scalapack=1 --with-scalapack-dir=/Users/davydden/spack/opt/spack/darwin-sierra-x86_64/clang-8.0.0-apple/netlib-scalapack-2.0.2-gu4tjf4bjvtia3ohzjqbickedmywqslk --with-superlu_dist-include=/Users/davydden/spack/opt/spack/darwin-sierra-x86_64/clang-8.0.0-apple/superlu-dist-5.1.1-hut4gapp5v6qzvjlqahattdvr3tyynoy/include --with-superlu_dist-lib=/Users/davydden/spack/opt/spack/darwin-sierra-x86_64/clang-8.0.0-apple/superlu-dist-5.1.1-hut4gapp5v6qzvjlqahattdvr3tyynoy/lib/libsuperlu_dist.a --with-superlu_dist=1
[0]PETSC ERROR: #1 KSPSolve() line 847 in /private/var/folders/5k/sqpp24tx3ylds4fgm13pfht00000gn/T/davydden/spack-stage/spack-stage-zUUkMX/petsc-3.7.5/src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: #2 PCGAMGOptProlongator_AGG() line 1227 in /private/var/folders/5k/sqpp24tx3ylds4fgm13pfht00000gn/T/davydden/spack-stage/spack-stage-zUUkMX/petsc-3.7.5/src/ksp/pc/impls/gamg/agg.c
[0]PETSC ERROR: #3 PCSetUp_GAMG() line 581 in /private/var/folders/5k/sqpp24tx3ylds4fgm13pfht00000gn/T/davydden/spack-stage/spack-stage-zUUkMX/petsc-3.7.5/src/ksp/pc/impls/gamg/gamg.c
[0]PETSC ERROR: #4 PCSetUp() line 968 in /private/var/folders/5k/sqpp24tx3ylds4fgm13pfht00000gn/T/davydden/spack-stage/spack-stage-zUUkMX/petsc-3.7.5/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: #5 KSPSetUp() line 390 in /private/var/folders/5k/sqpp24tx3ylds4fgm13pfht00000gn/T/davydden/spack-stage/spack-stage-zUUkMX/petsc-3.7.5/src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: #6 STSetUp_Sinvert() line 153 in /private/var/folders/5k/sqpp24tx3ylds4fgm13pfht00000gn/T/davydden/spack-stage/spack-stage-5WvuFP/slepc-3.7.3/src/sys/classes/st/impls/sinvert/sinvert.c
[0]PETSC ERROR: #7 STSetUp() line 301 in /private/var/folders/5k/sqpp24tx3ylds4fgm13pfht00000gn/T/davydden/spack-stage/spack-stage-5WvuFP/slepc-3.7.3/src/sys/classes/st/interface/stsolve.c
[0]PETSC ERROR: #8 EPSSetUp() line 205 in /private/var/folders/5k/sqpp24tx3ylds4fgm13pfht00000gn/T/davydden/spack-stage/spack-stage-5WvuFP/slepc-3.7.3/src/eps/interface/epssetup.c
[0]PETSC ERROR: #9 EPSSolve() line 89 in /private/var/folders/5k/sqpp24tx3ylds4fgm13pfht00000gn/T/davydden/spack-stage/spack-stage-5WvuFP/slepc-3.7.3/src/eps/interface/epssolve.c
***[0]PCReset_GAMG this should not happen, cleaned up in SetUp
ERROR: Uncaught exception in MPI_InitFinalize on proc 0. Skipping MPI_Finalize() to avoid a deadlock.
