[petsc-users] Replacement for Euclid ?
Tue Feb 7 13:02:14 CST 2017
> On Feb 7, 2017, at 2:49 AM, Michel Kern <michel.kern at inria.fr> wrote:
> I have a code that uses euclid for ILU preconditioning (as part of a CPR-AMG preconditioner for a mulitphase flow solver). As noted in the release notes, euclid is no longer supported starting from 3.6. What is the recommended replacement ? Is block Jacobi plus a local solver an alternative ?
   I would use block Jacobi with Gauss-Seidel as the local solver first. Does that not work due to zero pivots?
    Then you can use PCFIELDSPLIT with the option -pc_fieldsplit_detect_saddle_point
    or you can use block Jacobi with ILU(0) as the local solver.
    There are many combinations to try.
  Barry
> Thanks
> Michel
> Michel Kern
> Centre de Recherche Inria de Paris,    Maison de la Simulation
> 2 rue Simone Iff, bureau A413,            Digiteo Labs, bât 565, CEA Saclay
> 75012 Paris                                          91191 Gif-sur-Yvette cedex
> tel. : +33 (0)1 80 49 42 36,                  tel. : +33 (0)1 69 08 58 32
