[petsc-users] Replacement for Euclid ?
Michel Kern michel.kern at inria.fr
Tue Feb 7 07:53:26 CST 2017
Thanks Mat,
according tot he hypre documentation, pilut is "no longer supported by the hypre team", as less efficient than Euclid, so I wouldn't consider an option. I wsa looking for a "natural" upgrade path.
The problems we've looked at for the moment can be up to a few millions cells (that's the size of the pressure block, the saturation block is larger, but should be easier to solve). We're aiming for 10^6 cells, and 10^3 cores.
Yes, direct methods deserve a second look !
Michel
----- Mail original -----
> On Tue, Feb 7, 2017 at 2:49 AM, Michel Kern < michel.kern at inria.fr > wrote:
> > I have a code that uses euclid for ILU preconditioning (as part of a
> > CPR-AMG
> > preconditioner for a mulitphase flow solver). As noted in the release
> > notes,
> > euclid is no longer supported starting from 3.6. What is the recommended
> > replacement ? Is block Jacobi plus a local solver an alternative ?
> There is pilut from Hypre.
> How big is the problem? Did you try sparse direct on it (SuperLU, MUMPS)?
> Thanks,
> Matt
> > Thanks
> > Michel
> > Michel Kern
> > Centre de Recherche Inria de Paris, Maison de la Simulation
> > 2 rue Simone Iff, bureau A413, Digiteo Labs, bât 565, CEA Saclay
> > 75012 Paris 91191 Gif-sur-Yvette cedex
> > tel. : +33 (0)1 80 49 42 36 , tel. : +33 (0)1 69 08 58 32
> What most experimenters take for granted before they begin their experiments
> is infinitely more interesting than any results to which their experiments
> lead.
> -- Norbert Wiener
Michel Kern
Centre de recherche Inria de Paris, Maison de la Simulation,
2 rue Simone Iff, bureau A413, Digiteo Labs, bât. 565, CEA Saclay
75012 Paris 91191 Gif-sur-Yvette Cedex
tel. : +33 (0)1 80 49 42 36, tel. : +33 (0)1 69 08 58 32
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170207/efa3ccb1/attachment.html>
