[petsc-users] projection methods in TS
Zhang, Hong
hongzhang at anl.gov
Sat Feb 4 19:49:15 CST 2017
On Feb 4, 2017, at 7:35 PM, Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
On Sat, Feb 4, 2017 at 7:24 PM, Zhang, Hong <hongzhang at anl.gov<mailto:hongzhang at anl.gov>> wrote:
Can you elaborate a bit more on your problem?
If your problem is an index-1 DAE, there is no need to use a projection method, and it is perfectly fine to set it up as a DAE in PETSc. For high-index DAEs, you may have to use TSSetPostStep() to implement your own projection algorithm.
Please define index.
http://www.scholarpedia.org/article/Differential-algebraic_equations#Index
Hong
Matt
If you happen to have a Hamiltonian system to solve, I have a symplectic solver in my own branch that you can use directly.
Hong (Mr.)
On Feb 4, 2017, at 9:47 AM, Gideon Simpson <gideon.simpson at gmail.com<mailto:gideon.simpson at gmail.com>> wrote:
Would setting it up as a DAE in petsc be algorithmically euivalent to a projected method (i.e., step of standard RK followed by nonlinear projection)?
-gideon
On Feb 3, 2017, at 11:47 PM, Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
That is one answer. Another one is that this particular system is a DAE and we have methods for that.
Matt
On Fri, Feb 3, 2017 at 8:40 PM, Barry Smith <bsmith at mcs.anl.gov<mailto:bsmith at mcs.anl.gov>> wrote:
TSSetPostStep(); in your function use TSGetSolution() to get the current solution.
Please let us know how it works out
Barry
> On Feb 3, 2017, at 7:14 PM, Gideon Simpson <gideon.simpson at gmail.com<mailto:gideon.simpson at gmail.com>> wrote:
> I’m interested in implementing a projection method for an ODE of the form:
> y’ = f(y),
> such that g(y) = 0 for all time (i.e., g is conserved). Note that in a projection method, a standard time step is made to produce y* from y_{n}, and then this is corrected to obtain y_{n+1} satisfying g(y) = 0.
> There were two ways I was thinking of doing this, and I was hoping to get some input:
> Idea 1: Manually loop through using taking a time step and then implementing the projection routine. I see that there is a TSStep command, but this doesn’t seem to be much documentation on how to use it in this scenario. Does anyone have any guidance?
> Idea 2: Is there some analog to TSMonitor that allows me to modify the solution after each time step, instead of just allowing for some computation of a statistic?
-- Norbert Wiener
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170205/83c3fdd0/attachment.html>
