[petsc-users] projection methods in TS
Matthew Knepley
knepley at gmail.com
Sat Feb 4 19:47:41 CST 2017
On Sat, Feb 4, 2017 at 7:44 PM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > On Sat, Feb 4, 2017 at 7:24 PM, Zhang, Hong <hongzhang at anl.gov> wrote:
> >> Can you elaborate a bit more on your problem?
> >> If your problem is an index-1 DAE, there is no need to use a projection
> >> method, and it is perfectly fine to set it up as a DAE in PETSc. For
> >> high-index DAEs, you may have to use TSSetPostStep() to implement your
> own
> >> projection algorithm.
> > Please define index.
> Think of it as a measure of singularity of the "mass matrix". Higher
> index DAE have more complicated constraints on compatibility of initial
> conditions. It's covered in any book or paper on DAEs.
Both your explanation and Hong's use of the term do not help Gideon (or me)
know whether he has an index-1 DAE. There has
to be some simple form you can write down so that we can tell.
Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170204/640d9eaf/attachment.html>
