[petsc-users] projection methods in TS
    Matthew Knepley
    knepley at gmail.com
    Sat Feb  4 19:35:21 CST 2017
On Sat, Feb 4, 2017 at 7:24 PM, Zhang, Hong <hongzhang at anl.gov> wrote:
> Can you elaborate a bit more on your problem?
> If your problem is an index-1 DAE, there is no need to use a projection
> method, and it is perfectly fine to set it up as a DAE in PETSc. For
> high-index DAEs, you may have to use TSSetPostStep() to implement your own
> projection algorithm.
Please define index.
   Matt
> If you happen to have a Hamiltonian system to solve, I have a symplectic
> solver in my own branch that you can use directly.
> Hong (Mr.)
> On Feb 4, 2017, at 9:47 AM, Gideon Simpson <gideon.simpson at gmail.com>
> wrote:
> Would setting it up as a DAE in petsc be algorithmically euivalent to a
> projected method (i.e., step of standard RK followed by nonlinear
> projection)?
> -gideon
> On Feb 3, 2017, at 11:47 PM, Matthew Knepley <knepley at gmail.com> wrote:
> That is one answer. Another one is that this particular system is a DAE
> and we have methods for that.
>    Matt
> On Fri, Feb 3, 2017 at 8:40 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> TSSetPostStep(); in your function use TSGetSolution() to get the current
>> solution.
>>   Please let us know how it works out
>>    Barry
>> > On Feb 3, 2017, at 7:14 PM, Gideon Simpson <gideon.simpson at gmail.com>
>> wrote:
>> > I’m interested in implementing a projection method for an ODE of the
>> form:
>> > y’ = f(y),
>> > such that g(y) = 0 for all time (i.e., g is conserved).  Note that in a
>> projection method, a standard time step is made to produce y* from y_{n},
>> and then this is corrected to obtain y_{n+1} satisfying g(y) = 0.
>> > There were two ways I was thinking of doing this, and I was hoping to
>> get some input:
>> > Idea 1: Manually loop through using taking a time step and then
>> implementing the projection routine.  I see that there is a TSStep command,
>> but this doesn’t  seem to be much documentation on how to use it in this
>> scenario.  Does anyone have any guidance?
>> > Idea 2: Is there some analog to TSMonitor that allows me to modify the
>> solution after each time step, instead of just allowing for some
>> computation of a statistic?
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170204/c09f7430/attachment.html>
