[petsc-users] coding VecMDot_Seq as gemv
    Kokron, Daniel S. (ARC-606.2)[CSRA, LLC]
    daniel.s.kokron at nasa.gov
    Wed Dec 27 16:24:31 CST 2017
Barry,
Thanks for the reply.
Here is my attempt.  Do you see anything wrong with it?
#if 1
#include <mkl.h>
  PetscInt n = xin->map->n,i,j;
  const PetscScalar *xbase,*a;
  PetscScalar *b;
  Vec         *yy;
  yy   = (Vec*)y;
  ierr = PetscMalloc(n*nv*sizeof(PetscScalar),&b);CHKERRQ(ierr);
  for(i=0; i<nv; i++) {
     ierr = VecGetArrayRead(yy[i],&a);CHKERRQ(ierr);
     for(j=0; j<n; j++) {
        b[j] = a[j];
     b += n;
     ierr = VecRestoreArrayRead(yy[i],&a);CHKERRQ(ierr);
  ierr = VecGetArrayRead(xin,&xbase);CHKERRQ(ierr);
    cblas_dgemv(CblasRowMajor, CblasNoTrans, nv, n, 1., b, n, xbase, 1, 0., work, 1);
  ierr = VecRestoreArrayRead(xin,&xbase);CHKERRQ(ierr);
     PetscPrintf(PETSC_COMM_SELF,"VecMDot_MPI: %D %.16f\n",i,work[i]);
  ierr = PetscFree(b);CHKERRQ(ierr);
#else
  ierr = VecMDot_Seq(xin,nv,y,work);CHKERRQ(ierr);
  PetscInt i;
#endif
Daniel Kokron
NASA Ames (ARC-TN)
SciCon group
Sent: Wednesday, December 27, 2017 14:58
To: Kokron, Daniel S. (ARC-606.2)[CSRA, LLC]
Cc: petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] coding VecMDot_Seq as gemv
> On Dec 27, 2017, at 2:53 PM, Kokron, Daniel S. (ARC-606.2)[CSRA, LLC] <daniel.s.kokron at nasa.gov> wrote:
> I am looking into ways to improve performance of the VecMDot_Seq routine.  I am focusing on the variant that gets called when PETSC_THREADCOMM_ACTIVE and PETSC_USE_FORTRAN_KERNEL_MDOT are NOT defined.
> My current version of PETSc is 3.4.5 due solely to user requirement.  I am linking against MKL.
> I tried and failed to implement VecMDot_Seq as a call to cblas_dgemv in ~/mpi/pvec2.c
> I could not figure out a way to extract the vectors from 'Vec y[]' and store them as rows of an allocated array.
  Use VecGetArray on each one then do a memcpy of those values into the big allocated array (or a loop copy or whatever).
> This user post starts off with a similar request (how to construct a matrix from many vectors)
> https://lists.mcs.anl.gov/pipermail/petsc-users/2015-August/026848.html
> I understand that this sort of memory shuffling is expensive.  I was just hoping to prove the point to myself that it's possible.
   Yes the memory shuffling is possible and not that difficult, perhaps you just have the rows and columns backwards?
> The action performed by VecMDot_Seq is the same as matrix-vector multiplication, so I was wondering why it wasn't implemented as a call ?gemv?
   The reason is that we want each of the vectors to be independent of the other ones; to use gemv they have be shared in a single common array.
   I doubt that copying into a single array and calling the gemv will ever be faster. Better to just try to optimize/vectorize better the current code.
> Daniel Kokron
> NASA Ames (ARC-TN)
> SciCon group
