[petsc-users] PetscOptionsAllUsed in fortran
Smith, Barry F.
bsmith at mcs.anl.gov
Wed Dec 27 08:53:38 CST 2017
Here is a patch to provide this for PETSc version 3.8.x
Apply with
patch -p1 < petscoptionsallused.patch
make gnumake
It is also in the maint and master git branches of PETSc and will be in the next patch release.
Barry
> On Dec 27, 2017, at 3:37 AM, Praveen C <cpraveen at gmail.com> wrote:
> Hello
> I want to use this
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscOptionsAllUsed.html
> in a fortran code like this
> call PetscOptionsAllUsed(PETSC_NULL_OPTIONS, nunused, ierr); CHKERRQ(ierr)
> if(nunused > 0)then
> write(*,*)'Some command line options not used'
> ierr = 1
> endif
> but I cannot compile the code
> Undefined symbols for architecture x86_64:
> "_petscoptionsallused_", referenced from:
> _readparam_ in ccHwkiA6.o
> ld: symbol(s) not found for architecture x86_64
> collect2: error: ld returned 1 exit status
> make[1]: *** [ug3] Error 1
> make: *** [euler] Error 2
> Is this not implemented for fortran ?
> Is there any other way to detect some unused command line arguments ? If some argument is mis-spelled, it will be silently ignored, and I want to detect this case.
> Thanks
> praveen
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171227/e321046c/attachment.html>
Desc: petscoptionsallused.patch
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171227/e321046c/attachment.obj>
