Dear all
I have a fortran CFD code, 3d, unstructured grid.
I run the following code
do i=1,10000000
call VecGhostUpdateBegin(p%v_u, INSERT_VALUES, SCATTER_FORWARD, &
ierr); CHKERRQ(ierr)
call VecGhostUpdateEnd (p%v_u, INSERT_VALUES, SCATTER_FORWARD, &
enddo
and monitor memory usage using “top”. I find that the memory used by the processes increases continuously.
The vector p%v_u was created like this
call VecCreateGhostBlockWithArray(PETSC_COMM_WORLD, nvar, nvar*g%nvl, &
PETSC_DECIDE, g%nvg, g%vghost, &
s%u(1,1), p%v_u, ierr); CHKERRQ(ierr)
where I use a preallocated array s%u(nvar, g%nvl + g%nvg).
I have observed this memory issue on Linux with Petsc 3.8.3 and Openmpi 3.0.0, gcc-7.2.1, gfortran-7.2.1
On my macbook using clang and gfortran, I do not see this growing memory issue.
Can you suggest some way to debug this problem ?
Thank you
praveen
